Brother DCP-J315W via WiFi
  Kernel: 5.19.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
    root=UUID=d540af20-98bf-4853-84e1-5bce691c998d rw quiet
    udev.log_priority=3 i915.i915_enable_rc6=1 i915.i915_enable_fbc=1
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Swift SF314-511 v: V1.10
    serial: <superuser required>
  Mobo: TGL model: Sake_TL v: V1.10 serial: <superuser required>
    UEFI: Insyde v: 1.10 date: 09/16/2021
  ID-1: BAT1 charge: 42.9 Wh (76.3%) condition: 56.2/56.0 Wh (100.4%)
    volts: 16.1 min: 15.4 model: SMP AP18C7M type: Li-ion serial: <filter>
    status: discharging cycles: 57
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
    serial: <filtercharge: 55% (should be ignored) rechargeable: yes
    status: discharging
  RAM: total: 15.42 GiB used: 2.19 GiB (14.2%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA4
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1685 high: 2400 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2400 2: 1040 3: 2400
    4: 968 5: 887 6: 2400 7: 2400 8: 989 bogomips: 38720
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Acer
    Incorporated ALI driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-5:3
    chip-ID: 04f2:b6dd class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0xda91 built: 2020 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Acer Incorporated
    ALI driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound API: ALSA v: k5.19.16-2-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.58 running: no
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  IP v4: <filtertype: dynamic noprefixroute scope: global
  IP v6: <filtertype: noprefixroute scope: link
  Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: cdc_ncm
    bus-ID: 2-1:2 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
  IF: enp0s13f0u1c2 state: up speed: 100 Mbps duplex: half mac: <filter>
    bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 62.27 GiB (13.1%)
    model: MZVL2512HCJQ-00BT7 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: GXA7302Q temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 220.17 GiB size: 215.65 GiB (97.95%) used: 62.27 GiB
    (28.9%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: d540af20-98bf-4853-84e1-5bce691c998d
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: NO_LABEL
    uuid: 375E-CC05
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: ESP
    uuid: 44A6-6A0A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 255.37 GiB fs: ntfs label: Acer
    uuid: EE4AA6FE4AA6C327
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1024 MiB fs: ntfs
    label: Recovery uuid: 782CA7A32CA75B40
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-1:2 info: ASIX AX88179 Gigabit Ethernet
    type: Communication,CDC-Data driver: cdc_ncm interfaces: 2 rev: 3.2
    speed: 5 Gb/s power: 184mA chip-ID: 0b95:1790 class-ID: 0a00
    serial: <filter>
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-5:3 info: Chicony HD User Facing type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6dd
  Device-3: 3-7:4 info: LighTuning EgisTec EH575 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
    chip-ID: 1c7a:0575 class-ID: ff00 serial: <filter>
  Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 33.0 C mobo: N/A
  Processes: 285 Uptime: 8m wakeups: 320 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1405 pm: pacman pkgs: 1400 libs: 360 tools: pamac pm: flatpak
  pkgs: 5 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
The driver for  *brother-dcpj315w 1.1.3-6* is installed.
sudo systemctl -a list-units | grep -i cups
  cups.path        loaded    active   running   CUPS Scheduler
  cups.service        loaded    active   running   CUPS Scheduler
  cups.socket        loaded    active   running   CUPS Scheduler
I have tried:
sudo systemctl restart org.cups.cupsd.service
I can access the setting by means of:
http://localhost:631
Should I go with: https://github.com/manjaro/packages-core/blob/Chrysostomus-patch-1/filesystem/nsswitch.conf
Hi @korben,
Perhaps this helps:
On cable it works perfectly fine.
It used to be fully functional but now with freshly installed Manjaro I have lost the function.
The guide I am thankful, seems complicated. Oh boy
This thread was helpful
https://bbs.archlinux.org/viewtopic.php?id=189353
By adding lpd://192.168. the printer got started and I am happy now.
Basically I had to retrace all my steps and reconfigure the router to make things go right. It was the culprit of all evil.
Manjaro rules.
