Cannot upgrade to KDE plasma 5.27
Hi! first post ever right here. I am fairly new to Manjaro and I know that in February plasma 5.27 got released, but even though I am using the latest kernel I cannot seem to find the update. When I look in the AUR repositories the latest available is the one I have installed:
KDE Plasma Workspace 5.26.5-3
Other than that my system is fully up to date and have been waiting for a long time to get the update. Any idea on how to get it?
Thank you very much in advance!
Welcome to the forum! :wave:
Did you search before posting? :mag: :wink:
The other option is unstable or testing branch
 sudo pacman-mirrors -aS unstable && sudo pacman -Syyu
After a few minutes and a reboot you will have Plasma 5.27.2
  Host: tiger Kernel: 6.2.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.1 Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_wayland
    vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
I recommend getting it from testing and then go back to stable. In the command given above, just change the world unstable to testing/stable whenever you want to change the branch.
Of course, do a backup before such update.
I would add one thing to michaldybcza’s comment. You mentioned you were new to Manjaro, if you are also new to Linux as well, I would wait on the stable branch to release 5.27.
If you know what you are doing and the difference between stable/unstable/testing - have fun.
