I’m currently using a Minisforum UM700 Manjaro Edition as my daily driver. I just updated to the 6.9.0-1 kernel, and I have 767 updates to install; however, the GUI updater keeps failing, and when I try updating via terminal, this is what I get:
sudo pacman -Syu
[sudo] password for zacharyb:
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Starting full system upgrade…
:: Replace baloo5 with extra/baloo? [Y/n] y
:: Replace breeze with extra/breeze5? [Y/n] n
:: Replace ksysguard with extra/plasma-systemmonitor? [Y/n] y
:: Replace kuserfeedback5 with extra/kuserfeedback? [Y/n] y
:: Replace oxygen with extra/oxygen5? [Y/n] n
:: Replace plasma-integration with extra/plasma5-integration? [Y/n] y
:: Replace plasma5-themes-breath with extra/plasma6-themes-breath? [Y/n] y
:: Replace plasma5-themes-breath-migration with extra/plasma6-themes-breath-migration? [Y/n] y
warning: python-inputs: local (0.5.0-1) is newer than extra (0.5-6)
resolving dependencies…
:: There are 2 providers available for qt6-multimedia-backend:
:: Repository extra
qt6-multimedia-ffmpeg 2) qt6-multimedia-gstreamer
Enter a number (default=1): 1
warning: removing ‘jre11-openjdk’ from target list because it conflicts with ‘jdk11-openjdk’
warning: removing ‘jre11-openjdk-headless’ from target list because it conflicts with ‘jdk11-openjdk’
:: jdk11-openjdk and jre11-openjdk are in conflict. Remove jre11-openjdk? [y/N] y
:: jdk11-openjdk and jre11-openjdk-headless are in conflict. Remove jre11-openjdk-headless? [y/N] y
:: removing plasma5-themes-breath breaks dependency ‘plasma5-themes-breath’ required by plasma-theme-minisforum
(That error at the end is the same one that the GUI updater gives me, too.)
This may not be entirely straightforward: plasma5-themes-breath is required by plasma-theme-minisforum, which is required by minisforum-kde-settings, which conflicts with manjaro-kde-settings.
Maybe someone associated with the Minisforum project can provide Zakanuva with some guidance. Will minisforum-kde-settings be updated for Plasma 6, and if not, can minisforum-kde-settings be safely replaced by manjaro-kde-settings?
I didn’t have minisforum-kde-settings installed at all, and when I tried installing it just now, it failed because of that conflict with manjaro-kde-settings just like you mentioned.
I’ve successfully uninstalled manjaro-kde-settings, but when I tried to install minisforum-kde-settings to replace it, I just got the same error about plasma5-themes-breath again…
Same machine, same problem. sudo pacman -Rc plasma-theme-minisforum set me straight. Proceded with the full upgrade, no problems. Thank you! And has someone told Minisforum about this?
Did that; had to reboot a couple times and lost the old wallpaper and some other details, but almost all the updates/upgrades work now. Now my problem is that electron22 won’t update…
The last lines that the GUI updater’s backend gives me is:
RuntimeError: gsutil failed to download "gs://chromium-optimization-profiles/pgo_profiles/chrome-linux-5359-1669828006-dacdfc44d4f579ebe8c296dd8005586434849f0e.profdata"
==> ERROR: A failure occurred in prepare().
Aborting...
Preparing...
Checking dependencies...
Failed to prepare transaction:
could not satisfy dependencies:
- removing electron22 breaks dependency 'electron22' required by revolt-desktop-git
Do other versions of Revolt not use electron22, or is that app just not usable on Manjaro anymore?
Uninstalled them both, installed electron22-bin, and reinstalled revolt-desktop-git; it required a reboot to finish the job, but everything’s updated now and there don’t appear to be any remaining issues.
