Borg Mount Fails
So I’m trying to view some older versions of a few files (I just want to examine the filenames) and the docs said to use borg mount if I wasn’t sure where to look. First time doing this, so I try to mount the oldest archive in a new directory and it throws me the following error:
[jpbaiocchi@bruiser ~]$ borg mount /mnt/backup/backup::Sunday /mnt/borg
borg mount not available: loading FUSE support failed [ImportError: No module named 'llfuse']
Install python-llfuse, its a dependancy of borg for mounting
Okay, but now it says that my directory needs to be writable. Do I need to use sudo?
/mnt/borg: Mountpoint must be a writable directory
sudo chown username:username /mnt/borg
*change username by yours
That did the trick. I have access now. Thank you!
