Angela
13 October 2023 08:44
1
Hello, I’m new to Linux, installed Manjaro xfce (kernel 6.1.55) today.
I’ve been browsing through networking issues all day with my USB wireless adapter, only to find out the issue is the broken wireless switch on my laptop.
The USB adapter works when I manage to turn the switch on (proper drivers installed, finds networks to connect, all fine), but said switch is broken, and it doesn’t last long.
This looks like a hardware issue, but it does not happen on Windows. With the switch off, my USB adapter is still detected and works perfectly.
I tried blacklisting the driver module for the internal adapter but no dice, the switch still rules supreme.
What can I do? thank you in advance.
P.S: Currently I’m tethering with my phone and wasting data because ethernet isn’t an option, and the phone wifi signal is terrible. The USB adapter is my only real option.
banjo
13 October 2023 14:55
2
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Welcome, who ever can help, can do it only with system info.
Angela
15 October 2023 03:52
3
Sorry about that, and the delay adding the necessary info.
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=26792648-2907-47b5-ad96-01e874645fa5 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Sony product: VPCEG23EL v: C9028MG0
Mobo: Sony model: VAIO serial: <superuser required> BIOS: INSYDE v: R0240Z8
date: 01/06/2012
ID-1: BAT0 charge: 23.5 Wh (100.0%) condition: 23.5/62.6 Wh (37.5%)
volts: 12.3 min: 10.8 model: Sony Corp. VGP-BPS26A type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-2330M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1149 high: 2200 min/max: 800/2200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2200 2: 800 3: 800 4: 798
bogomips: 17567
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Sony driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Suyin Sony Visual Communication Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:3
chip-ID: 064e:a21b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: LVDS-1 model: LG Display 0x02e9 built: 2010 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
vendor: Sony 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn
driver: N/A modules: ath9k pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:002b class-ID: 0280
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Sony
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 09:00.0 chip-ID: 1969:1083 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
Device-3: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] driver: rtl8188eu
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.1:3
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
IF: wlp0s29u1u1 state: up mac: <filter>
Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.5:4 chip-ID: 0cf3:3005
class-ID: e001
Local Storage: total: 465.76 GiB used: 12.48 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK5059GSXP
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1H scheme: MBR
ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 12.48 GiB (6.4%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 206 Uptime: 2m wakeups: 1 Memory: total: 4 GiB available: 3.78 GiB
used: 1.8 GiB (47.8%) Init: systemd v: 254 default: graphical tool: systemctl
Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman pkgs: 1169
libs: 401 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.30
how should I proceed?
Angela:
The hardware switch has no bearing when using an usb adapter.
If you cannot turn on the internal wifi when returning to Manjaro from Windows - ensure you shutdown your windows cleanly - no hibernation or hybrid sleep - also disable Windows Fast Startup.
Angela
15 October 2023 05:59
5
I -can- turn the internal wifi adapter when the switch the decides to work, the problem is that there’s no wifi function at all unless the switch is on. The “Enable Wi-Fi” option is either greyed out or completely gone if I don’t turn it on. (Depends on whether the USB adapter is plugged in. The system detects it, it just won’t let me use it unless I turn the switch on)
I’m assuming it’s a software issue precisely because this does not happen on Windows, but I don’t know enough about Linux to guess what conflict could there possibly be.
Win7 (the one I have) has no fast start-up, and neither does my BIOS.
How do I make sure it’s not hybrid sleep or hibernation? I just either choose shut down or restart, and it always does the entire boot process, but it’s not something I’ve ever paid much attention to.
The hardware switch is only for the internal wifi adapter and has no value for USB wifi adapter.
What you experience is more likely caused by rfkill(8) — Arch manual pages
Use the power settings control panel item in Windows
