Btrfs slow read/write speed on nvme
Hello,
i recently bought a Tuxedo Pulse 15 Gen1, with AMD Ryzen™ 7 4800H with Radeon™ Graphics × 16 and 1TB Samsung SSD 980 pro nvme. I installed Manjaro Gnome Stable from ISO, because I would like to use btrfs as my filesystem and the preinstalled system uses ext4.
The laptop supports PCIe 3.0, the nvme even PCIe 4.0, so i would expect PCIe 3.0 speeds. But what I get are read rates under 700MB and write rates about 1.5GB
screenshot1
So I installed a second Manjaro Gnome from the same USB-drive next to the main system with ext4 filesystem and I get mutch higher rates. Read speed about 3.3GB and write speed about 3GB (screenshot2).
screenshot2
I tested both systems with kdiskmark 2.3.0 (appimage). Both systems are up to date. It doesn’t matter if tuxedo-control-center with kernel-headers is installed or not.
Is there a solution to increase the speed of btrfs?
Please let me know if you need any further information.
Best regards
Btrfs is CoW (Copy on write) filesystem that has more features than Ext4, that is why CoW is regularly slower than Non-CoW
But is it realy that much? I mean 645MB compared to 3.3GB … Realy? Can btrfs under no circumstances read more than 645MB per second even on new hardware?
kdiskmark using fio benchmark isn’t in a real world scenario.
I checked cat for reading a large game data 7z 30 GB in two different partitions (Ext4 and Btrfs) in the same Nvme SSD.
Open bash shell in terminal:
Btrfs
$ time cat Game.7z  > /dev/null
real	0m18,430s
user	0m0,045s
sys	0m10,223s
18 sec reading is done
Ext4
real	0m28,873s
user	0m0,053s
sys	0m12,955s
28 sec reading is done
However I don’t understand why.
So in your case btrfs is eaven faster than ext4?
Unfortunately I don’t have a 30GB file, so i tried the Manjaro.iso, witch is only 3.5GB
Btrfs:
ext4:
You can compress many different directories together in one new file.tar
Yes, Btrfs is faster than ext4 on my two different devices when reading the game data 7z.
But I do not notice the difference when using boot time and loading game. (I am using Linux Kernel 5.18)
In my other device:
Btrfs and ext4 in the same nvme SSD without LUKS
Btrfs
real    0m10,877s
user    0m0,042s
sys     0m8,518s
Ext4
real    0m13,300s
user    0m0,029s
sys     0m7,446s
So easy :sweat_smile: Now I feel stupid because I didn’t think of it right away
However, i compressed my biggest folder into a 40.7GB .zip file. Zip because for some reason it went faster than tar.
$ tar -czvf 1.zip ~/Downloads
Well it’s not related to the topic, but is there a possibility to use all 16 cores? Nautilus uses only one core for compressing and the command above also.
Anyway, this is btrfs:
$ time cat 1.zip  > /dev/null
cat 1.zip > /dev/null  0,04s user 23,44s system 94% cpu 24,794 total
And this is ext4:
cat 1.zip > /dev/null  0,05s user 14,95s system 98% cpu 15,190 total
So I’m not shure if I get this right, which place indicates the actual duration?
Thank’s vor helping so far!
@tuxer
Can you show how it is mounted?
mount -t btrfs
mount -t ext4
cat /etc/fstab
Edit: The scheduler can be also a culprit:
grep "" /sys/block/*/queue/scheduler
pamac install pigz
tar --use-compress-program="pigz -k -9" -cf 1.tar.gz ~/Downloads
gzip uses by default only one core, pigz is fully compatible, but uses all possible cores.
Shure, here is the btrfs installation:
$ mount -t btrfs
/dev/nvme0n1p7 on / type btrfs (rw,relatime,ssd,discard=async,space_cache=v2,subvolid=256,subvol=/@)
/dev/nvme0n1p7 on /home type btrfs (rw,relatime,ssd,discard=async,space_cache=v2,subvolid=257,subvol=/@home)
/dev/nvme0n1p7 on /var/cache type btrfs (rw,relatime,ssd,discard=async,space_cache=v2,subvolid=258,subvol=/@cache)
/dev/nvme0n1p7 on /var/log type btrfs (rw,relatime,ssd,discard=async,space_cache=v2,subvolid=259,subvol=/@log)
$ cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=68BD-1D13                            /boot/efi      vfat    umask=0077 0 2
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /              btrfs   subvol=/@,defaults,discard=async,ssd 0 0
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /home          btrfs   subvol=/@home,defaults,discard=async,ssd 0 0
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /var/cache     btrfs   subvol=/@cache,defaults,discard=async,ssd 0 0
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /var/log       btrfs   subvol=/@log,defaults,discard=async,ssd 0 0
UUID=4371b365-d8bf-430a-ade2-d4fab1a203ac swap           swap    defaults,noatime 0 0
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
$ grep "" /sys/block/*/queue/scheduler
/sys/block/loop0/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop1/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop2/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop3/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop4/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop5/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop6/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/loop7/queue/scheduler:[none] mq-deadline kyber bfq
/sys/block/nvme0n1/queue/scheduler:[none] mq-deadline kyber bfq
And this is ext4:
$ mount -t ext4
/dev/nvme0n1p4 on / type ext4 (rw,noatime)
$ cat /etc/fstab
UUID=37921521-2c1a-430c-800b-87d379e6326c /              ext4    defaults,noatime 0 1
Great thank you! Is it possible to make it the default in nautilus? Sometimes a right click on a file is easier for me than comandline
Add to fstab:
noatime,clear_cache,nospace_cache
and reboot.
space_cache=v2 can improve performance, but to be honest it wear out the SSD/NVME faster… At least on HDDs it is recommend in my opinion.
noatime improves latency. On modern systems atime is not needed, especially on desktops.
No idea. Maybe ask upstream: Issues · GNOME / Files · GitLab but in fact this menu is hardcoded.
Just to be shure, you mean like this?
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /              btrfs   subvol=/@,defaults,discard=async,ssd,noatime,clear_cache,nospace_cache 0 0
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /home          btrfs   subvol=/@home,defaults,discard=async,ssd,noatime,clear_cache,nospace_cache 0 0
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /var/cache     btrfs   subvol=/@cache,defaults,discard=async,ssd,noatime,clear_cache,nospace_cache 0 0
UUID=af6ff93b-3809-4e38-9acd-9031213e0a5b /var/log       btrfs   subvol=/@log,defaults,discard=async,ssd,noatime,clear_cache,nospace_cache 0 0
Everything is correct, BUT disabling fsck for btrfs is a bad idea, anyway it is your system.
0 00 1
Great thank you!
Now i got this on btrfs:
cat 1.zip > /dev/null  0,03s user 17,28s system 89% cpu 19,325 total
I am not sure if fsck is not for Btrfs in fstab, but it is for Ext4.
In Arch wiki:
If the root file system is btrfs or XFS, the fsck order should be set to 0 instead of 1
Check cat /usr/bin/fsck.btrfs
# fsck.btrfs is a type of utility that should exist for any filesystem and is
# called during system setup when the corresponding /etc/fstab entries contain
# non-zero value for fs_passno. (See fstab(5) for more.)
# Traditional filesystems need to run their respective fsck utility in case the
# filesystem was not unmounted cleanly and the log needs to be replayed before
# mount. This is not needed for BTRFS. You should set fs_passno to 0.
# If you wish to check the consistency of a BTRFS filesystem or repair a
# damaged filesystem, see btrfs(8) subcommand 'check'. By default the
# filesystem consistency is checked, the repair mode is enabled via --repair
# option (use with care!).
AUTO=false
while getopts ":aApy" c
do
 case $c in
 a|A|p|y)       AUTO=true;;
 esac
done
shift $(($OPTIND - 1))
eval DEV=\${$#}
if [ ! -e $DEV ]; then
 echo "$0: $DEV does not exist"
 exit 8
fi
if ! $AUTO; then
 echo "If you wish to check the consistency of a BTRFS filesystem or"
 echo "repair a damaged filesystem, see btrfs(8) subcommand 'check'."
fi
exit 0
Copying benchmark in a real world using cp.
Let check: Copying the Game data 30 GB in the same filesystem
Ext4:
$ time cp Game.7z Game1.7z
real    0m24,201s
user    0m0,001s
sys     0m21,379s
Btrfs:
real    0m0,011s
user    0m0,001s
sys     0m0,003s
Btrfs: copying the data from subvolume to another subvolume: (Linux Kernel 5.17+ improved deduplication)
$ time sudo cp Game.7z /opt/Game1.7z
real    0m2,141s
user    0m0,038s
sys     0m0,016s
Btrfs takes no additional space, because of deduplication ability.
Writing benchmark is difficult to test Btrfs due to deduplication.
Copy data from the Nvme SSD to Btrfs filesystem in other Nvme SSD. Both SSDs are similarly fast.
time sudo cp Game.7z /run/media/zesko/Backup/Game1.7z
real    0m19,409s
user    0m0,046s
sys     0m18,632s
btrfs is slower than other filesystems.
  • But it depends on the circumstances.
  • btrfs has a lot of safety. This comes not without costs.
Enable compression for btrfs, and you may gain some (space and speed) :wink:
When you search for speed, btrfs may be not the best choice !
You can find good Information about Btrfs in the wiki
So i should keep 0 0 on btrfs?
0 0 is default on btrfs — on ext4 it’s 0 1
My test-installation with ext4 has only 70GB root partition, so I had to generate another test file (25.6GB)
(Thanks @megavolt, using pigz and all 16 cores it’s done in seconds)
ext4:
$ time cp Test.tar.gz Test1.tar.gz
cp -i Test.tar.gz Test1.tar.gz  0,00s user 27,48s system 99% cpu 27,760 total
Btrfs:
(unfortunately I have no seccont nvme build in)
cp -i Test.tar.gz Test1.tar.gz  0,00s user 0,11s system 91% cpu 0,126 total
$ time sudo cp Test.tar.gz /opt/Test1.tar.gz
[sudo] Passwort für user:
sudo cp Test.tar.gz /opt/Test1.tar.gz  0,02s user 25,88s system 92% cpu 28,093 total
I made the changes, but could it gain some speed?
So eaven if the changes to the fstab could gain some speed, i guess it is still slower. But how much slower is it and is this just the normal slowdown? And based on my read/write tests bevore and after, did the changes to the fstab do anything? Like I said, I don’t quite understand the output. Which digit shows the actual speed or duration?
But if this is normal in the end, I guess there’s nothing I can do… I just wanted to be shure
And thanks again for your help so far
Yes
Which Linux kernel do you use?
Did you run sudo btrfs balance start -v /?
My fstab
UUID=bd9ea09d-153e-4e0c--b3e6cbcbab86f0 / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
Try to change the compress=zstd to compress=zstd:1
No need clear_cache,nospace_cache, space_cache=v2 is already default.
You do not need discard=async in fstab, just use sudo systemctl enable --now fstrim.timer
