Calamares crashes upon entering the custom disk partitioning section
I have issues with trying to install manjaro from newest ISO files: manjaro-gnome-24.2.1-241216-linux612 & manjaro-xfce-24.2.1-241216-linux612. Calamares crashes upon entering the custom partitioning section of installation - it shows content in the window for a second but then disappears. The manjaro-gnome-24.1.2-241104-linux610 and manjaro-xfce-24.1.2-241104-linux610 do not have this problem.
This problem occurs on two different nvme disks - if that helps anything, in both pre-partitioned in another tool and clean disk scenarios. It also doesn’t appear to be usb pendrive related; I tried different ones and also loading thru ventoy - without changes.
Here’s the session.log from installation. I did in the end pick the older ISO to install the system and run upgrade afterwards but I wanted to use newest installation source and ran on this issue. I wonder if someone else experienced this.
Here’s the calamares session.log
=== START CALAMARES 3.3.12
2025-02-16 - 21:58:07 [6]: void CalamaresApplication::init()
2025-02-16 - 21:58:07 [6]:     Calamares version: 3.3.12
2025-02-16 - 21:58:07 [6]:     .. Using Qt version: 6.8.1
2025-02-16 - 21:58:07 [6]:     .. Build type: Debug
2025-02-16 - 21:58:07 [6]:     .. Using PyBind11
2025-02-16 - 21:58:07 [6]:     .. Using settings: "/etc/calamares/settings.conf"
2025-02-16 - 21:58:07 [6]:     .. Using log file: "/home/manjaro/.cache/calamares/session.log"
2025-02-16 - 21:58:07 [6]:     .. Languages: QList("ar", "as", "ast", "az", "az_AZ", "be", "bg", "bn", "ca", "ca@valencia", "cs_CZ", "da", "de", "el", "en", "en_GB", "eo", "es", "es_AR", "es_MX", "et", "eu", "fa", "fi_FI", "fr", "fur", "gl", "he", "hi", "hr", "hu", "id", "is", "it_IT", "ja", "ka", "ko", "lt", "ml", "mr", "nb", "nl", "oc", "pl", "pt_BR", "pt_PT", "ro", "ru", "si", "sk", "sl", "sq", "sr", "sr@latin", "sv", "tg", "th", "tr_TR", "uk", "vi", "zh_CN", "zh_TW")
2025-02-16 - 21:58:07 [6]: bool Calamares::initQmlModulesDir()
2025-02-16 - 21:58:07 [6]:     Using Calamares QML directory "/usr/share/calamares/qml"
2025-02-16 - 21:58:07 [6]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2025-02-16 - 21:58:07 [6]:     Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2025-02-16 - 21:58:07 [2]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2025-02-16 - 21:58:07 [2]:     WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
2025-02-16 - 21:58:07 [6]:     Loaded branding component "manjaro"
2025-02-16 - 21:58:07 [2]: bool Calamares::validateStyleEntries(const QMap<QString, QString>&)
2025-02-16 - 21:58:07 [2]:     WARNING: Unknown branding *style* entry "SidebarTextSelect"
2025-02-16 - 21:58:07 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarBackground"
2025-02-16 - 21:58:07 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarText"
2025-02-16 - 21:58:07 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarTextHighlight"
2025-02-16 - 21:58:07 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarTextSelect"
2025-02-16 - 21:58:07 [6]:     .. No translation for "tz_" "C" using default (en)
2025-02-16 - 21:58:07 [6]:     .. No translation for "calamares_" "C" using default (en)
2025-02-16 - 21:58:07 [6]:     .. STARTUP: initSettings, initQmlPath, initBranding done
2025-02-16 - 21:58:07 [6]:     .. STARTUP: initModuleManager: module init started
2025-02-16 - 21:58:07 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
2025-02-16 - 21:58:07 [2]:     WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2025-02-16 - 21:58:07 [2]: WARNING:     ..  Module descriptor contains extra keys:
     "requires"
2025-02-16 - 21:58:07 [6]: void Calamares::ModuleManager::doInit()
2025-02-16 - 21:58:07 [6]:     Found 56 modules
2025-02-16 - 21:58:07 [6]: void CalamaresApplication::initView()
2025-02-16 - 21:58:07 [6]:     STARTUP: initModuleManager: all modules init done
2025-02-16 - 21:58:07 [6]:     STARTUP: initJobQueue done
2025-02-16 - 21:58:07 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
2025-02-16 - 21:58:07 [6]:     Available desktop QSize(1920, 1048) minimum size QSize(1024, 520)
2025-02-16 - 21:58:07 [6]:     .. Proposed window size: 1024 560
2025-02-16 - 21:58:07 [6]: QString Calamares::searchQmlFile(QmlSearch, const QString&)
2025-02-16 - 21:58:07 [6]:     Looking for QML for "calamares-sidebar"
2025-02-16 - 21:58:07 [6]:     .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
2025-02-16 - 21:58:07 [6]:     STARTUP: CalamaresWindow created; loadModules started
2025-02-16 - 21:58:07 [6]: void Config::initLanguages()
2025-02-16 - 21:58:07 [6]:     Trying to match locale "C"
2025-02-16 - 21:58:07 [6]:     Trying to match locale QLocale(C, Default, Default)
2025-02-16 - 21:58:07 [6]:     .. Trying to match approximate locale QLocale::C
2025-02-16 - 21:58:07 [6]:     .. Trying to match English (US)
2025-02-16 - 21:58:07 [6]: void Config::setLocaleIndex(int)
2025-02-16 - 21:58:07 [6]:     Index 14 Selected locale "en"
2025-02-16 - 21:58:07 [6]:     .. Loaded QRC translation "tz_" "en"
2025-02-16 - 21:58:07 [6]:     .. Loaded QRC translation "calamares_" "en"
2025-02-16 - 21:58:07 [6]: virtual void Calamares::ViewModule::loadSelf()
2025-02-16 - 21:58:07 [6]:     ViewModule "welcome@welcome" loading complete.
2025-02-16 - 21:58:07 [6]: QStringList loadLocales(const QString&)
2025-02-16 - 21:58:07 [6]:     Loading locales from "/usr/share/i18n/SUPPORTED"
2025-02-16 - 21:58:07 [6]:     ..  Read 501 lines
2025-02-16 - 21:58:07 [6]:     ..  After filtering 326 lines
2025-02-16 - 21:58:07 [6]:     ViewModule "locale@locale" loading complete.
2025-02-16 - 21:58:07 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
2025-02-16 - 21:58:07 [6]:     Loaded 183 keyboard models
2025-02-16 - 21:58:07 [6]: KeyboardGroupsSwitchersModel::KeyboardGroupsSwitchersModel(QObject*)
2025-02-16 - 21:58:07 [6]:     Loaded 45 keyboard groups
2025-02-16 - 21:58:07 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
2025-02-16 - 21:58:07 [6]:     Variants now total= 0 selected= -1
2025-02-16 - 21:58:07 [6]:     Groups now total= 45 selected= -1
2025-02-16 - 21:58:07 [6]:     .. Loaded QRC translation "kb_" "en"
2025-02-16 - 21:58:07 [6]: void Config::getCurrentKeyboardLayoutXkb(QString&, QString&, QString&)
2025-02-16 - 21:58:07 [6]:     QList("pc", "us", "inet(evdev)\"")
2025-02-16 - 21:58:08 [6]: virtual void Calamares::ViewModule::loadSelf()
2025-02-16 - 21:58:08 [6]:     ViewModule "keyboard@keyboard" loading complete.
2025-02-16 - 21:58:08 [6]: Calamares::Partition::InternalManager::InternalManager()
2025-02-16 - 21:58:08 [6]:     KPMCore backend starting ..
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): Loaded backend plugin:  "pmsfdiskbackendplugin"
2025-02-16 - 21:58:08 [6]:     .. Backend @0x5fdd13035ad0 "pmsfdiskbackendplugin" "1"
2025-02-16 - 21:58:08 [2]: void Config::fillConfigurationFSTypes(const QVariantMap&)
2025-02-16 - 21:58:08 [2]:     WARNING: Partition-module setting *luksGeneration* not found or invalid. Defaulting to luks1.
2025-02-16 - 21:58:08 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
2025-02-16 - 21:58:08 [2]:     WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
2025-02-16 - 21:58:08 [6]:     ViewModule "partition@partition" loading complete.
2025-02-16 - 21:58:08 [2]: bool addPasswordCheck(const QString&, const QVariant&, PasswordCheckList&)
2025-02-16 - 21:58:08 [2]:     WARNING: nonempty check is ignored; use minLength: 1
2025-02-16 - 21:58:08 [6]:     ViewModule "users@users" loading complete.
2025-02-16 - 21:58:08 [6]: virtual void Config::setConfigurationMap(const QVariantMap&)
2025-02-16 - 21:58:08 [6]:     Using module ID "packagechooser@packagechooser"
2025-02-16 - 21:58:08 [6]: void fillModel(PackageListModel*, const QVariantList&)
2025-02-16 - 21:58:08 [6]:     Loading PackageChooser model items from config
2025-02-16 - 21:58:08 [6]:     .. Loaded PackageChooser with 3 entries.
2025-02-16 - 21:58:08 [2]: WARNING (Qt): QPixmap::scaled: Pixmap is a null pixmap
2025-02-16 - 21:58:08 [6]:     ViewModule "packagechooser@packagechooser" loading complete.
2025-02-16 - 21:58:08 [6]:     ViewModule "summary@summary" loading complete.
2025-02-16 - 21:58:08 [6]: void Calamares::ModuleManager::loadModules()
2025-02-16 - 21:58:08 [6]:     Module "partition@partition" already loaded.
2025-02-16 - 21:58:08 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
2025-02-16 - 21:58:08 [6]:     QML import paths:
     "/usr/bin"
     "qrc:/qt-project.org/imports"
     "qrc:/qt/qml"
     "/usr/lib/qt6/qml"
2025-02-16 - 21:58:08 [6]:     QML load on startup, API 2.
2025-02-16 - 21:58:08 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
2025-02-16 - 21:58:08 [2]:     WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2025-02-16 - 21:58:08 [6]: virtual void Calamares::CppJobModule::loadSelf()
2025-02-16 - 21:58:08 [6]:     CppJobModule "machineid@machineid" loading complete.
2025-02-16 - 21:58:08 [6]:     Module "locale@locale" already loaded.
2025-02-16 - 21:58:08 [6]:     Module "keyboard@keyboard" already loaded.
2025-02-16 - 21:58:08 [6]:     CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
2025-02-16 - 21:58:08 [6]:     CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
2025-02-16 - 21:58:08 [6]:     CppJobModule "initcpio@initcpio" loading complete.
2025-02-16 - 21:58:08 [6]:     Module "users@users" already loaded.
2025-02-16 - 21:58:08 [6]:     CppJobModule "umount@umount" loading complete.
2025-02-16 - 21:58:08 [2]: void Config::setConfigurationMap(const QVariantMap&)
2025-02-16 - 21:58:08 [2]:     WARNING: Configuring the finished module with deprecated restartNowEnabled settings
2025-02-16 - 21:58:08 [6]:     ViewModule "finished@finished" loading complete.
