Turn printer on and Monjaro installs the printer automatically problem is the scanner.
I have been using Linux for many years but I am new to Nanjaro and Arch.
Any help would be greatly appreciated.
Well, let’s start with a little housekeeping…
In this forum we discuss issues related to the Manjaro Linux OS;
and, not;
nor;
With that out of the way, I’ll note that it’s often difficult to find Linux drivers for Brother multifunction devices, if they exist at all. However, it may be possible that this 7030 driver from the AUR also supports the 7020:
Plus there is this one:
Or, specifically for scanner functionality, perhaps this one:
Note the usual warnings apply with regard using the AUR:
The following links may be useful, generally:
Please provide your system information as described (below) to assist those wishing to help to identify other possible solutions.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a
at their disposal – instead, please help others to make informed suggestions based on information you provide.
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
| inxi man pages | (manual) |
--color=0 to the long-form command, or…inxi -zv8c0There is several scanner applications - I remember I had a wireless HP multi function device - the only way to make it work was to use simple-scan - available from the repos.
sudo pacman -Syu simple-scan
Launch the app and configure the application to use your scanner’s network address if applicable - an USB connected device work too.
I have limited experience with scanners, but it is also possible you need sane and sane-airscan packages.
