I meant "The issue occurred once again,’ which I have just edited to. Sorry I was not sure what information to provide; although perhaps I could have tried more to search for solutions.
I am using kernel 5.10.15-1.
[jr@fm ~]$ inxi -Fxxx
System: Host: fm Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF B450M-PLUS GAMING v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 1002 date: 03/07/2019
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ rev: 2 L2 cache: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118222
Speed: 2177 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2177 2: 2171 3: 4341 4: 2170 5: 4340
6: 2169 7: 2170 8: 2168 9: 4340 10: 2170 11: 4341 12: 2170 13: 2171 14: 2170 15: 2879 16: 2164
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: ASUSTeK driver: nvidia v: 460.39 bus ID: 07:00.0
chip ID: 10de:1e82 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz s-dpi: 93
OpenGL: renderer: GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
Audio: Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 10de:10f8
class ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 09:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-4:3 chip ID: 046d:0825
class ID: 0102 serial: 8D1EA6E0
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: f000
bus ID: 05:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 40:b0:76:5c:8c:4c
Drives: Local Storage: total: 465.76 GiB used: 44.37 GiB (9.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: S4EVNG0M116780W rev: 1B2QEXM7 temp: 36.9 C scheme: GPT
Partition: ID-1: / size: 109.37 GiB used: 44.35 GiB (40.5%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 299.4 MiB used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 44.5 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Info: Processes: 346 Uptime: 3d 22h 27m wakeups: 637 Memory: 62.81 GiB used: 14.95 GiB (23.8%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1433 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01
[jr@fm ~]$
I will check to see if there are any BIOS updates, but I have not made any.
[jr@fm ~]$ systemctl --user -l --no-pager status pipewire*
● pipewire.socket - Multimedia System
Loaded: loaded (/usr/lib/systemd/user/pipewire.socket; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-02-22 14:08:20 AEDT; 3 days ago
Triggers: ● pipewire.service
Listen: /run/user/1000/pipewire-0 (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.socket
Feb 22 14:08:20 fm systemd[1345]: Listening on Multimedia System.
● pipewire.service - Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: active (running) since Mon 2021-02-22 16:35:27 AEDT; 3 days ago
TriggeredBy: ● pipewire.socket
Main PID: 23556 (pipewire)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pipewire.service
├─23556 /usr/bin/pipewire
└─23558 /usr/bin/pipewire-media-session
Feb 22 16:35:27 fm systemd[1345]: Started Multimedia Service.
[jr@fm ~]$
[jr@fm ~]$ systemctl --user -l --no-pager status pulseaudio*
● pulseaudio.socket - Sound System
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; vendor preset: enabled)
Triggers: ● pulseaudio.service
Listen: /run/user/1000/pulse/native (Stream)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.socket
Feb 22 14:08:20 fm systemd[1345]: Listening on Sound System.
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
Active: active (running) since Wed 2021-02-24 22:39:21 AEDT; 1 day 13h ago
TriggeredBy: ● pulseaudio.socket
Main PID: 275841 (pulseaudio)
CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/pulseaudio.service
├─275841 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─276614 /usr/lib/pulse/gsettings-helper
Feb 24 22:39:18 fm systemd[1345]: Starting Sound Service...
Feb 24 22:39:21 fm systemd[1345]: Started Sound Service.
Feb 24 22:39:43 fm pulseaudio[275841]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
[jr@fm ~]$
Ignore this:
Installed bluez
. Currently it is working with the speakers.
Sorry, it was actually already installed, I just reinstalled it.
Similar issue with Centos:
https://bugs.centos.org/view.php?id=17796
https://www.ecosia.org/search?q=failed+to+activate+service+'org.bluez'%3A+timed+out+(service_start_timeout%3D25000ms)
Found this issue, not the same but the debugging could help:
[jr@fm ~]$ sudo systemctl status dbus-org.bluez.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Feb 22 14:08:21 fm systemd[1]: Condition check resulted in Bluetooth service being skipped.
Feb 23 18:58:03 fm systemd[1]: Condition check resulted in Bluetooth service being skipped.
Feb 23 21:03:34 fm systemd[1]: Condition check resulted in Bluetooth service being skipped.
Feb 24 22:39:18 fm systemd[1]: Condition check resulted in Bluetooth service being skipped.
Oh, bluez is just a Bluetooth stack
[jr@fm ~]$ cat /usr/lib/systemd/user/pulseaudio.service
[Unit]
Description=Sound Service
# We require pulseaudio.socket to be active before starting the daemon, because
# while it is possible to use the service without the socket, it is not clear
# why it would be desirable.
# A user installing pulseaudio and doing `systemctl --user start pulseaudio`
# will not get the socket started, which might be confusing and problematic if
# the server is to be restarted later on, as the client autospawn feature
# might kick in. Also, a start of the socket unit will fail, adding to the
# confusion.
# After=pulseaudio.socket is not needed, as it is already implicit in the
# socket-service relationship, see systemd.socket(5).
Requires=pulseaudio.socket
ConditionUser=!root
[Service]
ExecStart=/usr/bin/pulseaudio --daemonize=no --log-target=journal
LockPersonality=yes
MemoryDenyWriteExecute=yes
NoNewPrivileges=yes
Restart=on-failure
RestrictNamespaces=yes
SystemCallArchitectures=native
SystemCallFilter=@system-service
# Note that notify will only work if --daemonize=no
Type=notify
UMask=0077
[Install]
Also=pulseaudio.socket
WantedBy=default.target
[jr@fm ~]$ systemctl --user enable pulseaudio
Created symlink /home/jr/.config/systemd/user/default.target.wants/pulseaudio.service → /usr/lib/systemd/user/pulseaudio.service.
Created symlink /home/jr/.config/systemd/user/sockets.target.wants/pulseaudio.socket → /usr/lib/systemd/user/pulseaudio.socket.
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2021-02-24 22:39:21 AEDT; 1 day 14h ago
[jr@fm ~]$
Note this line: Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; vendor preset: enabled)
. It’s now enabled, was disabled before. Hopefully that will fix the issue.
