My laptop is an schmuck because when i opened manjaro it connects but refreshing the web will not load back. Windows is ok ( i am writing this on windows ) is my network adapter broken? What? /??? S
It’s probably a driver issue on Linux. You’ve been told multiple times in other threads you’ve posted how to post your inxi output so we know which hardware your laptop has. Without this information, nobody here can help you.
My inxi:
Kernel: 6.12.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=7d636cc1-cc97-4108-8039-fec5f183efb2 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: budgie-screensaver vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0974120000405F00000620180 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 2268 v: 73.35 serial: <superuser required>
part-nu: N8H90EA#UUW uuid: <superuser required> UEFI: American Megatrends
v: F.33 date: 11/21/2014
ID-1: BAT0 charge: 23.2 Wh (94.3%) condition: 24.6/24.6 Wh (100.0%)
power: 5.9 W volts: 17.2 min: 14.8 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: charging cycles: 221
System RAM: total: 16 GiB available: 14.57 GiB used: 978.1 MiB (6.6%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: Bottom-Slot 1 (left) type: DDR3 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: spec: 1600 MT/s actual: 1333 MT/s volts:
curr: 2 min: 1.35 max: 2 width (bits): data: 64 total: 64
manufacturer: Hynix part-no: HMT41GS6DFR8A-PB serial: <filter>
Device-2: Bottom-Slot 2 (right) type: DDR3 detail: synchronous unbuffered
manufacturer: Samsung part-no: M471B1G73QH0-YK0 serial: <filter>
Info: model: AMD A4-6210 APU with AMD Radeon R3 Graphics bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22)
model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1000 min/max: 1000/1800 boost: disabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1000 2: 1000 3: 1000
4: 1000 bogomips: 14377
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe
msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall
wdt xsave xsaveopt
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R3 Graphics]
vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9850
class-ID: 0300
Device-2: Chicony HP Truevision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.2:3 chip-ID: 04f2:b45e
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: radeon display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: BOE Display 0x0618 built: 2014 res: 1366x768
dpi: 102 gamma: 1.2 chroma: red: x: 0.584 y: 0.345 green: x: 0.333 y: 0.569
blue: x: 0.165 y: 0.118 white: x: 0.310 y: 0.337
size: 277x156mm (10.91x6.14") diag: 389mm (15.3") ratio: 16:9, 15:9
modes: 1366x768, 1280x720, 1152x768, 1024x768, 800x600, 848x480, 720x480,
640x480
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1 glx-v: 1.4
direct-render: yes renderer: KABINI (radeonsi LLVM 18.1.8 DRM 2.50
6.12.1-4-MANJARO) device-ID: 1002:9850 memory: 1000 MiB unified: no
Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:9840 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
class-ID: 0403
Device-3: Jieli USB Audio Device driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
chip-ID: 4c4a:3435 class-ID: 0300
API: ALSA v: k6.12.1-4-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off tools: qjackctl
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 2.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:3 chip-ID: 0bda:b001
Local Storage: total: 476.94 GiB used: 12.58 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T-FORCE 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: LA.5 scheme: GPT
ID-1: / raw-size: 59.31 GiB size: 58.08 GiB (97.92%) used: 12.55 GiB (21.6%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 7d636cc1-cc97-4108-8039-fec5f183efb2
used: 31.3 MiB (10.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1609-A1CB
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: ext4 label: kubuntu_2404
uuid: 4f03e560-d858-47c1-943e-688fd87097b2
ID-2: /dev/sda3 maj-min: 8:3 size: 417.32 GiB fs: ntfs label: N/A
uuid: EA4EC14F4EC114EB
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: Jieli USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
Device-2: 1-2:3 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:0300 class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
chip-ID: 0438:7900 class-ID: 0900
Device-1: 3-1.3:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b001 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 4-1.2:3 info: Chicony HP Truevision HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b45e class-ID: 0e02
System Temperatures: cpu: 53.0 C mobo: N/A gpu: radeon temp: 52.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1174 libs: 350 tools: pamac pm: flatpak pkgs: 0
1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
3: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
Processes:
CPU top: 5 of 196
1: cpu: 4.1% command: Xorg pid: 774 mem: 92.7 MiB (0.6%)
2: cpu: 3.8% command: xfdesktop pid: 1024 mem: 66.3 MiB (0.4%)
3: cpu: 2.7% command: xfce4-terminal pid: 1388 mem: 60.1 MiB (0.4%)
4: cpu: 2.6% command: xfwm4 pid: 968 mem: 99.9 MiB (0.6%)
5: cpu: 2.5% command: blueman-applet started-by: python pid: 1100
mem: 67.0 MiB (0.4%)
Memory top: 5 of 196
1: mem: 99.9 MiB (0.6%) command: xfwm4 pid: 968 cpu: 2.6%
2: mem: 92.7 MiB (0.6%) command: Xorg pid: 774 cpu: 4.1%
3: mem: 67.0 MiB (0.4%) command: blueman-applet started-by: python
pid: 1100 cpu: 2.5%
4: mem: 66.3 MiB (0.4%) command: xfdesktop pid: 1024 cpu: 3.8%
5: mem: 65.7 MiB (0.4%) command: nm-applet pid: 1091 cpu: 1.2%
Processes: 196 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.81 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.36
Hi @LinuxPersuasive ,
I wonder whether you could read this post in order to solve your problem:
‘Wifi randomly gets slow, but doesn't drop entirely - #4 by Mirdarthos’
I also notice that no mac address is assigned to the wifi card, from the inxi command output:
class-ID: 0280
IF: wlo1 state: up mac:
Could you post the following terminal command?
ip a
Hope it help,
Regards
Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
As I’m a moderator on the forum, I have taken the liberty of doing this for you, this time.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is pre-prepared as a general introduction for new forum Users. Please take the time to to understand how it is done and encourage quality responses.
Actually it’s filtered, by the inxi parameters used:
We don’t know which inxi options were used. This is why I would recommend that the command itself is included in the copy and paste.
As most hardware drivers are interal part of the kernel: Update your system!
sudo pacman -Syu
Not linked to your issue, but why are you using the radeon driver for your graphics? You should user the much better driver amdgpu instead.
