Canon pixma tr4756i
Hi, All I can’t find a printer driver that allows me to use the printer on the above. I’m attaching system information, I hope someone can help me. Thanks in advance.
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.12.0
Qt Version: 6.8.2
Kernel Version: 6.12.19-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i3-3220 CPU @ 3.30GHz
Memory: 15.6 GiB of RAM
Graphics Processor: NVC1
Same answer as here:
Network printer added but does not print (Cannon Pixma mx-410) - #4 by Nachlese
it doesn’t need a driver when connected via network.
AirPrint / IPP everywhere are keywords …
Or look here:
CUPS/Printer-specific problems - ArchWiki
AUR (en) - cnijfilter2
Information provided from *-fetch type applications might be fine for someone wishing to buy your computer, but for Support purposes it’s best to ask your system directly. Please provide system information as described (below).
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Thanks soundofthunder. Here is the link where I uploaded the result of the command you instructed me to use.
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e7de8309-daa4-4ca6-9e5b-6db656352a28 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Desktop Mobo: ASRock model: H61M-S serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: P1.60
    date: 07/11/2012
  System RAM: total: 16 GiB available: 15.58 GiB used: 2.65 GiB (17.0%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1067 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Micron part-no: CT102464BD160B.C16 serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i3-3220 bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 3300 min/max: 1600/3300 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 3300 2: 3300 3: 3300 4: 3300 bogomips: 26350
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GF108 [GeForce GT 620] vendor: Point of View BV
    driver: nouveau v: kernel non-free: series: 390.xx+
    status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
    xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DVI-I-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0f01 class-ID: 0300
    temp: 49.0 C
  Device-2: Arkmicro USB2.0 PC CAMERA driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:4
    chip-ID: 18ec:3399 class-ID: 0102
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: nouveau gpu: nouveau display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: 27N1 serial: <filter> built: 2021
    res: 1920x1080 dpi: 81 gamma: 1.2 chroma: red: x: 0.659 y: 0.329 green:
    x: 0.325 y: 0.612 blue: x: 0.149 y: 0.059 white: x: 0.310 y: 0.337
    size: 527x296mm (20.75x11.65") diag: 685mm (27") ratio: 16:9
    modes: 1920x1080, 1920x1080i, 1680x1050, 1280x1024, 1280x960, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
    drv: nouveau inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.1-arch1.2 glx-v: 1.4
    direct-render: yes renderer: NVC1 device-ID: 10de:0f01 memory: 1.94 GiB
    unified: no
    vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio vendor: Point of View BV
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  Device-3: Arkmicro USB2.0 PC CAMERA driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet vendor: ASRock
    driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000
    bus-ID: 03:00.0 chip-ID: 1969:2062 class-ID: 0200
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:3 chip-ID: 0bda:a725
  Local Storage: total: 2.38 TiB used: 42.52 GiB (1.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: HP74 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: JC4B scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Generic model: USB size: 111.79 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 9.02 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD5 rev: LV00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 146.49 GiB size: 143.13 GiB (97.71%)
    used: 42.48 GiB (29.7%) fs: ext4 dev: /dev/sdc8 maj-min: 8:40 label: N/A
    uuid: e7de8309-daa4-4ca6-9e5b-6db656352a28
    used: 37.8 MiB (39.3%) fs: vfat dev: /dev/sdc4 maj-min: 8:36 label: N/A
    uuid: 2272-631C
  ID-1: /dev/sda1 maj-min: 8:1 size: 1 KiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sda5 maj-min: 8:5 size: 465.76 GiB fs: ntfs label: N/A
    uuid: 01DA68249D4C8500
  ID-3: /dev/sdb1 maj-min: 8:17 size: 1 KiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/sdb5 maj-min: 8:21 size: 931.51 GiB fs: ntfs label: N/A
    uuid: 01DA682499BF8DB0
  ID-5: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: ntfs label: Riservato per
    il sistema uuid: 74F84A41F84A01BA
  ID-6: /dev/sdc2 maj-min: 8:34 size: 291.01 GiB fs: ntfs label: N/A
    uuid: 38104B26104AEA88
