Hi,
something happened today that was not there before now when i plug in my headphones in the front audio port it recognises it and gives you the option of analog headphones or microphone and you can adjust the volume level and different output of the headphones like analog stereo duplex and analog stereo output but i cant hear any sound or music playing i also checked the rear LINE OUT as you suggested that one works perfectly fine
this is the output of aplay -l as you asked
aplay -l ✔
**** List of PLAYBACK Hardware Devices ****
card 0: Audio [USB Audio], device 0: USB Audio [USB Audio]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Audio [USB Audio], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
card 0: Audio [USB Audio], device 2: USB Audio [USB Audio #2]
Subdevices: 1/1
card 0: Audio [USB Audio], device 3: USB Audio [USB Audio #3]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
and this is the output of pactl list cards
pactl list cards ✔
Card #52
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "1"
api.alsa.card.longname = "HDA ATI HDMI at 0xddb20000 irq 147"
api.alsa.card.name = "HDA ATI HDMI"
api.alsa.path = "hw:1"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio1"
api.dbus.ReserveDevice1.Priority = "-20"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:03:00.1"
device.description = "Navi 31 HDMI/DP Audio"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_03_00.1"
device.nick = "HDA ATI HDMI"
device.plugged.usec = "10094040"
device.product.id = "0xab30"
device.product.name = "Navi 31 HDMI/DP Audio"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.1/sound/card1"
device.vendor.id = "0x1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
media.class = "Audio/Device"
factory.id = "15"
client.id = "47"
object.id = "52"
object.serial = "52"
object.path = "alsa:acp:HDMI"
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xddb20000 irq 147"
alsa.mixer_name = "ATI R6xx HDMI"
alsa.components = "HDA:1002aa01,00aa0100,00100800"
alsa.id = "HDMI"
device.string = "1"
Profiles:
off: Uit (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digitaal stereo (HDMI) uitvoer (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) uitvoer (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) uitvoer (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) uitvoer (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround: Digitaal surround 5.1 (HDMI) uitvoer (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) uitvoer (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) uitvoer (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) uitvoer (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) uitvoer (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) uitvoer (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) uitvoer (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) uitvoer (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #53
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "Generic USB Audio at usb-0000:11:00.0-6, high speed"
api.alsa.card.name = "USB Audio"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-Generic_USB_Audio-00"
device.bus_path = "pci-0000:11:00.0-usb-0:6:1.0"
device.description = "USB Audio"
device.icon_name = "audio-card-analog-usb"
device.name = "alsa_card.usb-Generic_USB_Audio-00"
device.nick = "USB Audio"
device.plugged.usec = "15596074"
device.product.id = "0x1b9b"
device.product.name = "USB Audio"
device.serial = "Generic_USB_Audio"
sysfs.path = "/devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:11:00.0/usb3/3-6/3-6:1.0/sound/card0"
device.vendor.id = "0x0b05"
device.vendor.name = "ASUSTek Computer, Inc."
factory.id = "15"
client.id = "47"
object.id = "53"
object.serial = "53"
object.path = "alsa:acp:Audio"
alsa.card = "0"
alsa.card_name = "USB Audio"
alsa.long_card_name = "Generic USB Audio at usb-0000:11:00.0-6, high speed"
alsa.driver_name = "snd_usb_audio"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB0b05:1b9b"
alsa.id = "Audio"
device.string = "0"
Profiles:
output:analog-stereo+input:analog-stereo: Analoog stereo duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-stereo+input:iec958-stereo: Analoog stereo uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 6555, available: yes)
output:analog-stereo: Analoog stereo uitvoer (sinks: 1, sources: 0, priority: 6500, available: yes)
output:iec958-stereo+input:analog-stereo: Digitaal stereo (IEC958) uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 5565, available: no)
output:iec958-stereo+input:iec958-stereo: Digitaal stereo duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
output:iec958-stereo: Digitaal stereo (IEC958) uitvoer (sinks: 1, sources: 0, priority: 5500, available: yes)
output:analog-surround-21+input:analog-stereo: Analoog surround 2.1 uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-41+input:analog-stereo: Analoog surround 4.1 uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-51+input:analog-stereo: Analoog surround 5.1 uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-21+input:iec958-stereo: Analoog surround 2.1 uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 1355, available: yes)
output:analog-surround-41+input:iec958-stereo: Analoog surround 4.1 uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 1355, available: yes)
output:analog-surround-51+input:iec958-stereo: Analoog surround 5.1 uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 1355, available: yes)
output:analog-surround-21: Analoog surround 2.1 uitvoer (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-41: Analoog surround 4.1 uitvoer (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-51: Analoog surround 5.1 uitvoer (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-40+input:analog-stereo: Analoog surround 4.0 uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-50+input:analog-stereo: Analoog surround 5.0 uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-71+input:analog-stereo: Analoog surround 7.1 uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-40+input:iec958-stereo: Analoog surround 4.0 uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 1255, available: yes)
output:analog-surround-50+input:iec958-stereo: Analoog surround 5.0 uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 1255, available: yes)
output:analog-surround-71+input:iec958-stereo: Analoog surround 7.1 uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 1255, available: yes)
output:analog-surround-40: Analoog surround 4.0 uitvoer (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-50: Analoog surround 5.0 uitvoer (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-71: Analoog surround 7.1 uitvoer (sinks: 1, sources: 0, priority: 1200, available: yes)
output:iec958-ac3-surround-51+input:analog-stereo: Digitaal surround 5.1 (IEC958/AC3) uitvoer + Analoog stereo invoer (sinks: 1, sources: 1, priority: 365, available: no)
output:iec958-ac3-surround-51+input:iec958-stereo: Digitaal surround 5.1 (IEC958/AC3) uitvoer + Digitaal stereo (IEC958) invoer (sinks: 1, sources: 1, priority: 355, available: yes)
output:iec958-ac3-surround-51: Digitaal surround 5.1 (IEC958/AC3) uitvoer (sinks: 1, sources: 0, priority: 300, available: yes)
input:analog-stereo: Analoog stereo invoer (sinks: 0, sources: 1, priority: 65, available: no)
input:iec958-stereo: Digitaal stereo (IEC958) invoer (sinks: 0, sources: 1, priority: 55, available: yes)
pro-audio: Pro Audio (sinks: 4, sources: 3, priority: 1, available: yes)
Active Profile: output:analog-surround-71
Ports:
analog-input-mic: Microfoon (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
analog-input-linein: Lijn-in (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "line"
iec958-stereo-input: Digitale invoer (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-40+input:iec958-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51+input:iec958-stereo, output:analog-surround-71+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
analog-output-speaker: Luidsprekers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, available)
Properties:
port.type = "speaker"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-21+input:iec958-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-40+input:iec958-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-41+input:iec958-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-50+input:iec958-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-51+input:iec958-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo, output:analog-surround-71+input:iec958-stereo
analog-output-headphones: Analoge koptelefoon (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "headphones"
card.profile.port = "4"
iec958-stereo-output: Digitaal stereo (HDMI) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
card.profile.port = "5"
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #54
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "2"
api.alsa.card.longname = "HD-Audio Generic at 0xdd980000 irq 148"
api.alsa.card.name = "HD-Audio Generic"
api.alsa.path = "hw:2"
api.dbus.ReserveDevice1 = "Audio2"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:7b:00.1"
device.description = "Rembrandt Radeon High Definition Audio Controller"
device.name = "alsa_card.pci-0000_7b_00.1"
device.nick = "HD-Audio Generic"
device.plugged.usec = "10094076"
device.product.id = "0x1640"
device.product.name = "Rembrandt Radeon High Definition Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:7b:00.1/sound/card2"
factory.id = "15"
client.id = "47"
object.id = "54"
object.serial = "54"
object.path = "alsa:acp:Generic"
alsa.card = "2"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xdd980000 irq 148"
alsa.id = "Generic"
device.string = "2"
Profiles:
pro-audio: Pro Audio (sinks: 3, sources: 0, priority: 1, available: yes)
Active Profile: off
Ports:
Properties:
port.type = "hdmi"
Properties:
port.type = "hdmi"
Properties:
port.type = "hdmi"
