Can not connect or see any 5 GHz networks anymore
Up until now I was able to solve problems myself but this one is odd. I have searched the net and this forum but could not find anything that solves my issue.
All of a sudden so it seems I can not see or connect to 5 GHz WiFi anymore.
On various manjaro machines.
I take this Thinkpad T450 for this thread.
I tried different kernels, checked my WiFi regulatory domain, switched from wpa3 to wpa2, checked channels and even tried a different router/network.
Interestingly this happens on different computers, that previously all connected to 5Ghz.
Here is info on one machine I selected for troubleshooting:
  Kernel: 6.6.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=91d4d24b-c1b7-4237-bb8c-cc8d9fcff88b rw quiet splash
    resume=UUID=c4e5c249-6c15-44f5-8534-d5de1944ad2c udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Laptop System: LENOVO product: 20BUS3L502 v: ThinkPad T450
  Mobo: LENOVO model: 20BUS3L502 v: SDK0E50510 WIN
    serial: <superuser required>
    part-nu: LENOVO_MT_20BU_BU_Think_FM_ThinkPad T450
    uuid: <superuser required> UEFI: LENOVO v: JBET47WW (1.12 )
    date: 03/10/2015
  ID-1: BAT0 charge: 17.1 Wh (95.5%) condition: 17.9/23.2 Wh (76.9%)
    volts: 12.2 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
    status: not charging
  ID-2: BAT1 charge: 17.7 Wh (99.4%) condition: 17.8/23.2 Wh (76.9%)
    volts: 12.3 min: 11.1 model: SANYO 45N1775 type: Li-ion serial: <filter>
  Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1846 high: 2297 min/max: 500/2900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2297 2: 2295 3: 500
    4: 2295 bogomips: 18360
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
    class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:5 chip-ID: 04f2:b449
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
    device-ID: 8086:1616 memory: 3.73 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 5500 (BDW GT2) driver: mesa intel
    v: 24.1.3-manjaro1.1 device-ID: 8086:1616 surfaces: xcb,xlib,wayland
  Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  API: ALSA v: k6.6.41-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.1 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel
    port: 3080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
  IF-ID-1: wwp0s20u4 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  Local Storage: total: 238.47 GiB used: 59.33 GiB (24.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8TB8U256G1001
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0101 scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
    used: 59.33 GiB (26.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 47.0 C pch: 46.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0
  Memory: total: 8 GiB available: 7.64 GiB used: 4.94 GiB (64.6%)
  Processes: 200 Power: uptime: 1h 46m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1447 pm: pacman pkgs: 1433 libs: 432 tools: pamac,yay pm: flatpak
    pkgs: 14 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.35
Odd thing is one manjaro DELL machine can happily connect to 5Ghz wpa3.
Maybe someone could point me in the right direction.
Any help would be greatly appreciated!
Thank you in advance.
Alex
Sync the package pacmanlogviewer to dissect the log.
It is impossible to provide a meaningful response.
From the beginning - it is inconclusive - there is no one that can troubleshoot such a broad issue.
I would not even know where to begin… You will have to look at broad commonalities…
5G is ±half the wave length of 2.4G and thus more sensitive to
  • signal/noise level
  • obstructions
  • wireless crowd
Brain storming
  • Git bisect the kernel sources, build and rebuild until you find it.
  • Has the router firmware been updated
  • Does the router implement newer protocols and checks that excludes incompatible clients
  • Did you change your router configuration e.g. 802.11r or PMF or BSS Transition
I cannot provide further ideas … have fun :slight_smile:
Yep thanks. You are absolutely correct. It is a broad issue.
Therefore I was hesitant to post it here.
Reason why I did post is that any other device connects flawlessly to 5GHz wpa3 only the manjaro machines do not see 5 GHz anymore after the last update.
Only one DELL Manjaro with a centrino 6300 WiFi still connects flawlessly to 5Ghz wpa3.
The router I tried to rule out by trying a few completely different routers with a standard config. Still the manjaro machines could not connect to 5Ghz.
So IMHO it has to do with something that changed in those manjaro machines.
Thanks anyway.
In router configuration, try with WPA2 encryption.
journalctl -f
while you are (trying to) connect
could be helpful
I tried this. But it makes no difference.
