Broken pacman, can't fix keyring, broken solution, and can't update nvidia
I apologize for a previous post that had to do with this or a similar problem, but I was unable to respond because life got in the way. Fortunately it was resolved for someone else who chimed in with the same issue. :slight_smile:
I haven’t been able to install any packages that required importing keys. Nothing imperative so I did without extra packages. Now I’m having more issues.
First, I can’t update nvidia drivers with new kernel. This lead to working on updating the keyring, because that’s been a mess. I first noticed pacman was having issues when running ā€˜bmenu’, ā€œFix Pacmanā€ was highlighted RED and I ran it a few times. The problem persisted, or it stayed red anyway. Now I have looked for solutions and came to here: https://wiki.manjaro.org/index.php/Pacman_troubleshooting
successfully updated manjaro-keyring, but archlinux-keyring-*-any.pkg.tar.xz does not exist, at least not at that address.
I went back to trying to resolve the problem of installing my nvidia drivers. I found a solution here: https://forum.manjaro.org/t/unable-to-satisfy-dependency-nvidia-driver-install/22864
I get all the way to removing cuda to prepare for installing my nvidia-x-x-prime (i am on a hybrid/alienware laptop) and then follow up with:
sudo mhwd -f -i pci video-hybrid-intel-nvidia-450xx-prime
and get:
**> Installing video-hybrid-intel-nvidia-450xx-prime...**
Using default
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-450xx-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
resolving dependencies...
Packages (4) lib32-nvidia-450xx-utils-450.66-1  linux58-nvidia-450xx-450.66-15  nvidia-450xx-utils-450.66-1  nvidia-prime-1.0-4
Total Installed Size:  367.82 MiB
checking keyring...
downloading required keys...
:: Import PGP key CAA6A59611C7F07E, "Philip Mueller <philm@manjaro.org>"? [Y/n] error: key "CAA6A59611C7F07E" could not be looked up remotely
y:: Import PGP key 428F7ECC7117F726, "Helmut Stult <helmut@manjaro.org>"? [Y/n] error: key "428F7ECC7117F726" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
Error: pacman failed!
**Error: script failed!**
Seemed to have found solution here: https://www.cupoflinux.com/SBB/index.php?topic=2959.15
…but ran into multiple issues getting through anything. first:
sudo pacman-mirrors -g     # This will update the mirrors
sudo pacman -Syy           # This will sync your local package-list
sudo pacman -S gnupg       # This will (re-)install your gpg-keys
sudo pacman-key --populate archlinux manjaro   # This will re-populate your Arch- & Manjaro-keys
sudo pacman-key --refresh-keys                 # This will refresh your pacman-keys
sudo pacman -S archlinux-keyring               # This will install the archlinux-keyring
sudo pacman -Syyu          # This will finally upgrade all your packages
I got to second line and this is what I get:
> sudo pacman -Syy
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to synchronize all databases
So I followed up with the next:
sudo rm -R /etc/pacman.d/gnupg/
sudo rm -R /root/.gnupg/
sudo gpg --refresh-keys
sudo pacman-key --init && pacman-key --populate archlinux manjaro
got all the way to the last line thinking, OMG I’m saved but instead…
gpg: refreshing 139 keys from hkps://hkps.pool.sks-keyservers.net
gpg: keyserver refresh failed: General error
==> ERROR: A specified local key could not be updated from a keyserver.
I’m so hoping someone can help me get out of this. I am trying so hard just to get to work. I don’t know what I’m missing… I seem to fix one thing just to have something else break on me. My system was fine till I found out it wasn’t able to detect my audio interface due to being on a RT kernel. Once I switched to the newest stable (I think)… it picked it up without me even asking… at the same time, I lose my dual monitors because for some reason I can’t install the graphics card because of this keyring issue… that was never a problem before, until now, when I needed to get nvidia drivers. But this pgp problem has been here from the get go. I need to find a solution or i’m just gonna have to can it and move on to something else so I can have my studio back. :frowning:
Try sudo pacman-key --keyserver hkp://pool.sks-keyservers.net --refresh-keys
On top of @wntr 's advice:
Why are you trying to update to the 450 series unless you have a brand-new card?
(Have a look at my profile: the 450 series has a lot of bugs. If you have the 440 series: stay where you are!)
:scream:
I guess because keeping your graphics driver up to date has always been a standard for me. But, good to know. I somehow got past the issue. I have 2 monitors working and everything seems to be okay graphically… but then I seem to have this same problem happening again and again, I get one thing fixed and another things breaks… and it’s been the SAME 2 ISSUES back and forth. And that is my audio going completely dead.
I’m so ready to kick a hole in something cus it never ends… for months now anyway. I keep reinstalling Manjaro thinking I got it this time but it happens every time.
My audio works at first, then I set up the graphics… I barely succeed in getting it to work, like it is now, and somehow through that process I lose my audio. ALSA does not detect anything. Suddenly any volume controls or configs for pulseaudio and jack are empty and nothing I do works.
The whole point of getting this system running is to make a home audio station. I have somehow completely failed at it, never even being able to play a single note through it. I’m pretty much just distraught over this. Frustrated to the core.
I appreciate the feedback.
it’s something that is happening to me too much. And I think in the wiki of manjaro has to be…
I entered that and received gpg: keyserver refresh failed: Server indicated a failure
==> ERROR: A specified local key could not be updated from a keyserver. Help
