Brave Browser does not work anymore after Update to Kernel 6.17.11-1 a few days ago
After a big Manjaro update a few days ago my Brave Browser does not work anymore. Brave can be started and closed and the Brave window can be moved around. That´s all. It says Brave was unexpectedly closed. But it´s impossible to type in anything, search or perform a mouse-click. Everything is shown in light grey and the Browser doesn´t react to anything.
I tried to do a new installation which seemed to work but the result is the same. Brave doesn´t work!
The actual Brave version installed is 1.85.116
I have searched the Internet about this issue but I didn´t find any helpful results. Maybe someone in this Forum can point me in the right direction!
My System:
KDE Plasma Version: 6.5.3
KDE Frameworks Version: 6.20.0
Qt Version: 6.10.1
Kernel Version: 6.17.11-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × Intel® Core™ i7-3930K CPU @ 3.20GHz
Memory: 32 GiB of RAM (31.3 GiB usable)
Graphics Processor: NVE4
I have no idea what this is
Please provide the output from
inxi -Fxxyc0
Paste it inside a code fence like this
your output from
inxi -Fxxyc0
And for the record - the brave browser work just fine.
It may be corrupted cache. Log out, switch to a TTY, login an execute
rm -rf ~/.cache
reboot
Open a terminal console and execute brave command to see what’s happening and any error message.
Post written using Brave 1.85.116. :wink:
my output from
inxi -Fxxyc0
System:   Host: Chef Kernel: 6.17.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc     v: 15.2.1   Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM     Distro: Manjaro base: Arch Linux Machine:   Type: Desktop Mobo: ASUSTeK model: P9X79 DELUXE v: Rev 1.xx     serial: <superuser required> part-nu: SKU Firmware: BIOS     vendor: American Megatrends v: 4701 date: 05/07/2014 Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master     serial: 7f-8e-8f-5e charge: 100% (should be ignored) status: discharging CPU:   Info: 6-core model: Intel Core i7-3930K bits: 64 type: MT MCP     arch: Sandy Bridge rev: 7 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB   Speed (MHz): avg: 1200 min/max: 1200/3800 cores: 1: 1200 2: 1200 3: 1200     4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200     bogomips: 76840   Flags-basic: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx Graphics:   Device-1: NVIDIA GK104GL [Quadro K4200] vendor: Hewlett-Packard     driver: nouveau v: kernel arch: Kepler-2 pcie: speed: 5 GT/s lanes: 16 ports:     active: DP-1,DVI-I-1 empty: DP-2 bus-ID: 01:00.0 chip-ID: 10de:11b4     temp: 46.0 C   Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9     compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa     dri: nouveau gpu: nouveau d-rect: 3840x1200 display-ID: 0   Monitor-1: DP-1 pos: right model: HannSpree/HannStar HZ281H res: 1920x1200     hz: 60 dpi: 82 diag: 699mm (27.5")   Monitor-2: DVI-I-1 pos: primary,left model: HannSpree/HannStar HZ281H     res: 1920x1200 hz: 60 dpi: 82 diag: 699mm (27.5")   API: EGL v: 1.5 platforms: device: 0 drv: nouveau device: 1 drv: swrast     gbm: drv: nouveau surfaceless: drv: nouveau wayland: drv: nouveau x11:     drv: nouveau   API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.3.1-arch1.2 glx-v: 1.4     direct-render: yes renderer: NVE4 device-ID: 10de:11b4 display-ID: :1.0   API: Vulkan Message: No Vulkan data available.   Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo     de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdpyinfo,xprop Audio:   Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK     driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20   Device-2: NVIDIA GK104 HDMI Audio vendor: Hewlett-Packard     driver: snd_hda_intel v: kernel pcie: speed: 5 GT/s lanes: 16 bus-ID: 01:00.1     chip-ID: 10de:0e0a   API: ALSA v: k6.17.11-1-MANJARO status: kernel-api with: aoss     type: oss-emulator   Server-1: JACK v: 1.9.22 status: off   Server-2: PipeWire v: 1.4.9 status: off with: pipewire-media-session     status: active   Server-3: PulseAudio v: 17.0-93-gbe2efb status: active     with: pulseaudio-alsa type: plugin Network:   Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe     driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503   IF: eno1 state: down mac: 74:d0:2b:cb:02:27   Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet     vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel pcie:     speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 09:00.0 chip-ID: 10ec:8168   IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: 74:d0:2b:cb:02:19 Drives:   Local Storage: total: 939.01 GiB used: 90.72 GiB (9.7%)   ID-1: /dev/sda vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB     speed: 6.0 Gb/s serial: S75CNX0W339925V   ID-2: /dev/sdb model: General size: 7.5 GiB type: USB rev: 2.0     spd: 480 Mb/s lanes: 1 serial: UDisk Partition:   ID-1: / size: 915.81 GiB used: 90.14 GiB (9.8%) fs: ext4 dev: /dev/sda1 Swap:   Alert: No swap data was found. Sensors:   System Temperatures: cpu: 37.0 C mobo: N/A gpu: nouveau temp: 46.0 C   Fan Speeds (rpm): N/A gpu: nouveau fan: 2400 Info:   Memory: total: 32 GiB available: 31.28 GiB used: 5.84 GiB (18.7%)   Processes: 313 Power: uptime: 3h 33m wakeups: 0 Init: systemd v: 258     default: graphical   Packages: pm: pacman pkgs: 1508 Compilers: clang: 21.1.6 gcc: 15.2.1     Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
After starting Brave on the console this came up:
\[54500:54500:1214/132427.190762:ERROR:chrome/browser/ui/views/user_education/impl/browser_user_education_interface_impl.cc:154\] Attempting to show IPH IPH_DiscardRing before browser initialization complete; IPH will not be shown.
