your grub edit is wrong:
resume=resume=daee94db-bdb8-476b-8ad4-4fccb576592e
it should be:
and also there is a space in the mkinitcpio after resume:
udev resume autodetect - so correct it
@Mirdarthos @brahma
in fact it’s
resume=UUID=daee94db-bdb8-476b-8ad4-4fccb576592e
and it doesn’t work.
and did you run the update gurb and the mkinticpio -P commands afterwards?
yes,I did that
edit again the HOOKS line to look like this:
HOOKS="base udev autodetect modconf block keyboard keymap consolefont filesystems fsck resume"
run:
sudo mkinitcpio -P
reboot and test
dont use hibernate, and never have, so really dont know how to troubleshoot this… can you again hibernate, and then post logs, like you did before… maybe there will be something new since the grub/mkinit edits…
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_hq
Jun 10 21:49:24 FA5II06 systemd-sleep[11764]: Failed to put system to sleep. System resumed again: Invalid argument
Jun 10 21:49:24 FA5II06 kernel: Bluetooth: hci0: Found device firmware: intel/ibt-0041-0041.sfi
Jun 10 21:49:24 FA5II06 kernel: Bluetooth: hci0: Boot Address: 0x100800
Jun 10 21:49:24 FA5II06 kernel: Bluetooth: hci0: Firmware Version: 91-12.22
Jun 10 21:49:24 FA5II06 kernel: Bluetooth: hci0: Firmware already loaded
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_sq
Jun 10 21:49:24 FA5II06 systemd[880]: appimagelauncherd.service: Scheduled restart job, restart counter is at 55.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac_mq
Jun 10 21:49:24 FA5II06 systemd[880]: Stopped AppImageLauncher daemon.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/aptx_hd
Jun 10 21:49:24 FA5II06 systemd[1]: Starting Load/Save RF Kill Switch Status...
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_hd
Jun 10 21:49:24 FA5II06 systemd[880]: Started AppImageLauncher daemon.
Jun 10 21:49:24 FA5II06 systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 21:49:24 FA5II06 systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc
Jun 10 21:49:24 FA5II06 systemd[1]: Failed to start Hibernate.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc
Jun 10 21:49:24 FA5II06 systemd[880]: Stopped target Bluetooth.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Jun 10 21:49:24 FA5II06 systemd[1]: Dependency failed for System Hibernation.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Jun 10 21:49:24 FA5II06 systemd[1]: hibernate.target: Job hibernate.target/start failed with result 'dependency'.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Jun 10 21:49:24 FA5II06 systemd[1]: systemd-hibernate.service: Consumed 1.763s CPU time.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Jun 10 21:49:24 FA5II06 systemd[1]: Stopped target Bluetooth Support.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Jun 10 21:49:24 FA5II06 systemd[1]: Stopped target Sleep.
Jun 10 21:49:24 FA5II06 bluetoothd[594]: Endpoint unregistered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Jun 10 21:49:24 FA5II06 systemd[880]: Reached target Bluetooth.
Jun 10 21:49:24 FA5II06 systemd[1]: Reached target Bluetooth Support.
Jun 10 21:49:24 FA5II06 systemd-logind[599]: Operation 'sleep' finished.
Jun 10 21:49:24 FA5II06 NetworkManager[614]: <info> [1654868964.2273] manager: sleep: wake requested (sleeping: yes enabled: yes)
Jun 10 21:49:24 FA5II06 NetworkManager[614]: <info> [1654868964.2275] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jun 10 21:49:24 FA5II06 ModemManager[652]: <info> [sleep-monitor] system is resuming
Jun 10 21:49:24 FA5II06 systemd[1]: Started Load/Save RF Kill Switch Status.
Jun 10 21:49:24 FA5II06 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
the same… but there are also bluetooth logs, so disable bluetooth and try hibernate again?
I try it just now.
not work.
post again logs from:
journalctl --system --boot=0 --priority=3
Jun 10 21:54:00 FA5II06 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP4.WLAN], AE_NOT_FOUND (20210730/dswload2-162)
Jun 10 21:54:00 FA5II06 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
Jun 10 21:54:01 FA5II06 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20210730/psargs-330)
Jun 10 21:54:01 FA5II06 kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Jun 10 21:54:02 FA5II06 sddm[592]: Failed to read display number from pipe
Jun 10 21:54:06 FA5II06 systemd[808]: Failed to start Update XDG user dir configuration.
Jun 10 21:54:08 FA5II06 pppd[793]: Cannot determine ethernet address for proxy ARP
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Jun 10 21:54:18 FA5II06 kernel: nvkm: mm not clean!
Jun 10 21:54:18 FA5II06 kernel: nvkm: node list:
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00000000 00002000 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002000 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002018 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002020 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002038 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002040 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002058 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002060 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002078 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002080 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002098 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000020a0 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000020b8 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000020c0 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000020d8 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000020e0 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000020f8 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002100 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002118 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002120 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002138 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002140 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002158 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002160 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002178 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002180 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002198 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000021a0 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000021b8 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000021c0 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000021d8 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000021e0 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 000021f8 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002200 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002218 00000008 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002220 00000018 1
Jun 10 21:54:18 FA5II06 kernel: nvkm: 00002238 0000ddc8 0
Jun 10 21:54:18 FA5II06 kernel: nvkm: free list:
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: timer: stalled at ffffffffffffffff
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: fb: Falcon mem scrubbing timeout
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: fb: VPR still locked after scrub!
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: fb: init failed, -5
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: init failed with -5
Jun 10 21:54:18 FA5II06 kernel: nouveau: Xorg[770]:00000000:00000080: init failed with -5
Jun 10 21:54:18 FA5II06 kernel: nouveau: DRM-master:00000000:00000000: init failed with -5
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: DRM: Client resume failed with error: -5
Jun 10 21:54:18 FA5II06 kernel: nouveau 0000:01:00.0: DRM: resume failed with: -5
Jun 10 21:55:02 FA5II06 kernel: ucsi_acpi USBC000:00: PPM init failed (-110)
Jun 10 21:55:07 FA5II06 kernel: PM: pci_pm_freeze(): nouveau_pmops_freeze+0x0/0x10 [nouveau] returns -22
Jun 10 21:55:07 FA5II06 kernel: PM: dpm_run_callback(): pci_pm_freeze+0x0/0xc0 returns -22
Jun 10 21:55:07 FA5II06 kernel: nouveau 0000:01:00.0: PM: failed to freeze async: error -22
Jun 10 21:55:07 FA5II06 systemd-sleep[3623]: Failed to put system to sleep. System resumed again: Invalid argument
Jun 10 21:55:07 FA5II06 systemd[1]: Failed to start Hibernate.
Jun 10 21:55:24 FA5II06 pppd[3717]: PAP authentication failed
Jun 10 21:55:32 FA5II06 pppd[4552]: Cannot determine ethernet address for proxy ARP
this one looks suspicious:
post output from:
mhwd -l && mhwd -li
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1f95) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
> Installed PCI configs:
you dont have installed nvidia drivers, is there a reason for it?
so you using noveau as a nvidia driver, and maybe thats the issue preventing from hibernate… so install nvidia drivers, click in the screen auto install proprietary drivers, when its done, reboot and test
ok
Installing video-nvidia-470xx…
but I think I will offline sometime.
about an year ago,I install the driver from nvida,result to can’t boot.
why its installing the 470xx when there are available the latest hybrid drivers… so dont reboot when its done, uninstall it and install the hybrid ones
oh
I don’t know which is newest
And it can’t boot as except.
I need reinstall it
