Hi all.
I just updated a kde btrfs system (stable) with the latest updates and activated a new kernel (6.6->6.10) on my Samsung 900x3c.
I noticed it also started to update some aur stuff, which were orphans and things I never use. I deleted the few orphans and at the next boot suddenly the system is not booting anymore. Oops, did I remove something that I shouldn’t have?
It shows:
[FAILED] Failed to start Load/Save OS Random Seed, Create System Users, Record System Boot/Shutdown in UTMP, Rebuild Journal Catalog, Rebuid Dynamic Linker Cache, Update is completed, pkgfile database update, Samba NMB and SMB Deamon and Failed to listen on GnuPG …
So, I tried in Grub to boot a timeshift snapshot, but that also doesn’t work: I get similar but also different error messages.
Not all snapshots were visible, so I booted into the live USB and restored a snapshot in timeshift.
No luck either…
In the end I backupped important stuff in @home, and tried to run the calamares installer on top of the system without erasing anything. Calamares said it cannot mount.
So, how can I repair this?
Either boot in a snapshot or reinstall while keeping the @home folder?
Thanks for helping!
edit:
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2407 quiet systemd.show_status=1
splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: SAMSUNG product: 900X3C/900X3D/900X4C/900X4D v: 0.1
serial: <filter> Chassis: type: 9 v: 0.1 serial: <filter>
Mobo: SAMSUNG model: SAMSUNG_NP1234567890 v: FAB1 serial: <filter>
uuid: 19759a60-1dd2-11b2-8000-aa8ca0b6e579 UEFI-[Legacy]: Phoenix v: P07AAC
date: 11/18/2013
ID-1: BAT1 charge: 27.4 Wh (100.0%) condition: 27.4/40.3 Wh (68.0%)
volts: 8.2 min: 7.4 model: SAMSUNG Electronics type: Li-ion serial: N/A
status: full cycles: 1742
System RAM: total: 4 GiB available: 3.53 GiB used: 2.19 GiB (61.9%)
igpu: 64 MiB
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 2 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5674BM0-CK0 serial: N/A
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 2 GiB
Device-4: ChannelB-DIMM1 type: no module installed
Slot: 0 type: PCIe status: available length: long volts: 3.3 bus-ID: 00:00.0
Slot: 1 type: PCIe gen: 1 status: in use length: short volts: 3.3
bus-ID: 00:00.0
Slot: 2 type: PCIe gen: 2 status: available length: short volts: 3.3
bus-ID: 00:00.0
Slot: 3 type: PCIe gen: 3 status: available length: short volts: 3.3
bus-ID: 00:00.0
Slot: 4 type: PCIe gen: 4 status: in use length: short volts: 3.3
bus-ID: 00:00.0
Slot: 5 type: PCIe gen: 5 status: in use length: short volts: 3.3
bus-ID: 00:00.0
Info: model: Intel Core i5-3317U socket: rPGA988B (U3E1) note: check bits: 64
type: MT MCP arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15
process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9
microcode: 0x17
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 814 high: 859 min/max: 800/2600 base/boost: 1700/1700
scaling: driver: intel_cpufreq governor: schedutil volts: 0.8 V
ext-clock: 100 MHz cores: 1: 859 2: 800 3: 800 4: 800 bogomips: 13575
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority fpu fsgsbase fxsr ht ida lahf_lm lm mca mce
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sep smep
ss sse sse2 sse4_1 sse4_2 ssse3 syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
class-ID: 0300
Device-2: Silicon Motion Webcam SC-13HDL11624N [Namuga ] driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:3
chip-ID: 2232:1024 class-ID: 0e02 serial: <filter>
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: Seiko Epson 0x3546 built: 2011 res: 1600x900 hz: 60
dpi: 139 gamma: 1.2 chroma: red: x: 0.592 y: 0.341 green: x: 0.329 y: 0.541
blue: x: 0.153 y: 0.133 white: x: 0.314 y: 0.329
size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
modes: 1600x900
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
device-ID: 8086:0166 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 4000 (IVB GT2) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:0166 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
Device-1: Qualcomm Atheros AR928X Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 168c:002a class-ID: 0280
vendor: Samsung Co driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 495.06 GiB used: 445.19 GiB (89.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO mSATA 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 40 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 266d 19h cycles: 4757
written: 17.81 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Generic model: Flash Disk
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 8.07
scheme: GPT
ID-1: /run/media/manjaro/spiffy raw-size: 457.97 GiB
size: 457.97 GiB (100.00%) used: 445.19 GiB (97.2%) fs: btrfs
block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: spiffy
uuid: 9efe6e2e-7355-4b52-8b47-b545e67ae8c5
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.64 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 7.79 GiB fs: swap label: N/A
uuid: 90a910e5-a181-45e1-a749-47ce5ddc0aab
ID-3: /dev/sdb1 maj-min: 8:17 size: 29.26 GiB fs: exfat label: Ventoy
uuid: 4E21-0000
ID-4: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 3F32-27F5
Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.6:3 info: Silicon Motion Webcam SC-13HDL11624N [Namuga ]
type: video driver: uvcvideo interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 2-1:2 info: Alcor Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Hub-4: 3-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 62.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1260 libs: 333 tools: pamac pm: flatpak pkgs: 0
1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
3: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
5: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
6: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
7: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
8: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
9: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
10: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://mirrors.manjaro.org/repo/stable/$repo/$arch
12: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
13: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
14: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
16: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
17: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
18: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
19: https://mirror.init7.net/manjaro/stable/$repo/$arch
20: https://mirror.seahost.de/manjaro/stable/$repo/$arch
21: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
22: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
23: http://manjaro.grena.ge/stable/$repo/$arch
24: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
