Btrfs system crash, howto recover?
As this is the daily laptop of my partner. What would you recommend: which fs to use?
She’d like to just use the laptop without thinking to much about tech background, but with an easy possibility of restoring a snapshot when needed.
I thought that btrfs would be nice for that, but that may be my mistake.
Any other recommendations?
If you don’t know or even want to know
(that’s not a problem - just a practical evaluation …)
the intricacies of BTRFS …
don’t use it.
especially if it is not your own system, but someone elses
ext4 is much easier to handle
If a file system fills up near 100%
there is always going to be problems.
Whether you’d
or not.
Choose ext4.
BTRFS (and it’s maintenance) is just very different
Yes, we’d been speaking for some time now that she needs to delete some stuff from her laptop as it was filling up. But well, as you know, life came in between and she had started but not removed a significant chunk. Well, I guess now she learned not to wait :wink:
edit: and we might buy a new bigger internal ssd :slight_smile:
I would not burden myself or you or her or you with that.
Just choose ext4 next time - the impact won’t be so severe - and the learning curve not so steep.
… who want’s to keep track of the percentage the file system is used … ?
You probably should need to have had a good reason to set her up with that file system …
True.
After finishing the backup, I am considering even wiping her ssd and reinstalling.
As said above, I was looking for a robust system which had easy snapshots rollbacks. Ext4 doesn’t have that the way btrfs can provide.
What about other fs like f2fs or XFS or ZFS?
I would not know.
But:
I would not subscribe to that - that is either just wrong - or colored by opinion/prejudice.
… what did you expect from BTRFS which ext4 could not provide? …
Easy on the fly snapshots of system (@) which doesn’t cost a lot of extra space, to be able to rollback if some update goes wrong.
… and that’s not possible with ext4 ?
even if it wasn’t:
How is that helping her?
… not suspecting quite serious problems when filling up the file system up to the brim? :nerd_face:
… use a file system that you can easily manage
in this case, for ext4, the remedy would have been:
tune2fs -m 1 /dev/sdxy
and you’d have instantly had 4% more usable space
I am not sure what you are implying here.
It is already clear that having an almost full system is not a good thing. Everybody learns from it for the future.
you are not?
hopefully
I backuped and removed her music folder. That saves 107GB. :slight_smile:
ok, got it. thanks
Sure?
Whatever the case.
Don’t use BTRFS unless you understand it.
I confess:
I don’t.
That is why I do not use it.
Well, don’t we all learn by doing or using something?
And helping each other in learning more?
Thanks @andreas85, your contribution has helped a lot to understand the out-of-space situation.
After backup and removing the music folder, the laptop booted back into the system.
The kernels had no problems: 6.8 and 6.10 both booted fine.
hopefully
even:
certiainly :man_shrugging:
Well i don’t wrote Rsync recommendation this time… because i was thinking that he maybe wants exactly this.
On the otherside, he has no way to restore his system with a simple rollback now.
The valid question is now… was it worth to use Timeshift this way?
I think its a clear no, but on the otherside he saved time to create snapshots… Snapshots where he can’t rely on it now.
You are not the first one who run into this exact problem, where your (BTRFS/Rootstored) Snapshots are gone now.
Its exactly as @anon33601770 wrote here:
BTRFS is a advanced filesystem, use it only if you know what you doing.
@Molski That doesn’t mean that im against BTRFS or in a war against this Filesystem, the user just should get his homework done before he start using it and if the user isn’t willing to do this, BTRFS shouldn’t be recommend then to this user.
And i saw you get caught on surprise recently in another BTRFS Topic, where you didn’t know that repairing a file with FSCK can lead to even more dangerous situation, when the whole BTRFS Partition is in the read mode. (if i understand that recently topic, correctly).
@Kobold Well, in the end it turned out it wasn’t about timeshift, so I couldn’t check if the rollback actually works. As andreas85 explained correctly it was the out-of-space problem, where while thinking 12,3GB was available, there was not. After solving that, the system booted fine.
So, lessons learned about btrfs :slight_smile:
Pamac Cache (default is the last 3 version) you can reduce it to 1, this saved also a good amount of space.
Besides the shorter snapshot time creation (because they consume less space), Timeshift with Rsync on EXT4 is more reliable and its more easy to restore.
This cannot be an assumption. I thought of course when I researched filesystems I did my homework: But somehow haven’t come accross the out-of-space issue of btrfs at that time.
