You should consider updating BIOS for this motherboard
Asus website is showing 13 BIOS updates released since the version shown on your system
https://www.asus.com/Motherboards-Components/Motherboards/All-series/TUF-B450M-PLUS-GAMING/HelpDesk_BIOS/
OK just trying to figure out how to update. The files that I downloaded from that page extracts as an exe and cap files. I installed fwupd but I can’t run it from the command line with fwupd
and I don’t see a GUI program for it.
I can’t see TUF B450M-PLUS GAMING on that asrock site.
Nevermind, I see fwupd - ArchWiki now.
You posted system information on another discussion, that is showing both PulseAudio and Pipewire are active
You can choose either:
(KDE requires pipewire base package so uninstalling it is not possible for this DE)
OR
- Install
manjaro-pipewire
metapackage to get the additional dependency files for Pipewire to replace PulseAudio
Thanks, however, pipewire is not running now:
Sound Server-4: PipeWire v: 0.3.24 running: no
[jr@fm ~]$ inxi -Fxxx
System: Host: fm Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF B450M-PLUS GAMING v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 1002 date: 03/07/2019
Battery: Device-1: hidpp_battery_2 model: Logitech Wireless Mouse M315/M235 serial: 4009-26-6d-cc-a7
charge: 55% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ rev: 2 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118221
Speed: 2119 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2119 2: 2120 3: 4234 4: 4234 5: 3071
6: 2179 7: 2182 8: 2194 9: 4234 10: 4147 11: 2226 12: 2169 13: 2144 14: 2146 15: 2121 16: 2136
Graphics: Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: ASUSTeK driver: nvidia v: 460.67 bus-ID: 07:00.0
chip-ID: 10de:1e82 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2 chip-ID: 046d:0825
class-ID: 0102 serial: 8D1EA6E0
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia resolution: 1: 1920x1080~60Hz
2: 1920x1080~60Hz s-dpi: 94
OpenGL: renderer: GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.67 direct render: Yes
Audio: Device-1: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 10de:10f8
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2 chip-ID: 046d:0825
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 40:b0:76:5c:8c:4c
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu bus-ID: 5-2:2 chip-ID: 0bda:b812
class-ID: 0000 serial: 123456
IF: wlp8s0f3u2 state: up mac: bc:ec:23:c3:54:e2
Drives: Local Storage: total: 465.76 GiB used: 69.85 GiB (15.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB size: 465.76 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: S4EVNG0M116780W rev: 1B2QEXM7 temp: 37.9 C scheme: GPT
Partition: ID-1: / size: 109.37 GiB used: 69.83 GiB (63.8%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 299.4 MiB used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: file size: 256 MiB used: 202.6 MiB (79.1%) priority: 50 file: /var/lib/systemd-swap/swapfc/1
ID-2: swap-2 type: file size: 256 MiB used: 168.7 MiB (65.9%) priority: 49 file: /var/lib/systemd-swap/swapfc/2
ID-3: swap-3 type: file size: 256 MiB used: 28.5 MiB (11.1%) priority: 48 file: /var/lib/systemd-swap/swapfc/3
ID-4: swap-4 type: file size: 256 MiB used: 55.7 MiB (21.7%) priority: 47 file: /var/lib/systemd-swap/swapfc/4
ID-5: swap-5 type: file size: 256 MiB used: 33.1 MiB (12.9%) priority: 46 file: /var/lib/systemd-swap/swapfc/5
ID-6: swap-6 type: file size: 256 MiB used: 38.3 MiB (15.0%) priority: 45 file: /var/lib/systemd-swap/swapfc/6
ID-7: swap-7 type: file size: 256 MiB used: 165.3 MiB (64.6%) priority: 44 file: /var/lib/systemd-swap/swapfc/7
ID-8: swap-8 type: file size: 256 MiB used: 26.5 MiB (10.4%) priority: 43 file: /var/lib/systemd-swap/swapfc/8
ID-9: swap-9 type: file size: 256 MiB used: 672 KiB (0.3%) priority: 42 file: /var/lib/systemd-swap/swapfc/9
ID-10: swap-10 type: file size: 256 MiB used: 83.4 MiB (32.6%) priority: 41 file: /var/lib/systemd-swap/swapfc/10
ID-11: swap-11 type: file size: 256 MiB used: 60.9 MiB (23.8%) priority: 40 file: /var/lib/systemd-swap/swapfc/11
ID-12: swap-12 type: file size: 256 MiB used: 81 MiB (31.7%) priority: 39 file: /var/lib/systemd-swap/swapfc/12
ID-13: swap-13 type: file size: 256 MiB used: 65.7 MiB (25.7%) priority: 38 file: /var/lib/systemd-swap/swapfc/13
ID-14: swap-14 type: file size: 256 MiB used: 50.2 MiB (19.6%) priority: 37 file: /var/lib/systemd-swap/swapfc/14
ID-15: swap-15 type: file size: 256 MiB used: 115 MiB (44.9%) priority: 36 file: /var/lib/systemd-swap/swapfc/15
ID-16: swap-16 type: file size: 256 MiB used: 69.7 MiB (27.2%) priority: 35 file: /var/lib/systemd-swap/swapfc/16
ID-17: swap-17 type: file size: 256 MiB used: 48.2 MiB (18.8%) priority: 34 file: /var/lib/systemd-swap/swapfc/17
ID-18: swap-18 type: file size: 256 MiB used: 69.1 MiB (27.0%) priority: 33 file: /var/lib/systemd-swap/swapfc/18
ID-19: swap-19 type: file size: 256 MiB used: 162.3 MiB (63.4%) priority: 32 file: /var/lib/systemd-swap/swapfc/19
ID-20: swap-20 type: file size: 256 MiB used: 73.1 MiB (28.6%) priority: 31 file: /var/lib/systemd-swap/swapfc/20
ID-21: swap-21 type: file size: 256 MiB used: 74.5 MiB (29.1%) priority: 30 file: /var/lib/systemd-swap/swapfc/21
ID-22: swap-22 type: file size: 256 MiB used: 132.8 MiB (51.9%) priority: 29 file: /var/lib/systemd-swap/swapfc/22
ID-23: swap-23 type: file size: 256 MiB used: 57.9 MiB (22.6%) priority: 28 file: /var/lib/systemd-swap/swapfc/23
ID-24: swap-24 type: file size: 256 MiB used: 5.5 MiB (2.1%) priority: 27 file: /var/lib/systemd-swap/swapfc/24
ID-25: swap-25 type: file size: 256 MiB used: 8.9 MiB (3.5%) priority: 26 file: /var/lib/systemd-swap/swapfc/25
ID-26: swap-26 type: file size: 256 MiB used: 110.2 MiB (43.1%) priority: 25 file: /var/lib/systemd-swap/swapfc/26
ID-27: swap-27 type: file size: 256 MiB used: 75.8 MiB (29.6%) priority: 24 file: /var/lib/systemd-swap/swapfc/27
Sensors: System Temperatures: cpu: 47.5 C mobo: 0 C gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Info: Processes: 360 Uptime: 14d 10h 29m wakeups: 975 Memory: 62.81 GiB used: 37.1 GiB (59.1%) Init: systemd v: 247
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1480 Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.04
[jr@fm ~]$
However, I ran that command as you suggested.