2025-02-16 - 21:58:08 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
2025-02-16 - 21:58:08 [6]:     GeoIP result for welcome= "PL"
2025-02-16 - 21:58:08 [6]: void Config::setLocaleIndex(int)
2025-02-16 - 21:58:08 [6]:     Index 43 Selected locale "pl"
2025-02-16 - 21:58:08 [6]:     .. No translation for "tz_" "pl" using default (en)
2025-02-16 - 21:58:08 [6]:     .. Loaded QRC translation "calamares_" "pl"
2025-02-16 - 21:58:08 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
2025-02-16 - 21:58:08 [6]:     QML component complete, API 2
2025-02-16 - 21:58:08 [2]: WARNING (Qt): file:///usr/share/calamares/branding/manjaro/slideshow/sponsor/SponsoredBy.qml: No such file or directory
2025-02-16 - 21:58:08 [6]:     .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2025-02-16 - 21:58:08 [6]:     .. No translation for "kb_" "pl" using default (en)
2025-02-16 - 21:58:08 [6]: void CalamaresApplication::initViewSteps()
2025-02-16 - 21:58:08 [6]:     STARTUP: loadModules for all modules done
2025-02-16 - 21:58:08 [6]: void Calamares::ModuleManager::checkRequirements()
2025-02-16 - 21:58:08 [6]:     Checking module requirements ..
2025-02-16 - 21:58:08 [6]:     STARTUP: Window now visible and ProgressTreeView populated
2025-02-16 - 21:58:08 [6]:     .. 9 view steps loaded.
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 21:58:08 [6]: void Config::applyXkb()
2025-02-16 - 21:58:08 [6]:     xkbmap selection changed to:  "us" - ""
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 21:58:08 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-16 - 21:58:08 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-16 - 21:58:08 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
2025-02-16 - 21:58:08 [6]:     GeneralRequirements output:
     storage :   8482560409
     enoughStorage :   true
     RAM :   1073741824
     enoughRam :   true
     hasPower :   true
     hasInternet :   true
     isRoot :   true
2025-02-16 - 21:58:08 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-02-16 - 21:58:08 [6]:     Got 5 requirement results from "welcome"
2025-02-16 - 21:58:08 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): smartctl initialization failed for  "/dev/sde" :  No such file or directory
2025-02-16 - 21:58:08 [6]: DEBUG (Qt): error during smart output parsing for  "/dev/sde" :  No such file or directory
2025-02-16 - 21:58:09 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
2025-02-16 - 21:58:09 [6]:     Removing unsuitable devices: 7 candidates.
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme0n1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme0n1p3")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme0n1p1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme0n1p2")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "")
2025-02-16 - 21:58:09 [6]:     .. Target cmd: QList("blkid", "") Exit code: 2 (no output)
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme1n1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme1n1p1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme1n1p2")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme1n1p3")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/nvme1n1p4")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sda")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sda1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sda2")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdb")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdb1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdb2")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdb3")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdc")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdc1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdd")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sdd1")
2025-02-16 - 21:58:09 [6]:     .. Running QList("blkid", "/dev/sde")
2025-02-16 - 21:58:09 [6]:     .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sde"
2025-02-16 - 21:58:09 [6]:     .. there are 6 devices left.
2025-02-16 - 21:58:09 [6]: void PartitionCoreModule::doInit()
2025-02-16 - 21:58:09 [6]:     LIST OF DETECTED DEVICES:
2025-02-16 - 21:58:09 [6]:     .. node	capacity	name	prettyName
2025-02-16 - 21:58:09 [6]:     .. "/dev/nvme0n1" 1024209543168 DevName$ed5ae0c7 DevNamePretty$646270c7
2025-02-16 - 21:58:09 [6]:     .. "/dev/nvme1n1" 1000204886016 DevName$b7c39495 DevNamePretty$eee09f15
2025-02-16 - 21:58:09 [6]:     .. "/dev/sda" 2000398934016 DevName$7560702c DevNamePretty$5541f892
2025-02-16 - 21:58:09 [6]:     .. "/dev/sdb" 2000398934016 DevName$7560702c DevNamePretty$908476a9
2025-02-16 - 21:58:09 [6]:     .. "/dev/sdc" 250055122432 DevName$d5a31815 DevNamePretty$a4985c46
2025-02-16 - 21:58:09 [6]:     .. "/dev/sdd" 1024209543168 DevName$208bde51 DevNamePretty$e6f4efac
2025-02-16 - 21:58:09 [6]:     .. 6 devices detected.
2025-02-16 - 21:58:09 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-16 - 21:58:09 [6]:     Remaining modules: 1
     "partition"
2025-02-16 - 21:58:10 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-16 - 21:58:10 [6]:     Remaining modules: 1
     "partition"
2025-02-16 - 21:58:11 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-16 - 21:58:11 [6]:     Remaining modules: 1
     "partition"
2025-02-16 - 21:58:12 [6]:     .. Running QList("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p1")
2025-02-16 - 21:58:12 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
2025-02-16 - 21:58:12 [6]:     Checking device "/dev/nvme0n1p1" for fstab (fs= "ext4" )
2025-02-16 - 21:58:12 [6]:     .. Running QList("mount", "-o", "ro,noload", "/dev/nvme0n1p1", "/tmp/calamares-XQJmbr")
2025-02-16 - 21:58:12 [6]:     .. Running QList("udevadm", "settle")
2025-02-16 - 21:58:12 [6]:     .. Running QList("sync")
2025-02-16 - 21:58:12 [6]:     .. got 4 fstab entries from 12 lines in "/tmp/calamares-XQJmbr/etc/fstab"
2025-02-16 - 21:58:12 [6]:     .. Running QList("umount", "-R", "/tmp/calamares-XQJmbr")
2025-02-16 - 21:58:12 [6]: bool PartUtils::canBeResized(Partition*, const Logger::Once&)
2025-02-16 - 21:58:12 [6]:     Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2025-02-16 - 21:58:12 [6]:     .. Running QList("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p2")
2025-02-16 - 21:58:12 [6]:     Checking device "/dev/nvme0n1p2" for fstab (fs= "ext4" )
2025-02-16 - 21:58:12 [6]:     .. Running QList("mount", "-o", "ro,noload", "/dev/nvme0n1p2", "/tmp/calamares-NTLdWh")
2025-02-16 - 21:58:12 [6]:     .. got 4 fstab entries from 12 lines in "/tmp/calamares-NTLdWh/etc/fstab"
2025-02-16 - 21:58:12 [6]:     .. Running QList("umount", "-R", "/tmp/calamares-NTLdWh")
2025-02-16 - 21:58:12 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
2025-02-16 - 21:58:12 [6]:     ..  os-prober lines after cleanup:
     "/dev/nvme0n1p1:Manjaro Linux (25.0.0):ManjaroLinux:linux"
     "/dev/nvme0n1p2:Manjaro Linux (25.0.0):ManjaroLinux1:linux"
2025-02-16 - 21:58:12 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling endResetModel first
2025-02-16 - 21:58:12 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling beginResetModel first
2025-02-16 - 21:58:12 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2025-02-16 - 21:58:12 [6]:     system is EFI and new EFI system partition has been found.
2025-02-16 - 21:58:12 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-02-16 - 21:58:12 [6]:     Got 1 requirement results from "partition"
2025-02-16 - 21:58:12 [2]: void ChoicePage::updateActionDescriptionsTr()
2025-02-16 - 21:58:12 [2]:     WARNING: Invalid osprober count, labels and buttons not updated.
2025-02-16 - 21:58:12 [6]: void ChoicePage::updateDeviceStatePreview()
2025-02-16 - 21:58:12 [6]:     Updating partitioning state widgets.
2025-02-16 - 21:58:12 [6]: void ChoicePage::setupActions()
2025-02-16 - 21:58:12 [6]:     Setting up actions for "/dev/nvme0n1" with 2 entries.
2025-02-16 - 21:58:12 [6]:     ..  Can not resize "/dev/nvme0n1p3" , filesystem "fat32" does not support resize.
2025-02-16 - 21:58:12 [6]:     ..  Checking if "/dev/nvme0n1p3" can be replaced.
2025-02-16 - 21:58:12 [6]:     ..  NO, insufficient storage
     Required  storage B: 9019431321 "(7.9GiB)"
     Available storage B: 314572800 "(0GiB)"
2025-02-16 - 21:58:12 [6]:     ..  Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2025-02-16 - 21:58:12 [6]:     .. contains resizable "/dev/nvme0n1p1"
2025-02-16 - 21:58:12 [6]:     ..  Checking if "/dev/nvme0n1p1" can be replaced.
2025-02-16 - 21:58:12 [6]:     ..  Partition "/dev/nvme0n1p1" authorized for replace install.
2025-02-16 - 21:58:12 [6]:     .. contains replaceable "/dev/nvme0n1p1"
2025-02-16 - 21:58:12 [6]:     .. contains resizable "/dev/nvme0n1p2"
2025-02-16 - 21:58:12 [6]:     ..  Checking if "/dev/nvme0n1p2" can be replaced.
2025-02-16 - 21:58:12 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for replace install.
2025-02-16 - 21:58:12 [6]:     .. contains replaceable "/dev/nvme0n1p2"
2025-02-16 - 21:58:12 [6]:     ..  Can not resize "/dev/nvme0n1" , filesystem "unknown" does not support resize.
2025-02-16 - 21:58:12 [6]:     ..  Checking if "/dev/nvme0n1" can be replaced.
     Available storage B: 5902848 "(0GiB)"
2025-02-16 - 21:58:12 [6]: void ChoicePage::updateActionDescriptionsTr()
2025-02-16 - 21:58:12 [6]:     Setting texts for >= 2 osprober entries
2025-02-16 - 21:58:12 [6]: void ChoicePage::continueApplyDeviceChoice()
2025-02-16 - 21:58:12 [6]:     Previous device -1 new device 0
2025-02-16 - 21:58:12 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-16 - 21:58:12 [6]:     InstallChoice Config::Erase "erase"
2025-02-16 - 21:58:12 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2025-02-16 - 21:58:12 [6]:     CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme0n1"
2025-02-16 - 21:58:12 [6]: void Calamares::RequirementsChecker::finished()
2025-02-16 - 21:58:12 [6]:     All requirements have been checked.
2025-02-16 - 21:58:12 [6]: void Calamares::RequirementsModel::describe() const
2025-02-16 - 21:58:12 [6]:     Requirements model has 6 items
2025-02-16 - 21:58:12 [6]:     .. requirement 0 "storage" satisfied? true mandatory? true
2025-02-16 - 21:58:12 [6]:     .. requirement 1 "ram" satisfied? true mandatory? true
2025-02-16 - 21:58:12 [6]:     .. requirement 2 "power" satisfied? true mandatory? false
2025-02-16 - 21:58:12 [6]:     .. requirement 3 "internet" satisfied? true mandatory? false
2025-02-16 - 21:58:12 [6]:     .. requirement 4 "root" satisfied? true mandatory? true
2025-02-16 - 21:58:12 [6]:     .. requirement 5 "partitions" satisfied? true mandatory? true
2025-02-16 - 21:58:12 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2025-02-16 - 21:58:12 [2]:     WARNING: system is EFI but no EFI system partitions found.
2025-02-16 - 21:58:12 [6]: void PartitionCoreModule::dumpQueue() const
2025-02-16 - 21:58:12 [6]:     # Queue:
2025-02-16 - 21:58:12 [6]:     .. ## Device: "/dev/nvme0n1"
2025-02-16 - 21:58:12 [6]:     .. - CreatePartitionTableJob
2025-02-16 - 21:58:12 [6]:     .. - CreatePartitionJob
2025-02-16 - 21:58:12 [6]:     .. - SetPartFlagsJob
2025-02-16 - 21:58:12 [6]:     .. ## Device: "/dev/nvme1n1"
2025-02-16 - 21:58:12 [6]:     .. ## Device: "/dev/sda"
2025-02-16 - 21:58:12 [6]:     .. ## Device: "/dev/sdb"
2025-02-16 - 21:58:12 [6]:     .. ## Device: "/dev/sdc"
2025-02-16 - 21:58:12 [6]:     .. ## Device: "/dev/sdd"
2025-02-16 - 21:58:12 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-16 - 21:58:12 [6]:     Updating partitioning preview widgets.
2025-02-16 - 21:58:13 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2025-02-16 - 21:58:13 [6]:     Mapping "pl" in "PL" to locale.
2025-02-16 - 21:58:13 [6]:     .. Got best match for "pl" as "pl_PL.UTF-8"
2025-02-16 - 21:58:13 [6]:     .. Got best match for "pl_PL" as "pl_PL.UTF-8"
2025-02-16 - 22:58:13 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2025-02-16 - 22:58:13 [6]:     Mapping "pl" in "PL" to locale.
2025-02-16 - 22:58:13 [6]:     .. Got best match for "pl" as "pl_PL.UTF-8"
2025-02-16 - 22:58:13 [6]:     .. Got best match for "pl_PL" as "pl_PL.UTF-8"
2025-02-16 - 22:58:15 [6]: void Config::guessLocaleKeyboardLayout()
2025-02-16 - 22:58:15 [6]:     Got locale language "pl_PL.UTF-8"
2025-02-16 - 22:58:15 [6]:     .. looking for locale part "PL"
2025-02-16 - 22:58:15 [6]:     .. matched "pl"
2025-02-16 - 22:58:15 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
2025-02-16 - 22:58:15 [6]:     Next level: "pl"
2025-02-16 - 22:58:15 [6]: void Config::applyXkb()
2025-02-16 - 22:58:15 [6]:     xkbmap selection changed to:  "pl" - ""
2025-02-16 - 22:58:19 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 22:58:19 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 22:58:19 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 22:58:19 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling endResetModel first
2025-02-16 - 22:58:19 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling beginResetModel first
2025-02-16 - 22:58:19 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 22:58:19 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 22:58:19 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 22:58:19 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-16 - 22:58:19 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-16 - 22:58:18 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling endResetModel first
2025-02-16 - 22:58:18 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling beginResetModel first
2025-02-16 - 22:58:19 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
2025-02-16 - 22:58:19 [6]: void ChoicePage::updateDeviceStatePreview()
2025-02-16 - 22:58:19 [6]:     Updating partitioning state widgets.
2025-02-16 - 22:58:19 [6]: void ChoicePage::setupActions()
2025-02-16 - 22:58:19 [6]:     Setting up actions for "/dev/nvme1n1" with 0 entries.
2025-02-16 - 22:58:19 [6]:     ..  Can not resize "/dev/nvme1n1p1" , filesystem "unknown" does not support resize.
2025-02-16 - 22:58:19 [6]:     ..  Checking if "/dev/nvme1n1p1" can be replaced.
2025-02-16 - 22:58:19 [6]:     ..  NO, insufficient storage
2025-02-16 - 22:58:19 [6]:     ..  Can not resize "/dev/nvme1n1p2" , filesystem "unknown" does not support resize.
2025-02-16 - 22:58:19 [6]:     ..  Checking if "/dev/nvme1n1p2" can be replaced.
2025-02-16 - 22:58:19 [6]:     ..  Partition "/dev/nvme1n1p3" authorized for resize + autopartition install.
2025-02-16 - 22:58:19 [6]:     .. contains resizable "/dev/nvme1n1p3"
2025-02-16 - 22:58:19 [6]:     ..  Checking if "/dev/nvme1n1p3" can be replaced.
2025-02-16 - 22:58:19 [6]:     ..  Partition "/dev/nvme1n1p3" authorized for replace install.
2025-02-16 - 22:58:19 [6]:     .. contains replaceable "/dev/nvme1n1p3"
2025-02-16 - 22:58:19 [6]:     ..  Partition "/dev/nvme1n1p4" authorized for resize + autopartition install.
2025-02-16 - 22:58:19 [6]:     .. contains resizable "/dev/nvme1n1p4"
2025-02-16 - 22:58:19 [6]:     ..  Checking if "/dev/nvme1n1p4" can be replaced.
2025-02-16 - 22:58:19 [6]:     ..  Partition "/dev/nvme1n1p4" authorized for replace install.
2025-02-16 - 22:58:19 [6]:     .. contains replaceable "/dev/nvme1n1p4"
2025-02-16 - 22:58:19 [6]: void ChoicePage::updateActionDescriptionsTr()
2025-02-16 - 22:58:19 [6]:     Setting texts for 0 osprober entries
2025-02-16 - 22:58:19 [6]: void ChoicePage::continueApplyDeviceChoice()
2025-02-16 - 22:58:19 [6]:     Previous device 0 new device 1
2025-02-16 - 22:58:19 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-16 - 22:58:19 [6]:     InstallChoice Config::Erase "erase"
2025-02-16 - 22:58:19 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2025-02-16 - 22:58:19 [6]:     CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme1n1"
2025-02-16 - 22:58:19 [6]: void PartitionCoreModule::dumpQueue() const
2025-02-16 - 22:58:19 [6]:     # Queue:
2025-02-16 - 22:58:19 [6]:     .. ## Device: "/dev/nvme0n1"
2025-02-16 - 22:58:19 [6]:     .. ## Device: "/dev/nvme1n1"
2025-02-16 - 22:58:19 [6]:     .. - CreatePartitionTableJob
2025-02-16 - 22:58:19 [6]:     .. - CreatePartitionJob
2025-02-16 - 22:58:19 [6]:     .. - SetPartFlagsJob
2025-02-16 - 22:58:19 [6]:     .. ## Device: "/dev/sda"
2025-02-16 - 22:58:19 [6]:     .. ## Device: "/dev/sdb"
2025-02-16 - 22:58:19 [6]:     .. ## Device: "/dev/sdc"
2025-02-16 - 22:58:19 [6]:     .. ## Device: "/dev/sdd"
2025-02-16 - 22:58:19 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-16 - 22:58:19 [6]:     Updating partitioning preview widgets.
2025-02-16 - 22:58:21 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-16 - 22:58:21 [6]:     InstallChoice Config::Manual "manual"
2025-02-16 - 22:58:21 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-16 - 22:58:21 [6]:     Updating partitioning preview widgets.
2025-02-16 - 22:58:23 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling endResetModel first
2025-02-16 - 22:58:23 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling beginResetModel first
2025-02-16 - 22:58:23 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2025-02-16 - 22:58:23 [6]:     No path to restore, choosing default
2025-02-16 - 22:58:23 [6]: virtual void PartitionViewStep::next()
2025-02-16 - 22:58:23 [6]:     Choice applied:  Config::Manual
2025-02-16 - 22:58:23 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 22:58:23 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 22:58:23 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-16 - 22:58:23 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 22:58:23 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 22:58:23 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-16 - 22:58:23 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-16 - 22:58:23 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-16 - 22:58:24 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling endResetModel first
2025-02-16 - 22:58:24 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5fdd12f979f0) without calling beginResetModel first
2025-02-16 - 22:58:24 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2025-02-16 - 22:58:24 [6]:     No path to restore, choosing default
2025-02-16 - 22:58:24 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
As I’m a moderator on the forum, I have taken the liberty of doing this for you, this time.
Images with alternative kernels can be found here: Manjaro 24.2 Yonada released
Newer images here: Releases · manjaro/release-review · GitHub
Does your disk contains remnants of lvm ?
No, I never used lvm before - always “normal” partitioning and these nvme were used under Windows system previously without partitioning, as single “unsliced” storage devices
This is the latest (unofficial) .iso currently:
It might be worth a try.
Might be worth deleting all partitions from the disk in a Live Environment, and starting over.
Note:
Do not do this if you have data on the disc you wish to keep!!!
