Can´t perform system upgrade
This issue has been plaguing me for a while, and I haven’t been able to fix it. Am currently chrooted old enviroment, was hoping to avoid wiping my ssd. I understand VERY WELL that manjaro is an active roll-out distro, and have always treated it as such. Sometimes life gets in the way, and repeating this phrase doesn’t really take you any closer to performing said system upgrade which I very much would like to do in order to qualify for assistance. Asked for help regarding kernel installations (fixed, but alas it brought me no closer to succesfully booting nor upgrading my system).
System is using systemd, is encrypted with LUKS and boot is located in /dev/sda2/boot. I have tried updating gpg keys and mirrors. No matter what is answered the result is about the same. Here are two (minorly) differing outputs. On boot I am greeted with failed to start cups scheduler, & failed to start network time synchronization. BIOS options for secure boot are off, system doesn’t recognize live cd without legacy mode enabled, but in boot options menu if legacy mode is enabled, both OS and Live CD are marked with UEFI marking, and this has been stable for half a century. MODS may close if they deem necessary, I believe we are all learning here, progress is difficult to achieve without open communication and no-one is forced to help. Maybe someone has run into a similar situation. Thank you again! :slight_smile:
[manjaro /]# pacman -Syyu
 core                                  143.6 KiB  1496 KiB/s 00:00 [####################################] 100%
 extra                                1637.9 KiB  2.21 MiB/s 00:01 [####################################] 100%
 community                               7.0 MiB  4.50 MiB/s 00:02 [####################################] 100%
 multilib                              145.5 KiB  7.10 MiB/s 00:00 [####################################] 100%
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n]
:: Replace atk with extra/at-spi2-core? [Y/n]
:: Replace crda with core/wireless-regdb? [Y/n]
:: Replace hwids with core/hwdata? [Y/n]
:: Replace lib32-atk with multilib/lib32-at-spi2-core? [Y/n]
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n]
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n]
:: Replace libutil-linux with core/util-linux-libs? [Y/n]
:: Replace microsoft-office-online-jak with community/microsoft-office-web-jak? [Y/n]
:: Replace pygobject-devel with extra/python-gobject? [Y/n]
:: Replace python-dbus with extra/dbus-python? [Y/n]
:: Replace python-dbus-common with extra/dbus-python? [Y/n]
:: Replace python-pyqtwebengine with extra/python-pyqt5-webengine? [Y/n]
:: Replace python-xdg with extra/python-pyxdg? [Y/n]
:: Replace qca with extra/qca-qt5? [Y/n]
:: Replace qgpgme with core/qgpgme-qt5? [Y/n]
:: Replace quazip with extra/quazip-qt5? [Y/n]
:: Replace sdl with community/sdl12-compat? [Y/n]
warning: sndio: local (20180120-1) is newer than community (1.9.0-1)
:: Replace steam-manjaro with multilib/steam? [Y/n]
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n]
:: Replace xdg-desktop-portal-gtk with extra/xdg-desktop-portal-gnome? [Y/n]
:: Replace xorg-luit with extra/luit? [Y/n]
:: Replace xorg-server-xwayland with extra/xorg-xwayland? [Y/n]
resolving dependencies...
:: There are 2 providers available for pipewire-session-manager:
:: Repository extra
   1) wireplumber
:: Repository community
   2) pipewire-media-session
Enter a number (default=1):
:: There are 2 providers available for libjack.so=0-32:
:: Repository multilib
   1) lib32-jack2  2) lib32-pipewire-jack
:: lib32-jack2 and lib32-jack are in conflict. Remove lib32-jack? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
[manjaro /]#
:: Repository extra
   1) wireplumber
[manjaro /]#
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Hi @glitchyhippie.
I don’t know or even think I can help, because of:
However, I can give you some advice:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hello @glitchyhippie :wink:
lib32-jack and jack were dropped to the AUR and replaced by lib32-jack2 and jack2. If you need these packages, then you have to replace it. You need to type y when asked, since N is the default. Pamac replaces it without asking.
Thank you! I was wondering what the code was for that but am a bit busy, thank you for fixing it for me. And yes, it doesn’t matter whether I press Y or N, the end result is always the same :slight_smile:
The problem is, nothing is replaced, literally no matter what I answer the output is the same any which way.
I will continue training and hope that maybe something comes up :slight_smile:
 core                                  143.6 KiB  1381 KiB/s 00:00 [####################################] 100%
 extra                                1637.9 KiB  3.58 MiB/s 00:00 [####################################] 100%
 community                               7.0 MiB  2.48 MiB/s 00:03 [####################################] 100%
 multilib                              145.5 KiB  3.84 MiB/s 00:00 [####################################] 100%
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n] y
:: Replace atk with extra/at-spi2-core? [Y/n] y
:: Replace crda with core/wireless-regdb? [Y/n] y
:: Replace hwids with core/hwdata? [Y/n] y
:: Replace lib32-atk with multilib/lib32-at-spi2-core? [Y/n] y
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] y
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] y
:: Replace libutil-linux with core/util-linux-libs? [Y/n] y
:: Replace microsoft-office-online-jak with community/microsoft-office-web-jak? [Y/n] y
:: Replace pygobject-devel with extra/python-gobject? [Y/n] y
:: Replace python-dbus with extra/dbus-python? [Y/n] y
:: Replace python-dbus-common with extra/dbus-python? [Y/n] y
:: Replace python-pyqtwebengine with extra/python-pyqt5-webengine? [Y/n] y
:: Replace python-xdg with extra/python-pyxdg? [Y/n] y
:: Replace qca with extra/qca-qt5? [Y/n] y
:: Replace qgpgme with core/qgpgme-qt5? [Y/n] y
:: Replace quazip with extra/quazip-qt5? [Y/n] y
:: Replace sdl with community/sdl12-compat? [Y/n] y
:: Replace steam-manjaro with multilib/steam? [Y/n] y
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n] y
:: Replace xdg-desktop-portal-gtk with extra/xdg-desktop-portal-gnome? [Y/n] y
:: Replace xorg-luit with extra/luit? [Y/n] y
:: Replace xorg-server-xwayland with extra/xorg-xwayland? [Y/n] y
:: Repository extra
   1) wireplumber
Enter a number (default=1): y
error: invalid number: y
:: lib32-jack2 and lib32-jack are in conflict. Remove lib32-jack? [y/N] y
:: jack2 and jack are in conflict. Remove jack? [y/N] y
:: xorg-fonts-alias-misc and xorg-fonts-alias are in conflict. Remove xorg-fonts-alias? [y/N] y
:: dbus-python and python2-dbus are in conflict. Remove python2-dbus? [y/N] y
:: installing libappindicator-gtk3 (12.10.0.r298-1) breaks dependency 'libappindicator3' required by indicator-application
:: installing libappindicator-gtk3 (12.10.0.r298-1) breaks dependency 'libappindicator3' required by indicator-powersave
:: removing python2-dbus breaks dependency 'python2-dbus' required by indicator-powersave
:: installing db (6.2.32-1) breaks dependency 'db=5.3.28' required by lib32-db
:: installing lib32-libcanberra (1:0.30+r2+gc0620e4-2) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-1' required by lib32-libcanberra-gstreamer
:: installing libcanberra (1:0.30+r2+gc0620e4-3) breaks dependency 'libcanberra=0.30+2+gc0620e4-2' required by libcanberra-gstreamer
:: removing pygobject-devel breaks dependency 'pygobject-devel=3.34.0' required by python2-gobject
:: removing wxgtk-common breaks dependency 'wxgtk-common' required by wxgtk2
[manjaro /]#
p.s You guys should really add a thanks or similar button like on xda someday, it’s nice to thank people for help :slight_smile:
ok well… then just remove it and install lib32-jack2 before the upgrade. or use pamac:
pamac upgrade --force-refresh --enable-downgrade --no-aur
There is one: grafik
A heart means: I like it or thank you or what ever you think of.
I swear, this is ludicrous. I had to uninstall my desktop too, but I managed to update, and had a working kernel installed. For some reason I assumed that when it asked whether or not to “replace” something, it would remove it and install a newer version, though now that I type it out, it does seem like a mighty tall assumption. Thank you for your iron-clad patience. Much love :slight_smile:
