Bootloader could not be installed
Hello friends,
I need help.
The bootloader could not be installed. The installation command
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force
returned error code 1.
Why would you want or need to install it?
It should have been installed … long ago.
What is the back story?
What is the actual problem, prompting you to want to re-install grub?
Maybe your error is that :wink:
The efi directory should point to the ESP partition, which by conventions is mounted either on /boot/efi or /efi
Note:
An EFI system partition (ESP) has partition type = ef00
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
You can also use Maxi
to collect information about the boot process. This works,
  • when you are in your running system (with CTRL+ALT+F2).
  • And also in a live environment
