I tried to change the keyboard shortcuts of “Switch to workspace n” to Super + n
from settings menu. But it opens some applications.
This is my inxi
output:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=289e43c6-5a12-4548-b53b-0927e72f0eaa ro apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Dell product: Inspiron 7559 v: 1.3.0 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0H0CC0 v: A00 serial: <filter> UEFI: Dell v: 1.3.0
date: 12/01/2018
ID-1: BAT0 charge: 74.4 Wh (100.0%) condition: 74.4/76.1 Wh (97.9%)
volts: 13.0 min: 11.4 model: Dell type: Unknown serial: <filter>
status: Full
RAM: total: 15.5 GiB used: 3.27 GiB (21.1%)
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2 cache:
L2: 6 MiB bogomips: 41621
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 801 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] driver: nvidia v: 460.73.01
alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:139b
class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 1bcf:28b0 class-ID: 0e02
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: d000
bus-ID: 05:00.0 chip-ID: 8086:3165 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
bus-ID: 1-5:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 577.55 GiB used: 88.98 GiB (15.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS120GMTS820S
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WDS500G2B0A
rotation: SSD serial: <filter> rev: 90WD scheme: GPT
ID-1: / raw-size: 94.5 GiB size: 92.46 GiB (97.84%) used: 31.15 GiB (33.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 289e43c6-5a12-4548-b53b-0927e72f0eaa
used: 25.6 MiB (8.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: C5B2-14B8
ID-3: /home raw-size: 200 GiB size: 195.8 GiB (97.90%)
used: 57.79 GiB (29.5%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 671243e1-17bc-4741-893f-13ef242b7872
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 17 GiB used: 1.2 MiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 95ed6940-cc2b-4518-a7b7-a7918d207e57
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 265.75 GiB fs: ntfs label: N/A
uuid: 923499A234998A3D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:5 info: SiGma Micro Optical Wheel Mouse [Rapoo N1130]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 1c4f:0065 class-ID: 0301
Device-2: 1-4:3 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Device-3: 1-5:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C mobo: 29.8 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 1925
Processes: 296 Uptime: 3h 46m wakeups: 1 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1372 pacman: 1356 lib: 426
flatpak: 11 snap: 5 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.04
following some other forums, I thought the issue might be with dash-to-dock gnome extension but it was disabled, I disabled it again! ( enabling and disabling, hoping to see some changes!!) but that didn’t work. What should I do?
I think my issue is similar to this issue
