I am trying to install Manjaro Cinnamon I downloaded both full and minimal versions but in both the instalation wizard crashes immediatly after startup (it says it is loading some module but when it seems to finish loading it crashes immediatly. I tried that multiple times andI am pretty sure it is fault of the wizard… When running: /usr/bin/calamares_polkit %f
this is the command line output:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
23:10:34 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
.. Required settings.conf key hide-back-and-next-during-exec is missing.
23:10:34 [6]: void Logger::setupLogfile()
Using log file: "/root/.cache/calamares/session.log"
23:10:34 [6]: void CalamaresApplication::init()
Calamares version: 3.2.62-6
.. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, oc, pl, pt_BR, pt_PT, ro, ru, si, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
23:10:34 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
23:10:34 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
23:10:34 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
.. No translation for "tz_" "C" using default (en)
.. No translation for "calamares_" "C" using default (en)
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
23:10:34 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
WARNING: .. Module descriptor contains extra keys:
"requires"
23:10:34 [6]: void Calamares::ModuleManager::doInit()
Found 57 modules
23:10:34 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
23:10:34 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(2560, 1440) minimum size QSize(1024, 520)
.. Proposed window size: 1024 560
23:10:34 [6]: QString CalamaresUtils::searchQmlFile(QmlSearch, const QString&)
Looking for QML for "calamares-sidebar"
.. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
STARTUP: CalamaresWindow created; loadModules started
23:10:34 [6]: void Config::initLanguages()
Trying to match locale "C"
Trying to match locale QLocale(C, Default, Default)
.. Trying to match approximate locale QLocale::C
.. Trying to match English (US)
23:10:34 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale "en"
.. Loaded QRC translation "tz_" "en"
.. Loaded QRC translation "calamares_" "en"
23:10:34 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
23:10:34 [6]: QStringList loadLocales(const QString&)
Loading locales from "/usr/share/i18n/SUPPORTED"
.. Read 492 lines
.. After filtering 317 lines
ViewModule "locale@locale" loading complete.
23:10:34 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 189 keyboard models
23:10:34 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now total= 0 selected= -1
.. Loaded QRC translation "kb_" "en"
23:10:34 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
ViewModule "keyboard@keyboard" loading complete.
23:10:34 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
23:10:34 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x5593f7169e60 "pmsfdiskbackendplugin" "1"
23:10:34 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
23:10:34 [2]: void copyLegacy(const QVariantMap&, const QString&, QVariantMap&, const QString&)
WARNING: Legacy *users* key "userShell" overrides hostname-settings.
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
23:10:34 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
23:10:34 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
QML load on startup, API 2.
23:10:34 [2]: QThread::setPriority: Cannot set priority, thread is not running
23:10:34 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
23:10:34 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
CppJobModule "umount@umount" loading complete.
23:10:34 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
23:10:34 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
QML component complete, API 2
.. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
23:10:34 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= "CZ"
Index 10 Selected locale "cs_CZ"
.. No translation for "tz_" "cs_CZ" using default (en)
.. Loaded QRC translation "calamares_" "cs_CZ"
23:10:34 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
23:10:34 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
.. No translation for "kb_" "cs_CZ" using default (en)
23:10:34 [6]: getting temp failed for "/dev/nvme0n1" : Success
23:10:34 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
23:10:34 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
23:10:34 [6]: getting temp failed for "/dev/nvme1n1" : Success
23:10:34 [6]: getting powered on time failed for "/dev/nvme1n1" : Success
23:10:34 [6]: getting power cycles failed for "/dev/nvme1n1" : Success
23:10:34 [6]: 125026303 13785946 4096
23:10:34 [6]: 135423 25264 4096
23:10:34 [6]: void Config::xkbApply()
xkbmap selection changed to: "us" - ""
23:10:34 [2]: unknown file system type "" on "/dev/sda3"
23:10:34 [6]: 28979784 3350688 4096
23:10:34 [6]: 133887 22596 4096
23:10:34 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
23:10:34 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
23:10:35 [2]: unknown file system type "" on "/dev/sdb1"
23:10:35 [6]: smartctl initialization failed for "/dev/sdc" : Resource temporarily unavailable
23:10:35 [6]: error during smart output parsing for "/dev/sdc" : Success
23:10:35 [2]: unknown file system type "" on "/dev/md126"
23:10:35 [2]: unknown file system type "" on "/dev/md127"
23:10:35 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
Removing unsuitable devices: 7 candidates.
.. Running ("blkid", "/dev/nvme0n1")
.. Running ("blkid", "/dev/nvme0n1p1")
.. Running ("blkid", "/dev/nvme0n1p2")
.. Running ("blkid", "/dev/nvme1n1")
.. Running ("blkid", "/dev/nvme1n1p1")
.. Running ("blkid", "")
.. Target cmd: ("blkid", "") Exit code: 2 (no output)
.. Running ("blkid", "/dev/sda")
.. Running ("blkid", "/dev/sda1")
.. Running ("blkid", "/dev/sda2")
.. Running ("blkid", "/dev/sda3")
.. Running ("blkid", "/dev/sda4")
.. Running ("blkid", "/dev/sda5")
.. Running ("blkid", "/dev/sda6")
.. Running ("blkid", "/dev/sdb")
.. Running ("blkid", "/dev/sdb1")
.. Target cmd: ("blkid", "/dev/sdb1") Exit code: 2 (no output)
.. Running ("blkid", "/dev/sdc")
23:10:35 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
.. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sdc"
.. Running ("blkid", "/dev/md126")
.. Target cmd: ("blkid", "/dev/md126") Exit code: 2 (no output)
.. Running ("blkid", "/dev/md127")
.. Target cmd: ("blkid", "/dev/md127") Exit code: 2 (no output)
.. there are 6 devices left.
23:10:35 [6]: void PartitionCoreModule::doInit()
LIST OF DETECTED DEVICES:
.. node capacity name prettyName
.. "/dev/nvme0n1" 500105249280 DevName$b9f662a9 DevNamePretty$3b85b0da
.. "/dev/nvme1n1" 512105932800 DevName$2858183e DevNamePretty$5e7078a3
.. "/dev/sda" 120031511040 DevName$bec2ac73 DevNamePretty$67a68c35
.. "/dev/sdb" 2000396321280 DevName$efa8f2e3 DevNamePretty$88bdb235
.. "/dev/md126" -1 DevName$cd8ce465 DevNamePretty$36dafe09
.. "/dev/md127" -1 DevName$de2e7c12 DevNamePretty$335e4a8b
.. 6 devices detected.
23:10:37 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:10:38 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
.. Running ("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p2")
23:10:38 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
Checking device "/dev/nvme0n1p2" for fstab (fs= "ext4" )
.. Running ("mount", "-o", "ro,noload", "/dev/nvme0n1p2", "/tmp/calamares-ByRSTn")
.. Running ("udevadm", "settle")
.. Running ("sync")
.. got 5 fstab entries from 5 lines in "/tmp/calamares-ByRSTn/etc/fstab"
.. Running ("umount", "-R", "/tmp/calamares-ByRSTn")
.. Running ("sync")
23:10:38 [6]: bool PartUtils::canBeResized(Partition*, const Logger::Once&)
Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
.. Running ("blkid", "-s", "TYPE", "-o", "value", "/dev/sda2")
Checking device "/dev/sda2" for fstab (fs= "vfat" )
.. Running ("mount", "-o", "ro", "/dev/sda2", "/tmp/calamares-ObeZNk")
.. Running ("sync")
23:10:38 [2]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
WARNING: Could not read fstab from mounted fs
.. Running ("umount", "-R", "/tmp/calamares-ObeZNk")
.. Running ("sync")
.. Can not resize "/dev/sda2" , filesystem "fat32" does not support resize.
.. os-prober lines after cleanup:
"/dev/nvme0n1p2:Arch Linux:Arch:linux"
"/dev/sda2@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi"
23:10:38 [6]: void PartitionCoreModule::doInit()
Ignoring device that is not Disk_Device to bootLoaderDevices list.
23:10:39 [2]: unknown file system type "" on "/dev/md126"
23:10:39 [2]: unknown file system type "" on "/dev/md127"
23:10:39 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
system is EFI and new EFI system partition has been found.
23:10:39 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 1 requirement results from "partition"
23:10:39 [6]: void ChoicePage::updateDeviceStatePreview()
Updating partitioning state widgets.
23:10:39 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/md126" with 0 entries.
.. part of an inactive RAID device
23:10:39 [6]: ChoicePage::setupActions()::<lambda()>
Setting texts for 0 osprober entries
No partitions available for replace-action.
No partitions available for resize-action.
No partitions ( any-mounted? false is-raid? true ) for erase-action.
23:10:39 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device -1 new device 0
23:10:39 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Erase "erase"
23:10:39 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/md126"
23:10:39 [6]: void Calamares::RequirementsChecker::finished()
All requirements have been checked.
23:10:39 [6]: void Calamares::RequirementsModel::describe() const
Requirements model has 6 items
.. requirement 0 "storage" satisfied? true mandatory? true
.. requirement 1 "ram" satisfied? true mandatory? true
.. requirement 2 "power" satisfied? true mandatory? false
.. requirement 3 "internet" satisfied? true mandatory? false
.. requirement 4 "root" satisfied? true mandatory? true
.. requirement 5 "partitions" satisfied? true mandatory? true
23:10:39 [1]: ASSERT: "efiSectorCount > 0" in file /build/calamares/src/calamares-3.2.62/src/modules/partition/core/PartitionActions.cpp, line 123
/usr/bin/calamares_polkit: line 6: 5625 Aborted (core dumped) pkexec --disable-internal-agent "/usr/bin/calamares" "-D6" "$@"
This is the output with -d flag
23:17:24 [6]: Calamares::Settings::Settings(const QString&, bool)
23:17:24 [6]: void Logger::setupLogfile()
23:17:24 [6]: void CalamaresApplication::init()
23:17:24 [6]: bool CalamaresUtils::initQmlModulesDir()
23:17:24 [6]: Calamares::Branding::Branding(const QString&, QObject*)
23:17:24 [2]: Calamares::Branding::Branding(const QString&, QObject*)
23:17:24 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
"requires"
23:17:24 [6]: void Calamares::ModuleManager::doInit()
Found 57 modules
23:17:24 [6]: void CalamaresApplication::initView()
23:17:24 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
23:17:24 [6]: QString CalamaresUtils::searchQmlFile(QmlSearch, const QString&)
23:17:24 [6]: void Config::initLanguages()
23:17:24 [6]: void Config::setLocaleIndex(int)
23:17:24 [6]: virtual void Calamares::ViewModule::loadSelf()
23:17:24 [6]: QStringList loadLocales(const QString&)
.. Read 492 lines
23:17:24 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
23:17:24 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
23:17:24 [6]: void Config::detectCurrentKeyboardLayout()
23:17:24 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
23:17:24 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x5649ce757a30 "pmsfdiskbackendplugin" "1"
23:17:24 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
23:17:24 [2]: void copyLegacy(const QVariantMap&, const QString&, QVariantMap&, const QString&)
23:17:24 [6]: void Calamares::ModuleManager::loadModules()
23:17:24 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"/usr/lib/qt/qml"
23:17:24 [2]: QThread::setPriority: Cannot set priority, thread is not running
23:17:24 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
23:17:24 [6]: virtual void Calamares::CppJobModule::loadSelf()
23:17:24 [2]: void Config::setConfigurationMap(const QVariantMap&)
23:17:24 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
23:17:24 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
23:17:24 [6]: void CalamaresApplication::initViewSteps()
23:17:24 [6]: void Calamares::ModuleManager::checkRequirements()
23:17:24 [6]: getting temp failed for "/dev/nvme0n1" : Success
23:17:24 [6]: getting powered on time failed for "/dev/nvme0n1" : Success
23:17:24 [6]: getting power cycles failed for "/dev/nvme0n1" : Success
23:17:24 [6]: getting temp failed for "/dev/nvme1n1" : Success
23:17:24 [6]: getting powered on time failed for "/dev/nvme1n1" : Success
23:17:24 [6]: getting power cycles failed for "/dev/nvme1n1" : Success
23:17:24 [6]: 125026303 13785946 4096
23:17:24 [6]: void Config::xkbApply()
23:17:24 [6]: 135423 25264 4096
23:17:24 [2]: unknown file system type "" on "/dev/sda3"
23:17:24 [6]: 28979784 3350688 4096
23:17:24 [6]: 133887 22596 4096
23:17:24 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
23:17:24 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
23:17:25 [2]: unknown file system type "" on "/dev/sdb1"
23:17:25 [6]: smartctl initialization failed for "/dev/sdc" : Resource temporarily unavailable
23:17:25 [6]: error during smart output parsing for "/dev/sdc" : Success
23:17:25 [2]: unknown file system type "" on "/dev/md126"
23:17:25 [2]: unknown file system type "" on "/dev/md127"
23:17:25 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
.. Finished. Exit code: 0 output:
/dev/nvme0n1: PTUUID="601b62b5-f891-41a6-9061-1cb61168599f" PTTYPE="gpt"
/dev/nvme0n1p1: UUID="1BE5-EAB0" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="boot" PARTUUID="b6471b63-cbe4-4e23-8013-eb262b5cbf6d"
/dev/nvme0n1p2: UUID="16e9cdb5-364d-4dcd-804b-7e729723ed7e" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="0acb3944-8732-4500-8725-bafe2ddd5531"
/dev/nvme1n1: PTUUID="9762e7ff-4350-a742-bbbe-7bc24a9f20fd" PTTYPE="gpt"
/dev/nvme1n1p1: LABEL="NovM-CM-= svazek" BLOCK_SIZE="512" UUID="C472134572133C1C" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="b29e3cbf-82d5-4fb4-bac9-e66dcae8ee74"
/dev/sda: PTUUID="a49bac60-cde5-4589-8a76-0bfc5e6b74b2" PTTYPE="gpt"
/dev/sda1: LABEL="ObnovenM-CM--" BLOCK_SIZE="512" UUID="4E92AB1292AAFD99" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="4251dccf-2741-44dc-9dc2-23f65a9a633b"
/dev/sda2: UUID="8CAD-96EC" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="78d4823a-9609-4620-87db-68037fdf4221"
/dev/sda3: PARTLABEL="Microsoft reserved partition" PARTUUID="f78e67bd-d9ca-4879-9250-1c5ebe1605ba"
/dev/sda4: UUID="4C90-58B1" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="1cf76db3-bb77-4ee8-9087-66c08272e3bf"
/dev/sda5: BLOCK_SIZE="512" UUID="B2DE9219DE91D5C7" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="49127540-1720-4ab0-be17-e5270703c09b"
/dev/sda6: BLOCK_SIZE="512" UUID="36C685DEC6859EAD" TYPE="ntfs" PARTUUID="1bd406f7-8c8f-4010-8770-4980b0045047"
/dev/sdb: UUID="IBM ^P" TYPE="ddf_raid_member"
23:17:25 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
/dev/sdc: BLOCK_SIZE="2048" UUID="2023-09-21-13-57-41-00" LABEL="MANJARO_CINNAMONM_2301" TYPE="iso9660" PTTYPE="dos"
23:17:25 [6]: void PartitionCoreModule::doInit()
.. "/dev/nvme0n1" 500105249280 DevName$4c2dee36 DevNamePretty$3b26de45
.. "/dev/nvme1n1" 512105932800 DevName$f2b5ba03 DevNamePretty$c6c6216e
.. "/dev/sda" 120031511040 DevName$4b1920ec DevNamePretty$e3e0a5ad
.. "/dev/sdb" 2000396321280 DevName$f727779a DevNamePretty$51cfa36f
.. "/dev/md126" -1 DevName$1709d322 DevNamePretty$6ae15847
.. "/dev/md127" -1 DevName$4ab4b55 DevNamePretty$6f65ecc5
23:17:26 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
23:17:28 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
ext4
23:17:28 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
.. Running ("mount", "-o", "ro,noload", "/dev/nvme0n1p2", "/tmp/calamares-gIRkAF")
.. Running ("sync")
.. got 5 fstab entries from 5 lines in "/tmp/calamares-gIRkAF/etc/fstab"
.. Running ("umount", "-R", "/tmp/calamares-gIRkAF")
.. Running ("sync")
23:17:28 [6]: bool PartUtils::canBeResized(Partition*, const Logger::Once&)
vfat
.. Running ("mount", "-o", "ro", "/dev/sda2", "/tmp/calamares-kcGJty")
.. Running ("sync")
23:17:28 [2]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
.. Running ("umount", "-R", "/tmp/calamares-kcGJty")
.. Running ("sync")
23:17:28 [6]: void PartitionCoreModule::doInit()
23:17:28 [2]: unknown file system type "" on "/dev/md126"
23:17:28 [2]: unknown file system type "" on "/dev/md127"
23:17:28 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
23:17:28 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
23:17:28 [6]: void ChoicePage::updateDeviceStatePreview()
23:17:28 [6]: void ChoicePage::setupActions()
23:17:28 [6]: ChoicePage::setupActions()::<lambda()>
23:17:29 [6]: void ChoicePage::setupActions()
23:17:29 [6]: void ChoicePage::continueApplyDeviceChoice()
23:17:29 [6]: void ChoicePage::applyActionChoice(InstallChoice)
23:17:29 [6]: PartitionTable* CreatePartitionTableJob::createTable()
23:17:29 [6]: void Calamares::RequirementsChecker::finished()
23:17:29 [6]: void Calamares::RequirementsModel::describe() const
23:17:29 [2]: unknown file system type "" on "/dev/md126"
23:17:29 [2]: unknown file system type "" on "/dev/md127"
23:17:29 [1]: ASSERT: "efiSectorCount > 0" in file /build/calamares/src/calamares-3.2.62/src/modules/partition/core/PartitionActions.cpp, line 123
/usr/bin/calamares_polkit: line 6: 7610 Aborted (core dumped) pkexec --disable-internal-agent "/usr/bin/calamares" "-D6" "$@"
I noticed it fails on this part: 23:19:59 [1]: ASSERT: “efiSectorCount > 0”. Which does not make much sense to me I am in UEFI I certanly have efi sectors (I have multiple drives). I am very confused by this.
For debugging here is my disk setup (I have installed windows on the 120Gb drive and on the 500GB NTFS drive and the 2TB drive I have windows files. I want to install linux on the empty 500GB drive:
