Hello everyone.
I’ve installed Manjaro recently. Unfortunately booting succeds maybe once after 5 other tries.
Usually stucks on “dev/sdxx” clean screen or seconds after it disappears.
X is my number of disk/partition, it does not really matter.
I have dell inspiron 5577, with HDD and SSD. On a SSD I have windows installed.
What’s wrong? Please help.
Hi and welcome to the forum
If you could provide some good information there might be users who can help you solve this issue.
Posting the errors from the journal log could shed some light on your issue.
The command below lists the errors in the previous bootup of your machine, so run it after a successful boot and post the result (see how to provide good info for guidance on the formatting and what is also useful to post)
journalctl --boot -1 --priority=err
Below is a result of command you’ve provided:
wrz 22 19:29:33 msz-inspiron5577 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
wrz 22 19:29:33 msz-inspiron5577 kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
wrz 22 19:29:22 msz-inspiron5577 systemd-udevd[297]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
wrz 22 19:30:21 msz-inspiron5577 kernel: ACPI Error: Aborting method \_SB.PCI0.PGON due to previous error (AE_AML_LOOP_TIMEOUT) (20200925/psparse-529)
wrz 22 19:30:21 msz-inspiron5577 kernel: ACPI Error: Aborting method \_SB.PCI0.PEG0.PG00._ON due to previous error (AE_AML_LOOP_TIMEOUT) (20200925/psparse-529)
wrz 22 19:30:22 msz-inspiron5577 kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
and that’s a result of inxi command:
Kernel: 5.10.63-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=270c9db5-7429-4d57-8d0b-c29d638d59b0 rw quiet apparmor=1
security=apparmor resume=UUID=2ae23d0b-009b-4908-ab61-3c19970cf949
udev.log_priority=3
Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Dell product: Inspiron 5577 v: 1.0.4 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0MVD5F v: A00 serial: <filter> UEFI: Dell v: 1.0.4
date: 06/07/2017
ID-1: BAT0 charge: 5.0 Wh (9.4%) condition: 53.1/74.0 Wh (71.8%) volts: 11.1
min: 11.1 model: SDI Dell type: Li-ion serial: <filter> status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M185
status: Discharging
RAM: total: 7.54 GiB used: 1.84 GiB (24.4%)
Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: EA
cache: L2: 6 MiB bogomips: 44817
Speed: 900 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 943 5: 916 6: 930 7: 943 8: 943
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 1bcf:2b8a class-ID: 0e02
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2)
v: 4.6 Mesa 21.3.0-devel (git-4968313fe5) direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.10.63-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: d000
bus-ID: 03:00.0 chip-ID: 8086:3165 class-ID: 0280
bus-ID: 1-5:4 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.03 TiB used: 112.43 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba
model: THNSNK128GVN8 M.2 2280 128GB size: 119.24 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 4101 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: SDM2 scheme: GPT
ID-1: / raw-size: 145.31 GiB size: 141.97 GiB (97.70%)
used: 112.43 GiB (79.2%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 270c9db5-7429-4d57-8d0b-c29d638d59b0
ID-2: /boot/efi raw-size: 685.7 MiB size: 684.3 MiB (99.80%)
used: 316 KiB (0.0%) fs: vfat dev: /dev/sdb5 maj-min: 8:21 label: NO_LABEL
uuid: 80F8-1DC3
ID-1: swap-1 type: partition size: 7.97 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 2ae23d0b-009b-4908-ab61-3c19970cf949
ID-1: /dev/sda1 maj-min: 8:1 size: 500 MiB fs: vfat label: ESP
uuid: EA7E-05C6
ID-2: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 103.48 GiB fs: ntfs label: OS
uuid: B24CD7E04CD79D83
ID-4: /dev/sda4 maj-min: 8:4 size: 807 MiB fs: ntfs label: WINRETOOLS
uuid: 00B8F1DAB8F1CE62
ID-5: /dev/sda6 maj-min: 8:6 size: 1.12 GiB fs: ntfs label: DELLSUPPORT
uuid: 0EDE00C5DE00A755
ID-6: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
ID-7: /dev/sdb2 maj-min: 8:18 size: 784.9 GiB fs: ntfs label: DATA
uuid: DC44E33B44E316D4
ID-8: /dev/sdb4 maj-min: 8:20 size: 513 MiB fs: vfat label: N/A
uuid: 7452-606C
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-4:3 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Device-3: 1-5:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 1-7:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C mobo: 38.5 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 240 Uptime: 9m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1211 lib: 385
flatpak: 0 Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06 ```
There is a newer BIOS https://www.dell.com/support/home/en-en/drivers/driversdetails?driverid=mvxjd&driverid=mvxjd
and apparently will fix some firmware bugs.
In the past I tried to update BIOS on this laptop once. Never ever.
Windows went crazy, nothing worked properly. Really aren’t there any other solutions?
BIOS bugs can be fixed only by a better BIOS.
