Cannot update my system due to error below.
could not satisfy dependencies:
- removing lib32-libffi breaks dependency 'lib32-libffi' required by lib32-glib2
- removing lib32-pcre2 breaks dependency 'lib32-pcre2' required by lib32-glib2
- removing lib32-libffi breaks dependency 'libffi.so=8-32' required by lib32-glib2
When I try to remove “lib32-glib2”, it cannot remove it due to other dependencies below. It branches out and out and out and goes on and on and on. If you try to remove the first dependency and then the following one and the next one, on and on, I’m afraid to end up breaking the system. Is there any logical solution to this?
Excuse my frustration and ranting and bear with me and humor me for what I’m about to say, but I had to hunt around for information to fix the issues that the prior system update caused, which was about a month ago or so!
Now we have another big system update! And if you don’t mind me asking, what’s up with these constant 2GB or 3GB updates??? It is like changing your underwear 5 times a day unless you keep shi…ting yourself!
And why and why is every big system update a nightmare??? Even if you can update without any dependency issues, it is guaranteed! It is guaran-f…ing-teed!!! that the new update will screw something up in your system and something will not work right! I sh.t you not! As much as I love Manjaro and hate Windows, you cannot help but appreciate certain things about Windows. There I said it!!! I thought I would never say this!!! The 3-letter spy agencies must be having their heyday and mental orgasm, reading this!?!
Anyway, I’m done bit…ching and moaning!!!
Just frustrated with constant nuisance!!!
- removing lib32-glib2 breaks dependency 'lib32-glib2' required by lib32-at-spi2-core
- removing lib32-glib2 breaks dependency 'libglib-2.0.so=0-32' required by lib32-harfbuzz
- removing lib32-glib2 breaks dependency 'libgobject-2.0.so=0-32' required by lib32-harfbuzz
