First of all, hi everyone, this is my first post on the forum and I hope y’all will be able to give me a hand.
As the title already suggests, I’m having issues connecting my brand new dual booted manjaro installation to a network extender located in another room. The network I’m currently using is the “real” router, but as you might guess the signal is unbearably unstable and crappy. This issue is driving me crazy, I have like 10 other devices (including windows on this machine) that can connect just fine ranging from IOS, to android, even a raspberry Pi.
I’m attaching the output of lspci -v
as I’ve seen this requested in other threads. Btw, I’ve tried installing drivers with manjaro’s internal tool but to no avail
[nocturn9x@notturno ~]$ lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7b86
Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Flags: fast devsel, IRQ 25
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: fcf00000-fcffffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Kernel driver in use: pcieport
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 2
Bus: primary=00, secondary=03, subordinate=28, sec-latency=0
I/O behind bridge: 0000f000-0000ffff [size=4K]
Memory behind bridge: fc800000-fcafffff [size=3M]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 3
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 4
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 5
Bus: primary=00, secondary=29, subordinate=2b, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: fcb00000-fccfffff [size=2M]
Prefetchable memory behind bridge: 00000000e0000000-00000000f01fffff [size=258M]
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 6
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 7
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 8
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 9
Bus: primary=00, secondary=2c, subordinate=2c, sec-latency=0
Memory behind bridge: [disabled]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
Flags: fast devsel, IOMMU group 10
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 11
Bus: primary=00, secondary=2d, subordinate=2d, sec-latency=0
Memory behind bridge: fc500000-fc7fffff [size=3M]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 12
Bus: primary=00, secondary=30, subordinate=30, sec-latency=0
Memory behind bridge: fce00000-fcefffff [size=1M]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 13
Bus: primary=00, secondary=31, subordinate=31, sec-latency=0
Memory behind bridge: fcd00000-fcdfffff [size=1M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Flags: 66MHz, medium devsel, IOMMU group 14
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 14
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
Flags: fast devsel, IOMMU group 15
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 Non-Volatile memory controller: Phison Electronics Corporation E12 NVMe Controller (rev 01) (prog-if 02 [NVM Express])
Subsystem: Phison Electronics Corporation E12 NVMe Controller
Flags: bus master, fast devsel, latency 0, IRQ 46, NUMA node 0, IOMMU group 16
Memory at fcf00000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
03:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller (rev 01) (prog-if 30 [XHCI])
Subsystem: ASMedia Technology Inc. Device 1142
Flags: bus master, fast devsel, latency 0, IRQ 64, IOMMU group 17
Memory at fcaa0000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
03:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller (rev 01) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. Device 1062
Flags: bus master, fast devsel, latency 0, IRQ 48, IOMMU group 17
Memory at fca80000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at fca00000 [disabled] [size=512K]
Kernel driver in use: ahci
03:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 17
Bus: primary=03, secondary=20, subordinate=28, sec-latency=0
Memory behind bridge: fc800000-fc9fffff [size=2M]
20:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 17
Bus: primary=20, secondary=21, subordinate=21, sec-latency=0
20:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 17
Bus: primary=20, secondary=22, subordinate=22, sec-latency=0
Memory behind bridge: fc900000-fc9fffff [size=1M]
20:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39, IOMMU group 17
Bus: primary=20, secondary=25, subordinate=25, sec-latency=0
20:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 17
Bus: primary=20, secondary=26, subordinate=26, sec-latency=0
Memory behind bridge: fc800000-fc8fffff [size=1M]
20:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 41, IOMMU group 17
Bus: primary=20, secondary=27, subordinate=27, sec-latency=0
20:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 42, IOMMU group 17
Bus: primary=20, secondary=28, subordinate=28, sec-latency=0
22:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Flags: bus master, fast devsel, latency 0, IRQ 74, IOMMU group 17
I/O ports at f000 [size=256]
Memory at fc904000 (64-bit, non-prefetchable) [size=4K]
Memory at fc900000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8168
Kernel modules: r8169, r8168
26:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
Subsystem: Lite-On Communications Inc Device 6603
Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 17
Memory at fc800000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: ath9k
Kernel modules: ath9k
29:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch (rev c5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 44, IOMMU group 18
Memory at fcc00000 (32-bit, non-prefetchable) [size=16K]
Bus: primary=29, secondary=2a, subordinate=2b, sec-latency=0
Memory behind bridge: fcb00000-fcbfffff [size=1M]
2a:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 45, IOMMU group 19
Bus: primary=2a, secondary=2b, subordinate=2b, sec-latency=0
2b:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 14 [Radeon RX 5500/5500M / Pro 5500M] (rev c5) (prog-if 00 [VGA controller])
Subsystem: Sapphire Technology Limited Device e421
Flags: bus master, fast devsel, latency 0, IRQ 79, IOMMU group 20
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=2M]
I/O ports at e000 [size=256]
Memory at fcb00000 (32-bit, non-prefetchable) [size=512K]
Expansion ROM at fcb80000 [disabled] [size=128K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
2b:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio
Flags: bus master, fast devsel, latency 0, IRQ 76, IOMMU group 21
Memory at fcba0000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
2c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Flags: fast devsel, IOMMU group 22
2d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Flags: fast devsel, IOMMU group 23
2d:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Flags: bus master, fast devsel, latency 0, IRQ 61, IOMMU group 24
Memory at fc600000 (32-bit, non-prefetchable) [size=1M]
Memory at fc708000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
2d:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Flags: bus master, fast devsel, latency 0, IRQ 65, IOMMU group 25
Memory at fc500000 (64-bit, non-prefetchable) [size=1M]
2d:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: Micro-Star International Co., Ltd. [MSI] Device cb86
Flags: bus master, fast devsel, latency 0, IRQ 78, IOMMU group 26
Memory at fc700000 (32-bit, non-prefetchable) [size=32K]
30:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 50, IOMMU group 27
Memory at fce00000 (32-bit, non-prefetchable) [size=2K]
31:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51) (prog-if 01 [AHCI 1.0])
Flags: bus master, fast devsel, latency 0, IRQ 52, IOMMU group 28
Memory at fcd00000 (32-bit, non-prefetchable) [size=2K]