25: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
27: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
28: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirrors2.manjaro.org/stable/$repo/$arch
30: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
31: https://mirror.zetup.net/manjaro/stable/$repo/$arch
32: https://manjaro.ynh.ovh/stable/$repo/$arch
33: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
34: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
35: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
36: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
37: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
38: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
40: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
41: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
42: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
43: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
44: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
45: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
46: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
48: https://mirror.23m.com/manjaro/stable/$repo/$arch
49: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
50: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
51: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
52: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
53: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
54: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
55: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
56: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
57: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
58: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
59: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
60: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
61: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
62: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
63: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
64: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
65: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
66: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
67: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
68: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
69: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
70: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
71: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
72: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
73: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
74: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
75: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
76: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
77: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
78: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
79: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
80: https://mirror.funami.tech/manjaro/stable/$repo/$arch
81: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
82: https://linorg.usp.br/manjaro/stable/$repo/$arch
83: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
84: https://mirrors.netix.net/manjaro/stable/$repo/$arch
85: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
86: http://manjaro.mirror.ac.za/stable/$repo/$arch
87: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
88: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
89: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
90: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
91: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
92: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
93: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
94: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
95: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
96: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
97: https://mirror.koddos.net/manjaro/stable/$repo/$arch
98: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
99: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
100: https://muug.ca/mirror/manjaro/stable/$repo/$arch
101: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
102: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
103: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
104: https://mirror.easyname.at/manjaro/stable/$repo/$arch
105: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
106: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
107: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
108: https://manjaro.kurdy.org/stable/$repo/$arch
109: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
110: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
111: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
112: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
113: https://repos.silknet.com/manjaro/stable/$repo/$arch
114: https://mirror.dc.uz/manjaro/stable/$repo/$arch
115: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
116: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
117: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
118: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
119: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
120: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
121: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
122: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
123: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
124: http://mirror.fcix.net/manjaro/stable/$repo/$arch
125: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
126: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
127: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
128: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
129: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
130: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
131: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 212
1: cpu: 62.7% command: firefox pid: 2530 mem: 386.4 MiB (10.6%)
2: cpu: 50.0% command: ps pid: 3197 mem: 3.38 MiB (0.0%)
3: cpu: 14.2% command: konsole pid: 3129 mem: 118.8 MiB (3.2%)
4: cpu: 12.2% command: firefox pid: 2784 mem: 241.6 MiB (6.6%)
5: cpu: 6.7% command: zsh pid: 3143 mem: 7.81 MiB (0.2%)
Memory top: 5 of 212
1: mem: 386.4 MiB (10.6%) command: firefox pid: 2530 cpu: 62.7%
2: mem: 300.1 MiB (8.3%) command: plasmashell pid: 1460 cpu: 0.4%
3: mem: 241.6 MiB (6.6%) command: firefox pid: 2784 cpu: 12.2%
4: mem: 164.5 MiB (4.5%) command: kwin_x11 pid: 1427 cpu: 1.0%
5: mem: 130.0 MiB (3.5%) command: firefox pid: 2677 cpu: 1.0%
Processes: 212 Power: uptime: 46m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 1.37 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 256 default: graphical tool: systemctl
Compilers: N/A Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.32
running-in: konsole inxi: 3.3.35
