I use running dual boot Manjaro GNOME on Ideapad 5 15ITL05. Intel i5 11th gen.
Hotkeys for sound inc/dec/mute work and so does the flight mode and lock key.
But the Brightness keys on f5 and f6 do not show any response in Manjaro. There is no fault in the keyboard as they function well in windows.
I have tried various kernel versions as well but the problem still persists.
Also,
Hotkey f9 supposed to open settings type “i”
and key f12 should click screenshot type “S”
Here is my system info,
Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=67c8fb25-f5c7-4db5-9154-2e1f04a7ab8c rw quiet splash apparmor=1
security=apparmor resume=UUID=7bc34073-1434-480d-b900-89ea33f1d837
udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 82FG v: IdeaPad 5 15ITL05
serial: <filter> Chassis: type: 10 v: IdeaPad 5 15ITL05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: FHCN41WW date: 05/17/2021
ID-1: BAT0 charge: 8.4 Wh (14.7%) condition: 57.0/57.0 Wh (100.0%)
volts: 11.0 min: 11.5 model: Celxpert L19C3PF5 type: Li-poly
serial: <filter> status: Discharging cycles: 9
RAM: total: 15.42 GiB used: 3.63 GiB (23.5%)
Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
cache: L2: 8 MiB bogomips: 38720
Speed: 1828 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1828 2: 1470
3: 848 4: 1751 5: 1884 6: 1592 7: 1880 8: 1355
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-5:3
chip-ID: 174f:2459 class-ID: fe01 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.1.6
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 92.07 GiB (9.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TD9TNI-L2A0B
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 11010C10 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 589.36 GiB size: 579.04 GiB (98.25%)
used: 92.07 GiB (15.9%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: 67c8fb25-f5c7-4db5-9154-2e1f04a7ab8c
ID-2: /boot/efi raw-size: 500.9 MiB size: 499.9 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
label: NO_LABEL uuid: 1424-B942
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 7bc34073-1434-480d-b900-89ea33f1d837
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 2A72-BF77
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 347.79 GiB fs: ntfs label: N/A
uuid: 14E87364E87342D2
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 508 MiB fs: ntfs label: N/A
uuid: 6E3292173291E3FD
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-4:2 info: MosArt Wireless Keyboard/Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4101 class-ID: 0301
Device-2: 3-5:3 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:2459
Device-3: 3-7:4 info: Shenzhen Goodix Goodix FingerPrint Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 27c6:55a2 class-ID: ef00
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 287 Uptime: 44m wakeups: 749 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1389 pacman: 1378 lib: 343 flatpak: 5
snap: 6 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Also, I am adding xrandr
output below,
XWAYLAND0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 59.96*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.52
1680x1050 59.95
1440x900 59.89
1280x800 59.81
720x480 59.71
640x400 59.95
320x200 58.96
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
Please let me know if I am missing any important drivers and if what should I do to resolve them.
