loader almost takes 13 min , the manjaro-log-helper output is 5214 lines can i post it here?
here are more info โฆ
output of systemd-analyze
[shahad@Manjaro ~]$ systemd-analyze
Startup finished in 3.339s (firmware) + 12min 21.275s (loader) + 1.047s (kernel) + 8.271s (userspace) = 12min 33.934s
graphical.target reached after 7.891s in userspace.
output of dmesg --level emerg,alert,crit,err,warn
[shahad@Manjaro ~]$ sudo dmesg --level emerg,alert,crit,err,warn
[sudo] password for shahad:
[ 0.000000] [Firmware Bug]: TSC ADJUST: CPU0: -284019644 force to 0
[ 0.159273] x86/cpu: SGX disabled by BIOS.
[ 0.159273] Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
[ 0.011844] [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
[ 0.160859] #2 #3 #4
[ 0.166052] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.166171] #5 #6 #7
[ 0.173212] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.222954] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C1.TPL1], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.222960] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.223563] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.223566] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.223570] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.223573] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.225143] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.225146] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.225150] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.225152] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.226585] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.226588] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.226592] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.226594] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.228147] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.228150] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.228153] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.228155] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.229715] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.229718] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.229721] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.229723] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.231276] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.231279] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.231282] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.231285] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.232846] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.232849] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.232853] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.232855] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.234405] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.234408] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.234411] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.234414] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.235973] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.235977] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.235980] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.235982] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.237534] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.237537] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.237540] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.237543] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239150] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239153] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239156] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239158] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239163] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239165] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239168] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239170] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239199] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239202] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239205] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239207] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239236] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239238] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239241] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239243] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239272] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239277] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239280] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239282] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239313] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239315] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239319] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239321] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239349] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239352] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239355] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239357] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239385] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239388] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.239391] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.239393] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.425170] hpet_acpi_add: no address or irqs in _CRS
[ 0.877727] usb: port power management may be unreliable
[ 0.879872] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.412161] vboxdrv: loading out-of-tree module taints kernel.
[ 1.455794] VBoxNetAdp: Successfully started.
[ 1.462961] VBoxNetFlt: Successfully started.
[ 2.395008] ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20210730/psargs-330)
[ 2.395031] ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
[ 2.395082] ACPI Warning: \_SB.IETM._TRT: Return Package has no elements (empty) (20210730/nsprepkg-94)
[ 2.425081] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 2.425260] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 3.031833] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 3.114623] MXM: GUID detected in BIOS
[ 3.114766] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 3.115061] ACPI Warning: \_SB.PCI0.RP05.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 3.543150] thermal thermal_zone8: failed to read out thermal zone (-61)
[ 8.193109] kauditd_printk_skb: 205 callbacks suppressed
[ 14.213978] kauditd_printk_skb: 158 callbacks suppressed
[ 31.406673] kauditd_printk_skb: 41 callbacks suppressed
output of journalctl --catalog --priority=3 --boot=-1
[shahad@Manjaro ~]$ journalctl --catalog --priority=3 --boot=-1
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: x86/cpu: SGX disabled by BIOS.
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C1.TPL1], AE_NOT_FOUND (20210730/dswload2-162)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
ุฃุจุฑูู 10 02:18:47 Manjaro systemd-udevd[305]: /etc/udev/rules.d/99-jlink.rules:361 Unknown group 'dialout', ignoring
ุฃุจุฑูู 10 02:18:47 Manjaro systemd-udevd[305]: /etc/udev/rules.d/99-jlink.rules:362 Unknown group 'dialout', ignoring
ุฃุจุฑูู 10 02:18:47 Manjaro systemd-udevd[305]: /etc/udev/rules.d/99-jlink.rules:363 Unknown group 'dialout', ignoring
ุฃุจุฑูู 10 02:18:48 Manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20210730/psargs-330)
ุฃุจุฑูู 10 02:18:48 Manjaro kernel: ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
ุฃุจุฑูู 10 02:18:49 Manjaro systemd[1]: Failed to start VMware host USB services for Workstation and VMRC.
โโ Subject: A start job for unit vmware-USBArbitrator.service has failed
โโ Defined-By: systemd
โโ Support: https://forum.manjaro.org/c/support
โโ
โโ A start job for unit vmware-USBArbitrator.service has finished with a failure.
โโ
โโ The job identifier is 112 and the job result is failed.
ุฃุจุฑูู 10 02:18:50 Manjaro VMware-init[760]: /usr/lib/vmware/scripts/util.sh: line 70: /usr/sbin/vmware-authdlauncher: No such file or directory
ุฃุจุฑูู 10 02:18:50 Manjaro systemd[1]: Failed to start VMware host virtualization and network services for Workstation.
โโ Subject: A start job for unit vmware.service has failed
โโ
โโ A start job for unit vmware.service has finished with a failure.
โโ
โโ The job identifier is 96 and the job result is failed.
ุฃุจุฑูู 10 02:18:50 Manjaro bluetoothd[833]: src/plugin.c:plugin_init() Failed to init vcp plugin
ุฃุจุฑูู 10 02:18:50 Manjaro bluetoothd[833]: src/plugin.c:plugin_init() Failed to init mcp plugin
ุฃุจุฑูู 10 02:18:50 Manjaro bluetoothd[833]: src/plugin.c:plugin_init() Failed to init bap plugin
ุฃุจุฑูู 10 02:19:10 Manjaro systemd[1]: Failed to start Terminate Plymouth Boot Screen.
โโ Subject: A start job for unit plymouth-quit.service has failed
โโ
โโ A start job for unit plymouth-quit.service has finished with a failure.
โโ
โโ The job identifier is 109 and the job result is failed.
ุฃุจุฑูู 10 02:20:40 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ Subject: A start job for unit lightdm.service has failed
โโ
โโ A start job for unit lightdm.service has finished with a failure.
โโ
โโ The job identifier is 129 and the job result is failed.
ุฃุจุฑูู 10 02:22:10 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 733 and the job result is failed.
ุฃุจุฑูู 10 02:23:41 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 898 and the job result is failed.
ุฃุจุฑูู 10 02:25:11 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 981 and the job result is failed.
ุฃุจุฑูู 10 02:26:42 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 1064 and the job result is failed.
ุฃุจุฑูู 10 02:28:12 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 1147 and the job result is failed.
ุฃุจุฑูู 10 02:29:43 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 1312 and the job result is failed.
ุฃุจุฑูู 10 02:31:13 Manjaro systemd[1]: Failed to start Light Display Manager.
โโ
โโ
โโ The job identifier is 1395 and the job result is failed.
ุฃุจุฑูู 10 02:32:44 Manjaro systemd[1]: Failed to start Light Display Manager.
output of sudo inxi --admin --verbosity=7 --filter --width
[shahad@Manjaro ~]$ sudo inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.105-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=3c06cbf6-4e9b-4ef2-b6fb-2bf2233d18ef rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ZenBook UX434FLC_UX434FL v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX434FLC v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX434FLC.306 date: 05/15/2020
ID-1: BAT0 charge: 16.1 Wh (49.4%) condition: 32.6/50.0 Wh (65.3%)
volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 488
RAM: total: 15.43 GiB used: 1.93 GiB (12.5%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: Samsung part-no: K4EBE304ED-EGCG serial: <filter>
Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
Info: model: Intel Core i7-10510U socket: BGA1528 (U3E1) note: check bits: 64
type: MT MCP arch: Comet/Whiskey Lake note: check gen: core 10 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 882 high: 900 min/max: 400/4900 base/boost: 1782/8300
scaling: driver: intel_pstate governor: powersave volts: 0.6 V
ext-clock: 100 MHz cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 796
8: 865 bogomips: 36812
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 off: HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108BM [GeForce MX250] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-03) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d52
class-ID: 0302 temp: 34.0 C
Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris,nouveau gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 mapped: HDMI-1 note: disabled
model: Toshiba ScreenXpert- serial: <filter> built: 2011 res: N/A dpi: 457
gamma: 1.2 size: 66x134mm (2.6x5.28") diag: 140mm (5.5") modes:
max: 1080x2160 min: 504x1000
Monitor-2: eDP-1 pos: primary model: AU Optronics 0x323d built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k5.15.105-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl,pavucontrol
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 163.56 GiB (17.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-00000
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EXA7301Q temp: 30.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 163.56 GiB (17.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 3c06cbf6-4e9b-4ef2-b6fb-2bf2233d18ef
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 789B-2216
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-5:3 info: IMC Networks USB2.0 HD IR UVC WebCam type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C pch: 36.0 C mobo: N/A gpu: nouveau
temp: 35.0 C
Fan Speeds (RPM): cpu: 0
Processes: 241 Uptime: 30m wakeups: 1799 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1241 pm: pacman pkgs: 1235 libs: 360 tools: pamac,yay pm: flatpak
pkgs: 6 Shell: Bash (sudo) v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