@philm @growler Well that did the trick. I ran the installer about 5 times and each time it loaded manual partitioning part without any problems. Here’s the calamares log again - in case that could help you figuring out what could be the issue:
=== START CALAMARES 3.3.13
2025-02-17 - 10:47:06 [6]: void CalamaresApplication::init()
2025-02-17 - 10:47:06 [6]:     Calamares version: 3.3.13
2025-02-17 - 10:47:06 [6]:     .. Using Qt version: 6.8.1
2025-02-17 - 10:47:06 [6]:     .. Build type: Debug
2025-02-17 - 10:47:06 [6]:     .. Using PyBind11
2025-02-17 - 10:47:06 [6]:     .. Using settings: "/etc/calamares/settings.conf"
2025-02-17 - 10:47:06 [6]:     .. Using log file: "/home/manjaro/.cache/calamares/session.log"
2025-02-17 - 10:47:06 [6]:     .. Languages: QList("ar", "as", "ast", "az", "az_AZ", "be", "bg", "bn", "ca", "ca@valencia", "cs_CZ", "da", "de", "el", "en", "en_GB", "eo", "es", "es_AR", "es_MX", "et", "eu", "fa", "fi_FI", "fr", "fur", "gl", "he", "hi", "hr", "hu", "id", "is", "it_IT", "ja", "ka", "ko", "lt", "ml", "mr", "nb", "nl", "oc", "pl", "pt_BR", "pt_PT", "ro", "ru", "si", "sk", "sl", "sq", "sr", "sr@latin", "sv", "tg", "th", "tr_TR", "uk", "vi", "zh_CN", "zh_TW")
2025-02-17 - 10:47:06 [6]: bool Calamares::initQmlModulesDir()
2025-02-17 - 10:47:06 [6]:     Using Calamares QML directory "/usr/share/calamares/qml"
2025-02-17 - 10:47:06 [6]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2025-02-17 - 10:47:06 [6]:     Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2025-02-17 - 10:47:06 [2]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2025-02-17 - 10:47:06 [2]:     WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
2025-02-17 - 10:47:06 [6]:     Loaded branding component "manjaro"
2025-02-17 - 10:47:06 [2]: bool Calamares::validateStyleEntries(const QMap<QString, QString>&)
2025-02-17 - 10:47:06 [2]:     WARNING: Unknown branding *style* entry "SidebarTextSelect"
2025-02-17 - 10:47:06 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarBackground"
2025-02-17 - 10:47:06 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarText"
2025-02-17 - 10:47:06 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarTextHighlight"
2025-02-17 - 10:47:06 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarTextSelect"
2025-02-17 - 10:47:06 [6]:     .. No translation for "tz_" "C" using default (en)
2025-02-17 - 10:47:06 [6]:     .. No translation for "calamares_" "C" using default (en)
2025-02-17 - 10:47:06 [6]:     .. STARTUP: initSettings, initQmlPath, initBranding done
2025-02-17 - 10:47:06 [6]:     .. STARTUP: initModuleManager: module init started
2025-02-17 - 10:47:06 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
2025-02-17 - 10:47:06 [2]:     WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2025-02-17 - 10:47:06 [2]: WARNING:     ..  Module descriptor contains extra keys:
     "requires"
2025-02-17 - 10:47:06 [6]: void Calamares::ModuleManager::doInit()
2025-02-17 - 10:47:06 [6]:     Found 56 modules
2025-02-17 - 10:47:06 [6]: void CalamaresApplication::initView()
2025-02-17 - 10:47:06 [6]:     STARTUP: initModuleManager: all modules init done
2025-02-17 - 10:47:06 [6]:     STARTUP: initJobQueue done
2025-02-17 - 10:47:06 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
2025-02-17 - 10:47:06 [6]:     Available desktop QSize(1920, 1048) minimum size QSize(1024, 520)
2025-02-17 - 10:47:06 [6]:     .. Proposed window size: 1024 560
2025-02-17 - 10:47:07 [6]: QString Calamares::searchQmlFile(QmlSearch, const QString&)
2025-02-17 - 10:47:07 [6]:     Looking for QML for "calamares-sidebar"
2025-02-17 - 10:47:07 [6]:     .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
2025-02-17 - 10:47:07 [6]: void CalamaresApplication::initView()
2025-02-17 - 10:47:07 [6]:     STARTUP: CalamaresWindow created; loadModules started
2025-02-17 - 10:47:07 [6]: void Config::initLanguages()
2025-02-17 - 10:47:07 [6]:     Trying to match locale "C"
2025-02-17 - 10:47:07 [6]:     Trying to match locale QLocale(C, Default, Default)
2025-02-17 - 10:47:07 [6]:     .. Trying to match approximate locale QLocale::C
2025-02-17 - 10:47:07 [6]:     .. Trying to match English (US)
2025-02-17 - 10:47:07 [6]: void Config::setLocaleIndex(int)
2025-02-17 - 10:47:07 [6]:     Index 14 Selected locale "en"
2025-02-17 - 10:47:07 [6]:     .. Loaded QRC translation "tz_" "en"
2025-02-17 - 10:47:07 [6]:     .. Loaded QRC translation "calamares_" "en"
2025-02-17 - 10:47:07 [6]: virtual void Calamares::ViewModule::loadSelf()
2025-02-17 - 10:47:07 [6]:     ViewModule "welcome@welcome" loading complete.
2025-02-17 - 10:47:07 [6]: QStringList loadLocales(const QString&)
2025-02-17 - 10:47:07 [6]:     Loading locales from "/usr/share/i18n/SUPPORTED"
2025-02-17 - 10:47:07 [6]:     ..  Read 501 lines
2025-02-17 - 10:47:07 [6]:     ..  After filtering 326 lines
2025-02-17 - 10:47:07 [6]:     ViewModule "locale@locale" loading complete.
2025-02-17 - 10:47:07 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
2025-02-17 - 10:47:07 [6]:     Loaded 183 keyboard models
2025-02-17 - 10:47:07 [6]: KeyboardGroupsSwitchersModel::KeyboardGroupsSwitchersModel(QObject*)
2025-02-17 - 10:47:07 [6]:     Loaded 45 keyboard groups
2025-02-17 - 10:47:07 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
2025-02-17 - 10:47:07 [6]:     Variants now total= 0 selected= -1
2025-02-17 - 10:47:07 [6]:     Groups now total= 45 selected= -1
2025-02-17 - 10:47:07 [6]:     .. Loaded QRC translation "kb_" "en"
2025-02-17 - 10:47:07 [6]: void Config::getCurrentKeyboardLayoutXkb(QString&, QString&, QString&)
2025-02-17 - 10:47:07 [6]:     QList("pc", "us", "inet(evdev)\"")
2025-02-17 - 10:47:07 [6]:     ViewModule "keyboard@keyboard" loading complete.
2025-02-17 - 10:47:07 [6]: Calamares::Partition::InternalManager::InternalManager()
2025-02-17 - 10:47:07 [6]:     KPMCore backend starting ..
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): Loaded backend plugin:  "pmsfdiskbackendplugin"
2025-02-17 - 10:47:07 [6]:     .. Backend @0x594f6371bba0 "pmsfdiskbackendplugin" "1"
2025-02-17 - 10:47:07 [2]: void Config::fillConfigurationFSTypes(const QVariantMap&)
2025-02-17 - 10:47:07 [2]:     WARNING: Partition-module setting *luksGeneration* not found or invalid. Defaulting to luks1.
2025-02-17 - 10:47:07 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
2025-02-17 - 10:47:07 [2]:     WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
2025-02-17 - 10:47:07 [6]:     ViewModule "partition@partition" loading complete.
2025-02-17 - 10:47:07 [2]: bool addPasswordCheck(const QString&, const QVariant&, PasswordCheckList&)
2025-02-17 - 10:47:07 [2]:     WARNING: nonempty check is ignored; use minLength: 1
2025-02-17 - 10:47:07 [6]:     ViewModule "users@users" loading complete.
2025-02-17 - 10:47:07 [6]:     ViewModule "summary@summary" loading complete.
2025-02-17 - 10:47:07 [6]: void Calamares::ModuleManager::loadModules()
2025-02-17 - 10:47:07 [6]:     Module "partition@partition" already loaded.
2025-02-17 - 10:47:07 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
2025-02-17 - 10:47:07 [6]:     QML import paths:
     "/usr/bin"
     "qrc:/qt/qml"
     "/usr/lib/qt6/qml"
2025-02-17 - 10:47:07 [6]:     QML load on startup, API 2.
2025-02-17 - 10:47:07 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
2025-02-17 - 10:47:07 [2]:     WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2025-02-17 - 10:47:07 [6]: virtual void Calamares::CppJobModule::loadSelf()
2025-02-17 - 10:47:07 [6]:     CppJobModule "machineid@machineid" loading complete.
2025-02-17 - 10:47:07 [6]:     Module "locale@locale" already loaded.
2025-02-17 - 10:47:07 [6]:     Module "keyboard@keyboard" already loaded.
2025-02-17 - 10:47:07 [6]:     CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
2025-02-17 - 10:47:07 [6]:     CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
2025-02-17 - 10:47:07 [6]:     CppJobModule "initcpio@initcpio" loading complete.
2025-02-17 - 10:47:07 [6]:     Module "users@users" already loaded.
2025-02-17 - 10:47:07 [6]:     CppJobModule "umount@umount" loading complete.
2025-02-17 - 10:47:07 [2]: void Config::setConfigurationMap(const QVariantMap&)
2025-02-17 - 10:47:07 [2]:     WARNING: Configuring the finished module with deprecated restartNowEnabled settings
2025-02-17 - 10:47:07 [6]:     ViewModule "finished@finished" loading complete.
2025-02-17 - 10:47:07 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
2025-02-17 - 10:47:07 [6]:     GeoIP result for welcome= "PL"
2025-02-17 - 10:47:07 [6]:     Index 43 Selected locale "pl"
2025-02-17 - 10:47:07 [6]:     .. No translation for "tz_" "pl" using default (en)
2025-02-17 - 10:47:07 [6]:     .. Loaded QRC translation "calamares_" "pl"
2025-02-17 - 10:47:07 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
2025-02-17 - 10:47:07 [6]:     QML component complete, API 2
2025-02-17 - 10:47:07 [2]: WARNING (Qt): file:///usr/share/calamares/branding/manjaro/slideshow/sponsor/SponsoredBy.qml: No such file or directory
2025-02-17 - 10:47:07 [6]:     .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2025-02-17 - 10:47:07 [6]:     .. No translation for "kb_" "pl" using default (en)
2025-02-17 - 10:47:07 [6]: void CalamaresApplication::initViewSteps()
2025-02-17 - 10:47:07 [6]:     STARTUP: loadModules for all modules done
2025-02-17 - 10:47:07 [6]: void Calamares::ModuleManager::checkRequirements()
2025-02-17 - 10:47:07 [6]:     Checking module requirements ..
2025-02-17 - 10:47:07 [6]:     STARTUP: Window now visible and ProgressTreeView populated
2025-02-17 - 10:47:07 [6]:     .. 8 view steps loaded.
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 10:47:07 [6]: void Config::applyXkb()
2025-02-17 - 10:47:07 [6]:     xkbmap selection changed to:  "us" - ""
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 10:47:07 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 10:47:07 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-17 - 10:47:07 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-17 - 10:47:07 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
2025-02-17 - 10:47:07 [6]:     GeneralRequirements output:
     RAM :   1073741824
     enoughRam :   true
     hasPower :   true
     hasInternet :   true
     isRoot :   true
2025-02-17 - 10:47:07 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-02-17 - 10:47:07 [6]:     Got 5 requirement results from "welcome"
2025-02-17 - 10:47:08 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
2025-02-17 - 10:47:08 [6]: DEBUG (Qt): smartctl initialization failed for  "/dev/sde" :  No such file or directory
2025-02-17 - 10:47:08 [6]: DEBUG (Qt): error during smart output parsing for  "/dev/sde" :  No such file or directory
2025-02-17 - 10:47:08 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
2025-02-17 - 10:47:08 [6]:     Removing unsuitable devices: 7 candidates.
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme0n1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme0n1p3")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme0n1p1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme0n1p2")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "")
2025-02-17 - 10:47:08 [6]:     .. Target cmd: QList("blkid", "") Exit code: 2 (no output)
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme1n1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme1n1p1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme1n1p2")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme1n1p3")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/nvme1n1p4")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sda")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sda1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sda2")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdb")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdb1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdb2")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdb3")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdc")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdc1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdd")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sdd1")
2025-02-17 - 10:47:08 [6]:     .. Running QList("blkid", "/dev/sde")
2025-02-17 - 10:47:08 [6]:     .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sde"
2025-02-17 - 10:47:08 [6]:     .. there are 6 devices left.
