Btrfs snapshot issue with timeshift-autosnap-manjaro
Hi,
I made a small update of my system, i had updates for inxi, openrazer (from AUR) and system-monitoring-center (also from AUR).
I do not understand how timeshift-autosnap-manjaro managed it but it took me 3 different snapshot, look
Could anybody explain me why 3 different snapshots are needed and now, how to deal with those ?
I do not know what’s inside one or another of the three.
Thanks
You can check diff between two snapshots/subvolumes
 sudo btrfs send --no-data -p {snapshot1} {snapshot2} | sudo btrfs receive --dump | grep 'update_extent\|unlink\|chmod\|chown' | cut -c 17- | cut -d ' ' -f 1 | sort | uniq
You have to set timeshift-path of snapshot in {snapshot}
It can tell you why.
Thanks for your help but I just do NOT want to do that, i use a Timeshift, which is a GUI app. It’s a non-sense to have to play with command line afterwards.
There is probably something wrong with timeshift-autosnap-manjaro.
Does anybody use something else that does not take 3 snapshots instead of one ?
Thanks
I do not use timeshift.
Did you install snap-pac?
I guess that would be the conflict between snap-pac and timeshift-autosnap
You should choose one: snapper or timeshift, not both
Why moderated would i have snap-pac installed ?
I have an out of the box Manjaro btrfs installation
Because you installed btrfs-assistant in the screenshot, it needs the dependence snapper, I thought you would install snap-pac for this.
moderated i do not have it installed
You either want help or not.
My guess is that the three AUR packages are installed sequentially which might produce three snapshots. :person_shrugging:
I understand, it’s quite logical but not really relevant to me as i installed those packages in the same update. Then, i cannot differentiate them :frowning:
I understand your issue. However, I think this has to be changed by the pamac developers to install all packages in one go. (Or at least the AUR packages together.)
To confirm my theory, you should run the helpful command from the post above Btrfs snapshot issue with timeshift-autosnap-manjaro - #2 by Zesko to verify what changed from snapshot to snapshot.
On that matter, it’s hard to implement this correctly. AUR packages are often compiled and therefore the current installed libs are used but after a reboot, the new repo packages are used in combination with the AUR builds with the old packages. It’s not trivial to solve.
The snap is created by a pacman hook which runs when you install or update one or more packages.
When you run multiple actions consequitive there will be multiple calls to trigger the snapshot.
This is unavoidable - if you dislike this - you will have to remove the autosnap feature.
btrfs-assistant is a custom package
One of the reasons to ensure a fully synced system on testing or unstable when using custom packages.
There were 3 installations.
3 snapshots were taken.
Think of it this way: in order to be able to undo an installation from the AUR, each one is done individually (this is best practice).
Everything is OK.
In this case, I can confirm that the package did exactly what it was supposed to do. So there’s no error. There’s no cause for concern.
If this isn’t what you want, you can uninstall the package at any time.
As long as you don’t need to perform a rollback, it’s not necessary to be able to distinguish between these 3 snapshots.
If a rollback should become necessary, I’d be happy to help you differentiate between the 3 (they each have a timestamp and a log entry that distinguishes them).
And to say this in general: Snapshots are inexpensive. They don’t use any disk space. So there’s no reason to be concerned about the additional snapshots. More information about the disk space used by snapshots can be found in the Manjaro wiki under btrfs.
:footprints:
You realise the topic was 4 years old, right? :grinning_cat_with_smiling_eyes:
Yes, but only after i had posted. :rofl:
Ah, but at least you had the last word; oops, no you didn’t. :laughing:
