Brightness resets to full on every reboot
Hi , I am facing an issue with my brightness level. Brightness level on my system resets to full everytime after booting up or going to standby (Suspend) mode.
Is there any way to fix it
My system info :point_down:
  Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=862c3f08-7702-4095-a6db-2af19df49c8a ro quiet apparmor=1
  security=apparmor resume=UUID=f1124687-67f4-4db2-911b-5a7b8785b6e7
  udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
  wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
  base: Arch Linux
  Type: Portable System: Dell product: Inspiron N5010 v: A04 serial: <filter>
  Mobo: Dell model: 0WXY9J v: A04 serial: <filter> UEFI-[Legacy]: Dell v: A04
  date: 05/10/2010
  ID-1: BAT0 charge: 3.5 Wh (62.5%) condition: 5.6/48.8 Wh (11.5%) volts: 12.6
  min: 11.1 model: SMP-PA2.2 DELL W7H3N04 type: Li-ion serial: <filter>
  status: Charging
  RAM: total: 3.64 GiB used: 2.41 GiB (66.2%)
  Info: Dual Core model: Intel Core i3 M 350 bits: 64 type: MT MCP
  arch: Nehalem family: 6 model-id: 25 (37) stepping: 2 microcode: 11 cache:
  L2: 3 MiB bogomips: 18141
  Speed: 1467 MHz min/max: 931/2261 MHz Core speeds (MHz): 1: 1467 2: 1466
  3: 1025 4: 1466
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
  cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
  fpu fxsr ht ibpb ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc
  nopl nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good
  sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  vme vmx vnmi vpid xtopology xtpr
  Type: l1tf
  Type: mds
  status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
  Device-1: Intel Core Processor Integrated Graphics vendor: Dell driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
  Device-2: Microdia Laptop_Integrated_Webcam_1.3M type: USB driver: uvcvideo
  bus-ID: 1-1.6:3 chip-ID: 0c45:6461 class-ID: 0e02
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.2.2
  direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: yes
  Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter
  vendor: Dell Inspiron M5010 / XPS 8300 driver: wl v: kernel modules: bcma
  port: f000 bus-ID: 12:00.0 chip-ID: 14e4:4727 class-ID: 0280
  IF: wlp18s0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: e000 bus-ID: 13:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  IF: enp19s0 state: down mac: <filter>
  Local Storage: total: 232.89 GiB used: 53.76 GiB (23.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK2565GSX
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: HDD rpm: 5400 serial: <filter> rev: 2D scheme: MBR
  Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DS-8A4S rev: JD12
  dev-links: cdrom
  Features: speed: 8 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 60.01 GiB size: 58.82 GiB (98.01%) used: 53.72 GiB (91.3%)
  fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 862c3f08-7702-4095-a6db-2af19df49c8a
  ID-1: swap-1 type: partition size: 3.91 GiB used: 41.6 MiB (1.0%)
  priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: f1124687-67f4-4db2-911b-5a7b8785b6e7
  ID-1: /dev/sda2 maj-min: 8:2 size: 72.8 GiB fs: ext4 label: N/A
  uuid: f7fca390-c2c4-4295-b91d-a1d418ebe92c
  ID-2: /dev/sda4 maj-min: 8:4 size: 96.17 GiB fs: ntfs label: N/A
  uuid: D268537A68535BF3
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
  Device-1: 1-1.6:3 info: Microdia Laptop_Integrated_Webcam_1.3M type: Video
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.1:3 info: MOSART Semi. 2.4G Wireless Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 3938:1031 class-ID: 0301
  Hub-5: 2-1.6:4
  info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
  rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 2-1.6.1:5 info: Dell Integrated Keyboard type: Keyboard
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
  chip-ID: 413c:8161 class-ID: 0301
  Device-2: 2-1.6.2:6 info: Dell Integrated Touchpad [Synaptics] type: Mouse
  chip-ID: 413c:8162 class-ID: 0301
  System Temperatures: cpu: 57.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 3200
  Processes: 208 Uptime: 13h 36m wakeups: 5 Init: systemd v: 249
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1227 lib: 401
  flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
Thank you. That looks good.
Please do the following:
  • Sutdown
  • Note the time
  • start PC
  • Log in
  • provide the output of:
    journalctl --system --boot=0 --since "YYYY-MM-DD HH:MM:SS"
    where obviously --since is the datetime noted earlier.
:thinking:
The output was too long :grin:
[alan@alan-inspironn5010~] $ journalctl --system --boot=0 --since "2021-10-10 16:22:00"
-- Journal begins at Sat 2021-01-09 02:22:28 IST, ends at Sun 2021-10-10 16:24:>
Oct 10 16:23:08 alan-inspironn5010 kernel: microcode: microcode updated early t>
Oct 10 16:23:08 alan-inspironn5010 kernel: Linux version 5.10.68-1-MANJARO (bui>
Oct 10 16:23:08 alan-inspironn5010 kernel: Command line: BOOT_IMAGE=/boot/vmlin>
Oct 10 16:23:08 alan-inspironn5010 kernel: x86/fpu: x87 FPU will use FXSAVE
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-provided physical RAM map:
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x0000000000000000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x000000000009d400-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000000e0000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x0000000000100000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb587000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb5cf000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb5d9000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb5dc000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb621000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb629000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb62c000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb631000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb651000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bb694000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000bde00000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000e0000000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000fed1c000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x00000000ff000000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: BIOS-e820: [mem 0x0000000100000000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: NX (Execute Disable) protection: act>
Oct 10 16:23:08 alan-inspironn5010 kernel: SMBIOS 2.6 present.
Oct 10 16:23:08 alan-inspironn5010 kernel: DMI: Dell Inc. Inspiron N5010/0WXY9J>
Oct 10 16:23:08 alan-inspironn5010 kernel: tsc: Fast TSC calibration using PIT
Oct 10 16:23:08 alan-inspironn5010 kernel: tsc: Detected 2266.676 MHz processor
Oct 10 16:23:08 alan-inspironn5010 kernel: e820: update [mem 0x00000000-0x00000>
Oct 10 16:23:08 alan-inspironn5010 kernel: e820: remove [mem 0x000a0000-0x000ff>
Oct 10 16:23:08 alan-inspironn5010 kernel: last_pfn = 0x138000 max_arch_pfn = 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: MTRR default type: uncachable
Oct 10 16:23:08 alan-inspironn5010 kernel: MTRR fixed ranges enabled:
Oct 10 16:23:08 alan-inspironn5010 kernel:   00000-9FFFF write-back
Oct 10 16:23:08 alan-inspironn5010 kernel:   A0000-BFFFF uncachable
Oct 10 16:23:08 alan-inspironn5010 kernel:   C0000-D3FFF write-protect
Oct 10 16:23:08 alan-inspironn5010 kernel:   D4000-E7FFF uncachable
Oct 10 16:23:08 alan-inspironn5010 kernel:   E8000-FFFFF write-protect
Oct 10 16:23:08 alan-inspironn5010 kernel: MTRR variable ranges enabled:
Oct 10 16:23:08 alan-inspironn5010 kernel:   0 base 000000000 mask F00000000 wr>
Oct 10 16:23:08 alan-inspironn5010 kernel:   1 base 100000000 mask FC0000000 wr>
Oct 10 16:23:08 alan-inspironn5010 kernel:   2 base 0BC000000 mask FFC000000 un>
Oct 10 16:23:08 alan-inspironn5010 kernel:   3 base 0C0000000 mask FC0000000 un>
Oct 10 16:23:08 alan-inspironn5010 kernel:   4 base 138000000 mask FF8000000 un>
Oct 10 16:23:08 alan-inspironn5010 kernel:   5 disabled
Oct 10 16:23:08 alan-inspironn5010 kernel:   6 disabled
Oct 10 16:23:08 alan-inspironn5010 kernel:   7 disabled
Oct 10 16:23:08 alan-inspironn5010 kernel: x86/PAT: Configuration [0-7]: WB  WC>
Oct 10 16:23:08 alan-inspironn5010 kernel: total RAM covered: 3904M
Oct 10 16:23:08 alan-inspironn5010 kernel: Found optimal setting for mtrr clean>
Oct 10 16:23:08 alan-inspironn5010 kernel:  gran_size: 64K         chunk_size: >
Oct 10 16:23:08 alan-inspironn5010 kernel: e820: update [mem 0xbc000000-0xfffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: last_pfn = 0xbb800 max_arch_pfn = 0x>
Oct 10 16:23:08 alan-inspironn5010 kernel: found SMP MP-table at [mem 0x000fcda>
Oct 10 16:23:08 alan-inspironn5010 kernel: check: Scanning 1 areas for low memo>
Oct 10 16:23:08 alan-inspironn5010 kernel: RAMDISK: [mem 0x36813000-0x37400fff]
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Early table checksum verificat>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: RSDP 0x00000000000F0410 000024>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: XSDT 0x00000000BB5CF088 00005C>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: FACP 0x00000000BB5D8098 0000F4>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: DSDT 0x00000000BB5CF170 008F27>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: FACS 0x00000000BB62CF40 000040
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: FACS 0x00000000BB62CF80 000040
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: APIC 0x00000000BB5D8190 000072>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: SSDT 0x00000000BB5D8208 00014E>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: MCFG 0x00000000BB5D8358 00003C>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: HPET 0x00000000BB5D8398 000038>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: UEFI 0x00000000BB5D83D0 000042>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: OSFR 0x00000000BB5D8418 00008C>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving FACP table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving DSDT table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving FACS table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving APIC table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving SSDT table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving MCFG table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving HPET table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving UEFI table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Reserving OSFR table memory at>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Local APIC address 0xfee00000
Oct 10 16:23:08 alan-inspironn5010 kernel: No NUMA configuration found
Oct 10 16:23:08 alan-inspironn5010 kernel: Faking a node at [mem 0x000000000000>
Oct 10 16:23:08 alan-inspironn5010 kernel: NODE_DATA(0) allocated [mem 0x137ff9>
Oct 10 16:23:08 alan-inspironn5010 kernel: Zone ranges:
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA      [mem 0x0000000000001000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA32    [mem 0x0000000001000000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel:   Normal   [mem 0x0000000100000000-0>
Oct 10 16:23:08 alan-inspironn5010 kernel:   Device   empty
Oct 10 16:23:08 alan-inspironn5010 kernel: Movable zone start for each node
Oct 10 16:23:08 alan-inspironn5010 kernel: Early memory node ranges
Oct 10 16:23:08 alan-inspironn5010 kernel:   node   0: [mem 0x0000000000001000->
Oct 10 16:23:08 alan-inspironn5010 kernel:   node   0: [mem 0x0000000000100000->
Oct 10 16:23:08 alan-inspironn5010 kernel:   node   0: [mem 0x00000000bb694000->
Oct 10 16:23:08 alan-inspironn5010 kernel:   node   0: [mem 0x0000000100000000->
Oct 10 16:23:08 alan-inspironn5010 kernel: Initmem setup node 0 [mem 0x00000000>
Oct 10 16:23:08 alan-inspironn5010 kernel: On node 0 totalpages: 997007
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA zone: 64 pages used for memmap
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA zone: 21 pages reserved
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA zone: 3996 pages, LIFO batch:0
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA32 zone: 11932 pages used for m>
Oct 10 16:23:08 alan-inspironn5010 kernel:   DMA32 zone: 763635 pages, LIFO bat>
Oct 10 16:23:08 alan-inspironn5010 kernel:   Normal zone: 3584 pages used for m>
Oct 10 16:23:08 alan-inspironn5010 kernel:   Normal zone: 229376 pages, LIFO ba>
Oct 10 16:23:08 alan-inspironn5010 kernel: On node 0, zone DMA: 1 pages in unav>
Oct 10 16:23:08 alan-inspironn5010 kernel: On node 0, zone DMA: 99 pages in una>
Oct 10 16:23:08 alan-inspironn5010 kernel: On node 0, zone DMA32: 269 pages in >
Oct 10 16:23:08 alan-inspironn5010 kernel: On node 0, zone Normal: 18432 pages >
Oct 10 16:23:08 alan-inspironn5010 kernel: Reserving Intel graphics memory at [>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PM-Timer IO Port: 0x408
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high >
Oct 10 16:23:08 alan-inspironn5010 kernel: IOAPIC[0]: apic_id 0, version 32, ad>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 g>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 g>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: IRQ0 used by override.
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: IRQ9 used by override.
Oct 10 16:23:08 alan-inspironn5010 kernel: Using ACPI (MADT) for SMP configurat>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: HPET id: 0x8086a701 base: 0xfe>
Oct 10 16:23:08 alan-inspironn5010 kernel: smpboot: Allowing 4 CPUs, 0 hotplug >
Oct 10 16:23:08 alan-inspironn5010 kernel: PM: hibernation: Registered nosave m>
Oct 10 16:23:08 alan-inspironn5010 kernel: [mem 0xc0000000-0xdfffffff] availabl>
Oct 10 16:23:08 alan-inspironn5010 kernel: Booting paravirtualized kernel on ba>
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: refined-jiffies: mask: >
Oct 10 16:23:08 alan-inspironn5010 kernel: setup_percpu: NR_CPUS:320 nr_cpumask>
Oct 10 16:23:08 alan-inspironn5010 kernel: percpu: Embedded 56 pages/cpu s19251>
Oct 10 16:23:08 alan-inspironn5010 kernel: pcpu-alloc: s192512 r8192 d28672 u52>
Oct 10 16:23:08 alan-inspironn5010 kernel: pcpu-alloc: [0] 0 1 2 3
Oct 10 16:23:08 alan-inspironn5010 kernel: Built 1 zonelists, mobility grouping>
Oct 10 16:23:08 alan-inspironn5010 kernel: Policy zone: Normal
Oct 10 16:23:08 alan-inspironn5010 kernel: Kernel command line: BOOT_IMAGE=/boo>
Oct 10 16:23:08 alan-inspironn5010 kernel: Dentry cache hash table entries: 524>
Oct 10 16:23:08 alan-inspironn5010 kernel: Inode-cache hash table entries: 2621>
Oct 10 16:23:08 alan-inspironn5010 kernel: mem auto-init: stack:off, heap alloc>
Oct 10 16:23:08 alan-inspironn5010 kernel: Memory: 3799976K/3988028K available >
Oct 10 16:23:08 alan-inspironn5010 kernel: random: get_random_u64 called from _>
Oct 10 16:23:08 alan-inspironn5010 kernel: SLUB: HWalign=64, Order=0-3, MinObje>
Oct 10 16:23:08 alan-inspironn5010 kernel: Kernel/User page tables isolation: e>
Oct 10 16:23:08 alan-inspironn5010 kernel: ftrace: allocating 41919 entries in >
Oct 10 16:23:08 alan-inspironn5010 kernel: ftrace: allocated 164 pages with 3 g>
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu: Preemptible hierarchical RCU im>
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu:         RCU dyntick-idle grace->
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu:         RCU restricting CPUs fr>
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu:         RCU priority boosting: >
Oct 10 16:23:08 alan-inspironn5010 kernel:         Trampoline variant of Tasks >
Oct 10 16:23:08 alan-inspironn5010 kernel:         Rude variant of Tasks RCU en>
Oct 10 16:23:08 alan-inspironn5010 kernel:         Tracing variant of Tasks RCU>
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu: RCU calculated value of schedul>
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu: Adjusting geometry for rcu_fano>
Oct 10 16:23:08 alan-inspironn5010 kernel: NR_IRQS: 20736, nr_irqs: 456, preall>
Oct 10 16:23:08 alan-inspironn5010 kernel: Console: colour dummy device 80x25
Oct 10 16:23:08 alan-inspironn5010 kernel: printk: console [tty0] enabled
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Core revision 20200925
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: hpet: mask: 0xffffffff >
Oct 10 16:23:08 alan-inspironn5010 kernel: APIC: Switch to symmetric I/O mode s>
Oct 10 16:23:08 alan-inspironn5010 kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 >
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: tsc-early: mask: 0xffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: Calibrating delay loop (skipped), va>
Oct 10 16:23:08 alan-inspironn5010 kernel: pid_max: default: 32768 minimum: 301
Oct 10 16:23:08 alan-inspironn5010 kernel: LSM: Security Framework initializing
Oct 10 16:23:08 alan-inspironn5010 kernel: Yama: becoming mindful.
Oct 10 16:23:08 alan-inspironn5010 kernel: AppArmor: AppArmor initialized
Oct 10 16:23:08 alan-inspironn5010 kernel: Mount-cache hash table entries: 8192>
Oct 10 16:23:08 alan-inspironn5010 kernel: Mountpoint-cache hash table entries:>
Oct 10 16:23:08 alan-inspironn5010 kernel: mce: CPU0: Thermal monitoring enable>
Oct 10 16:23:08 alan-inspironn5010 kernel: process: using mwait in idle threads
Oct 10 16:23:08 alan-inspironn5010 kernel: Last level iTLB entries: 4KB 512, 2M>
Oct 10 16:23:08 alan-inspironn5010 kernel: Last level dTLB entries: 4KB 512, 2M>
Oct 10 16:23:08 alan-inspironn5010 kernel: Spectre V1 : Mitigation: usercopy/sw>
Oct 10 16:23:08 alan-inspironn5010 kernel: Spectre V2 : Mitigation: Full generi>
Oct 10 16:23:08 alan-inspironn5010 kernel: Spectre V2 : Spectre v2 / SpectreRSB>
Oct 10 16:23:08 alan-inspironn5010 kernel: Spectre V2 : Enabling Restricted Spe>
Oct 10 16:23:08 alan-inspironn5010 kernel: Spectre V2 : mitigation: Enabling co>
Oct 10 16:23:08 alan-inspironn5010 kernel: Spectre V2 : User space: Mitigation:>
Oct 10 16:23:08 alan-inspironn5010 kernel: Speculative Store Bypass: Mitigation>
Oct 10 16:23:08 alan-inspironn5010 kernel: MDS: Vulnerable: Clear CPU buffers a>
Oct 10 16:23:08 alan-inspironn5010 kernel: Freeing SMP alternatives memory: 36K
Oct 10 16:23:08 alan-inspironn5010 kernel: smpboot: CPU0: Intel(R) Core(TM) i3 >
Oct 10 16:23:08 alan-inspironn5010 kernel: Performance Events: PEBS fmt1+, West>
Oct 10 16:23:08 alan-inspironn5010 kernel: core: CPUID marked event: 'bus cycle>
Oct 10 16:23:08 alan-inspironn5010 kernel: ... version:                3
Oct 10 16:23:08 alan-inspironn5010 kernel: ... bit width:              48
Oct 10 16:23:08 alan-inspironn5010 kernel: ... generic registers:      4
Oct 10 16:23:08 alan-inspironn5010 kernel: ... value mask:             0000ffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: ... max period:             00000000>
Oct 10 16:23:08 alan-inspironn5010 kernel: ... fixed-purpose events:   3
Oct 10 16:23:08 alan-inspironn5010 kernel: ... event mask:             00000007>
Oct 10 16:23:08 alan-inspironn5010 kernel: rcu: Hierarchical SRCU implementatio>
Oct 10 16:23:08 alan-inspironn5010 kernel: NMI watchdog: Enabled. Permanently c>
Oct 10 16:23:08 alan-inspironn5010 kernel: smp: Bringing up secondary CPUs ...
Oct 10 16:23:08 alan-inspironn5010 kernel: x86: Booting SMP configuration:
Oct 10 16:23:08 alan-inspironn5010 kernel: .... node  #0, CPUs:      #1 #2
Oct 10 16:23:08 alan-inspironn5010 kernel: MDS CPU bug present and SMT on, data>
Oct 10 16:23:08 alan-inspironn5010 kernel:  #3
Oct 10 16:23:08 alan-inspironn5010 kernel: smp: Brought up 1 node, 4 CPUs
Oct 10 16:23:08 alan-inspironn5010 kernel: smpboot: Max logical packages: 1
Oct 10 16:23:08 alan-inspironn5010 kernel: smpboot: Total of 4 processors activ>
Oct 10 16:23:08 alan-inspironn5010 kernel: devtmpfs: initialized
Oct 10 16:23:08 alan-inspironn5010 kernel: x86/mm: Memory block size: 128MB
Oct 10 16:23:08 alan-inspironn5010 kernel: PM: Registering ACPI NVS region [mem>
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: jiffies: mask: 0xffffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: futex hash table entries: 1024 (orde>
Oct 10 16:23:08 alan-inspironn5010 kernel: pinctrl core: initialized pinctrl su>
Oct 10 16:23:08 alan-inspironn5010 kernel: PM: RTC time: 10:52:57, date: 2021-1>
Oct 10 16:23:08 alan-inspironn5010 kernel: NET: Registered protocol family 16
Oct 10 16:23:08 alan-inspironn5010 kernel: DMA: preallocated 512 KiB GFP_KERNEL>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: initializing netlink subsys (>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=2000 audit(1633863177.13>
Oct 10 16:23:08 alan-inspironn5010 kernel: thermal_sys: Registered thermal gove>
Oct 10 16:23:08 alan-inspironn5010 kernel: cpuidle: using governor ladder
Oct 10 16:23:08 alan-inspironn5010 kernel: cpuidle: using governor menu
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: bus type PCI registered
Oct 10 16:23:08 alan-inspironn5010 kernel: acpiphp: ACPI Hot Plug PCI Controlle>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: MMCONFIG for domain 0000 [bus 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: MMCONFIG at [mem 0xe0000000-0xe>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: Using configuration type 1 for >
Oct 10 16:23:08 alan-inspironn5010 kernel: Kprobes globally optimized
Oct 10 16:23:08 alan-inspironn5010 kernel: HugeTLB registered 2.00 MiB page siz>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(Module Device)
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(Processor Device)
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(Processor Aggregato>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(Linux-Dell-Video)
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDM>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Gr>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: 2 ACPI AML tables successfully>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linu>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Dynamic OEM Table Load:
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: SSDT 0xFFFF95AB8097A800 0003A4>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Interpreter enabled
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: (supports S0 S3 S4 S5)
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Using IOAPIC for interrupt rou>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: Using host bridge windows from >
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Enabled 9 GPEs in block 00 to >
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Root Bridge [PCI0] (domain>
Oct 10 16:23:08 alan-inspironn5010 kernel: acpi PNP0A08:00: _OSC: OS supports [>
Oct 10 16:23:08 alan-inspironn5010 kernel: acpi PNP0A08:00: _OSC: platform does>
Oct 10 16:23:08 alan-inspironn5010 kernel: acpi PNP0A08:00: _OSC: OS now contro>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI host bridge to bus 0000:00
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:00: root bus resource [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:00.0: [8086:0044] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:00.0: DMAR: BIOS has all>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: [8086:0046] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: reg 0x18: [mem 0xc>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: reg 0x20: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:16.0: [8086:3b64] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:16.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1a.0: [8086:3b3c] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1a.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1b.0: [8086:3b56] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1b.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: [8086:3b42] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: [8086:3b44] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.2: [8086:3b46] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.2: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.4: [8086:3b4a] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.4: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1d.0: [8086:3b34] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1d.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1e.0: [8086:2448] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.0: [8086:3b0b] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: [8086:3b2f] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: reg 0x10: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: reg 0x14: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: reg 0x18: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: reg 0x1c: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: reg 0x20: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.2: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.3: [8086:3b30] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.3: reg 0x20: [io  0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.6: [8086:3b32] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1f.6: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: PCI bridge to [bus>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:12:00.0: [14e4:4727] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:12:00.0: reg 0x10: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:12:00.0: enabling Extended >
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:12:00.0: supports D1 D2
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:12:00.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: PCI bridge to [bus>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1:   bridge window [m>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: [10ec:8136] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: reg 0x10: [io  0xe>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: reg 0x18: [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: reg 0x20: [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: reg 0x30: [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: supports D1 D2
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:13:00.0: PME# supported fro>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.2: PCI bridge to [bus>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.2:   bridge window [i>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.2:   bridge window [m>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.4: PCI bridge to [bus>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.4:   bridge window [i>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.4:   bridge window [m>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:20: extended config spa>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1e.0: PCI bridge to [bus>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1e.0:   bridge window [i>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1e.0:   bridge window [m>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKA] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKB] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKC] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKD] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKE] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKF] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKG] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: PCI Interrupt Link [LNKH] (IRQ>
Oct 10 16:23:08 alan-inspironn5010 kernel: iommu: Default domain type: Translat>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: vgaarb: setting as>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: vgaarb: VGA device>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: vgaarb: bridge con>
Oct 10 16:23:08 alan-inspironn5010 kernel: vgaarb: loaded
Oct 10 16:23:08 alan-inspironn5010 kernel: SCSI subsystem initialized
Oct 10 16:23:08 alan-inspironn5010 kernel: libata version 3.00 loaded.