\[54500:54574:1214/132457.044729:ERROR:content/browser/browser_main_loop.cc:290\] GLib: g_main_context_pop_thread_default: assertion ‘stack != NULL’ failed
\[54500:54573:1214/132457.044792:ERROR:content/browser/browser_main_loop.cc:290\] GLib: g_main_context_pop_thread_default: assertion ‘stack != NULL’ failed
\[54500:54575:1214/132457.044878:ERROR:content/browser/browser_main_loop.cc:290\] GLib: g_main_context_pop_thread_default: assertion ‘stack != NULL’ failed
Mod edit:- In future please format all code or command output as pre-formatted text (use the </> button in the Compose window). This has been done for you this time. No charge. Next time we expect you will tend to it yourself.
Could you please try that again?
The inxi output should normally be more accessible to those reading. :wink:
It should look something like this:
  Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=613798c9-333e-41e5-8114-1c265b87c073 rw quiet
    resume=UUID=55ad62ab-1366-46dc-b039-fdad5a3195b5 udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
  Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
    part-nu: SKU uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: 3001 date: 02/16/2024
See How to Post Command Output as Preformatted Text :eyes:
my output from
inxi -Fxxyc0
v: 15.2.1
serial:  part-nu: SKU Firmware: BIOS
bogomips: 76840
Device-1: NVIDIA GK104GL \[Quadro K4200\] vendor: Hewlett-Packard
temp: 46.0 C
Display: wayland server: X.or v: 1.21.1.21 with: Xwayland v: 24.1.9
drv: nouveau
chip-ID: 10de:0e0a
type: oss-emulator
status: active
Local Storage: total: 939.01 GiB used: 90.76 GiB (9.7%)
ID-1: / size: 915.81 GiB used: 90.18 GiB (9.8%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nouveau temp: 45.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 2370
Memory: total: 32 GiB available: 31.28 GiB used: 6.33 GiB (20.3%)
Processes: 319 Power: uptime: 4h 42m wakeups: 0 Init: systemd v: 258
default: graphical
MOD EDIT: I fixed the formatting for you this time. By placing your text inside the </> button.
@Madagassi
Now, please format the inxi output properly as pre-formatted text. :point_up:
And here’s the manual way:
Paste the inxi output between two rows of (3) backticks, like this:
Paste inxi command output here
When done properly, it will finally look like this:
or
Use the </> button in the Compose window instead.
That’s at the start, but are there more messages in Terminal when the “Brave was unexpectedly closed” error appears?
No! There are no more messages even if I wait for longer. And the strange thing is: the Browser was not really unexpectedly closed. It´s only a message telling that.
One test you can do is install the new 6.18.0 LTS kernel. I also had some problems with Brave closing without warning, but since I installed this kernel it seems that the problems have disappeared.
Another test, start Brave from Terminal with brave --disable-gpu to disable hardware acceleration and avoid problems with some graphic cards.
I have tried the disable gpu command above. Now the Brave browser is working like normal but I have the following messages at the console. Could I leave it as it is or is some action needed?
Mod edit:- Malformed inxi output removed. Mo charge.
I´m still struggeling with this preformatting… Maybe now:
[16604:16604:1214/195240.129926:ERROR:chrome/browser/ui/views/user_education/impl/browser_user_education_interface_impl.cc:154]
Attempting to show IPH IPH_DiscardRing before browser initialization complete; IPHwill not be shown.
[16648:16648:1214/195256.130602:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
Automatic fallback to software WebGL has been deprecated. Please use the --enable-unsafe-swiftshader (about:flags#enable-unsafe-swiftshader) flag to opt in to lower security guarantees for trusted content.
[16648:16648:1214/195256.133266:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195256.136197:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0805B004C020000]
[16648:16648:1214/195259.432562:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195304.123887:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195304.442759:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195309.708945:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16604:16696:1214/195309.966736:ERROR:content/browser/browser_main_loop.cc:290] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[16604:16694:1214/195309.966736:ERROR:content/browser/browser_main_loop.cc:290] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[16604:16695:1214/195309.966739:ERROR:content/browser/browser_main_loop.cc:290] GLib: g_main_context_pop_thread_default: assertion 'stack != NULL' failed
[16648:16648:1214/195310.790070:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195313.125129:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195313.331452:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195318.933483:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195323.132227:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195323.977249:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0805B004C020000]
[16648:16648:1214/195324.693929:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0805B004C020000]
[16648:16648:1214/195327.803567:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195327.841967:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0805B004C020000]
[16648:16648:1214/195328.346439:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0E05B004C020000]
[16648:16648:1214/195332.192779:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195337.278333:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16650:16670:1214/195337.310597:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for stun.services.mozilla.com., errorcode: -105 [16650:16670:1214/195337.312611:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for stun.services.mozilla.com., errorcode: -105
[16648:16648:1214/195338.738060:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A09026004C020000]
[16648:16648:1214/195346.403817:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195346.414936:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0805B004C020000]
[16648:16648:1214/195346.555744:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0B05B004C020000]
[16648:16648:1214/195346.564851:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195346.673751:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0E05B004C020000]
[16648:16648:1214/195346.685193:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0105C004C020000]
[16648:16648:1214/195347.745984:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0805B004C020000]
[16648:16648:1214/195405.028164:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195405.038028:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0C0FA014C020000]
[16648:16648:1214/195405.234513:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195405.242974:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0F0FA014C020000]
[16648:16648:1214/195405.321331:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A020FB014C020000]
[16648:16648:1214/195405.333634:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A050FB014C020000]
[16648:16648:1214/195411.845213:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195411.859876:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0C0FA014C020000]
[16648:16648:1214/195412.012496:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
[16648:16648:1214/195412.028990:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A0F0FA014C020000]
[16648:16648:1214/195412.243150:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A020FB014C020000]
[16648:16648:1214/195412.251727:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A050FB014C020000]
[16648:16648:1214/195413.505076:ERROR:gpu/command_buffer/service/gles2_cmd_decoder_passthrough.cc:1091] [GroupMarkerNotSet(crbug.com/242999)!:A06026004C020000]
Now we know hardware acceleration is the culprit, go to Brave Menu, Settings, System, disable “Use graphic acceleration…” and use Brave as always. Following one Mesa update about two years ago, Chromium based browsers are quite problematic with hardware acceleration.
I wonder how that is done:
posting the terminal output as one single line
instead of multiple lines as it appears in terminal
just highlight the output, paste it here, highlight it again and then use the </> button
or put three backticks at the beginning of it all and another three at the end
What terminal are you using?
That looks like the difference between Windows line feed and Linux line feed.
One uses carriage return and line feed (“\r\n”) as a line ending, the other (Unix) uses just line feed (“\n”)
That above looks horrible - not as intended.
I´m using zsh - console.
Very strange - have never seen that here - except multiple times in the past few days.
Just as an example and exercise:
ls -l
was the command
can you replicate this by copy/pasting the output here and then formatting it using `</>` ?
ls -l /
total 84
lrwxrwxrwx   1 root root     7 Oct 14 10:19 bin -> usr/bin
drwxr-xr-x   2 root root  4096 Feb 26  2024 bin.usr-is-merged
drwxr-xr-x   5 root root  4096 Dec 10 23:36 boot
drwxr-xr-x   2 root root  4096 Oct 14 10:28 cdrom
drwxr-xr-x  22 root root  4560 Dec 13 21:30 dev
drwxr-xr-x 168 root root 12288 Dec 13 12:24 etc
drwxr-xr-x   3 root root  4096 Oct 14 10:28 home
lrwxrwxrwx   1 root root     7 Oct 14 10:19 lib -> usr/lib
drwxr-xr-x   2 root root  4096 Apr  8  2024 lib.usr-is-merged
lrwxrwxrwx   1 root root     9 Oct 14 10:19 lib64 -> usr/lib64
drwx------   2 root root 16384 Oct 14 10:19 lost+found
drwxr-xr-x   4 root root  4096 Oct 14 12:49 media
drwxr-xr-x   2 root root  4096 Aug 28 12:50 mnt
drwxr-xr-x   2 root root  4096 Aug 28 12:50 opt
dr-xr-xr-x 310 root root     0 Dec 13 14:01 proc
drwx------  10 root root  4096 Nov 20 13:56 root
drwxr-xr-x  39 root root  1040 Dec 14 15:34 run
lrwxrwxrwx   1 root root     8 Oct 14 10:19 sbin -> usr/sbin
drwxr-xr-x   2 root root  4096 Mar 31  2024 sbin.usr-is-merged
drwxr-xr-x   2 root root  4096 Aug 28 12:50 srv
dr-xr-xr-x  13 root root     0 Dec 14 20:30 sys
drwxrwxrwt  20 root root  4096 Dec 14 15:30 tmp
drwxr-xr-x  12 root root  4096 Aug 28 12:50 usr
drwxr-xr-x  12 root root  4096 Oct 25 11:33 var
Now I highlighted all the text and then I pressed “</>”
Still as ugly as before.
It’s supposed to appear in a relatively short, scrollable box,
not how yours looks like
That is why I wanted you to try with something smaller:
the output of
ls -l
should look just as mine (which is not from Manjaro)
