are you stuck in black screen?
fixed it just now
ok so provide output from:
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
I’m trying to install
Installing video-hybrid-amd-nvidia-prime…
but are you installing these:
not the 470xx ones
yes,Boot normally.Iwill test Hibernate
Evething looks good!
The screen and keyboard light closed as windows hibernate. I will test it to verify.
Bad news, during the past three sleeps and wake-ups, there was a splash screen. And the second boot failed.
The good news is that the working state is indeed preserved intact.
i dont understand, so can you hibernate or not?
may you post the output of
It seems to function normally.
However, the screen displayed a snowflake like image when it was turned on, and after a while it displayed normally.
so post again logs from:
journalctl --system --boot=0 --priority=3
and also logs after you put your system to hibernate, just like before…
Jun 10 22:19:11 FA5II06 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP4.WLAN], AE_NOT_FOUND (20210730/dswload2-162)
Jun 10 22:19:11 FA5II06 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
Jun 10 22:19:11 FA5II06 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20210730/psargs-330)
Jun 10 22:19:11 FA5II06 kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 10 22:19:14 FA5II06 kernel:
Jun 10 22:19:17 FA5II06 systemd[858]: Failed to start Update XDG user dir configuration.
Jun 10 22:19:18 FA5II06 pppd[892]: Cannot determine ethernet address for proxy ARP
Jun 10 22:20:13 FA5II06 kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Jun 10 22:22:13 FA5II06 kernel: __common_interrupt: 1.36 No irq handler for vector
Jun 10 22:23:32 FA5II06 pppd[3645]: select (waitForPADO): Interrupted system call
Jun 10 22:23:32 FA5II06 pppd[3645]: Unable to complete PPPoE Discovery
Jun 10 22:23:41 FA5II06 pppd[4799]: Cannot determine ethernet address for proxy ARP
ok no noveau issues, like before… also the logs after hibernation…
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=bf845bc1-1423-40c6-97f4-af9d0b7ec984 rw fsck.mode=skip quiet
apparmor=1 security=apparmor
resume=UUID=daee94db-bdb8-476b-8ad4-4fccb576592e udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506II_FA506II
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FA506II v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA506II.316 date: 03/12/2021
ID-1: BAT1 charge: 37.1 Wh (98.4%) condition: 37.7/48.1 Wh (78.4%)
volts: 12.6 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: N/A
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
status: discharging
RAM: total: 15.12 GiB used: 4.11 GiB (27.2%)
RAM Report:
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1450 high: 1887 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1686 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1887 9: 1463 10: 1397 11: 1397
12: 1396 13: 1394 14: 1397 15: 1396 16: 1405 bogomips: 92656
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1521 built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.41-1-MANJARO)
v: 4.6 Mesa 22.0.4 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: ASUSTeK driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2725
class-ID: 0280
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
IF-ID-3: vethf27a400 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: ztwfuhb4ay state: unknown speed: 10 Mbps duplex: full
mac: <filter>
IP v6: <filter> scope: global
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-1:2
chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
something about disk was deleted.
ID-1: swap-1 type: partition size: 31.25 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5 label: 32G-SWAP
uuid: daee94db-bdb8-476b-8ad4-4fccb576592e
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 180.68 GiB fs: ntfs label: N/A
uuid: 26F20E3BF20E0FAB
ID-3: /dev/sda2 maj-min: 8:2 size: 367.68 GiB fs: ntfs label: WIN-D
uuid: 29539FCF180EF627
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 58.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): cpu: 2500
Processes: 430 Uptime: 10m wakeups: 5 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1419 lib: 355
flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.16
thanks and now please the output of
cat /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="fsck.mode=skip quiet apparmor=1 security=apparmor resume=UUID=daee94db-bdb8-476b-8ad4-4fccb576592e udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
~ journalctl --boot -0 --no-pager|grep hibernate ✔
Jun 10 22:50:53 FA5II06 systemd-sleep[4480]: Entering sleep state 'hibernate'...
Jun 10 22:52:02 FA5II06 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 10 22:52:02 FA5II06 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 10 22:52:02 FA5II06 kernel: audit: type=1130 audit(1654872722.049:214): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 10 22:52:02 FA5II06 kernel: audit: type=1131 audit(1654872722.049:215): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 10 22:52:02 FA5II06 systemd[1]: systemd-hibernate.service: Deactivated successfully.
Jun 10 22:52:02 FA5II06 systemd[1]: systemd-hibernate.service: Consumed 1.036s CPU time.
it is well.
I think the reason is about the 1650ti.
But I don’t kow how to do
yes it looks good, no errors:
it was related to the open source noveau drivers, and since you installed the proper drivers, it is resolved
YES
BUT