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: bus type USB registered
Oct 10 16:23:08 alan-inspironn5010 kernel: usbcore: registered new interface dr>
Oct 10 16:23:08 alan-inspironn5010 kernel: usbcore: registered new device drive>
Oct 10 16:23:08 alan-inspironn5010 kernel: pps_core: LinuxPPS API ver. 1 regist>
Oct 10 16:23:08 alan-inspironn5010 kernel: pps_core: Software ver. 5.3.6 - Copy>
Oct 10 16:23:08 alan-inspironn5010 kernel: PTP clock support registered
Oct 10 16:23:08 alan-inspironn5010 kernel: EDAC MC: Ver: 3.0.0
Oct 10 16:23:08 alan-inspironn5010 kernel: NetLabel: Initializing
Oct 10 16:23:08 alan-inspironn5010 kernel: NetLabel:  domain hash size = 128
Oct 10 16:23:08 alan-inspironn5010 kernel: NetLabel:  protocols = UNLABELED CIP>
Oct 10 16:23:08 alan-inspironn5010 kernel: NetLabel:  unlabeled traffic allowed>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: Using ACPI for IRQ routing
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: Discovered peer bus ff
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: root bus ff: using default reso>
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: Probing PCI hardware (bus ff)
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI host bridge to bus 0000:ff
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:ff: root bus resource [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:ff: No busn resource fo>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:ff: busn_res: can not i>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:ff:00.0: [8086:2c62] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:ff:00.1: [8086:2d01] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:ff:02.0: [8086:2d10] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:ff:02.1: [8086:2d11] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:ff:02.2: [8086:2d12] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:ff:02.3: [8086:2d13] type 0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:ff: busn_res: [bus ff] >
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI: pci_cache_line_size set to 64 b>
Oct 10 16:23:08 alan-inspironn5010 kernel: e820: reserve RAM buffer [mem 0x0009>
Oct 10 16:23:08 alan-inspironn5010 kernel: e820: reserve RAM buffer [mem 0xbb58>
Oct 10 16:23:08 alan-inspironn5010 kernel: e820: reserve RAM buffer [mem 0xbb80>
Oct 10 16:23:08 alan-inspironn5010 kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8>
Oct 10 16:23:08 alan-inspironn5010 kernel: hpet0: 8 comparators, 64-bit 14.3181>
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: Switched to clocksource>
Oct 10 16:23:08 alan-inspironn5010 kernel: VFS: Disk quotas dquot_6.6.0
Oct 10 16:23:08 alan-inspironn5010 kernel: VFS: Dquot-cache hash table entries:>
Oct 10 16:23:08 alan-inspironn5010 kernel: AppArmor: AppArmor Filesystem Enabled
Oct 10 16:23:08 alan-inspironn5010 kernel: pnp: PnP ACPI init
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:00: [mem 0xfed14000-0xfed1>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:00: [mem 0xe0000000-0xefff>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:00: [mem 0xfed90000-0xfed9>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:00: [mem 0xfed20000-0xfed3>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:00: [mem 0xfee00000-0xfee0>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:00: Plug and Play ACPI dev>
Oct 10 16:23:08 alan-inspironn5010 kernel: pnp 00:01: Plug and Play ACPI device>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:02: [io  0x04d0-0x04d1] ha>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:02: [mem 0xfe800000-0xfe80>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:02: Plug and Play ACPI dev>
Oct 10 16:23:08 alan-inspironn5010 kernel: pnp 00:03: Plug and Play ACPI device>
Oct 10 16:23:08 alan-inspironn5010 kernel: pnp 00:04: Plug and Play ACPI device>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [io  0x0400-0x047f] ha>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [io  0x1180-0x119f] ha>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [io  0x0500-0x057f] ha>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [mem 0xfed1c000-0xfed1>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [mem 0xfec00000-0xfecf>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [mem 0xfed08000-0xfed0>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: [mem 0xff000000-0xffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: system 00:05: Plug and Play ACPI dev>
Oct 10 16:23:08 alan-inspironn5010 kernel: pnp: PnP ACPI: found 6 devices
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: acpi_pm: mask: 0xffffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: NET: Registered protocol family 2
Oct 10 16:23:08 alan-inspironn5010 kernel: IP idents hash table entries: 65536 >
Oct 10 16:23:08 alan-inspironn5010 kernel: tcp_listen_portaddr_hash hash table >
Oct 10 16:23:08 alan-inspironn5010 kernel: TCP established hash table entries: >
Oct 10 16:23:08 alan-inspironn5010 kernel: TCP bind hash table entries: 32768 (>
Oct 10 16:23:08 alan-inspironn5010 kernel: TCP: Hash tables configured (establi>
Oct 10 16:23:08 alan-inspironn5010 kernel: MPTCP token hash table entries: 4096>
Oct 10 16:23:08 alan-inspironn5010 kernel: UDP hash table entries: 2048 (order:>
Oct 10 16:23:08 alan-inspironn5010 kernel: UDP-Lite hash table entries: 2048 (o>
Oct 10 16:23:08 alan-inspironn5010 kernel: NET: Registered protocol family 44
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: bridge window [io >
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: bridge window [mem>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: bridge window [io >
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: bridge window [mem>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: BAR 14: assigned [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: BAR 15: assigned [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: BAR 15: assigned [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0: BAR 13: assigned [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1: BAR 13: assigned [>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0:   bridge window [i>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.0:   bridge window [m>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1c.1:   bridge window [i>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:00: resource 4 [io  0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:00: resource 5 [io  0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:00: resource 6 [mem 0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:00: resource 7 [mem 0xc>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:11: resource 0 [io  0x2>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:11: resource 1 [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:11: resource 2 [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:12: resource 0 [io  0x3>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:12: resource 1 [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:12: resource 2 [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:13: resource 0 [io  0xe>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:13: resource 1 [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:13: resource 2 [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:15: resource 0 [io  0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:15: resource 1 [mem 0xf>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:15: resource 2 [mem 0xd>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:20: resource 4 [io  0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:20: resource 5 [io  0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:20: resource 6 [mem 0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:20: resource 7 [mem 0xc>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:ff: resource 4 [io  0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci_bus 0000:ff: resource 5 [mem 0x0>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: BIOS left Intel GP>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:02.0: Video device with >
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1a.0: quirk_usb_early_ha>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:00:1d.0: quirk_usb_early_ha>
Oct 10 16:23:08 alan-inspironn5010 kernel: pci 0000:12:00.0: CLS mismatch (64 !>
Oct 10 16:23:08 alan-inspironn5010 kernel: Trying to unpack rootfs image as ini>
Oct 10 16:23:08 alan-inspironn5010 kernel: Freeing initrd memory: 12216K
Oct 10 16:23:08 alan-inspironn5010 kernel: PCI-DMA: Using software bounce buffe>
Oct 10 16:23:08 alan-inspironn5010 kernel: software IO TLB: mapped [mem 0x00000>
Oct 10 16:23:08 alan-inspironn5010 kernel: check: Scanning for low memory corru>
Oct 10 16:23:08 alan-inspironn5010 kernel: Initialise system trusted keyrings
Oct 10 16:23:08 alan-inspironn5010 kernel: Key type blacklist registered
Oct 10 16:23:08 alan-inspironn5010 kernel: workingset: timestamp_bits=41 max_or>
Oct 10 16:23:08 alan-inspironn5010 kernel: zbud: loaded
Oct 10 16:23:08 alan-inspironn5010 kernel: Key type asymmetric registered
Oct 10 16:23:08 alan-inspironn5010 kernel: Asymmetric key parser 'x509' registe>
Oct 10 16:23:08 alan-inspironn5010 kernel: Block layer SCSI generic (bsg) drive>
Oct 10 16:23:08 alan-inspironn5010 kernel: io scheduler mq-deadline registered
Oct 10 16:23:08 alan-inspironn5010 kernel: io scheduler kyber registered
Oct 10 16:23:08 alan-inspironn5010 kernel: io scheduler bfq registered
Oct 10 16:23:08 alan-inspironn5010 kernel: atomic64_test: passed for x86-64 pla>
Oct 10 16:23:08 alan-inspironn5010 kernel: pcieport 0000:00:1c.0: pciehp: Slot >
Oct 10 16:23:08 alan-inspironn5010 kernel: pcieport 0000:00:1c.1: pciehp: Slot >
Oct 10 16:23:08 alan-inspironn5010 kernel: pcieport 0000:00:1c.2: pciehp: Slot >
Oct 10 16:23:08 alan-inspironn5010 kernel: pcieport 0000:00:1c.4: pciehp: Slot >
Oct 10 16:23:08 alan-inspironn5010 kernel: shpchp: Standard Hot Plug PCI Contro>
Oct 10 16:23:08 alan-inspironn5010 kernel: vesafb: mode is 1024x768x32, linelen>
Oct 10 16:23:08 alan-inspironn5010 kernel: vesafb: scrolling: redraw
Oct 10 16:23:08 alan-inspironn5010 kernel: vesafb: Truecolor: size=8:8:8:8, shi>
Oct 10 16:23:08 alan-inspironn5010 kernel: vesafb: framebuffer at 0xc0000000, m>
Oct 10 16:23:08 alan-inspironn5010 kernel: fbcon: Deferring console take-over
Oct 10 16:23:08 alan-inspironn5010 kernel: fb0: VESA VGA frame buffer device
Oct 10 16:23:08 alan-inspironn5010 kernel: intel_idle: MWAIT substates: 0x1120
Oct 10 16:23:08 alan-inspironn5010 kernel: intel_idle: v0.5.1 model 0x25
Oct 10 16:23:08 alan-inspironn5010 kernel: intel_idle: Local APIC timer is reli>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: AC Adapter [AC] (on-line)
Oct 10 16:23:08 alan-inspironn5010 kernel: input: Power Button as /devices/LNXS>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Power Button [PWRB]
Oct 10 16:23:08 alan-inspironn5010 kernel: input: Lid Switch as /devices/LNXSYS>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Lid Switch [LID0]
Oct 10 16:23:08 alan-inspironn5010 kernel: input: Sleep Button as /devices/LNXS>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Sleep Button [SBTN]
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Power Button [PWRF]
Oct 10 16:23:08 alan-inspironn5010 kernel: thermal LNXTHERM:00: registered as t>
Oct 10 16:23:08 alan-inspironn5010 kernel: ACPI: Thermal Zone [THM] (68 C)
Oct 10 16:23:08 alan-inspironn5010 kernel: Serial: 8250/16550 driver, 32 ports,>
Oct 10 16:23:08 alan-inspironn5010 kernel: Non-volatile memory driver v1.3
Oct 10 16:23:08 alan-inspironn5010 kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg >
Oct 10 16:23:08 alan-inspironn5010 kernel: AMD-Vi: AMD IOMMUv2 functionality no>
Oct 10 16:23:08 alan-inspironn5010 kernel: ahci 0000:00:1f.2: version 3.0
Oct 10 16:23:08 alan-inspironn5010 kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32>
Oct 10 16:23:08 alan-inspironn5010 kernel: ahci 0000:00:1f.2: flags: 64bit ncq >
Oct 10 16:23:08 alan-inspironn5010 kernel: battery: ACPI: Battery Slot [BAT0] (>
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi host0: ahci
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi host1: ahci
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi host2: ahci
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi host3: ahci
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi host4: ahci
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi host5: ahci
Oct 10 16:23:08 alan-inspironn5010 kernel: ata1: SATA max UDMA/133 abar m2048@0>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata2: SATA max UDMA/133 abar m2048@0>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata3: DUMMY
Oct 10 16:23:08 alan-inspironn5010 kernel: ata4: DUMMY
Oct 10 16:23:08 alan-inspironn5010 kernel: ata5: SATA max UDMA/133 abar m2048@0>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata6: DUMMY
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Co>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci: EHCI PCI platform driver
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1a.0: EHCI Host Con>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1a.0: new USB bus r>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1a.0: debug port 2
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1a.0: cache line si>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1a.0: irq 16, io me>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1a.0: USB 2.0 start>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb1: New USB device found, idVe>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb1: New USB device strings: Mf>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb1: Product: EHCI Host Control>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb1: Manufacturer: Linux 5.10.6>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb1: SerialNumber: 0000:00:1a.0
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 1-0:1.0: USB hub found
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 1-0:1.0: 2 ports detected
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1d.0: EHCI Host Con>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1d.0: new USB bus r>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1d.0: debug port 2
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1d.0: cache line si>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1d.0: irq 23, io me>
Oct 10 16:23:08 alan-inspironn5010 kernel: ehci-pci 0000:00:1d.0: USB 2.0 start>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb2: New USB device found, idVe>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb2: New USB device strings: Mf>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb2: Product: EHCI Host Control>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb2: Manufacturer: Linux 5.10.6>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb usb2: SerialNumber: 0000:00:1d.0
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 2-0:1.0: USB hub found
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 2-0:1.0: 2 ports detected
Oct 10 16:23:08 alan-inspironn5010 kernel: ohci_hcd: USB 1.1 'Open' Host Contro>
Oct 10 16:23:08 alan-inspironn5010 kernel: ohci-pci: OHCI PCI platform driver
Oct 10 16:23:08 alan-inspironn5010 kernel: uhci_hcd: USB Universal Host Control>
Oct 10 16:23:08 alan-inspironn5010 kernel: usbserial: USB Serial support regist>
Oct 10 16:23:08 alan-inspironn5010 kernel: i8042: PNP: PS/2 Controller [PNP0303>
Oct 10 16:23:08 alan-inspironn5010 kernel: serio: i8042 KBD port at 0x60,0x64 i>
Oct 10 16:23:08 alan-inspironn5010 kernel: serio: i8042 AUX port at 0x60,0x64 i>
Oct 10 16:23:08 alan-inspironn5010 kernel: rtc_cmos 00:01: RTC can wake from S4
Oct 10 16:23:08 alan-inspironn5010 kernel: rtc_cmos 00:01: registered as rtc0
Oct 10 16:23:08 alan-inspironn5010 kernel: rtc_cmos 00:01: setting system clock>
Oct 10 16:23:08 alan-inspironn5010 kernel: rtc_cmos 00:01: alarms up to one yea>
Oct 10 16:23:08 alan-inspironn5010 kernel: intel_pstate: CPU model not supported
Oct 10 16:23:08 alan-inspironn5010 kernel: ledtrig-cpu: registered to indicate >
Oct 10 16:23:08 alan-inspironn5010 kernel: hid: raw HID events driver (C) Jiri >
Oct 10 16:23:08 alan-inspironn5010 kernel: ashmem: initialized
Oct 10 16:23:08 alan-inspironn5010 kernel: drop_monitor: Initializing network d>
Oct 10 16:23:08 alan-inspironn5010 kernel: Initializing XFRM netlink socket
Oct 10 16:23:08 alan-inspironn5010 kernel: NET: Registered protocol family 10
Oct 10 16:23:08 alan-inspironn5010 kernel: Segment Routing with IPv6
Oct 10 16:23:08 alan-inspironn5010 kernel: RPL Segment Routing with IPv6
Oct 10 16:23:08 alan-inspironn5010 kernel: NET: Registered protocol family 17
Oct 10 16:23:08 alan-inspironn5010 kernel: microcode: sig=0x20652, pf=0x10, rev>
Oct 10 16:23:08 alan-inspironn5010 kernel: microcode: Microcode Update Driver: >
Oct 10 16:23:08 alan-inspironn5010 kernel: IPI shorthand broadcast: enabled
Oct 10 16:23:08 alan-inspironn5010 kernel: sched_clock: Marking stable (9504722>
Oct 10 16:23:08 alan-inspironn5010 kernel: registered taskstats version 1
Oct 10 16:23:08 alan-inspironn5010 kernel: Loading compiled-in X.509 certificat>
Oct 10 16:23:08 alan-inspironn5010 kernel: Loaded X.509 cert 'Build time autoge>
Oct 10 16:23:08 alan-inspironn5010 kernel: zswap: loaded using pool zstd/z3fold
Oct 10 16:23:08 alan-inspironn5010 kernel: Key type ._fscrypt registered
Oct 10 16:23:08 alan-inspironn5010 kernel: Key type .fscrypt registered
Oct 10 16:23:08 alan-inspironn5010 kernel: Key type fscrypt-provisioning regist>
Oct 10 16:23:08 alan-inspironn5010 kernel: AppArmor: AppArmor sha1 policy hashi>
Oct 10 16:23:08 alan-inspironn5010 kernel: PM:   Magic number: 9:175:881
Oct 10 16:23:08 alan-inspironn5010 kernel: RAS: Correctable Errors collector in>
Oct 10 16:23:08 alan-inspironn5010 kernel: input: AT Translated Set 2 keyboard >
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1: new high-speed USB device n>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1: new high-speed USB device n>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata2: SATA link up 1.5 Gbps (SStatus>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata1: SATA link up 3.0 Gbps (SStatus>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata2.00: ATAPI: PLDS DVD+/-RW DS-8A4>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata5: SATA link down (SStatus 0 SCon>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata2.00: configured for UDMA/100
Oct 10 16:23:08 alan-inspironn5010 kernel: ata1.00: ATA-8: TOSHIBA MK2565GSX, G>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata1.00: 488397168 sectors, multi 16>
Oct 10 16:23:08 alan-inspironn5010 kernel: ata1.00: configured for UDMA/100
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi 0:0:0:0: Direct-Access     ATA >
Oct 10 16:23:08 alan-inspironn5010 kernel: sd 0:0:0:0: [sda] 488397168 512-byte>
Oct 10 16:23:08 alan-inspironn5010 kernel: sd 0:0:0:0: [sda] Write Protect is o>
Oct 10 16:23:08 alan-inspironn5010 kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a >
Oct 10 16:23:08 alan-inspironn5010 kernel: sd 0:0:0:0: [sda] Write cache: enabl>
Oct 10 16:23:08 alan-inspironn5010 kernel: scsi 1:0:0:0: CD-ROM            PLDS>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1: New USB device found, idVen>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1: New USB device strings: Mfr>
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 1-1:1.0: USB hub found
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 1-1:1.0: 6 ports detected
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1: New USB device found, idVen>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1: New USB device strings: Mfr>
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 2-1:1.0: USB hub found
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 2-1:1.0: 8 ports detected
Oct 10 16:23:08 alan-inspironn5010 kernel:  sda: sda1 sda2 sda3 sda4
Oct 10 16:23:08 alan-inspironn5010 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Oct 10 16:23:08 alan-inspironn5010 kernel: Freeing unused decrypted memory: 203>
Oct 10 16:23:08 alan-inspironn5010 kernel: Freeing unused kernel image (initmem>
Oct 10 16:23:08 alan-inspironn5010 kernel: Write protecting the kernel read-onl>
Oct 10 16:23:08 alan-inspironn5010 kernel: Freeing unused kernel image (text/ro>
Oct 10 16:23:08 alan-inspironn5010 kernel: Freeing unused kernel image (rodata/>
Oct 10 16:23:08 alan-inspironn5010 kernel: x86/mm: Checked W+X mappings: passed>
Oct 10 16:23:08 alan-inspironn5010 kernel: rodata_test: all tests were successf>
Oct 10 16:23:08 alan-inspironn5010 kernel: x86/mm: Checking user space page tab>
Oct 10 16:23:08 alan-inspironn5010 kernel: Run /init as init process
Oct 10 16:23:08 alan-inspironn5010 kernel:   with arguments:
Oct 10 16:23:08 alan-inspironn5010 kernel:     /init
Oct 10 16:23:08 alan-inspironn5010 kernel:   with environment:
Oct 10 16:23:08 alan-inspironn5010 kernel:     HOME=/
Oct 10 16:23:08 alan-inspironn5010 kernel:     TERM=linux
Oct 10 16:23:08 alan-inspironn5010 kernel:     BOOT_IMAGE=/boot/vmlinuz-5.10-x8>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1.6: new high-speed USB device>
Oct 10 16:23:08 alan-inspironn5010 kernel: tsc: Refined TSC clocksource calibra>
Oct 10 16:23:08 alan-inspironn5010 kernel: clocksource: tsc: mask: 0xffffffffff>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.1: new full-speed USB device>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1.6: New USB device found, idV>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1.6: New USB device strings: M>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1.6: Product: Laptop_Integrate>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 1-1.6: Manufacturer: M091S-M01-0>
Oct 10 16:23:08 alan-inspironn5010 kernel: sr 1:0:0:0: [sr0] scsi3-mmc drive: 2>
Oct 10 16:23:08 alan-inspironn5010 kernel: cdrom: Uniform CD-ROM driver Revisio>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.1: New USB device found, idV>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.1: New USB device strings: M>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.1: Product: 2.4G Wireless Mo>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.1: Manufacturer: MOSART Semi.
Oct 10 16:23:08 alan-inspironn5010 kernel: sr 1:0:0:0: Attached scsi CD-ROM sr0
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6: new full-speed USB device>
Oct 10 16:23:08 alan-inspironn5010 kernel: random: fast init done
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6: New USB device found, idV>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6: New USB device strings: M>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6: Product: BCM2046B1
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6: Manufacturer: Broadcom
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 2-1.6:1.0: USB hub found
Oct 10 16:23:08 alan-inspironn5010 kernel: hub 2-1.6:1.0: 3 ports detected
Oct 10 16:23:08 alan-inspironn5010 kernel: input: MOSART Semi. 2.4G Wireless Mo>
Oct 10 16:23:08 alan-inspironn5010 kernel: hid-generic 0003:3938:1031.0001: inp>
Oct 10 16:23:08 alan-inspironn5010 kernel: usbhid: USB HID core driver
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6.1: new full-speed USB devi>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6.1: New USB device found, i>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6.1: New USB device strings:>
Oct 10 16:23:08 alan-inspironn5010 kernel: input: HID 413c:8161 as /devices/pci>
Oct 10 16:23:08 alan-inspironn5010 kernel: hid-generic 0003:413C:8161.0002: inp>
Oct 10 16:23:08 alan-inspironn5010 kernel: PM: Image not found (code -22)
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6.2: new full-speed USB devi>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6.2: New USB device found, i>
Oct 10 16:23:08 alan-inspironn5010 kernel: usb 2-1.6.2: New USB device strings:>
Oct 10 16:23:08 alan-inspironn5010 kernel: input: HID 413c:8162 Mouse as /devic>
Oct 10 16:23:08 alan-inspironn5010 kernel: hid-generic 0003:413C:8162.0003: inp>
Oct 10 16:23:08 alan-inspironn5010 kernel: EXT4-fs (sda1): mounted filesystem w>
Oct 10 16:23:08 alan-inspironn5010 kernel: random: crng init done
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: systemd 249.4-1-manjaro running >
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Detected architecture x86-64.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Hostname set to <alan-inspironn5>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Queued start job for default tar>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Created slice Slice /system/gett>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Created slice Slice /system/modp>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Created slice User and Session S>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Started Dispatch Password Reques>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Started Forward Password Request>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Set up automount Arbitrary Execu>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Reached target Local Encrypted V>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Reached target Login Prompts.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Reached target Remote File Syste>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Reached target Slice Units.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Reached target Local Verity Inte>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on Device-mapper event>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on LVM2 poll daemon so>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on Process Core Dump S>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on Journal Audit Socke>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on Journal Socket (/de>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on Journal Socket.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on udev Control Socket.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Listening on udev Kernel Socket.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounting Huge Pages File System.>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounting POSIX Message Queue Fil>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounting Kernel Debug File Syste>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounting Kernel Trace File Syste>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load AppArmor profiles.>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Create List of Static D>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Monitoring of LVM2 mirr>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load Kernel Module conf>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load Kernel Module drm.>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load Kernel Module fuse>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Set >
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting File System Check on Ro>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load Kernel Modules...
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Repa>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Coldplug All udev Devic>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounted Huge Pages File System.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounted POSIX Message Queue File>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounted Kernel Debug File System.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounted Kernel Trace File System.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Create List of Static D>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: modprobe@configfs.service: Deact>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load Kernel Module conf>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounting Kernel Configuration Fi>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounted Kernel Configuration Fil>
Oct 10 16:23:08 alan-inspironn5010 kernel: fuse: init (API version 7.32)
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: modprobe@fuse.service: Deactivat>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load Kernel Module fuse.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounting FUSE Control File Syste>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Mounted FUSE Control File System.
Oct 10 16:23:08 alan-inspironn5010 kernel: Linux agpgart interface v0.103
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Coldplug All udev Devic>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load Kernel Modules.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Apply Kernel Variables.>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: modprobe@drm.service: Deactivate>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load Kernel Module drm.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Apply Kernel Variables.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting CLI Netfilter Manager...
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Monitoring of LVM2 mirr>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished File System Check on Ro>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Remount Root and Kernel>
Oct 10 16:23:08 alan-inspironn5010 kernel: EXT4-fs (sda1): re-mounted. Opts: (n>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Remount Root and Kernel>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Firs>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1400 audit(1633863187.37>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Rebu>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load/Save Random Seed...
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Crea>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Create Static Device No>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1400 audit(1633863187.42>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1400 audit(1633863187.53>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load/Save Random Seed.
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1400 audit(1633863187.78>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1400 audit(1633863187.84>
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1400 audit(1633863188.25>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load AppArmor profiles.
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Load AppArmor profiles >
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Create Static Device No>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Reached target Preparation for L>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Virt>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Condition check resulted in Entr>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Journal Service...
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Rule-based Manager for >
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Finished Load AppArmor profiles >
Oct 10 16:23:08 alan-inspironn5010 systemd-journald[257]: Journal started
Oct 10 16:23:08 alan-inspironn5010 systemd-journald[257]: Runtime Journal (/run>
Oct 10 16:23:07 alan-inspironn5010 audit[228]: AVC apparmor="STATUS" operation=>
Oct 10 16:23:07 alan-inspironn5010 audit[229]: AVC apparmor="STATUS" operation=>
Oct 10 16:23:07 alan-inspironn5010 audit[230]: AVC apparmor="STATUS" operation=>
Oct 10 16:23:07 alan-inspironn5010 audit[227]: AVC apparmor="STATUS" operation=>
Oct 10 16:23:07 alan-inspironn5010 audit[234]: AVC apparmor="STATUS" operation=>
Oct 10 16:23:08 alan-inspironn5010 audit[237]: AVC apparmor="STATUS" operation=>
Oct 10 16:23:08 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:06 alan-inspironn5010 systemd-modules-load[214]: Inserted module '>
Oct 10 16:23:08 alan-inspironn5010 apparmor.systemd[207]: Restarting AppArmor
Oct 10 16:23:08 alan-inspironn5010 apparmor.systemd[207]: Reloading AppArmor pr>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Starting Flush Journal to Persis>
Oct 10 16:23:08 alan-inspironn5010 systemd[1]: Started Journal Service.
Oct 10 16:23:08 alan-inspironn5010 kernel: audit: type=1130 audit(1633863188.59>
Oct 10 16:23:08 alan-inspironn5010 systemd-fsck[223]: /dev/sda1: clean, 1273039>
Oct 10 16:23:08 alan-inspironn5010 snapd-apparmor[267]: find: ā€˜/var/lib/snapd/a>
Oct 10 16:23:08 alan-inspironn5010 systemd-journald[257]: Time spent on flushin>
Oct 10 16:23:08 alan-inspironn5010 systemd-journald[257]: System Journal (/var/>
Oct 10 16:23:14 alan-inspironn5010 kernel: i801_smbus 0000:00:1f.3: SMBus using>
Oct 10 16:23:14 alan-inspironn5010 kernel: i2c i2c-0: 2/2 memory slots populate>
Oct 10 16:23:14 alan-inspironn5010 kernel: i2c i2c-0: Successfully instantiated>
Oct 10 16:23:14 alan-inspironn5010 kernel: ACPI Warning: SystemIO range 0x00000>
Oct 10 16:23:14 alan-inspironn5010 kernel: ACPI: If an ACPI driver is available>
Oct 10 16:23:14 alan-inspironn5010 kernel: lpc_ich: Resource conflict(s) found >
Oct 10 16:23:14 alan-inspironn5010 kernel: intel ips 0000:00:1f.6: CPU TDP does>
Oct 10 16:23:14 alan-inspironn5010 kernel: intel ips 0000:00:1f.6: failed to ge>
Oct 10 16:23:14 alan-inspironn5010 kernel: intel ips 0000:00:1f.6: IPS driver i>
Oct 10 16:23:14 alan-inspironn5010 kernel: wmi_bus wmi_bus-PNP0C14:00: WQBC dat>
Oct 10 16:23:14 alan-inspironn5010 kernel: at24 0-0050: supply vcc not found, u>
Oct 10 16:23:14 alan-inspironn5010 kernel: at24 0-0050: 256 byte spd EEPROM, re>
Oct 10 16:23:14 alan-inspironn5010 kernel: dcdbas dcdbas: Dell Systems Manageme>
Oct 10 16:23:14 alan-inspironn5010 kernel: dell-smbios PNP0C14:00-A80593CE-A997>
Oct 10 16:23:14 alan-inspironn5010 kernel: iTCO_vendor_support: vendor-support=0
Oct 10 16:23:14 alan-inspironn5010 kernel: input: Dell WMI hotkeys as /devices/>
Oct 10 16:23:14 alan-inspironn5010 kernel: cfg80211: Loading compiled-in X.509 >
Oct 10 16:23:14 alan-inspironn5010 kernel: cfg80211: Loaded X.509 cert 'sforshe>
Oct 10 16:23:14 alan-inspironn5010 kernel: libphy: r8169: probed
Oct 10 16:23:14 alan-inspironn5010 kernel: r8169 0000:13:00.0 eth0: RTL8102e/RT>
Oct 10 16:23:14 alan-inspironn5010 kernel: iTCO_wdt: Intel TCO WatchDog Timer D>
Oct 10 16:23:14 alan-inspironn5010 kernel: iTCO_wdt: Found a HM57 TCO device (V>
Oct 10 16:23:14 alan-inspironn5010 kernel: iTCO_wdt: initialized. heartbeat=30 >
Oct 10 16:23:14 alan-inspironn5010 kernel: Adding 4095996k swap on /dev/sda3.  >
Oct 10 16:23:14 alan-inspironn5010 kernel: r8169 0000:13:00.0 enp19s0: renamed >
Oct 10 16:23:14 alan-inspironn5010 kernel: kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_C>
Oct 10 16:23:14 alan-inspironn5010 kernel: psmouse serio1: synaptics: queried m>
Oct 10 16:23:14 alan-inspironn5010 kernel: psmouse serio1: synaptics: Touchpad >
Oct 10 16:23:14 alan-inspironn5010 kernel: input: SynPS/2 Synaptics TouchPad as>
Oct 10 16:23:14 alan-inspironn5010 kernel: mousedev: PS/2 mouse device common f>
Oct 10 16:23:14 alan-inspironn5010 kernel: pci 0000:00:00.0: Intel HD Graphics >
Oct 10 16:23:14 alan-inspironn5010 kernel: pci 0000:00:00.0: detected gtt size:>
Oct 10 16:23:14 alan-inspironn5010 kernel: pci 0000:00:00.0: detected 32768K st>
Oct 10 16:23:14 alan-inspironn5010 kernel: checking generic (c0000000 300000) v>
Oct 10 16:23:14 alan-inspironn5010 kernel: fb0: switching to inteldrmfb from VE>
Oct 10 16:23:14 alan-inspironn5010 kernel: i915 0000:00:02.0: vgaarb: deactivat>
Oct 10 16:23:14 alan-inspironn5010 kernel: i801_smbus 0000:00:1f.3: BIOS is acc>
Oct 10 16:23:14 alan-inspironn5010 kernel: i801_smbus 0000:00:1f.3: Driver SMBu>
Oct 10 16:23:14 alan-inspironn5010 kernel: i915 0000:00:02.0: vgaarb: changed V>
Oct 10 16:23:14 alan-inspironn5010 kernel: [drm] Initialized i915 1.6.0 2020091>
Oct 10 16:23:14 alan-inspironn5010 kernel: ACPI: Video Device [GFX0] (multi-hea>
Oct 10 16:23:14 alan-inspironn5010 kernel: acpi device:2a: registered as coolin>
Oct 10 16:23:14 alan-inspironn5010 kernel: input: Video Bus as /devices/LNXSYST>
Oct 10 16:23:14 alan-inspironn5010 kernel: fbcon: i915drmfb (fb0) is primary de>
Oct 10 16:23:14 alan-inspironn5010 kernel: fbcon: Deferring console take-over
Oct 10 16:23:14 alan-inspironn5010 kernel: i915 0000:00:02.0: [drm] fb0: i915dr>
Oct 10 16:23:14 alan-inspironn5010 kernel: wl: loading out-of-tree module taint>
Oct 10 16:23:14 alan-inspironn5010 kernel: wl: module license 'MIXED/Proprietar>
Oct 10 16:23:14 alan-inspironn5010 kernel: Disabling lock debugging due to kern>
Oct 10 16:23:14 alan-inspironn5010 kernel: wl: module verification failed: sign>
Oct 10 16:23:14 alan-inspironn5010 kernel: wlan0: Broadcom BCM4727 802.11 Hybri>
Oct 10 16:23:14 alan-inspironn5010 kernel: kauditd_printk_skb: 17 callbacks sup>
Oct 10 16:23:14 alan-inspironn5010 kernel: audit: type=1130 audit(1633863193.16>
Oct 10 16:23:14 alan-inspironn5010 kernel: audit: type=1130 audit(1633863193.30>
Oct 10 16:23:14 alan-inspironn5010 kernel: wl 0000:12:00.0 wlp18s0: renamed fro>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_intel 0000:00:1b.0: bound 00>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_codec_idt hdaudioC0D0: autoc>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_codec_idt hdaudioC0D0:    sp>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_codec_idt hdaudioC0D0:    hp>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_codec_idt hdaudioC0D0:    mo>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_codec_idt hdaudioC0D0:    in>
Oct 10 16:23:14 alan-inspironn5010 kernel: snd_hda_codec_idt hdaudioC0D0:      >
Oct 10 16:23:14 alan-inspironn5010 kernel: input: HDA Intel MID Mic as /devices>
Oct 10 16:23:14 alan-inspironn5010 kernel: input: HDA Intel MID Headphone as /d>
Oct 10 16:23:14 alan-inspironn5010 kernel: input: HDA Intel MID HDMI/DP,pcm=3 a>
Oct 10 16:23:08 alan-inspironn5010 audit[265]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:08 alan-inspironn5010 audit[273]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:08 alan-inspironn5010 audit[276]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[277]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[282]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[284]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[287]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[289]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[292]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[295]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[296]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[299]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[302]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[303]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[307]: NETFILTER_CFG table=filter famil>
Oct 10 16:23:09 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:10 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:13 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:14 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:09 alan-inspironn5010 systemd[1]: Finished CLI Netfilter Manager.
Oct 10 16:23:10 alan-inspironn5010 systemd[1]: Started Rule-based Manager for D>
Oct 10 16:23:11 alan-inspironn5010 systemd[1]: Listening on Load/Save RF Kill S>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Found device TOSHIBA_MK2565GSX 3.
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Activating swap /dev/disk/by-uui>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Activated swap /dev/disk/by-uuid>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Reached target Swaps.
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Mounting Temporary Directory /tm>
Oct 10 16:23:14 alan-inspironn5010 kernel: audit: type=1130 audit(1633863194.53>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Mounted Temporary Directory /tmp.
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Reached target Local File System>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Condition check resulted in Rebu>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Condition check resulted in Stor>
Oct 10 16:23:12 alan-inspironn5010 systemd[1]: Condition check resulted in Comm>
Oct 10 16:23:13 alan-inspironn5010 systemd[1]: Created slice Slice /system/syst>
Oct 10 16:23:13 alan-inspironn5010 systemd[1]: Starting Load/Save Screen Backli>
Oct 10 16:23:13 alan-inspironn5010 systemd[1]: Starting Load/Save RF Kill Switc>
Oct 10 16:23:13 alan-inspironn5010 systemd[1]: Finished Load/Save Screen Backli>
Oct 10 16:23:13 alan-inspironn5010 systemd[1]: Started Load/Save RF Kill Switch>
Oct 10 16:23:14 alan-inspironn5010 systemd[1]: Finished Flush Journal to Persis>
Oct 10 16:23:14 alan-inspironn5010 systemd[1]: Starting Create Volatile Files a>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Finished Create Volatile Files a>
Oct 10 16:23:15 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Entr>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Rebu>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Set >
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Stor>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Firs>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Comm>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Repa>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Crea>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Upda>
Oct 10 16:23:15 alan-inspironn5010 kernel: audit: type=1130 audit(1633863195.06>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Record System Boot/Shut>
Oct 10 16:23:15 alan-inspironn5010 audit[393]: SYSTEM_BOOT pid=393 uid=0 auid=4>
Oct 10 16:23:15 alan-inspironn5010 kernel: audit: type=1127 audit(1633863195.13>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Finished Record System Boot/Shut>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Reached target System Initializa>
Oct 10 16:23:15 alan-inspironn5010 kernel: audit: type=1130 audit(1633863195.19>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started CUPS Scheduler.
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Daily rotation of log fi>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Daily man-db regeneratio>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Monthly clean packages c>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Generate mirrorlist week>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Daily verification of pa>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Daily Cleanup of Tempora>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Daily locate database up>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Reached target Path Units.
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Reached target Timer Units.
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Listening on Avahi mDNS/DNS-SD S>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Listening on CUPS Scheduler.
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Listening on D-Bus System Messag>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Socket activation for s>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Listening on Socket activation f>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Reached target Socket Units.
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Reached target Basic System.
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Save/Restore Sound Card>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Condition check resulted in Mana>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Avahi mDNS/DNS-SD Stack>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started Periodic Command Schedul>
Oct 10 16:23:15 alan-inspironn5010 kernel: audit: type=1130 audit(1633863195.31>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Started D-Bus System Message Bus.
Oct 10 16:23:15 alan-inspironn5010 alsactl[395]: alsa-lib parser.c:242:(error_n>
Oct 10 16:23:15 alan-inspironn5010 alsactl[395]: alsa-lib main.c:1405:(snd_use_>
Oct 10 16:23:15 alan-inspironn5010 kernel: audit: type=1130 audit(1633863195.32>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Network Manager...
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Clean up modules from o>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Authorization Manager...
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting Snap Daemon...
Oct 10 16:23:15 alan-inspironn5010 audit: BPF prog-id=9 op=LOAD
Oct 10 16:23:15 alan-inspironn5010 audit: BPF prog-id=10 op=LOAD
Oct 10 16:23:15 alan-inspironn5010 audit: BPF prog-id=11 op=LOAD
Oct 10 16:23:15 alan-inspironn5010 kernel: audit: type=1334 audit(1633863195.33>
Oct 10 16:23:15 alan-inspironn5010 crond[397]: (CRON) STARTUP (1.5.7)
Oct 10 16:23:15 alan-inspironn5010 crond[397]: (CRON) INFO (Syslog will be used>
Oct 10 16:23:15 alan-inspironn5010 crond[397]: (CRON) INFO (RANDOM_DELAY will b>
Oct 10 16:23:15 alan-inspironn5010 crond[397]: (CRON) INFO (running with inotif>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Starting User Login Management...
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Finished Save/Restore Sound Card>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Reached target Sound Card.
Oct 10 16:23:15 alan-inspironn5010 linux-module-cleanup[403]: cat: /usr/lib/mod>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: linux-module-cleanup.service: De>
Oct 10 16:23:15 alan-inspironn5010 systemd[1]: Finished Clean up modules from o>
Oct 10 16:23:15 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294>
Oct 10 16:23:15 alan-inspironn5010 systemd-logind[404]: New seat seat0.
Oct 10 16:23:15 alan-inspironn5010 systemd-logind[404]: Watching system buttons>
Oct 10 16:23:15 alan-inspironn5010 avahi-daemon[396]: Found user 'avahi' (UID 9>
Oct 10 16:23:15 alan-inspironn5010 avahi-daemon[396]: Successfully dropped root>
Oct 10 16:23:15 alan-inspironn5010 avahi-daemon[396]: avahi-daemon 0.8 starting>
Oct 10 16:23:16 alan-inspironn5010 kernel: intel ips 0000:00:1f.6: i915 driver >
Oct 10 16:23:16 alan-inspironn5010 polkitd[401]: Started polkitd version 0.119
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[490]: checking bus 1, device 3: "/>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[488]: checking bus 2, device 3: "/>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[490]: bus: 1, device: 3 was not an>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[488]: bus: 2, device: 3 was not an>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[555]: checking bus 2, device 6: "/>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[556]: checking bus 2, device 5: "/>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[555]: bus: 2, device: 6 was not an>
Oct 10 16:23:17 alan-inspironn5010 mtp-probe[556]: bus: 2, device: 5 was not an>
Oct 10 16:23:18 alan-inspironn5010 kernel: mc: Linux media interface: v0.10
Oct 10 16:23:18 alan-inspironn5010 kernel: videodev: Linux video capture interf>
Oct 10 16:23:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863198.114>
Oct 10 16:23:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863198.176>
Oct 10 16:23:18 alan-inspironn5010 systemd[1]: systemd-rfkill.service: Deactiva>
Oct 10 16:23:18 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294>
Oct 10 16:23:18 alan-inspironn5010 kernel: kauditd_printk_skb: 5 callbacks supp>
Oct 10 16:23:18 alan-inspironn5010 kernel: audit: type=1131 audit(1633863198.30>
Oct 10 16:23:18 alan-inspironn5010 systemd-logind[404]: Watching system buttons>
Oct 10 16:23:18 alan-inspironn5010 kernel: uvcvideo: Found UVC 1.00 device Lapt>
Oct 10 16:23:18 alan-inspironn5010 snapd[402]: AppArmor status: apparmor is ena>
Oct 10 16:23:18 alan-inspironn5010 kernel: input: Laptop_Integrated_Webcam_1.3M>
Oct 10 16:23:18 alan-inspironn5010 kernel: usbcore: registered new interface dr>
Oct 10 16:23:18 alan-inspironn5010 kernel: USB Video Class driver (1.1.1)
Oct 10 16:23:19 alan-inspironn5010 snapd[402]: daemon.go:248: started snapd/2.5>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Started User Login Management.
Oct 10 16:23:19 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:19 alan-inspironn5010 kernel: audit: type=1130 audit(1633863199.36>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: Successfully called chroo>
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: Successfully dropped rema>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Started Network Manager.
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.374>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Reached target Network.
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Starting CUPS Scheduler...
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Starting Permit User Sessions...
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: No service file found in >
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: Joining mDNS multicast gr>
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: New relevant interface lo>
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: Network interface enumera>
Oct 10 16:23:19 alan-inspironn5010 avahi-daemon[396]: Registering new address r>
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.466>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Finished Permit User Sessions.
Oct 10 16:23:19 alan-inspironn5010 kernel: audit: type=1130 audit(1633863199.48>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Starting Light Display Manager...
