I’m trying to launch dota on my new Manjaro desktop… It used to work but not anymore… I can launch the game, I see the logo and hear the music and then it’s black screen, the music continue and the cursor is the one from the game…
Might be a vulkan problem, but I’m not sure to understand how drivers work on Linux (proprietary vs open source in hardware conf).
Please read this: How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Kernel 5.11 is EOL so please install both 5.4 and 5.10 LTS (Long Time Support) and see which one of the two troubles you least.
Why are you on the 390.143 series driver? Remove that following the uninstall instructions from the readme that you followed to install it before continuing!
Now use the correct way to install the latest nVidia driver as the GeForce GTX 1060 supports the 465.31 series:
Print this page so you have it as a reference while in TTY2
Thanks Fabby and I’m very very sorry for the late reply… I didn’t have access to my laptop for few weeks…
So I did install the kernel 54 and 510 but when I ran the command sudo mhwd --install pci video-nvidia
I had a conflict with video-nvidia-390xx. I tried to remove it using the terminal but without success. So I went to the hardware configuration in order to remove it, which worked
Because nothing really worked (when I booted with the 54 or 510 kernel and run the command
I still had errors, I tried to boot with the latest (513) and try to install the latest nvidia with
yay linux513-nvidia
and installed “linux513-nvidia 470.57.02-2”. So now, when I run the command above, I get :
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
warning: nvidia-utils-470.57.02-1 is up to date -- skipping
error: target not found: linux511-nvidia
warning: linux513-nvidia-470.57.02-2 is up to date -- skipping
Error: pacman failed!
Error: script failed!
Dota2 finally launched, but it was super laggy on 5.13. So I assumed that the driver wasn’t working properly.
But I realized that just having the kernel 5.11 was a problem. So I uninstalled it, and I could finally run the mhwd install command it finally works! So now it runs with the 5.10 but not with the 5.13.
Just have a last question before closing, why in the hardware configuration page in the setting is there only the driver 390 ? I installed it from here first. So how can I do proper update next time?
I don’t know because I tell Manjaro what I want it to do:
Therefore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
mhwd is the official Manjaro Hardware Detection tool and takes a lot of the complexities out of the Arch tools.
The method you’re using is to install the Linux kernel 5.13 nVidia driver on the 5.10 LTS and though maybe you got lucky this time, it might cause problems down the road when a newer driver gets published.