2025-02-17 - 10:47:08 [6]: void PartitionCoreModule::doInit()
2025-02-17 - 10:47:08 [6]:     LIST OF DETECTED DEVICES:
2025-02-17 - 10:47:08 [6]:     .. node	capacity	name	prettyName
2025-02-17 - 10:47:08 [6]:     .. "/dev/nvme0n1" 1024209543168 DevName$e22bdf4 DevNamePretty$3abd12ba
2025-02-17 - 10:47:08 [6]:     .. "/dev/nvme1n1" 1000204886016 DevName$6c7970 DevNamePretty$ecc3342c
2025-02-17 - 10:47:08 [6]:     .. "/dev/sda" 2000398934016 DevName$b01d4cce DevNamePretty$b1fad48c
2025-02-17 - 10:47:08 [6]:     .. "/dev/sdb" 2000398934016 DevName$b01d4cce DevNamePretty$975b0c1f
2025-02-17 - 10:47:08 [6]:     .. "/dev/sdc" 250055122432 DevName$cfb60a51 DevNamePretty$d98f43ff
2025-02-17 - 10:47:08 [6]:     .. "/dev/sdd" 1024209543168 DevName$565cef44 DevNamePretty$7a3327e7
2025-02-17 - 10:47:08 [6]:     .. 6 devices detected.
2025-02-17 - 10:47:08 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-17 - 10:47:08 [6]:     Remaining modules: 1
     "partition"
2025-02-17 - 10:47:10 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-17 - 10:47:10 [6]:     Remaining modules: 1
     "partition"
2025-02-17 - 10:47:11 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-17 - 10:47:11 [6]:     Remaining modules: 1
     "partition"
2025-02-17 - 10:47:11 [6]:     .. Running QList("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p1")
2025-02-17 - 10:47:11 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
2025-02-17 - 10:47:11 [6]:     Checking device "/dev/nvme0n1p1" for fstab (fs= "ext4" )
2025-02-17 - 10:47:11 [6]:     .. Running QList("mount", "-o", "ro,noload", "/dev/nvme0n1p1", "/tmp/calamares-eSCrkx")
2025-02-17 - 10:47:11 [6]:     .. Running QList("udevadm", "settle")
2025-02-17 - 10:47:11 [6]:     .. Running QList("sync")
2025-02-17 - 10:47:11 [6]:     .. got 4 fstab entries from 12 lines in "/tmp/calamares-eSCrkx/etc/fstab"
2025-02-17 - 10:47:11 [6]:     .. Running QList("umount", "-R", "/tmp/calamares-eSCrkx")
2025-02-17 - 10:47:11 [6]: bool PartUtils::canBeResized(Partition*, const Logger::Once&)
2025-02-17 - 10:47:11 [6]:     Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2025-02-17 - 10:47:11 [6]:     .. Running QList("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p2")
2025-02-17 - 10:47:11 [6]:     Checking device "/dev/nvme0n1p2" for fstab (fs= "ext4" )
2025-02-17 - 10:47:11 [6]:     .. Running QList("mount", "-o", "ro,noload", "/dev/nvme0n1p2", "/tmp/calamares-Ymqqlo")
2025-02-17 - 10:47:11 [6]:     .. got 4 fstab entries from 12 lines in "/tmp/calamares-Ymqqlo/etc/fstab"
2025-02-17 - 10:47:11 [6]:     .. Running QList("umount", "-R", "/tmp/calamares-Ymqqlo")
2025-02-17 - 10:47:11 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
2025-02-17 - 10:47:11 [6]:     ..  os-prober lines after cleanup:
2025-02-17 - 10:47:11 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x594f63723f70) without calling endResetModel first
2025-02-17 - 10:47:11 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x594f63723f70) without calling beginResetModel first
2025-02-17 - 10:47:12 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2025-02-17 - 10:47:12 [6]:     system is EFI and new EFI system partition has been found.
2025-02-17 - 10:47:12 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-02-17 - 10:47:12 [6]:     Got 1 requirement results from "partition"
2025-02-17 - 10:47:12 [2]: void ChoicePage::updateActionDescriptionsTr()
2025-02-17 - 10:47:12 [2]:     WARNING: Invalid osprober count, labels and buttons not updated.
2025-02-17 - 10:47:12 [6]: void ChoicePage::updateDeviceStatePreview()
2025-02-17 - 10:47:12 [6]:     Updating partitioning state widgets.
2025-02-17 - 10:47:12 [6]: void ChoicePage::setupActions()
2025-02-17 - 10:47:12 [6]:     Setting up actions for "/dev/nvme0n1" with 2 entries.
2025-02-17 - 10:47:12 [6]:     ..  Can not resize "/dev/nvme0n1p3" , filesystem "fat32" does not support resize.
2025-02-17 - 10:47:12 [6]:     ..  Checking if "/dev/nvme0n1p3" can be replaced.
2025-02-17 - 10:47:12 [6]:     ..  NO, insufficient storage
2025-02-17 - 10:47:12 [6]:     ..  Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2025-02-17 - 10:47:12 [6]:     .. contains resizable "/dev/nvme0n1p1"
2025-02-17 - 10:47:12 [6]:     ..  Checking if "/dev/nvme0n1p1" can be replaced.
2025-02-17 - 10:47:12 [6]:     ..  Partition "/dev/nvme0n1p1" authorized for replace install.
2025-02-17 - 10:47:12 [6]:     .. contains replaceable "/dev/nvme0n1p1"
2025-02-17 - 10:47:12 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
2025-02-17 - 10:47:12 [6]:     .. contains resizable "/dev/nvme0n1p2"
2025-02-17 - 10:47:12 [6]:     ..  Checking if "/dev/nvme0n1p2" can be replaced.
2025-02-17 - 10:47:12 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for replace install.
2025-02-17 - 10:47:12 [6]:     .. contains replaceable "/dev/nvme0n1p2"
2025-02-17 - 10:47:12 [6]:     ..  Can not resize "/dev/nvme0n1" , filesystem "unknown" does not support resize.
2025-02-17 - 10:47:12 [6]:     ..  Checking if "/dev/nvme0n1" can be replaced.
2025-02-17 - 10:47:12 [6]: void ChoicePage::updateActionDescriptionsTr()
2025-02-17 - 10:47:12 [6]:     Setting texts for >= 2 osprober entries
2025-02-17 - 10:47:12 [6]: void ChoicePage::continueApplyDeviceChoice()
2025-02-17 - 10:47:12 [6]:     Previous device -1 new device 0
2025-02-17 - 10:47:12 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-17 - 10:47:12 [6]:     InstallChoice Config::Erase "erase"
2025-02-17 - 10:47:12 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2025-02-17 - 10:47:12 [6]:     CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme0n1"
2025-02-17 - 10:47:12 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x594f63723f70) without calling endResetModel first
2025-02-17 - 10:47:12 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x594f63723f70) without calling beginResetModel first
2025-02-17 - 10:47:12 [6]: void Calamares::RequirementsChecker::finished()
2025-02-17 - 10:47:12 [6]:     All requirements have been checked.
2025-02-17 - 10:47:12 [6]: void Calamares::RequirementsModel::describe() const
2025-02-17 - 10:47:12 [6]:     Requirements model has 6 items
2025-02-17 - 10:47:12 [6]:     .. requirement 0 "storage" satisfied? true mandatory? true
2025-02-17 - 10:47:12 [6]:     .. requirement 1 "ram" satisfied? true mandatory? true
2025-02-17 - 10:47:12 [6]:     .. requirement 2 "power" satisfied? true mandatory? false
2025-02-17 - 10:47:12 [6]:     .. requirement 3 "internet" satisfied? true mandatory? false
2025-02-17 - 10:47:12 [6]:     .. requirement 4 "root" satisfied? true mandatory? true
2025-02-17 - 10:47:12 [6]:     .. requirement 5 "partitions" satisfied? true mandatory? true
2025-02-17 - 10:47:12 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2025-02-17 - 10:47:12 [2]:     WARNING: system is EFI but no EFI system partitions found.
2025-02-17 - 10:47:12 [6]: void PartitionCoreModule::dumpQueue() const
2025-02-17 - 10:47:12 [6]:     # Queue:
2025-02-17 - 10:47:12 [6]:     .. ## Device: "/dev/nvme0n1"
2025-02-17 - 10:47:12 [6]:     .. - CreatePartitionTableJob
2025-02-17 - 10:47:12 [6]:     .. - CreatePartitionJob
2025-02-17 - 10:47:12 [6]:     .. - SetPartFlagsJob
2025-02-17 - 10:47:12 [6]:     .. ## Device: "/dev/nvme1n1"
2025-02-17 - 10:47:12 [6]:     .. ## Device: "/dev/sda"
2025-02-17 - 10:47:12 [6]:     .. ## Device: "/dev/sdb"
2025-02-17 - 10:47:12 [6]:     .. ## Device: "/dev/sdc"
2025-02-17 - 10:47:12 [6]:     .. ## Device: "/dev/sdd"
2025-02-17 - 10:47:12 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-17 - 10:47:12 [6]:     Updating partitioning preview widgets.
2025-02-17 - 10:47:13 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2025-02-17 - 10:47:13 [6]:     Mapping "pl" in "PL" to locale.
2025-02-17 - 10:47:13 [6]:     .. Got best match for "pl" as "pl_PL.UTF-8"
2025-02-17 - 10:47:13 [6]:     .. Got best match for "pl_PL" as "pl_PL.UTF-8"
2025-02-17 - 11:47:13 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2025-02-17 - 11:47:13 [6]:     Mapping "pl" in "PL" to locale.
2025-02-17 - 11:47:13 [6]:     .. Got best match for "pl" as "pl_PL.UTF-8"
2025-02-17 - 11:47:13 [6]:     .. Got best match for "pl_PL" as "pl_PL.UTF-8"
2025-02-17 - 11:47:14 [6]: void Config::guessLocaleKeyboardLayout()
2025-02-17 - 11:47:14 [6]:     Got locale language "pl_PL.UTF-8"
2025-02-17 - 11:47:14 [6]:     .. looking for locale part "PL"
2025-02-17 - 11:47:14 [6]:     .. matched "pl"
2025-02-17 - 11:47:14 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
2025-02-17 - 11:47:14 [6]:     Next level: "pl"
2025-02-17 - 11:47:14 [6]: void Config::applyXkb()
2025-02-17 - 11:47:14 [6]:     xkbmap selection changed to:  "pl" - ""
2025-02-17 - 11:47:18 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:18 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:18 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:18 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x594f63723f70) without calling endResetModel first
2025-02-17 - 11:47:18 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x594f63723f70) without calling beginResetModel first
2025-02-17 - 11:47:18 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:18 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:18 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:18 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-17 - 11:47:18 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-17 - 11:47:18 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
2025-02-17 - 11:47:19 [6]: void ChoicePage::updateDeviceStatePreview()
2025-02-17 - 11:47:19 [6]:     Updating partitioning state widgets.
2025-02-17 - 11:47:19 [6]: void ChoicePage::setupActions()
2025-02-17 - 11:47:19 [6]:     Setting up actions for "/dev/nvme1n1" with 0 entries.
2025-02-17 - 11:47:19 [6]:     ..  Can not resize "/dev/nvme1n1p1" , filesystem "unknown" does not support resize.
2025-02-17 - 11:47:19 [6]:     ..  Checking if "/dev/nvme1n1p1" can be replaced.
2025-02-17 - 11:47:19 [6]:     ..  NO, insufficient storage
2025-02-17 - 11:47:19 [6]:     ..  Can not resize "/dev/nvme1n1p2" , filesystem "unknown" does not support resize.
2025-02-17 - 11:47:19 [6]:     ..  Checking if "/dev/nvme1n1p2" can be replaced.
2025-02-17 - 11:47:19 [6]:     ..  Partition "/dev/nvme1n1p3" authorized for resize + autopartition install.
2025-02-17 - 11:47:19 [6]:     .. contains resizable "/dev/nvme1n1p3"
2025-02-17 - 11:47:19 [6]:     ..  Checking if "/dev/nvme1n1p3" can be replaced.
2025-02-17 - 11:47:19 [6]:     ..  Partition "/dev/nvme1n1p3" authorized for replace install.
2025-02-17 - 11:47:19 [6]:     .. contains replaceable "/dev/nvme1n1p3"
2025-02-17 - 11:47:19 [6]:     ..  Partition "/dev/nvme1n1p4" authorized for resize + autopartition install.
2025-02-17 - 11:47:19 [6]:     .. contains resizable "/dev/nvme1n1p4"
2025-02-17 - 11:47:19 [6]:     ..  Checking if "/dev/nvme1n1p4" can be replaced.
2025-02-17 - 11:47:19 [6]:     ..  Partition "/dev/nvme1n1p4" authorized for replace install.
2025-02-17 - 11:47:19 [6]:     .. contains replaceable "/dev/nvme1n1p4"
2025-02-17 - 11:47:19 [6]: void ChoicePage::updateActionDescriptionsTr()
2025-02-17 - 11:47:19 [6]:     Setting texts for 0 osprober entries
2025-02-17 - 11:47:19 [6]: void ChoicePage::continueApplyDeviceChoice()
2025-02-17 - 11:47:19 [6]:     Previous device 0 new device 1
2025-02-17 - 11:47:19 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-17 - 11:47:19 [6]:     InstallChoice Config::Erase "erase"
2025-02-17 - 11:47:19 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2025-02-17 - 11:47:19 [6]:     CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme1n1"
2025-02-17 - 11:47:19 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x594f63723f70) without calling endResetModel first
2025-02-17 - 11:47:19 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x594f63723f70) without calling beginResetModel first
2025-02-17 - 11:47:19 [6]: void PartitionCoreModule::dumpQueue() const
2025-02-17 - 11:47:19 [6]:     # Queue:
2025-02-17 - 11:47:19 [6]:     .. ## Device: "/dev/nvme0n1"
2025-02-17 - 11:47:19 [6]:     .. ## Device: "/dev/nvme1n1"
2025-02-17 - 11:47:19 [6]:     .. - CreatePartitionTableJob
2025-02-17 - 11:47:19 [6]:     .. - CreatePartitionJob
2025-02-17 - 11:47:19 [6]:     .. - SetPartFlagsJob
2025-02-17 - 11:47:19 [6]:     .. ## Device: "/dev/sda"
2025-02-17 - 11:47:19 [6]:     .. ## Device: "/dev/sdb"
2025-02-17 - 11:47:19 [6]:     .. ## Device: "/dev/sdc"
2025-02-17 - 11:47:19 [6]:     .. ## Device: "/dev/sdd"
2025-02-17 - 11:47:19 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-17 - 11:47:19 [6]:     Updating partitioning preview widgets.
2025-02-17 - 11:47:23 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-17 - 11:47:23 [6]:     InstallChoice Config::Manual "manual"
2025-02-17 - 11:47:23 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-17 - 11:47:23 [6]:     Updating partitioning preview widgets.
2025-02-17 - 11:47:23 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:23 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:23 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:23 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-17 - 11:47:23 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-17 - 11:47:23 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x594f63723f70) without calling endResetModel first
2025-02-17 - 11:47:23 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x594f63723f70) without calling beginResetModel first
2025-02-17 - 11:47:25 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x594f63723f70) without calling endResetModel first
2025-02-17 - 11:47:25 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x594f63723f70) without calling beginResetModel first
2025-02-17 - 11:47:25 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2025-02-17 - 11:47:25 [6]:     No path to restore, choosing default
2025-02-17 - 11:47:25 [6]: virtual void PartitionViewStep::next()
2025-02-17 - 11:47:25 [6]:     Choice applied:  Config::Manual
2025-02-17 - 11:47:31 [6]: void CalamaresApplication::init()
2025-02-17 - 11:47:31 [6]:     Calamares version: 3.3.13
2025-02-17 - 11:47:31 [6]:     .. Using Qt version: 6.8.1
2025-02-17 - 11:47:31 [6]:     .. Build type: Debug
2025-02-17 - 11:47:31 [6]:     .. Using PyBind11
2025-02-17 - 11:47:31 [6]:     .. Using settings: "/etc/calamares/settings.conf"
2025-02-17 - 11:47:31 [6]:     .. Using log file: "/home/manjaro/.cache/calamares/session.log"
2025-02-17 - 11:47:31 [6]:     .. Languages: QList("ar", "as", "ast", "az", "az_AZ", "be", "bg", "bn", "ca", "ca@valencia", "cs_CZ", "da", "de", "el", "en", "en_GB", "eo", "es", "es_AR", "es_MX", "et", "eu", "fa", "fi_FI", "fr", "fur", "gl", "he", "hi", "hr", "hu", "id", "is", "it_IT", "ja", "ka", "ko", "lt", "ml", "mr", "nb", "nl", "oc", "pl", "pt_BR", "pt_PT", "ro", "ru", "si", "sk", "sl", "sq", "sr", "sr@latin", "sv", "tg", "th", "tr_TR", "uk", "vi", "zh_CN", "zh_TW")
2025-02-17 - 11:47:31 [6]: bool Calamares::initQmlModulesDir()
2025-02-17 - 11:47:31 [6]:     Using Calamares QML directory "/usr/share/calamares/qml"
2025-02-17 - 11:47:31 [6]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2025-02-17 - 11:47:31 [6]:     Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2025-02-17 - 11:47:31 [2]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
2025-02-17 - 11:47:31 [2]:     WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
2025-02-17 - 11:47:31 [6]:     Loaded branding component "manjaro"
2025-02-17 - 11:47:31 [2]: bool Calamares::validateStyleEntries(const QMap<QString, QString>&)
2025-02-17 - 11:47:31 [2]:     WARNING: Unknown branding *style* entry "SidebarTextSelect"
2025-02-17 - 11:47:31 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarBackground"
2025-02-17 - 11:47:31 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarText"
2025-02-17 - 11:47:31 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarTextHighlight"
2025-02-17 - 11:47:31 [2]: WARNING:     ..  Unknown branding *style* entry "sidebarTextSelect"
2025-02-17 - 11:47:31 [6]:     .. No translation for "tz_" "C" using default (en)
2025-02-17 - 11:47:31 [6]:     .. No translation for "calamares_" "C" using default (en)
2025-02-17 - 11:47:31 [6]:     .. STARTUP: initSettings, initQmlPath, initBranding done
2025-02-17 - 11:47:31 [6]:     .. STARTUP: initModuleManager: module init started
2025-02-17 - 11:47:31 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
2025-02-17 - 11:47:31 [2]:     WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2025-02-17 - 11:47:31 [2]: WARNING:     ..  Module descriptor contains extra keys:
     "requires"
2025-02-17 - 11:47:31 [6]: void Calamares::ModuleManager::doInit()
2025-02-17 - 11:47:31 [6]:     Found 56 modules
2025-02-17 - 11:47:31 [6]: void CalamaresApplication::initView()
2025-02-17 - 11:47:31 [6]:     STARTUP: initModuleManager: all modules init done
2025-02-17 - 11:47:31 [6]:     STARTUP: initJobQueue done
2025-02-17 - 11:47:31 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
2025-02-17 - 11:47:31 [6]:     Available desktop QSize(1920, 1048) minimum size QSize(1024, 520)
2025-02-17 - 11:47:31 [6]:     .. Proposed window size: 1024 560
2025-02-17 - 11:47:31 [6]: QString Calamares::searchQmlFile(QmlSearch, const QString&)
2025-02-17 - 11:47:31 [6]:     Looking for QML for "calamares-sidebar"
2025-02-17 - 11:47:31 [6]:     .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
2025-02-17 - 11:47:31 [6]:     STARTUP: CalamaresWindow created; loadModules started
2025-02-17 - 11:47:31 [6]: void Config::initLanguages()
2025-02-17 - 11:47:31 [6]:     Trying to match locale "C"
2025-02-17 - 11:47:31 [6]:     Trying to match locale QLocale(C, Default, Default)
2025-02-17 - 11:47:31 [6]:     .. Trying to match approximate locale QLocale::C
2025-02-17 - 11:47:31 [6]:     .. Trying to match English (US)
2025-02-17 - 11:47:31 [6]: void Config::setLocaleIndex(int)
2025-02-17 - 11:47:31 [6]:     Index 14 Selected locale "en"
2025-02-17 - 11:47:31 [6]:     .. Loaded QRC translation "tz_" "en"
2025-02-17 - 11:47:31 [6]:     .. Loaded QRC translation "calamares_" "en"
2025-02-17 - 11:47:31 [6]: virtual void Calamares::ViewModule::loadSelf()
2025-02-17 - 11:47:31 [6]:     ViewModule "welcome@welcome" loading complete.
2025-02-17 - 11:47:31 [6]: QStringList loadLocales(const QString&)
2025-02-17 - 11:47:31 [6]:     Loading locales from "/usr/share/i18n/SUPPORTED"
2025-02-17 - 11:47:31 [6]:     ..  Read 501 lines
2025-02-17 - 11:47:31 [6]:     ..  After filtering 326 lines
2025-02-17 - 11:47:31 [6]:     ViewModule "locale@locale" loading complete.
2025-02-17 - 11:47:31 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
2025-02-17 - 11:47:31 [6]:     Loaded 183 keyboard models
2025-02-17 - 11:47:31 [6]: KeyboardGroupsSwitchersModel::KeyboardGroupsSwitchersModel(QObject*)
2025-02-17 - 11:47:31 [6]:     Loaded 45 keyboard groups
2025-02-17 - 11:47:31 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
2025-02-17 - 11:47:31 [6]:     Variants now total= 0 selected= -1
2025-02-17 - 11:47:31 [6]:     Groups now total= 45 selected= -1
2025-02-17 - 11:47:31 [6]:     .. Loaded QRC translation "kb_" "en"
2025-02-17 - 11:47:31 [6]: void Config::getCurrentKeyboardLayoutXkb(QString&, QString&, QString&)
2025-02-17 - 11:47:31 [6]:     QList("pc", "pl", "inet(evdev)\"")
2025-02-17 - 11:47:31 [6]:     ViewModule "keyboard@keyboard" loading complete.
2025-02-17 - 11:47:31 [6]: Calamares::Partition::InternalManager::InternalManager()
2025-02-17 - 11:47:31 [6]:     KPMCore backend starting ..
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): Loaded backend plugin:  "pmsfdiskbackendplugin"
2025-02-17 - 11:47:31 [6]:     .. Backend @0x5f41cb085db0 "pmsfdiskbackendplugin" "1"
2025-02-17 - 11:47:31 [2]: void Config::fillConfigurationFSTypes(const QVariantMap&)
2025-02-17 - 11:47:31 [2]:     WARNING: Partition-module setting *luksGeneration* not found or invalid. Defaulting to luks1.
2025-02-17 - 11:47:31 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
2025-02-17 - 11:47:31 [2]:     WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
2025-02-17 - 11:47:31 [6]:     ViewModule "partition@partition" loading complete.
2025-02-17 - 11:47:31 [2]: bool addPasswordCheck(const QString&, const QVariant&, PasswordCheckList&)
2025-02-17 - 11:47:31 [2]:     WARNING: nonempty check is ignored; use minLength: 1
2025-02-17 - 11:47:31 [6]:     ViewModule "users@users" loading complete.
2025-02-17 - 11:47:31 [6]:     ViewModule "summary@summary" loading complete.
2025-02-17 - 11:47:31 [6]: void Calamares::ModuleManager::loadModules()
2025-02-17 - 11:47:31 [6]:     Module "partition@partition" already loaded.
2025-02-17 - 11:47:31 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
2025-02-17 - 11:47:31 [6]:     QML import paths:
     "/usr/bin"
     "qrc:/qt/qml"
     "/usr/lib/qt6/qml"
2025-02-17 - 11:47:31 [6]:     QML load on startup, API 2.
2025-02-17 - 11:47:31 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
2025-02-17 - 11:47:31 [2]:     WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2025-02-17 - 11:47:31 [6]: virtual void Calamares::CppJobModule::loadSelf()
2025-02-17 - 11:47:31 [6]:     CppJobModule "machineid@machineid" loading complete.
2025-02-17 - 11:47:31 [6]:     Module "locale@locale" already loaded.
2025-02-17 - 11:47:31 [6]:     Module "keyboard@keyboard" already loaded.
2025-02-17 - 11:47:31 [6]:     CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
2025-02-17 - 11:47:31 [6]:     CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
2025-02-17 - 11:47:31 [6]:     CppJobModule "initcpio@initcpio" loading complete.
2025-02-17 - 11:47:31 [6]:     Module "users@users" already loaded.
2025-02-17 - 11:47:31 [6]:     CppJobModule "umount@umount" loading complete.
2025-02-17 - 11:47:31 [2]: void Config::setConfigurationMap(const QVariantMap&)
2025-02-17 - 11:47:31 [2]:     WARNING: Configuring the finished module with deprecated restartNowEnabled settings
2025-02-17 - 11:47:31 [6]:     ViewModule "finished@finished" loading complete.
2025-02-17 - 11:47:31 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
2025-02-17 - 11:47:31 [6]:     QML component complete, API 2
2025-02-17 - 11:47:31 [2]: WARNING (Qt): file:///usr/share/calamares/branding/manjaro/slideshow/sponsor/SponsoredBy.qml: No such file or directory
2025-02-17 - 11:47:31 [6]:     .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2025-02-17 - 11:47:31 [6]: void CalamaresApplication::initViewSteps()
2025-02-17 - 11:47:31 [6]:     STARTUP: loadModules for all modules done
2025-02-17 - 11:47:31 [6]: void Calamares::ModuleManager::checkRequirements()
2025-02-17 - 11:47:31 [6]:     Checking module requirements ..
2025-02-17 - 11:47:31 [6]:     STARTUP: Window now visible and ProgressTreeView populated
2025-02-17 - 11:47:31 [6]:     .. 8 view steps loaded.
2025-02-17 - 11:47:31 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
2025-02-17 - 11:47:31 [6]:     GeoIP result for welcome= "PL"
2025-02-17 - 11:47:31 [6]:     Index 43 Selected locale "pl"
2025-02-17 - 11:47:31 [6]:     .. No translation for "tz_" "pl" using default (en)
2025-02-17 - 11:47:31 [6]:     .. Loaded QRC translation "calamares_" "pl"
2025-02-17 - 11:47:31 [6]:     .. No translation for "kb_" "pl" using default (en)
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:31 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:31 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-17 - 11:47:31 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-17 - 11:47:31 [6]: void Config::applyXkb()
2025-02-17 - 11:47:31 [6]:     xkbmap selection changed to:  "pl" - ""
2025-02-17 - 11:47:31 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
2025-02-17 - 11:47:31 [6]:     GeneralRequirements output:
     RAM :   1073741824
     enoughRam :   true
     hasPower :   true
     hasInternet :   true
     isRoot :   true
2025-02-17 - 11:47:31 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-02-17 - 11:47:31 [6]:     Got 5 requirement results from "welcome"
2025-02-17 - 11:47:32 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
2025-02-17 - 11:47:32 [6]: DEBUG (Qt): smartctl initialization failed for  "/dev/sde" :  No such file or directory
2025-02-17 - 11:47:32 [6]: DEBUG (Qt): error during smart output parsing for  "/dev/sde" :  No such file or directory
2025-02-17 - 11:47:32 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
2025-02-17 - 11:47:32 [6]:     Removing unsuitable devices: 7 candidates.
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme0n1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme0n1p3")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme0n1p1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme0n1p2")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "")
2025-02-17 - 11:47:32 [6]:     .. Target cmd: QList("blkid", "") Exit code: 2 (no output)
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme1n1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme1n1p1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme1n1p2")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme1n1p3")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/nvme1n1p4")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sda")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sda1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sda2")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdb")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdb1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdb2")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdb3")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdc")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdc1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdd")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sdd1")
2025-02-17 - 11:47:32 [6]:     .. Running QList("blkid", "/dev/sde")
2025-02-17 - 11:47:32 [6]:     .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sde"
2025-02-17 - 11:47:32 [6]:     .. there are 6 devices left.
2025-02-17 - 11:47:32 [6]: void PartitionCoreModule::doInit()
2025-02-17 - 11:47:32 [6]:     LIST OF DETECTED DEVICES:
2025-02-17 - 11:47:32 [6]:     .. node	capacity	name	prettyName
2025-02-17 - 11:47:32 [6]:     .. "/dev/nvme0n1" 1024209543168 DevName$ee66c7e9 DevNamePretty$651be6b1
2025-02-17 - 11:47:32 [6]:     .. "/dev/nvme1n1" 1000204886016 DevName$641d31e6 DevNamePretty$65aa56c3
2025-02-17 - 11:47:32 [6]:     .. "/dev/sda" 2000398934016 DevName$a5dfbfac DevNamePretty$668a29cc
2025-02-17 - 11:47:32 [6]:     .. "/dev/sdb" 2000398934016 DevName$a5dfbfac DevNamePretty$47ae5641
2025-02-17 - 11:47:32 [6]:     .. "/dev/sdc" 250055122432 DevName$1c5e390e DevNamePretty$b71752b2
2025-02-17 - 11:47:32 [6]:     .. "/dev/sdd" 1024209543168 DevName$aefe9a36 DevNamePretty$3bdc9e79
2025-02-17 - 11:47:32 [6]:     .. 6 devices detected.
2025-02-17 - 11:47:32 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-17 - 11:47:32 [6]:     Remaining modules: 1
     "partition"
2025-02-17 - 11:47:33 [6]: void Calamares::RequirementsChecker::reportProgress()
2025-02-17 - 11:47:33 [6]:     Remaining modules: 1
     "partition"
2025-02-17 - 11:47:34 [6]:     .. Running QList("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p1")
2025-02-17 - 11:47:34 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
2025-02-17 - 11:47:34 [6]:     Checking device "/dev/nvme0n1p1" for fstab (fs= "ext4" )
2025-02-17 - 11:47:34 [6]:     .. Running QList("mount", "-o", "ro,noload", "/dev/nvme0n1p1", "/tmp/calamares-FaolJX")
2025-02-17 - 11:47:34 [6]:     .. Running QList("udevadm", "settle")
2025-02-17 - 11:47:35 [6]:     .. Running QList("sync")
2025-02-17 - 11:47:35 [6]:     .. got 4 fstab entries from 12 lines in "/tmp/calamares-FaolJX/etc/fstab"
2025-02-17 - 11:47:35 [6]:     .. Running QList("umount", "-R", "/tmp/calamares-FaolJX")
2025-02-17 - 11:47:35 [6]:     .. Running QList("udevadm", "settle")
2025-02-17 - 11:47:35 [6]: bool PartUtils::canBeResized(Partition*, const Logger::Once&)
2025-02-17 - 11:47:35 [6]:     Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2025-02-17 - 11:47:35 [6]:     .. Running QList("blkid", "-s", "TYPE", "-o", "value", "/dev/nvme0n1p2")
2025-02-17 - 11:47:35 [6]: FstabEntryList PartUtils::lookForFstabEntries(const QString&)
2025-02-17 - 11:47:35 [6]:     Checking device "/dev/nvme0n1p2" for fstab (fs= "ext4" )
2025-02-17 - 11:47:35 [6]:     .. Running QList("mount", "-o", "ro,noload", "/dev/nvme0n1p2", "/tmp/calamares-bdmhaF")
2025-02-17 - 11:47:35 [6]:     .. got 4 fstab entries from 12 lines in "/tmp/calamares-bdmhaF/etc/fstab"
2025-02-17 - 11:47:35 [6]:     .. Running QList("umount", "-R", "/tmp/calamares-bdmhaF")
2025-02-17 - 11:47:35 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for resize + autopartition install.
2025-02-17 - 11:47:35 [6]:     ..  os-prober lines after cleanup:
2025-02-17 - 11:47:35 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5f41cb274040) without calling endResetModel first
2025-02-17 - 11:47:35 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5f41cb274040) without calling beginResetModel first
2025-02-17 - 11:47:35 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
2025-02-17 - 11:47:35 [6]:     system is EFI and new EFI system partition has been found.
2025-02-17 - 11:47:35 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
2025-02-17 - 11:47:35 [6]:     Got 1 requirement results from "partition"
2025-02-17 - 11:47:35 [2]: void ChoicePage::updateActionDescriptionsTr()
2025-02-17 - 11:47:35 [2]:     WARNING: Invalid osprober count, labels and buttons not updated.
2025-02-17 - 11:47:35 [6]: void ChoicePage::updateDeviceStatePreview()
2025-02-17 - 11:47:35 [6]:     Updating partitioning state widgets.
2025-02-17 - 11:47:35 [6]: void ChoicePage::setupActions()
2025-02-17 - 11:47:35 [6]:     Setting up actions for "/dev/nvme0n1" with 2 entries.
2025-02-17 - 11:47:35 [6]:     ..  Can not resize "/dev/nvme0n1p3" , filesystem "fat32" does not support resize.
2025-02-17 - 11:47:35 [6]:     ..  Checking if "/dev/nvme0n1p3" can be replaced.
2025-02-17 - 11:47:35 [6]:     ..  NO, insufficient storage
2025-02-17 - 11:47:35 [6]:     ..  Partition "/dev/nvme0n1p1" authorized for resize + autopartition install.
2025-02-17 - 11:47:35 [6]:     .. contains resizable "/dev/nvme0n1p1"
2025-02-17 - 11:47:35 [6]:     ..  Checking if "/dev/nvme0n1p1" can be replaced.
2025-02-17 - 11:47:35 [6]:     ..  Partition "/dev/nvme0n1p1" authorized for replace install.
2025-02-17 - 11:47:35 [6]:     .. contains replaceable "/dev/nvme0n1p1"
2025-02-17 - 11:47:35 [6]:     .. contains resizable "/dev/nvme0n1p2"
2025-02-17 - 11:47:35 [6]:     ..  Checking if "/dev/nvme0n1p2" can be replaced.
2025-02-17 - 11:47:35 [6]:     ..  Partition "/dev/nvme0n1p2" authorized for replace install.
2025-02-17 - 11:47:35 [6]:     .. contains replaceable "/dev/nvme0n1p2"
2025-02-17 - 11:47:35 [6]:     ..  Can not resize "/dev/nvme0n1" , filesystem "unknown" does not support resize.
2025-02-17 - 11:47:35 [6]:     ..  Checking if "/dev/nvme0n1" can be replaced.
2025-02-17 - 11:47:35 [6]: void ChoicePage::updateActionDescriptionsTr()
2025-02-17 - 11:47:35 [6]:     Setting texts for >= 2 osprober entries
2025-02-17 - 11:47:35 [6]: void ChoicePage::continueApplyDeviceChoice()
2025-02-17 - 11:47:35 [6]:     Previous device -1 new device 0
2025-02-17 - 11:47:35 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-17 - 11:47:35 [6]:     InstallChoice Config::Erase "erase"
2025-02-17 - 11:47:35 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2025-02-17 - 11:47:35 [6]:     CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme0n1"
2025-02-17 - 11:47:35 [6]: void Calamares::RequirementsChecker::finished()
2025-02-17 - 11:47:35 [6]:     All requirements have been checked.
2025-02-17 - 11:47:35 [6]: void Calamares::RequirementsModel::describe() const
2025-02-17 - 11:47:35 [6]:     Requirements model has 6 items
2025-02-17 - 11:47:35 [6]:     .. requirement 0 "storage" satisfied? true mandatory? true
2025-02-17 - 11:47:35 [6]:     .. requirement 1 "ram" satisfied? true mandatory? true
2025-02-17 - 11:47:35 [6]:     .. requirement 2 "power" satisfied? true mandatory? false
2025-02-17 - 11:47:35 [6]:     .. requirement 3 "internet" satisfied? true mandatory? false
2025-02-17 - 11:47:35 [6]:     .. requirement 4 "root" satisfied? true mandatory? true
2025-02-17 - 11:47:35 [6]:     .. requirement 5 "partitions" satisfied? true mandatory? true
2025-02-17 - 11:47:35 [2]: void PartitionCoreModule::scanForEfiSystemPartitions()
2025-02-17 - 11:47:35 [2]:     WARNING: system is EFI but no EFI system partitions found.
2025-02-17 - 11:47:35 [6]: void PartitionCoreModule::dumpQueue() const
2025-02-17 - 11:47:35 [6]:     # Queue:
2025-02-17 - 11:47:35 [6]:     .. ## Device: "/dev/nvme0n1"
2025-02-17 - 11:47:35 [6]:     .. - CreatePartitionTableJob
2025-02-17 - 11:47:35 [6]:     .. - CreatePartitionJob
2025-02-17 - 11:47:35 [6]:     .. - SetPartFlagsJob
2025-02-17 - 11:47:35 [6]:     .. ## Device: "/dev/nvme1n1"
2025-02-17 - 11:47:35 [6]:     .. ## Device: "/dev/sda"
2025-02-17 - 11:47:35 [6]:     .. ## Device: "/dev/sdb"
2025-02-17 - 11:47:35 [6]:     .. ## Device: "/dev/sdc"
2025-02-17 - 11:47:35 [6]:     .. ## Device: "/dev/sdd"
2025-02-17 - 11:47:35 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-17 - 11:47:35 [6]:     Updating partitioning preview widgets.
2025-02-17 - 11:47:38 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2025-02-17 - 11:47:38 [6]:     Mapping "pl" in "PL" to locale.
2025-02-17 - 11:47:38 [6]:     .. Got best match for "pl" as "pl_PL.UTF-8"
2025-02-17 - 11:47:38 [6]:     .. Got best match for "pl_PL" as "pl_PL.UTF-8"
2025-02-17 - 11:47:39 [6]: void Config::guessLocaleKeyboardLayout()
2025-02-17 - 11:47:39 [6]:     Got locale language "pl_PL.UTF-8"
2025-02-17 - 11:47:39 [6]:     .. looking for locale part "PL"
2025-02-17 - 11:47:39 [6]:     .. matched "pl"
2025-02-17 - 11:47:39 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
2025-02-17 - 11:47:39 [6]:     Next level: "pl"
2025-02-17 - 11:47:42 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:42 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:42 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme0n1" :  No such file or directory
2025-02-17 - 11:47:42 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5f41cb274040) without calling endResetModel first
2025-02-17 - 11:47:42 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5f41cb274040) without calling beginResetModel first
2025-02-17 - 11:47:42 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:42 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:42 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:42 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-17 - 11:47:42 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-17 - 11:47:42 [2]: WARNING (Qt): unknown file system type  "dos"  on  "/dev/sdc"
2025-02-17 - 11:47:42 [6]: void ChoicePage::updateDeviceStatePreview()
2025-02-17 - 11:47:42 [6]:     Updating partitioning state widgets.
2025-02-17 - 11:47:42 [6]: void ChoicePage::setupActions()
2025-02-17 - 11:47:42 [6]:     Setting up actions for "/dev/nvme1n1" with 0 entries.
2025-02-17 - 11:47:42 [6]:     ..  Can not resize "/dev/nvme1n1p1" , filesystem "unknown" does not support resize.
2025-02-17 - 11:47:42 [6]:     ..  Checking if "/dev/nvme1n1p1" can be replaced.
2025-02-17 - 11:47:42 [6]:     ..  NO, insufficient storage
     Required  storage B: 9019431321 "(7.9GiB)"
     Available storage B: 314572800 "(0GiB)"
2025-02-17 - 11:47:42 [6]:     ..  Can not resize "/dev/nvme1n1p2" , filesystem "unknown" does not support resize.
2025-02-17 - 11:47:42 [6]:     ..  Checking if "/dev/nvme1n1p2" can be replaced.
2025-02-17 - 11:47:42 [6]:     ..  Partition "/dev/nvme1n1p3" authorized for resize + autopartition install.
2025-02-17 - 11:47:42 [6]:     .. contains resizable "/dev/nvme1n1p3"
2025-02-17 - 11:47:42 [6]:     ..  Checking if "/dev/nvme1n1p3" can be replaced.
2025-02-17 - 11:47:42 [6]:     ..  Partition "/dev/nvme1n1p3" authorized for replace install.
2025-02-17 - 11:47:42 [6]:     .. contains replaceable "/dev/nvme1n1p3"
2025-02-17 - 11:47:42 [6]:     ..  Partition "/dev/nvme1n1p4" authorized for resize + autopartition install.
2025-02-17 - 11:47:42 [6]:     .. contains resizable "/dev/nvme1n1p4"
2025-02-17 - 11:47:42 [6]:     ..  Checking if "/dev/nvme1n1p4" can be replaced.
2025-02-17 - 11:47:42 [6]:     ..  Partition "/dev/nvme1n1p4" authorized for replace install.
2025-02-17 - 11:47:42 [6]:     .. contains replaceable "/dev/nvme1n1p4"
2025-02-17 - 11:47:42 [6]: void ChoicePage::updateActionDescriptionsTr()
2025-02-17 - 11:47:42 [6]:     Setting texts for 0 osprober entries
2025-02-17 - 11:47:42 [6]: void ChoicePage::continueApplyDeviceChoice()
2025-02-17 - 11:47:42 [6]:     Previous device 0 new device 1
2025-02-17 - 11:47:42 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-17 - 11:47:42 [6]:     InstallChoice Config::Erase "erase"
2025-02-17 - 11:47:42 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2025-02-17 - 11:47:42 [6]:     CreatePartitionTableJob::createTable trying to make table for device "/dev/nvme1n1"
2025-02-17 - 11:47:43 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5f41cb274040) without calling endResetModel first
2025-02-17 - 11:47:43 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5f41cb274040) without calling beginResetModel first
2025-02-17 - 11:47:43 [6]: void PartitionCoreModule::dumpQueue() const
2025-02-17 - 11:47:43 [6]:     # Queue:
2025-02-17 - 11:47:43 [6]:     .. ## Device: "/dev/nvme0n1"
2025-02-17 - 11:47:43 [6]:     .. ## Device: "/dev/nvme1n1"
2025-02-17 - 11:47:43 [6]:     .. - CreatePartitionTableJob
2025-02-17 - 11:47:43 [6]:     .. - CreatePartitionJob
2025-02-17 - 11:47:43 [6]:     .. - SetPartFlagsJob
2025-02-17 - 11:47:43 [6]:     .. ## Device: "/dev/sda"
2025-02-17 - 11:47:43 [6]:     .. ## Device: "/dev/sdb"
2025-02-17 - 11:47:43 [6]:     .. ## Device: "/dev/sdc"
2025-02-17 - 11:47:43 [6]:     .. ## Device: "/dev/sdd"
2025-02-17 - 11:47:43 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-17 - 11:47:43 [6]:     Updating partitioning preview widgets.
2025-02-17 - 11:47:44 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2025-02-17 - 11:47:44 [6]:     InstallChoice Config::Manual "manual"
2025-02-17 - 11:47:44 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2025-02-17 - 11:47:44 [6]:     Updating partitioning preview widgets.
2025-02-17 - 11:47:44 [6]: DEBUG (Qt): getting temp failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:44 [6]: DEBUG (Qt): getting powered on time failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:44 [6]: DEBUG (Qt): getting power cycles failed for  "/dev/nvme1n1" :  No such file or directory
2025-02-17 - 11:47:44 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p1"
2025-02-17 - 11:47:44 [2]: WARNING (Qt): unknown file system type  ""  on  "/dev/nvme1n1p2"
2025-02-17 - 11:47:44 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5f41cb274040) without calling endResetModel first
2025-02-17 - 11:47:44 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5f41cb274040) without calling beginResetModel first
2025-02-17 - 11:47:45 [2]: WARNING (Qt): beginResetModel called on BootLoaderModel(0x5f41cb274040) without calling endResetModel first
2025-02-17 - 11:47:45 [2]: WARNING (Qt): endResetModel called on BootLoaderModel(0x5f41cb274040) without calling beginResetModel first
2025-02-17 - 11:47:45 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
2025-02-17 - 11:47:45 [6]:     No path to restore, choosing default
2025-02-17 - 11:47:45 [6]: virtual void PartitionViewStep::next()
2025-02-17 - 11:47:45 [6]:     Choice applied:  Config::Manual
When the newer official images are expected to be released?
[Stable Update] 2025-02-04
This will start the development cycle of Manjaro 25.0 we code-named Zetar. Most likely the stable installer ISOs will be available in Mid-March featuring Plasma 6.3, GNOME 48 and XFCE 4.20