Oct 10 16:23:19 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:19 alan-inspironn5010 kernel: loop: module loaded
Oct 10 16:23:19 alan-inspironn5010 audit: BPF prog-id=12 op=LOAD
Oct 10 16:23:19 alan-inspironn5010 audit: BPF prog-id=13 op=LOAD
Oct 10 16:23:19 alan-inspironn5010 audit: BPF prog-id=14 op=LOAD
Oct 10 16:23:19 alan-inspironn5010 kernel: audit: type=1334 audit(1633863199.54>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Starting Hostname Service...
Oct 10 16:23:19 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: Started Hostname Service.
Oct 10 16:23:19 alan-inspironn5010 kernel: audit: type=1130 audit(1633863199.75>
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.761>
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.762>
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.763>
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.764>
Oct 10 16:23:19 alan-inspironn5010 NetworkManager[399]: <info>  [1633863199.765>
Oct 10 16:23:19 alan-inspironn5010 kernel: squashfs: version 4.0 (2009/01/31) P>
Oct 10 16:23:19 alan-inspironn5010 systemd[1]: tmp-sanity\x2dmountpoint\x2d3977>
Oct 10 16:23:19 alan-inspironn5010 snapd[402]: daemon.go:341: adjusting startup>
Oct 10 16:23:20 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:20 alan-inspironn5010 systemd[1]: Reached target User and Group Na>
Oct 10 16:23:20 alan-inspironn5010 systemd[1]: Starting Accounts Service...
Oct 10 16:23:20 alan-inspironn5010 avahi-daemon[396]: Server startup complete. >
Oct 10 16:23:20 alan-inspironn5010 NetworkManager[399]: <info>  [1633863200.787>
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.016>
Oct 10 16:23:21 alan-inspironn5010 systemd[1]: Started Snap Daemon.
Oct 10 16:23:21 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:21 alan-inspironn5010 kernel: audit: type=1130 audit(1633863201.11>
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.258>
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.320>
Oct 10 16:23:21 alan-inspironn5010 polkitd[401]: Loading rules from directory />
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.389>
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.757>
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.758>
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.847>
Oct 10 16:23:21 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:21 alan-inspironn5010 polkitd[401]: Finished loading, compiling an>
Oct 10 16:23:21 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:21 alan-inspironn5010 polkitd[401]: Acquired the name org.freedesk>
Oct 10 16:23:21 alan-inspironn5010 systemd[1]: Starting Network Manager Script >
Oct 10 16:23:21 alan-inspironn5010 systemd[1]: Started Authorization Manager.
Oct 10 16:23:21 alan-inspironn5010 accounts-daemon[634]: started daemon version>
Oct 10 16:23:21 alan-inspironn5010 systemd[1]: Starting Modem Manager...
Oct 10 16:23:21 alan-inspironn5010 systemd[1]: Started Accounts Service.
Oct 10 16:23:21 alan-inspironn5010 systemd[1]: Started CUPS Scheduler.
Oct 10 16:23:21 alan-inspironn5010 NetworkManager[399]: <info>  [1633863201.951>
Oct 10 16:23:22 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:22 alan-inspironn5010 systemd[1]: Started Network Manager Script D>
Oct 10 16:23:22 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.488>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.489>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.492>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.495>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.496>
Oct 10 16:23:22 alan-inspironn5010 kernel: RTL8201CP Ethernet r8169-0-1300:00: >
Oct 10 16:23:22 alan-inspironn5010 kernel: r8169 0000:13:00.0 enp19s0: Link is >
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.528>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.529>
Oct 10 16:23:22 alan-inspironn5010 ModemManager[653]: <info>  ModemManager (ver>
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.592>
Oct 10 16:23:22 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:22 alan-inspironn5010 systemd[1]: Starting WPA supplicant...
Oct 10 16:23:22 alan-inspironn5010 NetworkManager[399]: <info>  [1633863202.807>
Oct 10 16:23:23 alan-inspironn5010 systemd[1]: Started Light Display Manager.
Oct 10 16:23:23 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:23 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:23 alan-inspironn5010 systemd[1]: Started WPA supplicant.
Oct 10 16:23:23 alan-inspironn5010 kernel: kauditd_printk_skb: 5 callbacks supp>
Oct 10 16:23:23 alan-inspironn5010 kernel: audit: type=1130 audit(1633863203.35>
Oct 10 16:23:23 alan-inspironn5010 wpa_supplicant[657]: Successfully initialize>
Oct 10 16:23:23 alan-inspironn5010 wpa_supplicant[657]: dbus: fill_dict_with_pr>
Oct 10 16:23:23 alan-inspironn5010 NetworkManager[399]: <info>  [1633863203.698>
Oct 10 16:23:23 alan-inspironn5010 NetworkManager[399]: <info>  [1633863203.699>
Oct 10 16:23:24 alan-inspironn5010 ModemManager[653]: [qrtr] socket lookup from>
Oct 10 16:23:24 alan-inspironn5010 ModemManager[653]: [qrtr] initial lookup fin>
Oct 10 16:23:24 alan-inspironn5010 systemd[1]: Started Modem Manager.
Oct 10 16:23:24 alan-inspironn5010 NetworkManager[399]: <info>  [1633863204.573>
Oct 10 16:23:24 alan-inspironn5010 systemd[1]: Reached target Multi-User System.
Oct 10 16:23:24 alan-inspironn5010 systemd[1]: Reached target Graphical Interfa>
Oct 10 16:23:24 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:24 alan-inspironn5010 kernel: NET: Registered protocol family 42
Oct 10 16:23:24 alan-inspironn5010 kernel: audit: type=1130 audit(1633863204.56>
Oct 10 16:23:24 alan-inspironn5010 systemd[1]: Starting TLP system startup/shut>
Oct 10 16:23:24 alan-inspironn5010 NetworkManager[399]: <info>  [1633863204.637>
Oct 10 16:23:26 alan-inspironn5010 tlp[666]: Applying power save settings...don>
Oct 10 16:23:26 alan-inspironn5010 tlp[666]: Setting battery charge thresholds.>
Oct 10 16:23:26 alan-inspironn5010 systemd[1]: Finished TLP system startup/shut>
Oct 10 16:23:26 alan-inspironn5010 systemd[1]: Startup finished in 3.928s (kern>
Oct 10 16:23:26 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:26 alan-inspironn5010 kernel: audit: type=1130 audit(1633863206.60>
Oct 10 16:23:27 alan-inspironn5010 ModemManager[653]: <info>  [base-manager] co>
Oct 10 16:23:27 alan-inspironn5010 snapd[402]: stateengine.go:150: state ensure>
Oct 10 16:23:28 alan-inspironn5010 NetworkManager[399]: <info>  [1633863208.527>
Oct 10 16:23:30 alan-inspironn5010 lightdm[842]: pam_succeed_if(lightdm-autolog>
Oct 10 16:23:30 alan-inspironn5010 audit[842]: USER_AUTH pid=842 uid=0 auid=429>
Oct 10 16:23:30 alan-inspironn5010 lightdm[842]: gkr-pam: no password is availa>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1100 audit(1633863210.33>
Oct 10 16:23:30 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:30 alan-inspironn5010 dbus-daemon[398]: [system] Activation via sy>
Oct 10 16:23:30 alan-inspironn5010 lightdm[842]: pam_systemd_home(lightdm-autol>
Oct 10 16:23:30 alan-inspironn5010 audit[842]: USER_ACCT pid=842 uid=0 auid=429>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1101 audit(1633863210.37>
Oct 10 16:23:30 alan-inspironn5010 audit[842]: CRED_ACQ pid=842 uid=0 auid=4294>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1103 audit(1633863210.41>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1006 audit(1633863210.41>
Oct 10 16:23:30 alan-inspironn5010 lightdm[842]: pam_unix(lightdm-autologin:ses>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.492>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.493>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.494>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.496>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.497>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.501>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.502>
Oct 10 16:23:30 alan-inspironn5010 systemd[1]: Created slice User Slice of UID >
Oct 10 16:23:30 alan-inspironn5010 systemd[1]: Starting User Runtime Directory >
Oct 10 16:23:30 alan-inspironn5010 systemd-logind[404]: New session 1 of user a>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.570>
Oct 10 16:23:30 alan-inspironn5010 systemd[1]: Finished User Runtime Directory >
Oct 10 16:23:30 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:30 alan-inspironn5010 systemd[1]: Starting User Manager for UID 10>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1130 audit(1633863210.56>
Oct 10 16:23:30 alan-inspironn5010 NetworkManager[399]: <info>  [1633863210.576>
Oct 10 16:23:30 alan-inspironn5010 systemd[847]: pam_systemd_home(systemd-user:>
Oct 10 16:23:30 alan-inspironn5010 audit[847]: USER_ACCT pid=847 uid=0 auid=429>
Oct 10 16:23:30 alan-inspironn5010 audit[847]: CRED_ACQ pid=847 uid=0 auid=4294>
Oct 10 16:23:30 alan-inspironn5010 systemd[847]: pam_warn(systemd-user:setcred)>
Oct 10 16:23:30 alan-inspironn5010 systemd[847]: pam_unix(systemd-user:session)>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1101 audit(1633863210.59>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1103 audit(1633863210.59>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1006 audit(1633863210.59>
Oct 10 16:23:30 alan-inspironn5010 systemd[847]: pam_env(systemd-user:session):>
Oct 10 16:23:30 alan-inspironn5010 audit[847]: USER_START pid=847 uid=0 auid=10>
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1105 audit(1633863210.61>
Oct 10 16:23:30 alan-inspironn5010 audit: BPF prog-id=15 op=LOAD
Oct 10 16:23:30 alan-inspironn5010 audit: BPF prog-id=15 op=UNLOAD
Oct 10 16:23:30 alan-inspironn5010 kernel: audit: type=1334 audit(1633863210.66>
Oct 10 16:23:31 alan-inspironn5010 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp18>
Oct 10 16:23:31 alan-inspironn5010 wpa_supplicant[657]: wlp18s0: Trying to asso>
Oct 10 16:23:31 alan-inspironn5010 wpa_supplicant[657]: wlp18s0: Associated wit>
Oct 10 16:23:31 alan-inspironn5010 wpa_supplicant[657]: wlp18s0: CTRL-EVENT-SUB>
Oct 10 16:23:31 alan-inspironn5010 wpa_supplicant[657]: wlp18s0: WPA: Key negot>
Oct 10 16:23:31 alan-inspironn5010 wpa_supplicant[657]: wlp18s0: CTRL-EVENT-CON>
Oct 10 16:23:31 alan-inspironn5010 wpa_supplicant[657]: bgscan simple: Failed t>
Oct 10 16:23:31 alan-inspironn5010 avahi-daemon[396]: Joining mDNS multicast gr>
Oct 10 16:23:31 alan-inspironn5010 avahi-daemon[396]: New relevant interface wl>
Oct 10 16:23:31 alan-inspironn5010 avahi-daemon[396]: Registering new address r>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.097>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.191>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.279>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.288>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.289>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.290>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.678>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.679>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.716>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.717>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.719>
Oct 10 16:23:31 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:31 alan-inspironn5010 dbus-daemon[398]: [system] Activation via sy>
Oct 10 16:23:31 alan-inspironn5010 NetworkManager[399]: <info>  [1633863211.865>
Oct 10 16:23:32 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:32 alan-inspironn5010 audit[842]: USER_START pid=842 uid=0 auid=10>
Oct 10 16:23:32 alan-inspironn5010 lightdm[842]: pam_env(lightdm-autologin:sess>
Oct 10 16:23:32 alan-inspironn5010 lightdm[842]: gkr-pam: gnome-keyring-daemon >
Oct 10 16:23:32 alan-inspironn5010 systemd[1]: Started User Manager for UID 100>
Oct 10 16:23:32 alan-inspironn5010 audit[842]: USER_LOGIN pid=842 uid=0 auid=10>
Oct 10 16:23:32 alan-inspironn5010 systemd[1]: Started Session 1 of User alan.