  ID-7: /dev/sdc3 maj-min: 8:35 size: 292.97 GiB fs: ntfs label: Volume
    uuid: EC967C34967C017E
  ID-8: /dev/sdc5 maj-min: 8:37 size: 99.65 GiB fs: ext4 label: N/A
    uuid: f86673f8-c65d-438e-a9a8-b7c73276e0f6
  ID-9: /dev/sdc6 maj-min: 8:38 size: 100.44 GiB fs: ext4 label: N/A
    uuid: 390f4c3d-8458-46a9-8cc9-6884834d5c59
  ID-10: /dev/sdc7 maj-min: 8:39 size: 773 MiB fs: ntfs label: N/A
    uuid: C234269A34269189
  ID-11: /dev/sdd1 maj-min: 8:49 size: 111.79 GiB fs: ext4 label: Bkup
    uuid: 2701671c-d6ef-0a48-8570-6aaeecab88cc
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.3:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.1:3 info: Logitech Mouse type: mouse
    chip-ID: 046d:c077 class-ID: 0301
  Device-2: 2-1.2:4 info: Arkmicro USB2.0 PC CAMERA type: video,audio
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
  Device-3: 2-1.3:5 info: Logitech Keyboard K120 type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-4: 2-1.5:7 info: Alcor Micro USB 2.0-IDE bridge type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 058f:6390 class-ID: 0806
  Device-5: 2-1.6:8 info: SCM Microsystems uTrust 2700 R Smart Card Reader
    type: smart card driver: N/A interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 76mA
    chip-ID: 04e6:5810 class-ID: 0b00 serial: <filter>
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 49.0 C
  Fan Speeds (rpm): N/A
  Packages: 1387 pm: pacman pkgs: 1369 libs: 380 tools: octopi,pamac,yay
    pm: flatpak pkgs: 5 pm: snap pkgs: 13
    1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    3: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 219
  1: cpu: 15.6% command: firefox pid: 23421 mem: 590.3 MiB (3.6%)
  2: cpu: 10.1% command: zsh pid: 25017 mem: 10.2 MiB (0.0%)
  3: cpu: 8.0% command: kwin_x11 pid: 979 mem: 220.7 MiB (1.3%)
  4: cpu: 7.2% command: konsole pid: 25008 mem: 223.5 MiB (1.4%)
  5: cpu: 6.6% command: Xorg pid: 778 mem: 86.7 MiB (0.5%)
  Memory top: 5 of 219
  1: mem: 600.6 MiB (3.7%) command: plasmashell pid: 996 cpu: 4.7%
  2: mem: 590.3 MiB (3.6%) command: firefox pid: 23421 cpu: 15.6%
  3: mem: 234.2 MiB (1.4%) command: firefox pid: 24192 cpu: 5.0%
  4: mem: 228.1 MiB (1.4%) command: acestreamengine pid: 1389 cpu: 0.4%
  5: mem: 223.5 MiB (1.4%) command: konsole pid: 25008 cpu: 7.2%
  Processes: 219 Power: uptime: 2h 40m states: freeze,standby,mem,disk
    suspend: deep avail: s2idle,shallow wakeups: 1 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.21 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Your BIOS is quite old. It may be beneficial to check your mainboard manufacturer for the latest non-beta BIOS update.
Yes I am aware of this, but I have other distros installed on the same machine and since everything works perfectly I would like to avoid any risk unless forced.
Mod edit:- Only use preformatted text when it’s needed for code or command output.
Well, you’re the administrator of your machine, and ultimately responsible for your own maintenance; we can only bring these potential issues to your attention.
Cheers.
Thanks soundofthunder. I followed your suggestion and updated my computer's bios. Now I'm waiting for someone to tell me if it's possible to solve the printer problem. Best regards and thanks again for your suggestions.
Have you tried the driver that @anon33601770 suggested?
In order to build packages from the AUR, make certain that you have the base-devel package installed.
You also may need linux-headers appropriate for your kernel. (sudo pacman -S linux612-headers)
If you plan on using Pamac to build the package you also have to have AUR support enabled in Pamac.
sudo pacman -S base-devel
In terminal:
pamac build cnijfilter2
Most welcome.
Again, a reminder to;
For any other comments just enter them as you normally would.
Hi Nachlese. After several days of inactivity I put your advice into practice and solved the problem by installing cnijfilter2 and using the configuration program. I don’t really know how to thank you. Best regards
Thanks jrichard326. You helped solve my problem. Best regards.
@muflo - a quick tip:
When you mention another member, use @ – this causes a dropdown to appear, and you can select the intended member.
This prevents accidental wrong spelling of a member’s username, and more importantly, notifies them that they have been mentioned.
Go on, try it. :wink:
P.S: I also merged your previous two posts to keep the topic tidy. Successive posts by the same user are usually discouraged; use a separator of some kind instead;
Example; a solid linecan be created with; ---
Or, you could add a bolded title, like this; **words here**:
words here
@soundofthunder copy all and thanks for your patience.
