Can not receive sms
Bonjour,
j ai un probleme
j ai l impression de ne plus recevoir de sms
je recois deux anciens sms quand j active les donnees mobiles
et j arrive pas a acceder a taper les numeros de telephone dans l application telephone
je suis sous pinephone manjaro beta 10 plasma mobile
et je copie un fichier texte de spacebar lors de la mise a jour /home/user/local/share/spacebar/messages.sqlite et la j ai copie deux dossier vide downloads et notifications
in english now
hi,
i have a problem
i think i can not receive sms
i receive two sms when i active mobile data
i can not use the application Telephon i can not access to compose a number
i am on pinephone manjaro beta 10 plasma mobile
i use /home/user/local/share/spacebar/messages.sqlite To save my sms when i update to most update manjaro beta
and for beta 10 i have copy two folder too downloads and notifications
Yes with the command
mmcli -e -m any
I can view the operator on left on top
But I received no sms always
Oui avec la commande
mmcli -e -m any
Je peux voir mon opérateur téléphonique sans cliquez sur activer les données mobiles
Mais je ne peux toujours pas recevoir de sms
So you normally have mobile data disabled? When you do that, it is a known issue in Beta 10 (and Beta 9 – anything using Plasma Mobile on ModemManager) that your modem is completely disabled, so you can neither send nor receive SMS messages nor phone calls, see:
Ok I will wait a new update