Oct 10 16:23:32 alan-inspironn5010 NetworkManager[399]: <info>  [1633863212.357>
Oct 10 16:23:32 alan-inspironn5010 systemd[1]: NetworkManager-dispatcher.servic>
Oct 10 16:23:32 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294>
Oct 10 16:23:33 alan-inspironn5010 NetworkManager[399]: <info>  [1633863213.316>
Oct 10 16:23:33 alan-inspironn5010 NetworkManager[399]: <info>  [1633863213.317>
Oct 10 16:23:36 alan-inspironn5010 snapd[402]: daemon.go:508: gracefully waitin>
Oct 10 16:23:36 alan-inspironn5010 snapd[402]: daemon.go:510: done waiting for >
Oct 10 16:23:36 alan-inspironn5010 snapd[402]: daemon stop requested to wait fo>
Oct 10 16:23:36 alan-inspironn5010 systemd[1]: snapd.service: Deactivated succe>
Oct 10 16:23:36 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294>
Oct 10 16:23:36 alan-inspironn5010 kernel: kauditd_printk_skb: 5 callbacks supp>
Oct 10 16:23:36 alan-inspironn5010 kernel: audit: type=1131 audit(1633863216.24>
Oct 10 16:23:39 alan-inspironn5010 kernel: [UFW BLOCK] IN=wlp18s0 OUT= MAC=01:0>
Oct 10 16:23:40 alan-inspironn5010 kernel: [UFW BLOCK] IN=wlp18s0 OUT= MAC=01:0>
Oct 10 16:23:40 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:40 alan-inspironn5010 systemd[1]: Starting RealtimeKit Scheduling >
Oct 10 16:23:40 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:40 alan-inspironn5010 systemd[1]: Started RealtimeKit Scheduling P>
Oct 10 16:23:40 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Successfully called chroo>
Oct 10 16:23:40 alan-inspironn5010 kernel: audit: type=1130 audit(1633863220.12>
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Successfully dropped priv>
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Successfully limited reso>
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Running.
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Watchdog thread running.
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Canary thread running.
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Successfully made thread >
Oct 10 16:23:40 alan-inspironn5010 rtkit-daemon[936]: Supervising 1 threads of >
Oct 10 16:23:41 alan-inspironn5010 rtkit-daemon[936]: Supervising 1 threads of >
Oct 10 16:23:41 alan-inspironn5010 rtkit-daemon[936]: Successfully made thread >
Oct 10 16:23:41 alan-inspironn5010 rtkit-daemon[936]: Supervising 2 threads of >
Oct 10 16:23:41 alan-inspironn5010 rtkit-daemon[936]: Supervising 3 threads of >
Oct 10 16:23:41 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:41 alan-inspironn5010 systemd[1]: Condition check resulted in Blue>
Oct 10 16:23:48 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:48 alan-inspironn5010 polkitd[401]: Registered Authentication Agen>
Oct 10 16:23:48 alan-inspironn5010 systemd[1]: Starting Manage, Install and Gen>
Oct 10 16:23:49 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:49 alan-inspironn5010 systemd[1]: Started Manage, Install and Gene>
Oct 10 16:23:49 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:49 alan-inspironn5010 kernel: audit: type=1130 audit(1633863229.62>
Oct 10 16:23:49 alan-inspironn5010 systemd[1]: systemd-hostnamed.service: Deact>
Oct 10 16:23:49 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294>
Oct 10 16:23:49 alan-inspironn5010 kernel: audit: type=1131 audit(1633863229.78>
Oct 10 16:23:49 alan-inspironn5010 audit: BPF prog-id=14 op=UNLOAD
Oct 10 16:23:49 alan-inspironn5010 audit: BPF prog-id=13 op=UNLOAD
Oct 10 16:23:49 alan-inspironn5010 audit: BPF prog-id=12 op=UNLOAD
Oct 10 16:23:49 alan-inspironn5010 kernel: audit: type=1334 audit(1633863229.93>
Oct 10 16:23:50 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:50 alan-inspironn5010 audit: BPF prog-id=16 op=LOAD
Oct 10 16:23:50 alan-inspironn5010 audit: BPF prog-id=17 op=LOAD
Oct 10 16:23:50 alan-inspironn5010 kernel: audit: type=1334 audit(1633863230.36>
Oct 10 16:23:50 alan-inspironn5010 systemd[1]: Starting Daemon for power manage>
Oct 10 16:23:50 alan-inspironn5010 NetworkManager[399]: <info>  [1633863230.908>
Oct 10 16:23:51 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:51 alan-inspironn5010 systemd[1]: Started Daemon for power managem>
Oct 10 16:23:51 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:51 alan-inspironn5010 kernel: audit: type=1130 audit(1633863231.60>
Oct 10 16:23:53 alan-inspironn5010 kernel: audit: type=1105 audit(1633863233.07>
Oct 10 16:23:53 alan-inspironn5010 audit[1157]: USER_START pid=1157 uid=1000 au>
Oct 10 16:23:53 alan-inspironn5010 pkexec[1157]: alan: Executing command [USER=>
Oct 10 16:23:53 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:23:53 alan-inspironn5010 systemd[1]: Starting Disk Manager...
Oct 10 16:23:54 alan-inspironn5010 udisksd[1163]: udisks daemon version 2.9.3 s>
Oct 10 16:23:59 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:23:59 alan-inspironn5010 systemd[1]: Started Disk Manager.
Oct 10 16:23:59 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:23:59 alan-inspironn5010 kernel: audit: type=1130 audit(1633863239.40>
Oct 10 16:23:59 alan-inspironn5010 udisksd[1163]: Acquired the name org.freedes>
Oct 10 16:24:05 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:24:05 alan-inspironn5010 systemd[1]: Starting Bluetooth management me>
Oct 10 16:24:05 alan-inspironn5010 blueman-mechanism[1270]: Unable to init serv>
Oct 10 16:24:05 alan-inspironn5010 dbus-daemon[398]: [system] Successfully acti>
Oct 10 16:24:05 alan-inspironn5010 systemd[1]: Started Bluetooth management mec>
Oct 10 16:24:05 alan-inspironn5010 audit[1]: SERVICE_START pid=1 uid=0 auid=429>
Oct 10 16:24:05 alan-inspironn5010 kernel: audit: type=1130 audit(1633863245.91>
Oct 10 16:24:06 alan-inspironn5010 dbus-daemon[398]: [system] Failed to activat>
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <warn>  [1633863258.567>
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863258.567>
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863258.568>
Oct 10 16:24:34 alan-inspironn5010 dbus-daemon[398]: [system] Activating via sy>
Oct 10 16:24:34 alan-inspironn5010 systemd[1]: Condition check resulted in Blue>
Oct 10 16:24:35 alan-inspironn5010 systemd[1]: blueman-mechanism.service: Deact>
Oct 10 16:24:35 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294>
Oct 10 16:24:35 alan-inspironn5010 kernel: audit: type=1131 audit(1633863275.78>
Oct 10 16:24:43 alan-inspironn5010 rtkit-daemon[936]: Successfully made thread >
Oct 10 16:24:43 alan-inspironn5010 rtkit-daemon[936]: Supervising 4 threads of >
Oct 10 16:24:44 alan-inspironn5010 rtkit-daemon[936]: Supervising 4 threads of >
Oct 10 16:24:44 alan-inspironn5010 rtkit-daemon[936]: Successfully made thread >
Oct 10 16:24:44 alan-inspironn5010 rtkit-daemon[936]: Supervising 5 threads of >
Oct 10 16:24:59 alan-inspironn5010 dbus-daemon[398]: [system] Failed to activat>
Oct 10 16:25:45 alan-inspironn5010 kernel: [UFW BLOCK] IN=wlp18s0 OUT= MAC=01:0>
lines 1346-1368/1368 (END)
Oct 10 16:24:06 alan-inspironn5010 dbus-daemon[398]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <warn>  [1633863258.5678] dhcp6 (wlp18s0): request timed out
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863258.5679] dhcp6 (wlp18s0): state changed unknown -> timeout
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863258.5680] dhcp6 (wlp18s0): canceled DHCP transaction
Oct 10 16:24:18 alan-inspironn5010 NetworkManager[399]: <info>  [1633863258.5680] dhcp6 (wlp18s0): state changed timeout -> terminated
Oct 10 16:24:34 alan-inspironn5010 dbus-daemon[398]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requeste>
Oct 10 16:24:34 alan-inspironn5010 systemd[1]: Condition check resulted in Bluetooth service being skipped.
Oct 10 16:24:35 alan-inspironn5010 systemd[1]: blueman-mechanism.service: Deactivated successfully.
Oct 10 16:24:35 alan-inspironn5010 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism com>
Oct 10 16:24:35 alan-inspironn5010 kernel: audit: type=1131 audit(1633863275.788:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg>
Oct 10 16:24:43 alan-inspironn5010 rtkit-daemon[936]: Successfully made thread 1521 of process 1521 owned by '1000' high priority at nice level -11.
Oct 10 16:24:43 alan-inspironn5010 rtkit-daemon[936]: Supervising 4 threads of 2 processes of 1 users.
Oct 10 16:24:44 alan-inspironn5010 rtkit-daemon[936]: Supervising 4 threads of 2 processes of 1 users.
Oct 10 16:24:44 alan-inspironn5010 rtkit-daemon[936]: Successfully made thread 1523 of process 1521 owned by '1000' RT at priority 20.
Oct 10 16:24:44 alan-inspironn5010 rtkit-daemon[936]: Supervising 5 threads of 2 processes of 1 users.
Oct 10 16:24:59 alan-inspironn5010 dbus-daemon[398]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Oct 10 16:25:45 alan-inspironn5010 kernel: [UFW BLOCK] IN=wlp18s0 OUT= MAC=01:00:5e:00:00:01:bc:62:d2:7a:cb:60:08:00 SRC=0.0.0.0 DST=224.0.0.1 LEN=32>
Oct 10 16:25:45 alan-inspironn5010 kernel: [UFW BLOCK] IN=wlp18s0 OUT= MAC=01:00:5e:00:00:fb:08:25:25:bd:4a:96:08:00 SRC=192.168.1.5 DST=224.0.0.251 >
You did something wrong because that’s 9 January 2021.
:grin:
Please edit that and provide the relevant info only and then leave a :heart: and I’ll come back and have another look.
:+1:
I dont know what went wrong but this is the command i entered and i am only getting results since another date. :confused: I tried another date and time and only getting the results since the same date. Can you help me on that? :slightly_smiling_face:
Oops, I misread that because you said ā€œIt’s too longā€.
:blush:
Part of the output is missing, Starting Load/Save Screen Backli>but there is also no error message, can you do a:
journalctl --system --priority=err | grep "Screen Backli" > ~/Documents/spidermonkey-backlight.txt
and post the contents of spidermonkey-backlight.txt?
If none, I don’t know how to help you any further…
:crossed_fingers:
I am sorry but the file was empty :cry:
I’ve found a similar problem with a linux mint user while searching. You can check that out if you wish.
https://forums.linuxmint.com/viewtopic.php?t=277385
They also couldn’t find out the cause of the problem.
Thanks for helping btw. :grin: :slightly_smiling_face:
