Buzzing sound with my HyperX Cloud II wireless headset
Hello penguins,
I’m having an annoying issue with my new headset. (It’s fully working in Windows 10, so no RMA needed)
I keep hearing a buzzing sound for few seconds after a sound is played.
For example, when I listen to a song and I stop the music, I hear a buzzing sound for about 6 seconds~ Same with a game loading screen or a voice call.
I have the exact same headset in wired mode, and I don’t hear the buzzing sound at all. So maybe it’s the wireless 2.4Gz dongle that is having an issue with linux ? Any of you had this problem before ?
I’m on the LInux5.10.56-1 kernel and I use KDE plasma ^^
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. USB wired or Audoio Jack wired?
  4. The output of pacmd list would be helpful as well.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
Hello Fabby and sorry for the delay ^^’
I can’t modify my message… when I click the “edit” icon, it leads me to the edit history and I can’t do anything from there.
The one not making a buzzing sound is a audio jack one :3
I tried another linux distro (popOS) and it also had the exact same problem :c
Here is the inix output ^^
  Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=2ac65666-d0c8-40f6-b520-3903e717fccb rw quiet apparmor=1
  security=apparmor resume=UUID=c82bf3a0-6939-4b1c-bd6e-cc758d6cdced
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: Z490 AORUS ELITE AC v: x.x
  serial: <filter> UEFI: American Megatrends v: F4 date: 06/17/2020
  RAM: total: 31.27 GiB used: 4.45 GiB (14.2%)
  Info: 10-Core model: Intel Core i9-10850K bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 5 microcode: EC
  cache: L2: 20 MiB bogomips: 144040
  Speed: 885 MHz min/max: 800/5200 MHz Core speeds (MHz): 1: 885 2: 1714
  3: 2503 4: 811 5: 2043 6: 800 7: 845 8: 4688 9: 2487 10: 4138 11: 4225
  12: 3367 13: 4113 14: 1718 15: 1983 16: 4290 17: 3007 18: 4755 19: 4478
  20: 1631
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M]
  vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 03:00.0
  chip-ID: 1002:73ff class-ID: 0300
  Device-2: HTC (High Tech ) Vive type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-4.1.2:39 chip-ID: 0bb4:2c87 class-ID: 0102
  loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
  s-diag: 1055mm (41.5")
  Monitor-1: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 94
  size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
  Monitor-2: DisplayPort-2 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8")
  diag: 609mm (24")
  OpenGL:
  renderer: AMD DIMGREY_CAVEFISH (DRM 3.41.0 5.13.13-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
  chip-ID: 8086:06c8 class-ID: 0403
  Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
  driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28
  class-ID: 0403
  Device-3: Kingston HyperX Cloud II Wireless type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:4 chip-ID: 0951:1718
  class-ID: 0300 serial: <filter>
  Device-4: HTC (High Tech ) Vive type: USB driver: snd-usb-audio,uvcvideo
  Device-5: HTC (High Tech ) Vive type: USB driver: hid-generic,usbhid
  bus-ID: 1-4.1.5:35 chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
  port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:16 chip-ID: 8087:0aaa class-ID: e001
  Report: hciconfig ID: hci1 rfk-id: 2 state: down bt-service: enabled,running
  rfk-block: hardware: no software: yes address: <filter>
  Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
  link-mode: slave accept
  Report-ID: ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  rfk-block: hardware: no software: no address: <filter>
  Info: acl-mtu: 0:0 sco-mtu: 0:0 link-mode: slave accept
  Local Storage: total: 4.09 TiB used: 1.81 TiB (44.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
  model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
  rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
  rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500BX100SSD1
  type: SSD serial: <filter> rev: MU02 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM008-2DM166
  size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
  ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
  used: 104.45 GiB (23.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
  label: N/A uuid: 2ac65666-d0c8-40f6-b520-3903e717fccb
  used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
  label: NO_LABEL uuid: 1593-C23B
  ID-3: /mnt/Gaming raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
  used: 392.61 GiB (85.8%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:2
  label: Gaming uuid: 7cd964ff-5518-4a12-9b28-225e20a33bd4
  ID-4: /mnt/TBM raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
  used: 1.33 TiB (48.6%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
  label: That big MTF uuid: A00A0B070A0AD9E4
  dev: /dev/nvme0n1p3 maj-min: 259:5 label: swap
  uuid: c82bf3a0-6939-4b1c-bd6e-cc758d6cdced
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 465.75 GiB fs: ntfs label: N/A
  uuid: 14462DFF462DE26A
  ID-3: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-4:2 info: HTC (High Tech ) CB USB2 ports: 4 rev: 2.1
  speed: 480 Mb/s chip-ID: 0bb4:2210 class-ID: 0900
  Hub-3: 1-4.1:33 info: HTC (High Tech ) Vive Hub (SMSC USB2137B) ports: 7
  rev: 2.1 speed: 480 Mb/s chip-ID: 0bb4:2134 class-ID: 0900
  Device-1: 1-4.1.1:38 info: Valve Lighthouse FPGA RX type: HID
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 28de:2000 class-ID: 0300 serial: <filter>
  Device-2: 1-4.1.2:39 info: HTC (High Tech ) Vive type: Video,Audio
  driver: snd-usb-audio,uvcvideo interfaces: 6 rev: 2.0 speed: 480 Mb/s
  power: 500mA chip-ID: 0bb4:2c87 class-ID: 0102
  Device-3: 1-4.1.3:34 info: Valve Watchman Dongle type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 20mA
  chip-ID: 28de:2101 class-ID: 0300 serial: <filter>
  Device-4: 1-4.1.5:35 info: HTC (High Tech ) Vive type: HID
  power: 500mA chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
  Device-5: 1-4.1.6:36 info: Valve Watchman Dongle type: HID
  Device-6: 1-4.1.7:37 info: Valve Watchman Dongle type: HID
  Device-7: 1-4.2:8
  info: HTC (High Tech ) Vive Hub Bluetooth 4.1 (Broadcom BCM920703) type: Hub
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0bb4:0306
  Hub-4: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 1-6.2:6 info: Logitech G502 Proteus Spectrum Optical Mouse
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
  serial: <filter>
  Device-2: 1-10:4 info: Kingston HyperX Cloud II Wireless type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 0951:1718 class-ID: 0300
  serial: <filter>
  Hub-5: 1-11:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-11.2:11 info: Razer USA BlackWidow Chroma type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1532:0203 class-ID: 0300
  Device-2: 1-11.3:14 info: Valve Watchman Dongle type: HID
  Device-3: 1-11.4:17 info: Valve Watchman Dongle type: HID
  Device-4: 1-12:20 info: Integrated Express ITE Device type: HID
  power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Hub-6: 1-13:13 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-13.4:18 info: Corsair Lighting Node Pro type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
  chip-ID: 1b1c:0c0b class-ID: 0300 serial: <filter>
  Device-2: 1-14:16 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-7: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  System Temperatures: cpu: 42.0 C mobo: 16.8 C gpu: amdgpu temp: 58.0 C
  mem: 60.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 400 Uptime: 35m wakeups: 4 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1314 lib: 378 flatpak: 0 Shell: Zsh
  v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
    ~  inxi --admin --verbosity=7 --filter --no-host --width         ✔
  udev.log_priority=3
  RAM: total: 31.27 GiB used: 3.78 GiB (12.1%)
  Speed: 3723 MHz min/max: 800/5200 MHz Core speeds (MHz): 1: 3723 2: 4802
  3: 4801 4: 4800 5: 3466 6: 4679 7: 3639 8: 2678 9: 3147 10: 2766 11: 4800
  12: 2702 13: 4550 14: 4801 15: 4628 16: 4800 17: 4800 18: 4502 19: 2214
  20: 4309
  diag: 609mm (24")
  OpenGL:
  class-ID: 0403
  rev: 2B2QEXM7 temp: 43.9 C scheme: GPT
  Device-7: 1-4.2:8
  serial: <filter>
  Device-2: 1-9:42 info: Nintendo Switch Pro Controller type: HID
  power: 500mA chip-ID: 057e:2009 class-ID: 0300 serial: <filter>
  Device-3: 1-10:4 info: Kingston HyperX Cloud II Wireless type: Audio,HID
  serial: <filter>
  System Temperatures: cpu: 43.0 C mobo: 16.8 C gpu: amdgpu temp: 55.0 C
  mem: 58.0 C
Thanks for helping ^^
You can only edit for 5 days or so… Just post it as a reply.
That’s because you didn’t do this:
Thank me after I’ve resolved your issue!
:stuck_out_tongue_winking_eye:
