Hi there,
First of all I just want to say, I’ve been running Manjaro off and on for several years (on this same machine/hardware) and mostly it’s been very stable. I think one time I had to re-install a driver after a major system update. I love Manjaro for the ability to find pretty much any package I need (if it’s not in the repos, it’s probably in the AUR), staying up to date with current packages, and ease of use.
That said, after the last update to 25.1 I noticed a few glitches. It’s not completely broken, but there’s a lot of pretty annoying things going on that I’d like to fix. I’ve tried to diagnose the issue but nothing much is jumping out at me, other than it seems display-driver or wayland-related. I’ve searched for others having the same problem but not finding much. I did see this one guy having one of the same issues, but it was just posted in the announcement thread without any info and no responses:
Yesterday, I just noticed that brave and chromium both crash at launch (a few seconds after prompting me to configure global shortcuts). Found a supposed fix by adding –disable-features=GlobalShortcutsPortal to the arguments, but all this did was make that prompt stop appearing (but the crashes still happen).
Firefox works (it’s running in firejail, which is the nrom in my case); but it seems to hang for, I want to say…10s of seconds, when trying to load a page. It also had a few crashes last night. Normally it’s very stable (along with the other browsers).
I just remembered I have Edge installed from a long time ago (because it was the only browser that would actually let me log in to any Microsoft portals, at least at the time), and I just tried it just to see. I expected it to fail along with the other chromium-based browsers, but it’s actually working. Seems to be a very old version though (116.0.1938.62-1). I think I installed it from the AUR a few years ago because I couldn’t find it in the main repos. (Actually, now that I look, I still don’t see one in the main repos. I must’ve gotten it from the AUR, and just forgot about and neglected it).
I also noticed a couple other weird issues. For example, Firefox doesn’t render the minimize, maximize, and close buttons in the top-right corner. I just tried to get a screenshot, but spectacle also crashes after freezing the display for 10s of seconds.
Another weird thing I noticed is Veracrypt doesn’t run in the system tray if I click the close button. It’s still running though, and if I try to open it again with the .desktop launcher it opens with a prompt telling me it’s already running.
Anyhow, all that said; near as I can tell it has something to do with my display drivers or wayland.
I gathered a bunch of info from my system, but nothing is jumping out at me. Figured I’d dump it in here, and see if any folks will take a look and could maybe point me in the right direction. I appreciate any insights!
Running chromium:
[1619:1619:1213/074851.307190:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074851.723740:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074852.162506:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074852.664663:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074853.134512:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074853.603057:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074853.817683:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074854.029127:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074854.240379:ERROR:content/browser/gpu/gpu_process_host.cc:1005] GPU process exited unexpectedly: exit_code=139
[1619:1619:1213/074854.240397:FATAL:content/browser/gpu/gpu_data_manager_impl_private.cc:415] GPU process isn't usable. Goodbye.
[1213/074854.250101:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.250230:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.250309:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.253444:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.254788:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.254922:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.254971:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.255239:ERROR:third_party/crashpad/crashpad/snapshot/elf/elf_dynamic_array_reader.h:64] tag not found
[1213/074854.255607:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[1213/074854.255617:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[1213/074854.259764:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[1213/074854.259772:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[1213/074854.259788:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
[1213/074854.259796:ERROR:third_party/crashpad/crashpad/util/process/process_memory_range.cc:75] read out of range
Trace/breakpoint trap (core dumped) chromium
Chromium package info:
chromium /usr/
chromium /usr/bin/
chromium /usr/bin/chromedriver
chromium /usr/bin/chromium
chromium /usr/lib/
chromium /usr/lib/chromium/
chromium /usr/lib/chromium/chrome-sandbox
chromium /usr/lib/chromium/chrome_100_percent.pak
chromium /usr/lib/chromium/chrome_200_percent.pak
chromium /usr/lib/chromium/chrome_crashpad_handler
chromium /usr/lib/chromium/chromium
chromium /usr/lib/chromium/icudtl.dat
chromium /usr/lib/chromium/libEGL.so
chromium /usr/lib/chromium/libGLESv2.so
chromium /usr/lib/chromium/libqt6_shim.so
chromium /usr/lib/chromium/libvk_swiftshader.so
chromium /usr/lib/chromium/libvulkan.so.1
chromium /usr/lib/chromium/locales/
chromium /usr/lib/chromium/locales/af.pak
chromium /usr/lib/chromium/locales/af_FEMININE.pak
chromium /usr/lib/chromium/locales/af_MASCULINE.pak
chromium /usr/lib/chromium/locales/af_NEUTER.pak
chromium /usr/lib/chromium/locales/am.pak
chromium /usr/lib/chromium/locales/am_FEMININE.pak
chromium /usr/lib/chromium/locales/am_MASCULINE.pak
chromium /usr/lib/chromium/locales/am_NEUTER.pak
chromium /usr/lib/chromium/locales/ar.pak
chromium /usr/lib/chromium/locales/ar_FEMININE.pak
chromium /usr/lib/chromium/locales/ar_MASCULINE.pak
chromium /usr/lib/chromium/locales/ar_NEUTER.pak
chromium /usr/lib/chromium/locales/bg.pak
chromium /usr/lib/chromium/locales/bg_FEMININE.pak
chromium /usr/lib/chromium/locales/bg_MASCULINE.pak
chromium /usr/lib/chromium/locales/bg_NEUTER.pak
chromium /usr/lib/chromium/locales/bn.pak
chromium /usr/lib/chromium/locales/bn_FEMININE.pak
chromium /usr/lib/chromium/locales/bn_MASCULINE.pak
chromium /usr/lib/chromium/locales/bn_NEUTER.pak
chromium /usr/lib/chromium/locales/ca.pak
chromium /usr/lib/chromium/locales/ca_FEMININE.pak
chromium /usr/lib/chromium/locales/ca_MASCULINE.pak
chromium /usr/lib/chromium/locales/ca_NEUTER.pak
chromium /usr/lib/chromium/locales/cs.pak
chromium /usr/lib/chromium/locales/cs_FEMININE.pak
chromium /usr/lib/chromium/locales/cs_MASCULINE.pak
chromium /usr/lib/chromium/locales/cs_NEUTER.pak
chromium /usr/lib/chromium/locales/da.pak
chromium /usr/lib/chromium/locales/da_FEMININE.pak
chromium /usr/lib/chromium/locales/da_MASCULINE.pak
chromium /usr/lib/chromium/locales/da_NEUTER.pak
chromium /usr/lib/chromium/locales/de.pak
chromium /usr/lib/chromium/locales/de_FEMININE.pak
chromium /usr/lib/chromium/locales/de_MASCULINE.pak
chromium /usr/lib/chromium/locales/de_NEUTER.pak
chromium /usr/lib/chromium/locales/el.pak
chromium /usr/lib/chromium/locales/el_FEMININE.pak
chromium /usr/lib/chromium/locales/el_MASCULINE.pak
chromium /usr/lib/chromium/locales/el_NEUTER.pak
chromium /usr/lib/chromium/locales/en-GB.pak
chromium /usr/lib/chromium/locales/en-GB_FEMININE.pak
chromium /usr/lib/chromium/locales/en-GB_MASCULINE.pak
chromium /usr/lib/chromium/locales/en-GB_NEUTER.pak
chromium /usr/lib/chromium/locales/en-US.pak
chromium /usr/lib/chromium/locales/en-US_FEMININE.pak
chromium /usr/lib/chromium/locales/en-US_MASCULINE.pak
chromium /usr/lib/chromium/locales/en-US_NEUTER.pak
chromium /usr/lib/chromium/locales/es-419.pak
chromium /usr/lib/chromium/locales/es-419_FEMININE.pak
chromium /usr/lib/chromium/locales/es-419_MASCULINE.pak
chromium /usr/lib/chromium/locales/es-419_NEUTER.pak
chromium /usr/lib/chromium/locales/es.pak
chromium /usr/lib/chromium/locales/es_FEMININE.pak
chromium /usr/lib/chromium/locales/es_MASCULINE.pak
chromium /usr/lib/chromium/locales/es_NEUTER.pak
chromium /usr/lib/chromium/locales/et.pak
chromium /usr/lib/chromium/locales/et_FEMININE.pak
chromium /usr/lib/chromium/locales/et_MASCULINE.pak
chromium /usr/lib/chromium/locales/et_NEUTER.pak
chromium /usr/lib/chromium/locales/fa.pak
chromium /usr/lib/chromium/locales/fa_FEMININE.pak
chromium /usr/lib/chromium/locales/fa_MASCULINE.pak
chromium /usr/lib/chromium/locales/fa_NEUTER.pak
chromium /usr/lib/chromium/locales/fi.pak
chromium /usr/lib/chromium/locales/fi_FEMININE.pak
chromium /usr/lib/chromium/locales/fi_MASCULINE.pak
chromium /usr/lib/chromium/locales/fi_NEUTER.pak
chromium /usr/lib/chromium/locales/fil.pak
chromium /usr/lib/chromium/locales/fil_FEMININE.pak
chromium /usr/lib/chromium/locales/fil_MASCULINE.pak
chromium /usr/lib/chromium/locales/fil_NEUTER.pak
chromium /usr/lib/chromium/locales/fr.pak
chromium /usr/lib/chromium/locales/fr_FEMININE.pak
chromium /usr/lib/chromium/locales/fr_MASCULINE.pak
chromium /usr/lib/chromium/locales/fr_NEUTER.pak
chromium /usr/lib/chromium/locales/gu.pak
chromium /usr/lib/chromium/locales/gu_FEMININE.pak
chromium /usr/lib/chromium/locales/gu_MASCULINE.pak
chromium /usr/lib/chromium/locales/gu_NEUTER.pak
chromium /usr/lib/chromium/locales/he.pak
chromium /usr/lib/chromium/locales/he_FEMININE.pak
chromium /usr/lib/chromium/locales/he_MASCULINE.pak
chromium /usr/lib/chromium/locales/he_NEUTER.pak
chromium /usr/lib/chromium/locales/hi.pak
chromium /usr/lib/chromium/locales/hi_FEMININE.pak
chromium /usr/lib/chromium/locales/hi_MASCULINE.pak
chromium /usr/lib/chromium/locales/hi_NEUTER.pak
chromium /usr/lib/chromium/locales/hr.pak
chromium /usr/lib/chromium/locales/hr_FEMININE.pak
chromium /usr/lib/chromium/locales/hr_MASCULINE.pak
chromium /usr/lib/chromium/locales/hr_NEUTER.pak
chromium /usr/lib/chromium/locales/hu.pak
chromium /usr/lib/chromium/locales/hu_FEMININE.pak
chromium /usr/lib/chromium/locales/hu_MASCULINE.pak
chromium /usr/lib/chromium/locales/hu_NEUTER.pak
chromium /usr/lib/chromium/locales/id.pak
chromium /usr/lib/chromium/locales/id_FEMININE.pak
chromium /usr/lib/chromium/locales/id_MASCULINE.pak
chromium /usr/lib/chromium/locales/id_NEUTER.pak
chromium /usr/lib/chromium/locales/it.pak
chromium /usr/lib/chromium/locales/it_FEMININE.pak
chromium /usr/lib/chromium/locales/it_MASCULINE.pak
chromium /usr/lib/chromium/locales/it_NEUTER.pak
chromium /usr/lib/chromium/locales/ja.pak
chromium /usr/lib/chromium/locales/ja_FEMININE.pak
chromium /usr/lib/chromium/locales/ja_MASCULINE.pak
chromium /usr/lib/chromium/locales/ja_NEUTER.pak
chromium /usr/lib/chromium/locales/kn.pak
chromium /usr/lib/chromium/locales/kn_FEMININE.pak
chromium /usr/lib/chromium/locales/kn_MASCULINE.pak
chromium /usr/lib/chromium/locales/kn_NEUTER.pak
chromium /usr/lib/chromium/locales/ko.pak
chromium /usr/lib/chromium/locales/ko_FEMININE.pak
chromium /usr/lib/chromium/locales/ko_MASCULINE.pak
chromium /usr/lib/chromium/locales/ko_NEUTER.pak
chromium /usr/lib/chromium/locales/lt.pak
chromium /usr/lib/chromium/locales/lt_FEMININE.pak
chromium /usr/lib/chromium/locales/lt_MASCULINE.pak
chromium /usr/lib/chromium/locales/lt_NEUTER.pak
chromium /usr/lib/chromium/locales/lv.pak
chromium /usr/lib/chromium/locales/lv_FEMININE.pak
chromium /usr/lib/chromium/locales/lv_MASCULINE.pak
chromium /usr/lib/chromium/locales/lv_NEUTER.pak
chromium /usr/lib/chromium/locales/ml.pak
chromium /usr/lib/chromium/locales/ml_FEMININE.pak
chromium /usr/lib/chromium/locales/ml_MASCULINE.pak
chromium /usr/lib/chromium/locales/ml_NEUTER.pak
chromium /usr/lib/chromium/locales/mr.pak
chromium /usr/lib/chromium/locales/mr_FEMININE.pak
chromium /usr/lib/chromium/locales/mr_MASCULINE.pak
chromium /usr/lib/chromium/locales/mr_NEUTER.pak
chromium /usr/lib/chromium/locales/ms.pak
chromium /usr/lib/chromium/locales/ms_FEMININE.pak
chromium /usr/lib/chromium/locales/ms_MASCULINE.pak
chromium /usr/lib/chromium/locales/ms_NEUTER.pak
chromium /usr/lib/chromium/locales/nb.pak
chromium /usr/lib/chromium/locales/nb_FEMININE.pak
chromium /usr/lib/chromium/locales/nb_MASCULINE.pak
chromium /usr/lib/chromium/locales/nb_NEUTER.pak
chromium /usr/lib/chromium/locales/nl.pak
chromium /usr/lib/chromium/locales/nl_FEMININE.pak
chromium /usr/lib/chromium/locales/nl_MASCULINE.pak
chromium /usr/lib/chromium/locales/nl_NEUTER.pak
chromium /usr/lib/chromium/locales/pl.pak
chromium /usr/lib/chromium/locales/pl_FEMININE.pak
chromium /usr/lib/chromium/locales/pl_MASCULINE.pak
chromium /usr/lib/chromium/locales/pl_NEUTER.pak
chromium /usr/lib/chromium/locales/pt-BR.pak
chromium /usr/lib/chromium/locales/pt-BR_FEMININE.pak
chromium /usr/lib/chromium/locales/pt-BR_MASCULINE.pak
chromium /usr/lib/chromium/locales/pt-BR_NEUTER.pak
chromium /usr/lib/chromium/locales/pt-PT.pak
chromium /usr/lib/chromium/locales/pt-PT_FEMININE.pak
chromium /usr/lib/chromium/locales/pt-PT_MASCULINE.pak
chromium /usr/lib/chromium/locales/pt-PT_NEUTER.pak
chromium /usr/lib/chromium/locales/ro.pak
chromium /usr/lib/chromium/locales/ro_FEMININE.pak
chromium /usr/lib/chromium/locales/ro_MASCULINE.pak
chromium /usr/lib/chromium/locales/ro_NEUTER.pak
chromium /usr/lib/chromium/locales/ru.pak
chromium /usr/lib/chromium/locales/ru_FEMININE.pak
chromium /usr/lib/chromium/locales/ru_MASCULINE.pak
chromium /usr/lib/chromium/locales/ru_NEUTER.pak
chromium /usr/lib/chromium/locales/sk.pak
chromium /usr/lib/chromium/locales/sk_FEMININE.pak
chromium /usr/lib/chromium/locales/sk_MASCULINE.pak
chromium /usr/lib/chromium/locales/sk_NEUTER.pak
chromium /usr/lib/chromium/locales/sl.pak
chromium /usr/lib/chromium/locales/sl_FEMININE.pak
chromium /usr/lib/chromium/locales/sl_MASCULINE.pak
chromium /usr/lib/chromium/locales/sl_NEUTER.pak
chromium /usr/lib/chromium/locales/sr.pak
chromium /usr/lib/chromium/locales/sr_FEMININE.pak
chromium /usr/lib/chromium/locales/sr_MASCULINE.pak
chromium /usr/lib/chromium/locales/sr_NEUTER.pak
chromium /usr/lib/chromium/locales/sv.pak
chromium /usr/lib/chromium/locales/sv_FEMININE.pak
chromium /usr/lib/chromium/locales/sv_MASCULINE.pak
chromium /usr/lib/chromium/locales/sv_NEUTER.pak
chromium /usr/lib/chromium/locales/sw.pak
chromium /usr/lib/chromium/locales/sw_FEMININE.pak
chromium /usr/lib/chromium/locales/sw_MASCULINE.pak
chromium /usr/lib/chromium/locales/sw_NEUTER.pak
chromium /usr/lib/chromium/locales/ta.pak
chromium /usr/lib/chromium/locales/ta_FEMININE.pak
chromium /usr/lib/chromium/locales/ta_MASCULINE.pak
chromium /usr/lib/chromium/locales/ta_NEUTER.pak
chromium /usr/lib/chromium/locales/te.pak
chromium /usr/lib/chromium/locales/te_FEMININE.pak
chromium /usr/lib/chromium/locales/te_MASCULINE.pak
chromium /usr/lib/chromium/locales/te_NEUTER.pak
chromium /usr/lib/chromium/locales/th.pak
chromium /usr/lib/chromium/locales/th_FEMININE.pak
chromium /usr/lib/chromium/locales/th_MASCULINE.pak
chromium /usr/lib/chromium/locales/th_NEUTER.pak
chromium /usr/lib/chromium/locales/tr.pak
chromium /usr/lib/chromium/locales/tr_FEMININE.pak
chromium /usr/lib/chromium/locales/tr_MASCULINE.pak
chromium /usr/lib/chromium/locales/tr_NEUTER.pak
chromium /usr/lib/chromium/locales/uk.pak
chromium /usr/lib/chromium/locales/uk_FEMININE.pak
chromium /usr/lib/chromium/locales/uk_MASCULINE.pak
chromium /usr/lib/chromium/locales/uk_NEUTER.pak
chromium /usr/lib/chromium/locales/ur.pak
chromium /usr/lib/chromium/locales/ur_FEMININE.pak
chromium /usr/lib/chromium/locales/ur_MASCULINE.pak
chromium /usr/lib/chromium/locales/ur_NEUTER.pak
chromium /usr/lib/chromium/locales/vi.pak
chromium /usr/lib/chromium/locales/vi_FEMININE.pak
chromium /usr/lib/chromium/locales/vi_MASCULINE.pak
chromium /usr/lib/chromium/locales/vi_NEUTER.pak
chromium /usr/lib/chromium/locales/zh-CN.pak
chromium /usr/lib/chromium/locales/zh-CN_FEMININE.pak
chromium /usr/lib/chromium/locales/zh-CN_MASCULINE.pak
chromium /usr/lib/chromium/locales/zh-CN_NEUTER.pak
chromium /usr/lib/chromium/locales/zh-TW.pak
chromium /usr/lib/chromium/locales/zh-TW_FEMININE.pak
chromium /usr/lib/chromium/locales/zh-TW_MASCULINE.pak
chromium /usr/lib/chromium/locales/zh-TW_NEUTER.pak
chromium /usr/lib/chromium/resources.pak
chromium /usr/lib/chromium/v8_context_snapshot.bin
chromium /usr/lib/chromium/vk_swiftshader_icd.json
chromium /usr/share/
chromium /usr/share/applications/
chromium /usr/share/applications/chromium.desktop
chromium /usr/share/icons/
chromium /usr/share/icons/hicolor/
chromium /usr/share/icons/hicolor/128x128/
chromium /usr/share/icons/hicolor/128x128/apps/
chromium /usr/share/icons/hicolor/128x128/apps/chromium.png
chromium /usr/share/icons/hicolor/16x16/
chromium /usr/share/icons/hicolor/16x16/apps/
chromium /usr/share/icons/hicolor/16x16/apps/chromium.png
chromium /usr/share/icons/hicolor/24x24/
chromium /usr/share/icons/hicolor/24x24/apps/
chromium /usr/share/icons/hicolor/24x24/apps/chromium.png
chromium /usr/share/icons/hicolor/256x256/
chromium /usr/share/icons/hicolor/256x256/apps/
chromium /usr/share/icons/hicolor/256x256/apps/chromium.png
chromium /usr/share/icons/hicolor/32x32/
chromium /usr/share/icons/hicolor/32x32/apps/
chromium /usr/share/icons/hicolor/32x32/apps/chromium.png
chromium /usr/share/icons/hicolor/48x48/
chromium /usr/share/icons/hicolor/48x48/apps/
chromium /usr/share/icons/hicolor/48x48/apps/chromium.png
chromium /usr/share/icons/hicolor/64x64/
chromium /usr/share/icons/hicolor/64x64/apps/
chromium /usr/share/icons/hicolor/64x64/apps/chromium.png
chromium /usr/share/licenses/
chromium /usr/share/licenses/chromium/
chromium /usr/share/licenses/chromium/LICENSE
chromium /usr/share/licenses/chromium/LICENSE.launcher
chromium /usr/share/man/
chromium /usr/share/man/man1/
chromium /usr/share/man/man1/chromium.1.gz
chromium /usr/share/metainfo/
chromium /usr/share/metainfo/chromium.appdata.xml
Contents of ~/.config/chromium/
ActorSafetyLists/ Default/ Last Version PrivacySandboxAttestationsPreloaded/ TpcdMetadata/
AmountExtractionHeuristicRegexes/ Dictionaries/ Local State ProbabilisticRevealTokenRegistry/ TrustTokenKeyCommitments/
AutofillStates/ extensions_crx_cache/ Local Traces/ Safe Browsing/ Variations
BrowserMetrics/ FileTypePolicies/ MEIPreload/ SafetyTips/ WasmTtsEngine/
CertificateRevocation/ first_party_sets.db NativeMessagingHosts/ segmentation_platform/ Webstore Downloads/
chrome_shutdown_ms.txt first_party_sets.db-journal OnDeviceHeadSuggestModel/ ShaderCache/ WidevineCdm/
ClientSidePhishing/ FirstPartySetsPreloaded/ OpenCookieDatabase/ SingletonCookie ZxcvbnData/
component_crx_cache/ First Run OptimizationGuidePredictionModels/ SingletonLock
CookieReadinessList/ GraphiteDawnCache/ OptimizationHints/ SingletonSocket
Crash Reports/ GrShaderCache/ OriginTrials/ SSLErrorAssistant/
Crowd Deny/ hyphen-data/ PKIMetadata/ Subresource Filter/
journalctl after trying to launch chromium (this is a long one, but perhaps the most telling?):
Aaand my post is apparently about 200k chars too large. Will have to put this output into a reply I guess.
inxi -zv8:
Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c9e25bfa-5813-4f2f-82e0-833adc8bd7f8 rw quiet
cryptdevice=UUID=69e882ed-f1ef-4bb2-84ca-c2010e8649e7:luks-69e882ed-f1ef-4bb2-84ca-c2010e8649e7
root=/dev/mapper/luks-69e882ed-f1ef-4bb2-84ca-c2010e8649e7 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
Firmware: UEFI vendor: American Megatrends v: 6232 date: 09/29/2024
System RAM: total: 32 GiB available: 31.25 GiB used: 2.1 GiB (6.7%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Team Group Inc
part-no: TEAMGROUP-UD4-3600 serial: <filter>
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3599 min/max: 581/4825 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3599 2: 3599 3: 3599
4: 3599 5: 3599 6: 3599 7: 3599 8: 3599 9: 3599 10: 3599 11: 3599 12: 3599
13: 3599 14: 3599 15: 3599 16: 3599 bogomips: 108808
xsaves xtopology
affected
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
v: 580.105.08 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2,DVI-D-1 bus-ID: 0a:00.0
chip-ID: 10de:1b81 class-ID: 0300
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-3 pos: top-right model: LG (GoldStar) HDR QHD
serial: <filter> built: 2020 res: mode: 2560x1440 hz: 144 scale: 100% (1)
dpi: 93 gamma: 1.2 chroma: red: x: 0.671 y: 0.310 green: x: 0.255 y: 0.682
blue: x: 0.149 y: 0.075 white: x: 0.314 y: 0.329
size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
modes: 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024, 1280x800,
1152x864, 1280x720, 1024x768, 800x600, 640x480
Monitor-2: HDMI-A-1 pos: bottom-l model: BenQ GL2760 serial: <filter>
built: 2014 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
chroma: red: x: 0.643 y: 0.345 green: x: 0.322 y: 0.627 blue: x: 0.149
y: 0.051 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1280x800, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 580.105.08
device-ID: 10de:1b81 surfaces: N/A
Device-1: NVIDIA GP104 High Definition Audio vendor: ZOTAC
bus-ID: 0a:00.1 chip-ID: 10de:10f0 class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0951:16a4 class-ID: 0300
serial: <filter>
Device-4: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:3
chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-93-gbe2efb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
Info: services: NetworkManager, smbd, systemd-timesyncd
Device-1: luks-69e882ed-f1ef-4bb2-84ca-c2010e8649e7 maj-min: 253:0
type: LUKS dm: dm-0 size: 223.27 GiB
Components:
p-1: sdb2 maj-min: 8:18 size: 223.27 GiB
Local Storage: total: 5.35 TiB used: 973.69 GiB (17.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 37.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 500GB
tech: SSD serial: <filter> fw-rev: DB6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDA240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 80RL scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM001-1ER164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 71E0 scheme: GPT
ID-7: /dev/sdf maj-min: 8:80 model: USB DISK size: 126.5 MiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: 3.90
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24F1ST c rev: 1.01
dev-links: cdrom
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 120.23 GiB (55.0%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-69e882ed-f1ef-4bb2-84ca-c2010e8649e7 label: N/A
uuid: c9e25bfa-5813-4f2f-82e0-833adc8bd7f8
used: 476 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 31DA-2A33
ID-3: /run/media/user001/Game_Library raw-size: 953.87 GiB
size: 953.87 GiB (100.00%) used: 853.46 GiB (89.5%) fs: ntfs
dev: /dev/nvme0n1p1 maj-min: 259:1 label: Game_Library
uuid: 65005827629FD3D8
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 196.1 MiB fs: vfat label: N/A
uuid: 4289-6578
ID-2: /dev/sda2 maj-min: 8:2 size: 464.57 GiB fs: ntfs label: N/A
uuid: EA228B5E228B2F1F
ID-3: /dev/sda3 maj-min: 8:3 size: 1 GiB fs: ntfs label: Windows RE tools
uuid: 1AD82167D821427D
ID-4: /dev/sdc1 maj-min: 8:33 size: 150 GiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdc2 maj-min: 8:34 size: 1.67 TiB fs: <superuser required>
ID-6: /dev/sdd1 maj-min: 8:49 size: 150 GiB fs: <superuser required>
ID-7: /dev/sdd2 maj-min: 8:50 size: 1.67 TiB fs: <superuser required>
ID-8: /dev/sde1 maj-min: 8:65 size: 16 MiB fs: <superuser required>
ID-9: /dev/sde2 maj-min: 8:66 size: 111 GiB fs: ntfs label: N/A
uuid: 76F496A0F4966263
ID-10: /dev/sde3 maj-min: 8:67 size: 792 MiB fs: ntfs label: N/A
uuid: D4E6D944E6D9278E
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-3:2 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Device-1: 3-1:2 info: Kingston HyperX 7.1 Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
chip-ID: 0951:16a4 class-ID: 0300 serial: <filter>
Device-2: 3-2:3 info: Focusrite-Novation Scarlett 2i2 3rd Gen type: audio
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1235:8210 class-ID: 0102
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-2:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0451:8142
Device-1: 5-2.2:4 info: Logitech F310 Gamepad [XInput Mode]
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
Device-2: 5-2.3:6 info: manufacturer Disk (Thumb drive) type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 100mA chip-ID: 1221:3234 class-ID: 0806
serial: <filter>
Device-3: 5-2.4:7 info: LG USA 27UP850 - WK.AEUDCSN External Monitor 4K
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 043e:9a39
Device-4: 5-3:3 info: Winbond WHIFTEC Mechanical Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 0416:a0f8 class-ID: 0301 serial: <filter>
Device-5: 5-4:5 info: Logitech G402 Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07e class-ID: 0300
serial: <filter>
Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 6-2:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0451:8140
System Temperatures: cpu: 44.4 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1669 libs: 513 tools: pamac
1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
2: https://mirrors2.manjaro.org/stable/$repo/$arch
3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 329
1: cpu: 1.9% command: kwin_wayland pid: 1035 mem: 208.3 MiB (0.6%)
2: cpu: 1.3% command: kate pid: 2110 mem: 162.1 MiB (0.5%)
3: cpu: 1.2% command: konsole pid: 1596 mem: 124.4 MiB (0.3%)
4: cpu: 0.5% command: plasmashell pid: 1186 mem: 463.3 MiB (1.4%)
5: cpu: 0.2% command: [nvidia-modeset/kthread_q] pid: 690
mem: 0.00 MiB (0.0%)
Memory top: 5 of 329
1: mem: 463.3 MiB (1.4%) command: plasmashell pid: 1186 cpu: 0.5%
2: mem: 208.3 MiB (0.6%) command: kwin_wayland pid: 1035 cpu: 1.9%
3: mem: 186.9 MiB (0.5%) command: Mullvad pid: 1395 cpu: 0.1%
4: mem: 162.1 MiB (0.5%) command: kate pid: 2110 cpu: 1.3%
5: mem: 158.7 MiB (0.4%) command: Mullvad pid: 1534 cpu: 0.0%
Processes: 329 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 alt: 14 Shell: Bash v: 5.3.8
running-in: konsole inxi: 3.3.40
Oh right, I forgot to mention, when I did the update, I noticed a linux-meta package and a few other ‘meta’ packages I’d never seen before. I don’t usually check through the list of packages, other than to see what’s changing kernel-wise and gpu-driver-wise, but I’m pretty sure I had never had these installed before.
Before the update, I was running kernel 6.16, and IIRC I just had whatever linux-video-nvidia packages were installed by mhwd. But after the update, mhwd was reporting that there were no installed packages. I’ve dicked around with re-installing drivers and installing kernel 6.18, but nothing made any difference (aside from trying to run linux-nvidia-open and ending up booting to a black screen).
Currently I’m running 6.18, and I’ve installed video-nvidia from mhwd, and I’ve also installed linux618-nvidia; but the same issue was happening on 6.12 and 6.17 before I ever dicked around with these packages.
mhwd -li:
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2025.09.29 false PCI
pacman -Qs linux
local/alsa-lib 1.2.14-2
An alternative implementation of Linux sound support
local/alsa-utils 1.2.14-1
Advanced Linux Sound Architecture - Utilities
local/android-udev 20250525-1
Udev rules to connect Android devices to your linux box
local/apparmor 4.1.2-1
Mandatory Access Control (MAC) using Linux Security Module (LSM)
local/archlinux-appstream-data 20251025-2
Arch Linux application database for AppStream-based software centers
local/archlinux-keyring 20251116-1
Arch Linux PGP keyring
local/avahi 1:0.9rc2-1
Service Discovery for Linux using mDNS/DNS-SD (compatible with Bonjour)
local/base 3-3
Minimal package set to define a basic Manjaro Linux installation
local/base-devel 1-3
Basic tools to build Manjaro Linux packages
local/cpupower 6.17-2 (linux-tools)
Linux kernel tool to examine and tune power saving related features of your processor
local/dbus-broker 37-2
Linux D-Bus Message Broker
local/dbus-broker-units 37-2
Linux D-Bus Message Broker - Service units
local/ddcutil 2.2.3-1
Query and change Linux monitor settings using DDC/CI and USB.
local/ecryptfs-utils 111-9
Enterprise-class stacked cryptographic filesystem for Linux
local/efibootmgr 18-3
Linux user-space application to modify the EFI Boot Manager
local/exfatprogs 1.3.0-1
exFAT filesystem userspace utilities for the Linux Kernel exfat driver
local/filesystem 2025.10.12-1
Base Manjaro Linux files
local/firejail 0.9.76-3
Linux namespaces sandbox program
local/fuse2 2.9.9-5
Interface for userspace programs to export a filesystem to the Linux kernel
local/fuse3 3.17.4-1
local/grub-theme-manjaro 20.2-16
Manjaro Linux grub theme
local/i2c-tools 4.4-3
Heterogeneous set of I2C tools for Linux that used to be part of lm-sensors
local/iptables 1:1.8.11-2
Linux kernel packet control tool (using legacy interface)
local/kcpuid 6.17-2 (linux-tools)
Kernel tool for various cpu debug outputs
local/keyutils 1.6.3-3
Linux Key Management Utilities
local/kmod 34.2-1
Linux kernel module management tools and library
local/lib32-alsa-lib 1.2.14-2
An alternative implementation of Linux sound support (32 bit)
local/lib32-keyutils 1.6.3-2
Linux Key Management Utilities (32-bit)
local/lib32-libva 2.22.0-1
Video Acceleration (VA) API for Linux (32-bit)
local/lib32-libxshmfence 1.3.3-1
a library that exposes a event API on top of Linux futexes (32-bit)
local/lib32-util-linux 2.41.2-1
Miscellaneous system utilities for Linux (32-bit)
local/libaio 0.3.113-3
The Linux-native asynchronous I/O facility (aio) library
local/libcamera 0.6.0-1
A complex camera support library for Linux, Android, and ChromeOS
local/libcamera-ipa 0.6.0-1
A complex camera support library for Linux, Android, and ChromeOS - signed IPA
local/libcap-ng 0.8.5-3
A library for Linux that makes using posix capabilities easy
local/libiec61883 1.2.0-9
A higher level API for streaming DV, MPEG-2 and audio over Linux IEEE 1394
local/libnvme 1.16.1-1
C Library for NVM Express on Linux
local/libraw1394 2.1.2-4
Provides an API to the Linux IEEE1394 (FireWire) driver
local/libtraceevent 1:1.8.6-1
Linux kernel trace event library
local/libtracefs 1.8.2-2
Linux kernel trace file system library
local/liburing 2.12-1
Linux-native io_uring I/O access library
local/libva 2.22.0-1
local/libxshmfence 1.3.3-1
local/linux-api-headers 6.17-1
Kernel headers sanitized for use in userspace
local/linux-firmware-amdgpu 20251125-2
Firmware files for Linux - Firmware for AMD Radeon GPUs
local/linux-firmware-atheros 20251125-2
Firmware files for Linux - Firmware for Qualcomm Atheros WiFi and Bluetooth adapters
local/linux-firmware-broadcom 20251125-2
Firmware files for Linux - Firmware for Broadcom and Cypress network adapters
local/linux-firmware-cirrus 20251125-2
Firmware files for Linux - Firmware for Cirrus Logic audio devices
local/linux-firmware-intel 20251125-2
Firmware files for Linux - Firmware for Intel devices
local/linux-firmware-mediatek 20251125-2
Firmware files for Linux - Firmware for MediaTek and Ralink devices
local/linux-firmware-meta 20251125-2
Firmware files for Linux - Default set (Meta Package)
local/linux-firmware-nvidia 20251125-2
Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/linux-firmware-other 20251125-2
Firmware files for Linux - Unsorted firmware for various devices
local/linux-firmware-radeon 20251125-2
Firmware files for Linux - Firmware for ATI Radeon GPUs
local/linux-firmware-realtek 20251125-2
Firmware files for Linux - Firmware for Realtek devices
local/linux-firmware-whence 20251125-2
Firmware files for Linux - WHENCE file (vendor licenses)
local/linux-meta 6.17-1
Manjaro stable kernel meta package
local/linux-nvidia-meta 6.17-1
Recommended stable nvidia kernel module
local/linux612 6.12.61-1
The Linux 6.12 kernel and modules
local/linux612-nvidia 580.105.08-5 (linux612-extramodules)
NVIDIA kernel modules for linux612
local/linux617 6.17.11-1
The Linux 6.17 kernel and modules
local/linux617-nvidia 580.105.08-7 (linux617-extramodules)
NVIDIA kernel modules for linux617
local/linux618 6.18.0-1
The Linux 6.18 kernel and modules
local/linux618-nvidia 580.105.08-2 (linux618-extramodules)
NVIDIA kernel modules for linux618
local/man-pages 6.16-1
Linux man pages
local/manjaro-application-utility 1.4.1-3
A simple application utility for Manjaro Linux
local/manjaro-base-skel 20171029-4
Manjaro Linux base skeleton files
local/manjaro-browser-settings 20231111-1
Manjaro Linux settings browser defaults
local/manjaro-kde-settings 20241119-1
Manjaro Linux KDE settings
local/manjaro-settings-manager 0.5.8-7
Manjaro Linux System Settings Tool
local/manjaro-settings-manager-kcm 0.5.7-21
Manjaro Linux System Settings Tool (KCM for Plasma 5)
local/manjaro-settings-manager-knotifier 0.5.8-7
Manjaro Linux System Settings Tool (Notifier for Plasma 5)
local/manjaro-system 20250814-1
Manjaro Linux System - Update script
local/mdadm 4.4-2
A tool for managing/monitoring Linux md device arrays, also known as Software RAID
local/mhwd 0.6.6-6
Manjaro Linux Hardware Detection library and application
local/mhwd-db 20250929-2
Manjaro Linux Hardware Detection Database
local/ndctl 79-1
Utility library for managing the libnvdimm (non-volatile memory device) sub-system in the Linux kernel
local/pacman-mirrors 5.2.1-1
Manjaro Linux mirror list generator for use by pacman
local/signal-desktop 7.82.0-1
Signal Private Messenger for Linux
local/squashfs-tools 4.7.4-1
Tools for squashfs, a highly compressed read-only filesystem for Linux
local/stoken 0.92-5
RSA SecurID-compatible software token for Linux/UNIX systems
local/timeshift 25.07.7-1
A system restore utility for Linux
local/usb_modeswitch 2.6.2-1
Activating switchable USB devices on Linux.
local/util-linux 2.41.2-1
local/util-linux-libs 2.41.2-1
util-linux runtime libraries
local/v4l-utils 1.32.0-1
Userspace tools and conversion library for Video 4 Linux
local/virt-install 5.1.0-1
Command line tool for creating new KVM , Xen, or Linux container guests using the libvirt hypervisor
pacman -Qs nvidia
local/cuda 13.0.2-3
NVIDIA's GPU programming toolkit
local/egl-gbm 1.1.2.1-1
The GBM EGL external platform library
local/egl-wayland 4:1.1.20-1
EGLStream-based Wayland external platform
local/egl-x11 1.0.3-1
NVIDIA XLib and XCB EGL Platform Library
local/lib32-libvdpau 1.5-3
Nvidia VDPAU library
local/lib32-nvidia-utils 580.105.08-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-3
local/mhwd-nvidia 580.105.08-4
MHWD module-ids for nvidia 580.105.08
local/mhwd-nvidia-390xx 390.157-21
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.256.02-15
MHWD module-ids for nvidia 470.256.02
local/mhwd-nvidia-570xx 570.207-1
MHWD module-ids for nvidia 570.207
local/mhwd-nvidia-575xx 575.64.05-2
MHWD module-ids for nvidia 575.64.05
local/nvidia-driver-assistant 0.22.105.08-1
Detect and install the best NVIDIA driver packages for the system
local/nvidia-settings 580.105.08-4
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 580.105.08-4
local/opencl-nvidia 580.105.08-4
OpenCL implemention for NVIDIA
journalctl after launching Firefox and trying to get a screenshot of my min/max/close buttons, and having spectacle freeze up the display before eventually crashing:
Dec 13 08:04:01 COMPUTER000 systemd[947]: Started Firefox (Firejail) - Web Browser.
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/firefox.profile
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/firefox.local
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/firefox-common.profile
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/disable-common.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/disable-devel.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/disable-exec.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/disable-interpreters.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/disable-proc.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/disable-programs.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/whitelist-common.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/whitelist-run-common.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/whitelist-runuser-common.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/whitelist-usr-share-common.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Reading profile /etc/firejail/whitelist-var-common.inc
Dec 13 08:04:01 COMPUTER000 firejail[2504]: firejail version 0.9.76
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Seccomp list in: !chroot, check list: @default-keep, prelist: unknown,
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Parent pid 2504, child pid 2508
Dec 13 08:04:01 COMPUTER000 firejail[2512]: Warning: NVIDIA card detected, nogroups command ignored
Dec 13 08:04:01 COMPUTER000 firejail[2508]: Warning: An abstract unix socket for session D-BUS might still be available. Use --net or remove unix from --protocol set.
Dec 13 08:04:01 COMPUTER000 firejail[2508]: Private /etc installed in 71.77 ms
Dec 13 08:04:01 COMPUTER000 firejail[2508]: Warning: /sbin directory link was not blacklisted
Dec 13 08:04:01 COMPUTER000 firejail[2508]: Warning: /usr/sbin directory link was not blacklisted
Dec 13 08:04:01 COMPUTER000 firejail[2508]: Base filesystem installed in 172.56 ms
Dec 13 08:04:01 COMPUTER000 firejail[2545]: Warning: NVIDIA card detected, nogroups command ignored
Dec 13 08:04:01 COMPUTER000 firejail[2546]: Seccomp list in: !chroot, check list: @default-keep, prelist: unknown,
Dec 13 08:04:01 COMPUTER000 firejail[2504]: Warning: NVIDIA card detected, nogroups command ignored
Dec 13 08:04:01 COMPUTER000 firejail[2508]: Warning: NVIDIA card detected, nogroups command ignored
Dec 13 08:04:01 COMPUTER000 firejail[2548]: Warning: Replacing profile instead of stacking it. It is a legacy behavior that can result in relaxation of the protection. It is here as a temporary measure >
Dec 13 08:04:01 COMPUTER000 firejail[2548]: Warning: Cannot confine the application using AppArmor.
Dec 13 08:04:01 COMPUTER000 firejail[2548]: Maybe firejail-default AppArmor profile is not loaded into the kernel.
Dec 13 08:04:01 COMPUTER000 firejail[2548]: As root, run "aa-enforce firejail-default" to load it.
Dec 13 08:04:01 COMPUTER000 firejail[2548]: Child process initialized in 337.84 ms
Dec 13 08:04:02 COMPUTER000 firejail[2548]: [Parent 39, Main Thread] WARNING: Could not load a pixbuf from icon theme.
Dec 13 08:04:02 COMPUTER000 firejail[2548]: This may indicate that pixbuf loaders or the mime database could not be found.: 'glib warning', file /usr/src/debug/firefox/firefox-146.0/toolkit/xre/nsSigHan>
Dec 13 08:04:02 COMPUTER000 firefox[2548]: Could not load a pixbuf from icon theme.
Dec 13 08:04:18 COMPUTER000 systemd[947]: Starting Spectacle screenshot capture utility...
Dec 13 08:04:18 COMPUTER000 kernel: NVRM: GPU at PCI:0000:0a:00: GPU-c7bdbba8-91e4-98de-1f2c-238a131a7cef
Dec 13 08:04:18 COMPUTER000 kernel: NVRM: Xid (PCI:0000:0a:00): 32, pid=2972, name=spectacle, channel 0x000000a0 intr 00040000
Dec 13 08:04:18 COMPUTER000 systemd[947]: Started Spectacle screenshot capture utility.
Dec 13 08:04:22 COMPUTER000 plasmashell[1186]: error creating screencast "Could not find window id {d43ac80b-a918-4179-be83-e3a6eab82cb7}"
Dec 13 08:04:22 COMPUTER000 plasmashell[1186]: error creating screencast "Could not find window id {2b4b83b1-f60a-4632-ad4c-14d90ee300eb}"
Dec 13 08:04:23 COMPUTER000 plasmashell[1186]: "Could not convert argument 0 from undefined to QModelIndex"
Dec 13 08:04:23 COMPUTER000 plasmashell[1186]: "activateTask@file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/code/tools.js:137"
Dec 13 08:04:23 COMPUTER000 plasmashell[1186]: "leftClick@file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:422"
Dec 13 08:04:23 COMPUTER000 plasmashell[1186]: "@file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:416"
Dec 13 08:04:23 COMPUTER000 plasmashell[1186]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/code/tools.js:137: TypeError: Passing incompatible arguments to C++ functions fro>
Dec 13 08:04:25 COMPUTER000 plasmashell[1186]: error creating screencast "Could not find window id {2b4b83b1-f60a-4632-ad4c-14d90ee300eb}"
Dec 13 08:04:28 COMPUTER000 plasmashell[1186]: QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Udev event detected
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-3 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-4 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-5 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-6 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-7 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-8 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-9 lacks R/W permissions
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Removing connected display on bus 7
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Emitting DDCA_Display_Status_Event[1020.194: DDCA_EVENT_DISPLAY_DISCONNECTED, card1-HDMI-A-1, dref: DDCA_Display_Ref[1], io_path:/dev/i2c->
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Starting 1 callback threads
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] libddcutil callback thread 0x7fcd780014c0 started
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Started 1 event callback thread(s)
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Removing connected display on bus 9
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Emitting DDCA_Display_Status_Event[1020.194: DDCA_EVENT_DISPLAY_DISCONNECTED, card1-DP-3, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-9, d>
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 3061] Invoking callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1020.194: DDCA_EVENT_DISPLAY_DISCONNECTED, card1-HDMI-A-1, d>
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] libddcutil callback thread 0x7fcd78002cc0 started
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 3061] Callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1020.194: DDCA_EVENT_DISPLAY_DISCONNECTED, card1-HDMI-A-1, dref: DDCA>
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 3062] Invoking callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1020.194: DDCA_EVENT_DISPLAY_DISCONNECTED, card1-DP-3, dref:>
Dec 13 08:05:25 COMPUTER000 org_kde_powerdevil[1229]: [ 3062] Callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1020.194: DDCA_EVENT_DISPLAY_DISCONNECTED, card1-DP-3, dref: DDCA_Dis>
Dec 13 08:05:25 COMPUTER000 kwin_wayland[1035]: Atomic modeset test failed! Permission denied
Dec 13 08:05:25 COMPUTER000 kwin_wayland[1035]: Applying output configuration failed!
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Udev event detected
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-3 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-4 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-5 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-6 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-7 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-8 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Device /dev/i2c-9 lacks R/W permissions
Dec 13 08:05:42 COMPUTER000 spectacle[2972]: warning: queue 0x56098d596c10 destroyed while proxies still attached:
Dec 13 08:05:42 COMPUTER000 spectacle[2972]: wl_callback#61 still attached
Dec 13 08:05:42 COMPUTER000 spectacle[2972]: wl_callback#80 still attached
Dec 13 08:05:42 COMPUTER000 systemd[947]: app-org.kde.spectacle.service: Consumed 6.475s CPU time, 262.1M memory peak.
Dec 13 08:06:15 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Udev event detected
Dec 13 08:06:15 COMPUTER000 rtkit-daemon[1107]: Supervising 11 threads of 3 processes of 1 users.
Dec 13 08:06:15 COMPUTER000 rtkit-daemon[1107]: Successfully made thread 3122 of process 1146 owned by '1000' RT at priority 5.
Dec 13 08:06:15 COMPUTER000 rtkit-daemon[1107]: Supervising 12 threads of 3 processes of 1 users.
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: wp-device: SPA handle 'api.bluez5.enum.dbus' could not be loaded; is it installed?
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: s-monitors: PipeWire's BlueZ SPA plugin is missing or broken. Bluetooth devices will not be supported.
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: wp-device: SPA handle 'api.bluez5.midi.enum' could not be loaded; is it installed?
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: s-monitors: PipeWire's BlueZ MIDI SPA missing or broken. Bluetooth not supported.
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: pw.resource: can't create node: No such file or directory
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: wp-node: failed to create node from factory 'spa-node-factory'
Dec 13 08:06:15 COMPUTER000 wireplumber[1102]: s-monitors: Failed to create BLE MIDI server.
Dec 13 08:06:15 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Adding connected display with bus 7
Dec 13 08:06:15 COMPUTER000 rtkit-daemon[1107]: Successfully made thread 3146 of process 1146 owned by '1000' RT at priority 5.
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: Error detecting VCP version using VCP feature xDF: Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Error detecting VCP version using VCP feature xDF: Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_DDC_DATA(10)]
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Emitting DDCA_Display_Status_Event[1074.522: DDCA_EVENT_DISPLAY_CONNECTED, card1-HDMI-A-1, dref: DDCA_Display_Ref[3], io_path:/dev/i2c-7, >
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Starting 1 callback threads
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] libddcutil callback thread 0x7fcd78003200 started
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Started 1 event callback thread(s)
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Adding connected display with bus 9
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 3161] Invoking callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1074.522: DDCA_EVENT_DISPLAY_CONNECTED, card1-HDMI-A-1, dref>
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 3161] Callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1074.522: DDCA_EVENT_DISPLAY_CONNECTED, card1-HDMI-A-1, dref: DDCA_Di>
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Quiescing libddcutil API...
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Quiesce libddcutil API complete
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Display redetection starting.
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1360] recheck thread terminating because watch thread terminated
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] Emitting DDCA_Display_Status_Event[1074.649: DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-3, dref: DDCA_Display_Ref[4], io_path:/dev/i2c-9, ddc >
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1361] libddcutil callback thread 0x7fcd78024a60 started
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Watch thread terminated.
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 3162] Invoking callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1074.649: DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-3, dref: DD>
Dec 13 08:06:19 COMPUTER000 org_kde_powerdevil[1229]: [ 3162] Callback function 0x7fcda79ec7d0 for event DDCA_Display_Status_Event[1074.649: DDCA_EVENT_DISPLAY_CONNECTED, card1-DP-3, dref: DDCA_Displa>
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] extra_stabilization_millisec: 0, stabilization_poll_millisec: 100
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] libddcutil recheck thread 0x56437a233be0 started
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] libddcutil watch thread 0x56437a220920 started
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Display redetection finished.
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Unquiescing libddcutil API...
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 3170] (dw_recheck_displays_func) Recheck interval: Sleeping for 200 milliseconds
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Quiescing libddcutil API...
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Quiesce libddcutil API complete
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Display redetection starting.
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 3170] recheck thread terminating because watch thread terminated
Dec 13 08:06:22 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Watch thread terminated.
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] extra_stabilization_millisec: 0, stabilization_poll_millisec: 100
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] libddcutil recheck thread 0x56437a236590 started
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] libddcutil watch thread 0x56437a1442b0 started
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Display redetection finished.
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 1229] Unquiescing libddcutil API...
Dec 13 08:06:24 COMPUTER000 org_kde_powerdevil[1229]: [ 3174] (dw_recheck_displays_func) Recheck interval: Sleeping for 200 milliseconds
dmesg (The output starts after a lot of the hardware initialization was done, and just after mounting the filesystem. This was captured after the chromium crash, and after launching firefox and spectacle, and having specactle crash [about 15 minutes after booting]):
[ 8.052790] systemd[1]: RTC configured in localtime, applying delta of -240 minutes to system time.
[ 8.442960] systemd[1]: systemd 258.2-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 8.442970] systemd[1]: Detected architecture x86-64.
[ 8.448083] systemd[1]: Hostname set to <COMPUTER000>.
[ 8.554173] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 8.763717] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.779158] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 8.780038] systemd[1]: Created slice Slice /system/dirmngr.
[ 8.780421] systemd[1]: Created slice Slice /system/getty.
[ 8.780733] systemd[1]: Created slice Slice /system/gpg-agent.
[ 8.781067] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 8.781379] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 8.781677] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 8.781984] systemd[1]: Created slice Slice /system/keyboxd.
[ 8.782303] systemd[1]: Created slice Slice /system/modprobe.
[ 8.782612] systemd[1]: Created slice Encrypted Volume Units Service Slice.
[ 8.782928] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 8.783145] systemd[1]: Created slice User and Session Slice.
[ 8.783201] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.783349] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.783365] systemd[1]: Expecting device /dev/disk/by-uuid/31DA-2A33...
[ 8.783371] systemd[1]: Expecting device /dev/disk/by-uuid/65005827629FD3D8...
[ 8.783376] systemd[1]: Expecting device /dev/disk/by-uuid/69e882ed-f1ef-4bb2-84ca-c2010e8649e7...
[ 8.783386] systemd[1]: Reached target Login Prompts.
[ 8.783394] systemd[1]: Reached target Image Downloads.
[ 8.783401] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 8.783420] systemd[1]: Reached target Remote File Systems.
[ 8.783427] systemd[1]: Reached target Slice Units.
[ 8.783447] systemd[1]: Reached target Local Verity Protected Volumes.
[ 8.783498] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.783567] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.784215] systemd[1]: Listening on Query the User Interactively for a Password.
[ 8.784924] systemd[1]: Listening on Process Core Dump Socket.
[ 8.785418] systemd[1]: Listening on Credential Encryption/Decryption.
[ 8.786020] systemd[1]: Listening on Factory Reset Management.
[ 8.786088] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.786148] systemd[1]: Listening on Journal Sockets.
[ 8.786440] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.786453] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.786501] systemd[1]: Listening on udev Control Socket.
[ 8.786542] systemd[1]: Listening on udev Kernel Socket.
[ 8.786587] systemd[1]: Listening on udev Varlink Socket.
[ 8.787413] systemd[1]: Mounting Huge Pages File System...
[ 8.788012] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.788524] systemd[1]: Mounting Kernel Debug File System...
[ 8.789130] systemd[1]: Mounting Kernel Trace File System...
[ 8.789863] systemd[1]: Starting Create List of Static Device Nodes...
[ 8.790443] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.790465] systemd[1]: Load Kernel Module configfs was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!configfs).
[ 8.791040] systemd[1]: Mounting Kernel Configuration File System...
[ 8.791071] systemd[1]: Load Kernel Module dm_mod was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!dm_mod).
[ 8.791094] systemd[1]: Load Kernel Module drm was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!drm).
[ 8.791115] systemd[1]: Load Kernel Module fuse was skipped because of an unmet condition check (ConditionKernelModuleLoaded=!fuse).
[ 8.791703] systemd[1]: Mounting FUSE Control File System...
[ 8.792367] systemd[1]: Starting Load Kernel Module loop...
[ 8.793033] systemd[1]: Starting Mullvad early boot network blocker...
[ 8.793104] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[ 8.793133] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 8.794625] systemd[1]: Starting Load Kernel Modules...
[ 8.794638] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.795241] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.795270] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.795799] systemd[1]: Starting Load udev Rules from Credentials...
[ 8.796401] systemd[1]: Starting Coldplug All udev Devices...
[ 8.796913] systemd[1]: Starting Virtual Console Setup...
[ 8.798233] systemd[1]: Mounted Huge Pages File System.
[ 8.798313] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.798386] systemd[1]: Mounted Kernel Debug File System.
[ 8.798457] systemd[1]: Mounted Kernel Trace File System.
[ 8.798638] systemd[1]: Finished Create List of Static Device Nodes.
[ 8.798764] systemd[1]: Mounted Kernel Configuration File System.
[ 8.798837] systemd[1]: Mounted FUSE Control File System.
[ 8.799486] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 8.806503] loop: module loaded
[ 8.806897] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 8.807071] systemd[1]: Finished Load Kernel Module loop.
[ 8.807249] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 8.816241] EXT4-fs (dm-0): re-mounted c9e25bfa-5813-4f2f-82e0-833adc8bd7f8.
[ 8.816983] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.817675] systemd[1]: Activating swap /swapfile...
[ 8.822506] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[ 8.823100] systemd[1]: Starting Load/Save OS Random Seed...
[ 8.823120] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 8.823602] systemd[1]: Finished Virtual Console Setup.
[ 8.825557] systemd[1]: Finished Load udev Rules from Credentials.
[ 8.847855] Adding 524284k swap on /swapfile. Priority:-2 extents:1 across:524284k SS
[ 8.847888] systemd[1]: Activated swap /swapfile.
[ 8.847925] systemd[1]: Reached target Swaps.
[ 8.850586] i2c_dev: i2c /dev entries driver
[ 8.851929] systemd[1]: Finished Load/Save OS Random Seed.
[ 9.033543] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 9.076382] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 9.077216] systemd[1]: Starting Create System Users...
[ 9.106100] systemd[1]: Finished Create System Users.
[ 9.107501] systemd[1]: Starting Network Time Synchronization...
[ 9.108136] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 9.115315] systemd[1]: Finished Coldplug All udev Devices.
[ 9.131912] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 9.132001] systemd[1]: Reached target Preparation for Local File Systems.
[ 9.132035] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionVersion=<5.6).
[ 9.134032] systemd[1]: Starting Journal Service...
[ 9.135442] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 9.142006] nvidia: loading out-of-tree module taints kernel.
[ 9.142012] nvidia: module license 'NVIDIA' taints kernel.
[ 9.142014] Disabling lock debugging due to kernel taint
[ 9.142016] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 9.142017] nvidia: module license taints kernel.
[ 9.142331] systemd[1]: Started Network Time Synchronization.
[ 9.142437] systemd[1]: Reached target System Time Set.
[ 9.158614] systemd[1]: mullvad-early-boot-blocking.service: Deactivated successfully.
[ 9.158786] systemd[1]: Finished Mullvad early boot network blocker.
[ 9.159568] systemd-journald[507]: Collecting audit messages is disabled.
[ 9.221122] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 9.221913] systemd[1]: Starting Show Plymouth Boot Screen...
[ 9.240282] systemd[1]: Started Journal Service.
[ 9.247045] systemd-journald[507]: Received client request to flush runtime journal.
[ 9.584444] mc: Linux media interface: v0.10
[ 9.584475] input: PC Speaker as /devices/platform/pcspkr/input/input26
[ 9.585321] dca service started, version 1.12.1
[ 9.585581] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[ 9.585584] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 9.585586] RAPL PMU: hw unit of domain core 2^-16 Joules
[ 9.591605] pps_core: LinuxPPS API ver. 1 registered
[ 9.591607] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 9.591711] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 9.591714] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 9.592244] mousedev: PS/2 mouse device common for all mice
[ 9.593342] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 9.593482] input: Logitech Gamepad F310 as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2.2/5-2.2:1.0/input/input27
[ 9.593957] i2c i2c-0: Successfully instantiated SPD at 0x52
[ 9.594599] i2c i2c-0: Successfully instantiated SPD at 0x53
[ 9.595338] usbcore: registered new interface driver xpad
[ 9.596910] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 9.601077] nvidia 0000:0a:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[ 9.601211] PTP clock support registered
[ 9.622661] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 9.623609] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 9.624880] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 9.633797] asus_wmi: ASUS WMI generic driver loaded
[ 9.658958] asus_wmi: failed to register LPS0 sleep handler in asus-wmi
[ 9.658977] igb: Intel(R) Gigabit Ethernet Network Driver
[ 9.658979] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 9.659283] asus_wmi: Initialization: 0x0
[ 9.659392] asus_wmi: BIOS WMI version: 0.9
[ 9.659656] asus_wmi: SFUN value: 0x0
[ 9.659659] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 9.663414] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input28
[ 9.667354] kvm_amd: TSC scaling supported
[ 9.667356] kvm_amd: Nested Virtualization enabled
[ 9.667358] kvm_amd: Nested Paging enabled
[ 9.667359] kvm_amd: LBR virtualization supported
[ 9.667361] kvm_amd: Virtual VMLOAD VMSAVE supported
[ 9.667362] kvm_amd: Virtual GIF supported
[ 9.687681] igb 0000:08:00.0: added PHC on eth0
[ 9.687711] igb 0000:08:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.687713] igb 0000:08:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 60:45:cb:9a:cf:7d
[ 9.687715] igb 0000:08:00.0: eth0: PBA No: FFFFFF-0FF
[ 9.687717] igb 0000:08:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[ 9.709506] snd_hda_intel 0000:0a:00.1: Disabling MSI
[ 9.709515] snd_hda_intel 0000:0a:00.1: Handle vga_switcheroo audio client
[ 9.709584] snd_hda_intel 0000:0c:00.4: enabling device (0000 -> 0002)
[ 9.713747] ee1004 0-0052: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 9.713811] igb 0000:08:00.0 enp8s0: renamed from eth0
[ 9.715744] ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[ 9.715920] intel_rapl_common: Found RAPL domain package
[ 9.715922] intel_rapl_common: Found RAPL domain core
[ 9.717320] amd_atl: AMD Address Translation Library initialized
[ 9.734636] snd_hda_codec_alc882 hdaudioC2D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 9.734646] snd_hda_codec_alc882 hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 9.734649] snd_hda_codec_alc882 hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 9.734650] snd_hda_codec_alc882 hdaudioC2D0: mono: mono_out=0x0
[ 9.734652] snd_hda_codec_alc882 hdaudioC2D0: dig-out=0x1e/0x0
[ 9.734653] snd_hda_codec_alc882 hdaudioC2D0: inputs:
[ 9.734654] snd_hda_codec_alc882 hdaudioC2D0: Rear Mic=0x18
[ 9.734656] snd_hda_codec_alc882 hdaudioC2D0: Front Mic=0x19
[ 9.734657] snd_hda_codec_alc882 hdaudioC2D0: Line=0x1a
[ 9.739565] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input29
[ 9.739622] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input30
[ 9.739675] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input31
[ 9.739731] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:0a:00.1/sound/card1/input32
[ 9.756735] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input33
[ 9.756811] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input34
[ 9.756864] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input35
[ 9.756929] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input36
[ 9.756981] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input37
[ 9.757040] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input38
[ 9.757093] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0c:00.4/sound/card2/input39
[ 9.757162] snd_hda_intel 0000:0c:00.4: device 1043:8733 is on the power_save denylist, forcing power_save to 0
[ 9.825324] ntfs3: Enabled Linux POSIX ACLs support
[ 9.825327] ntfs3: Read-only LZX/Xpress compression included
[ 9.830226] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 580.105.08 Wed Oct 29 23:15:11 UTC 2025
[ 9.853032] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 580.105.08 Wed Oct 29 22:15:26 UTC 2025
[ 9.859241] [drm] [nvidia-drm] [GPU ID 0x00000a00] Loading driver
[ 10.138517] usb 3-2: Focusrite Scarlett Gen 3 Mixer Driver enabled (pid=0x8210); report any issues to https://github.com/geoffreybennett/scarlett-gen2/issues
[ 10.159486] usb 3-2: Firmware version 1605
[ 10.161166] usbcore: registered new interface driver snd-usb-audio
[ 10.576016] [drm] Initialized nvidia-drm 0.0.0 for 0000:0a:00.0 on minor 1
[ 10.600420] nvidia 0000:0a:00.0: vgaarb: deactivate vga console
[ 10.651593] fbcon: nvidia-drmdrmfb (fb0) is primary device
[ 10.651595] fbcon: Deferring console take-over
[ 10.651597] nvidia 0000:0a:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
[ 10.677672] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 11.175165] NET: Registered PF_QIPCRTR protocol family
[ 13.986982] igb 0000:08:00.0 enp8s0: igb: enp8s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 14.321097] tun: Universal TUN/TAP device driver, 1.6
[ 42.047075] nvme nvme0: using unchecked data buffer
[ 42.051108] block nvme0n1: No UUID available providing old NGUID
[ 642.715812] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 642.860404] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 642.860436] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 642.860463] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 642.860493] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 642.860519] sd 4:0:0:0: Attached scsi generic sg4 type 0
[ 642.860547] sr 6:0:0:0: Attached scsi generic sg5 type 5
[ 642.860572] sd 8:0:0:0: Attached scsi generic sg6 type 0
[ 996.841393] NVRM: GPU at PCI:0000:0a:00: GPU-c7bdbba8-91e4-98de-1f2c-238a131a7cef
[ 996.841397] NVRM: Xid (PCI:0000:0a:00): 32, pid=2972, name=spectacle, channel 0x000000a0 intr 00040000
lsb_release -rics:
ManjaroLinux 25.1.0 Anh-Linh
lspci -vv:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: ASUSTeK Computer Inc. Device 8808
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin ? routed to IRQ 27
Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Subsystem: Advanced Micro Devices, Inc. [AMD] Device 1234
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin ? routed to IRQ 29
IOMMU group: 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled] [32-bit]
Memory behind bridge: f6800000-f68fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
Kernel modules: shpchp
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Interrupt: pin ? routed to IRQ 30
IOMMU group: 2
Bus: primary=00, secondary=02, subordinate=09, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: f6500000-f67fffff [size=3M] [32-bit]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
DeviceName: Onboard IGD
IOMMU group: 3
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 4
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge (prog-if 00 [Normal decode])
Interrupt: pin ? routed to IRQ 31
IOMMU group: 5
Bus: primary=00, secondary=0a, subordinate=0a, sec-latency=0
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: f5000000-f60fffff [size=17M] [32-bit]
Prefetchable memory behind bridge: e0000000-f1ffffff [size=288M] [32-bit]
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 6
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 7
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 8
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 32
IOMMU group: 9
Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
Memory behind bridge: [disabled] [32-bit]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group: 10
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 33
IOMMU group: 11
Bus: primary=00, secondary=0c, subordinate=0c, sec-latency=0
Memory behind bridge: f6200000-f64fffff [size=3M] [32-bit]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: ASUSTeK Computer Inc. Device 87c0
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
IOMMU group: 12
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
IOMMU group: 12
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 0
IOMMU group: 13
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 1
IOMMU group: 13
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 2
IOMMU group: 13
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 3
IOMMU group: 13
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 4
IOMMU group: 13
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 5
IOMMU group: 13
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 6
IOMMU group: 13
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse/Vermeer Data Fabric: Device 18h; Function 7
IOMMU group: 13
01:00.0 Non-Volatile memory controller: Intel Corporation SSD 660P Series (rev 03) (prog-if 02 [NVM Express])
Subsystem: Intel Corporation Device 390d
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 70
IOMMU group: 14
Region 0: Memory at f6800000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset USB 3.1 xHCI Controller (rev 02) (prog-if 30 [XHCI])
Subsystem: ASMedia Technology Inc. Device 1142
Interrupt: pin A routed to IRQ 25
IOMMU group: 15
Region 0: Memory at f67a0000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset SATA Controller (rev 02) (prog-if 01 [AHCI 1.0])
Subsystem: ASMedia Technology Inc. Device 1062
Interrupt: pin B routed to IRQ 41
IOMMU group: 15
Region 5: Memory at f6780000 (32-bit, non-prefetchable) [size=128K]
Expansion ROM at f6700000 [disabled] [size=512K]
Kernel driver in use: ahci
Kernel modules: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] X370 Series Chipset PCIe Upstream Port (rev 02) (prog-if 00 [Normal decode])
Subsystem: ASMedia Technology Inc. Device 0201
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin C routed to IRQ 24
IOMMU group: 15
Bus: primary=02, secondary=03, subordinate=09, sec-latency=0
Memory behind bridge: f6500000-f66fffff [size=2M] [32-bit]
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Subsystem: ASMedia Technology Inc. Device 3306
Interrupt: pin A routed to IRQ 34
IOMMU group: 15
Bus: primary=03, secondary=04, subordinate=04, sec-latency=0
03:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 35
IOMMU group: 15
Bus: primary=03, secondary=05, subordinate=05, sec-latency=0
03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 36
IOMMU group: 15
Bus: primary=03, secondary=06, subordinate=06, sec-latency=0
03:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 37
IOMMU group: 15
Bus: primary=03, secondary=07, subordinate=07, sec-latency=0
Memory behind bridge: f6600000-f66fffff [size=1M] [32-bit]
03:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 38
IOMMU group: 15
Bus: primary=03, secondary=08, subordinate=08, sec-latency=0
Memory behind bridge: f6500000-f65fffff [size=1M] [32-bit]
03:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 39
IOMMU group: 15
Bus: primary=03, secondary=09, subordinate=09, sec-latency=0
07:00.0 USB controller: ASMedia Technology Inc. ASM1143 USB 3.1 Host Controller (prog-if 30 [XHCI])
Subsystem: ASUSTeK Computer Inc. Device 86f2
IOMMU group: 15
Region 0: Memory at f6600000 (64-bit, non-prefetchable) [size=32K]
08:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
Subsystem: ASUSTeK Computer Inc. Device 85f0
Interrupt: pin A routed to IRQ 24
IOMMU group: 15
Region 0: Memory at f6500000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at e000 [size=32]
Region 3: Memory at f6520000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: igb
Kernel modules: igb
0a:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device 1445
Latency: 0
Interrupt: pin A routed to IRQ 89
IOMMU group: 16
Region 0: Memory at f5000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at f0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at d000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nova_core, nvidia_drm, nvidia
0a:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 86
IOMMU group: 16
Region 0: Memory at f6080000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group: 17
0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group: 18
0c:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 67
IOMMU group: 19
Region 2: Memory at f6300000 (32-bit, non-prefetchable) [size=1M]
Region 5: Memory at f6408000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: ccp
Kernel modules: ccp
0c:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller (prog-if 30 [XHCI])
Interrupt: pin C routed to IRQ 58
IOMMU group: 20
Region 0: Memory at f6200000 (64-bit, non-prefetchable) [size=1M]
0c:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: ASUSTeK Computer Inc. Device 8733
Interrupt: pin D routed to IRQ 88
IOMMU group: 21
Region 0: Memory at f6400000 (32-bit, non-prefetchable) [size=32K]
If you made it this far, thanks for taking a look! Sorry for the book! That wasn’t supposed to rhyme, but it is what it is.