It is strange because it seems that the WiFi card does not support 5Ghz.
But why then does it work on another distro. Odd.
   ~  journalctl -f         ✔
Aug 04 10:34:46 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760486.1103] device (wlp3s0): set-hw-addr: set MAC address to 1E:DE:6F:C3:28:E2 (scanning)
Aug 04 10:34:46 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760486.1147] manager: NetworkManager state is now DISCONNECTED
Aug 04 10:34:46 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760486.1156] device (wlp3s0): supplicant interface state: completed -> disconnected
Aug 04 10:34:46 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760486.1157] device (p2p-dev-wlp3s0): supplicant management interface state: completed -> disconnected
Aug 04 10:34:47 linux-lenovo-t450 rtkit-daemon[677]: Supervising 7 threads of 4 processes of 1 users.
Aug 04 10:34:51 linux-lenovo-t450 plasmashell[840]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible"
Aug 04 10:34:51 linux-lenovo-t450 wireplumber[720]: wp-event-dispatcher: <WpAsyncEventHook:0x55e8017f8ce0> failed: <WpSiStandardLink:0x55e8018e2200> link failed: 1 of 1 PipeWire links failed to activate
Aug 04 10:34:55 linux-lenovo-t450 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5585] device (wlp3s0): Activation: starting connection 'SynoResidence' (04b4f166-2fdc-45e5-8f1a-487bed46ed2c)
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5587] audit: op="connection-activate" uuid="04b4f166-2fdc-45e5-8f1a-487bed46ed2c" name="SynoResidence" pid=840 uid=1000 result="success"
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5588] device (wlp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5595] manager: NetworkManager state is now CONNECTING
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5738] device (wlp3s0): set-hw-addr: reset MAC address to 18:5E:0F:33:85:6F (preserve)
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5779] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5784] device (wlp3s0): Activation: (wifi) access point 'SynoResidence' has security, but secrets are required.
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5785] device (wlp3s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:11 linux-lenovo-t450 kded6[799]: org.kde.plasma.nm.kded: Unhandled active connection state change:  1
Aug 04 10:35:11 linux-lenovo-t450 kded6[799]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5919] device (wlp3s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5922] device (wlp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5927] device (wlp3s0): Activation: (wifi) connection 'SynoResidence' has security, and secrets exist.  No new secrets needed.
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5928] Config: added 'ssid' value 'SynoResidence'
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5928] Config: added 'scan_ssid' value '1'
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5928] Config: added 'bgscan' value 'simple:30:-65:300'
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5928] Config: added 'key_mgmt' value 'SAE FT-SAE'
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5928] Config: added 'auth_alg' value 'OPEN'
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5928] Config: added 'psk' value '<hidden>'
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.5929] Config: added 'ieee80211w' value '2'
Aug 04 10:35:11 linux-lenovo-t450 plasmashell[840]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.6188] device (wlp3s0): supplicant interface state: disconnected -> scanning
Aug 04 10:35:11 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760511.6189] device (p2p-dev-wlp3s0): supplicant management interface state: disconnected -> scanning
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: SME: Trying to authenticate with 00:11:32:a5:48:7e (SSID='SynoResidence' freq=2412 MHz)
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: authenticate with 00:11:32:a5:48:7e
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: 80 MHz not supported, disabling VHT
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: send auth to 00:11:32:a5:48:7e (try 1/3)
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.2629] device (wlp3s0): supplicant interface state: scanning -> authenticating
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.2630] device (p2p-dev-wlp3s0): supplicant management interface state: scanning -> authenticating
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: PMKSA-CACHE-ADDED 00:11:32:a5:48:7e 0
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: Trying to associate with 00:11:32:a5:48:7e (SSID='SynoResidence' freq=2412 MHz)
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.3668] device (wlp3s0): supplicant interface state: authenticating -> associating
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.3668] device (p2p-dev-wlp3s0): supplicant management interface state: authenticating -> associating
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: authenticated
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: associate with 00:11:32:a5:48:7e (try 1/3)
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: Associated with 00:11:32:a5:48:7e
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: RX AssocResp from 00:11:32:a5:48:7e (capab=0x1431 status=0 aid=1)
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: associated
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.3867] device (wlp3s0): supplicant interface state: associating -> associated
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.3867] device (p2p-dev-wlp3s0): supplicant management interface state: associating -> associated
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.3960] device (wlp3s0): supplicant interface state: associated -> 4way_handshake
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.3960] device (p2p-dev-wlp3s0): supplicant management interface state: associated -> 4way_handshake
Aug 04 10:35:12 linux-lenovo-t450 kernel: wlp3s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 00:11:32:a5:48:7e
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: WPA: Key negotiation completed with 00:11:32:a5:48:7e [PTK=CCMP GTK=CCMP]
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: CTRL-EVENT-CONNECTED - Connection to 00:11:32:a5:48:7e completed [id=0 id_str=]
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.4873] device (wlp3s0): supplicant interface state: 4way_handshake -> completed
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.4875] device (wlp3s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "SynoResidence"
Aug 04 10:35:12 linux-lenovo-t450 wpa_supplicant[507]: wlp3s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-40 noise=9999 txrate=1000
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.4875] device (p2p-dev-wlp3s0): supplicant management interface state: 4way_handshake -> completed
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.4881] device (wlp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.4887] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Aug 04 10:35:12 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760512.8780] dhcp4 (wlp3s0): state changed new lease, address=192.168.1.139, acd pending
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.0217] dhcp4 (wlp3s0): state changed new lease, address=192.168.1.139
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.0223] policy: set 'SynoResidence' (wlp3s0) as default for IPv4 routing and DNS
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.0665] device (wlp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:13 linux-lenovo-t450 systemd[1]: Starting Network Manager Script Dispatcher Service...
Aug 04 10:35:13 linux-lenovo-t450 systemd[1]: Started Network Manager Script Dispatcher Service.
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.1088] device (wlp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.1091] device (wlp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.1096] manager: NetworkManager state is now CONNECTED_SITE
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.1106] device (wlp3s0): Activation: successful, device activated.
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.1274] audit: op="statistics" interface="wlp3s0" ifindex=4 args="2000" pid=840 uid=1000 result="success"
Aug 04 10:35:13 linux-lenovo-t450 NetworkManager[447]: <info>  [1722760513.3850] manager: NetworkManager state is now CONNECTED_GLOBAL
Aug 04 10:35:13 linux-lenovo-t450 kdeconnectd[1038]: 2024-08-04T10:35:13 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
Aug 04 10:35:14 linux-lenovo-t450 rtkit-daemon[677]: Supervising 7 threads of 4 processes of 1 users.
Aug 04 10:35:20 linux-lenovo-t450 plasmashell[840]: qrc:/qt/qml/org/kde/plasma/components/ScrollView.qml:53:29: QML ScrollBar: Binding loop detected for property "visible"
Aug 04 10:35:23 linux-lenovo-t450 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
I belive I read somewere on the net that these Intel Wireless 7265 cards do have problems.
Well for now I have installed a different distro to get the work done on the machine that is important.
After that the quickest way is to ditch the card and get a known good one and put back the SSD with the manjaro install and be done with it.
Thanks again to all. Your time and effort is greatly appreciated.
Alex
How did you manage to make the terminal output look that awful?
copy/paste and then mark and have it formatted with </> as preformatted text
same as with your system info above
I’ll not even try to read this. :man_shrugging:
another question:
what exact command did you use to generate this output in the initial post (system info):
because this looks strange to me:
the two last lines, the second interface ID and the info
Providing terminal output
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
If you want more assistance, I recommend correcting this because, as @anon33601770 said, he won’t attempt reading it and no doubt just about everyone feels that way.
Got it thanks!
The command i used is: inxi -Fazy.
Here is the output from: inxi -zv8
    date: 03/10/2015
  ID-1: BAT0 charge: 17.9 Wh (100.0%) condition: 17.9/23.2 Wh (76.9%)
    volts: 12.4 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
    status: full
  ID-2: BAT1 charge: 17.8 Wh (100.0%) condition: 17.8/23.2 Wh (76.9%)
  System RAM: total: 8 GiB available: 7.64 GiB used: 4.85 GiB (63.5%)
  Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471B1G73EB0-YK0 serial: <filter>
  Device-2: ChannelB-DIMM0 type: no module installed
  Speed (MHz): avg: 798 high: 998 min/max: 500/2900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 998 2: 500 3: 897 4: 798
    bogomips: 18366
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu
    fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme
    x2apic xsave xsaveopt xtopology xtpr
    affected
    class-ID: 0300
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
    GT2) device-ID: 8086:1616 memory: 3.73 GiB unified: yes display-ID: :1.0
    class-ID: 0403
    tools: pw-cli,wpctl
  Local Storage: total: 238.47 GiB used: 59.51 GiB (25.0%)
    used: 59.51 GiB (26.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 91d4d24b-c1b7-4237-bb8c-cc8d9fcff88b
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 2B15-F1D9
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: c4e5c249-6c15-44f5-8534-d5de1944ad2c
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 2-3:2 info: Racal Data type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 0581:0105 class-ID: 0301
  Device-2: 2-4:3 info: Sierra Wireless Wireless EM7345 4G LTE
    type: communication,CDC-data,abstract (modem) driver: cdc_acm,cdc_mbim
    interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 100mA chip-ID: 1199:a001 class-ID: 0a00 serial: <filter>
  Device-3: 2-8:5 info: Chicony Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b449 class-ID: 0e02
    serial: <filter>
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 43.0 C pch: 43.5 C mobo: N/A
  Packages: 1449 pm: pacman pkgs: 1435 libs: 432 tools: pamac,yay pm: flatpak
    pkgs: 14
    1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 198
  1: cpu: 15.0% command: firefox pid: 1337 mem: 666.2 MiB (8.5%)
  2: cpu: 13.1% command: firefox pid: 1782 mem: 91.7 MiB (1.1%)
  3: cpu: 9.7% command: firefox pid: 4607 mem: 458.5 MiB (5.8%)
  4: cpu: 5.5% command: kwin_wayland pid: 669 mem: 196.2 MiB (2.5%)
  5: cpu: 1.5% command: firefox pid: 1488 mem: 313.7 MiB (4.0%)
  Memory top: 5 of 198
  1: mem: 666.2 MiB (8.5%) command: firefox pid: 1337 cpu: 15.0%
  2: mem: 458.5 MiB (5.8%) command: firefox pid: 4607 cpu: 9.7%
  3: mem: 384.5 MiB (4.9%) command: firefox pid: 4132 cpu: 0.6%
  4: mem: 369.9 MiB (4.7%) command: plasmashell pid: 840 cpu: 0.2%
  5: mem: 340.5 MiB (4.3%) command: firefox pid: 1474 cpu: 0.8%
  Processes: 198 Power: uptime: 4h 12m states: freeze,mem,disk suspend: deep
    tool: systemctl
Thanks - I asked because I have never seen this with my wireless interface.
Neither have I seen this:
nor do I have a separate interface ID - I have never seen this:
to my untrained eye it looks like you have two interfaces running on one device
and
but that may have to do with IPv6 - but usually the WAN interface is on the router, no?
Perhaps some accidental misconfiguration?
can you point to what makes you say this?
Well I did iwlist wlp3s0 freq and I got:
 iwlist wlp3s0 freq         ✔  8s 
wlp3s0    13 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
          Current Frequency:2.412 GHz (Channel 1)
Shoudn’t it also have the 5Ghz info?
If I pull up the manufacturers page it does clearly state it has 5GHz.
And it has worked in the past with 5GHz.
https://www.intel.com/content/www/us/en/products/sku/83635/intel-dual-band-wirelessac-7265/specifications.html
Under “networks” in kde I exclusively see 2.5GHz APs.
In LinSSID I also only see 2.4 GHz APs.
It is as if 5GHz doesn’t exist anymore. :stuck_out_tongue:
Alex
Not sure, but you might be on to something…
Maybe the 5GHz controller is malfunctioning…
:man_shrugging:
If so, it’s a hardware issue…
Yes. A hardware issue That’s what I was thinking too.
I’ll just ditch It I guess. A few bucks will get me one that works. :slightly_smiling_face:
Alex
That’s all I can recommend, too.
Just tested - it should. Even if i am currently on a 2.4 network.
So it is either a firmware or hardware. But judging by the green on the linux hardware site, even from many arch distros, it cannot be firmware. So it looks like a hardware issue to me too.
Okay off to the recycling bin it goes.
It just goes to show that it is not always software.
Thanks all !! :+1:
