Hello,
I am trying to install Windows 10 on my laptop and then dual boot it with Manjaro (uefi) which I am using currently. I downloaded the WIN10 iso from the official site and dd’d it on my usb. I think that I have GRUB (by default?) and while tinkering around all this I also tried using rEFInd… and other. Whatever I do, I can’t boot from the usb. Secure boot disabled, in BIOS the ‘CD/ROM/USB’ is first on the list, neither does refind or the boot options (F9) list this usb. I am desperate.
Here are some lines:
sudo parted -l
Model: ATA HGST HTS545050A7 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 ESP boot, esp
2 538MB 500GB 500GB ext4 primary
Model: Verbatim STORE N GO (scsi)
Disk /dev/sdb: 62.0GB
Partition Table: loop
Disk Flags:
Number Start End Size File system Flags
1 0.00B 62.0GB 62.0GB udf
___________________________________________________
test -d /sys/firmware/efi && echo efi || echo bios
efi
efibootmgr -v
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 0001,3001,0003,0000,0002,2001,2002,2004
Boot0000* rEFInd Boot Manager HD(1,GPT,3338bf45-4929-47c9-b8aa-e5d83a287d65,0x800,0x100000)/File(\EFI\refind\refind_x64.efi)
Boot0001* manjaro HD(1,GPT,3338bf45-4929-47c9-b8aa-e5d83a287d65,0x800,0x100000)/File(\EFI\manjaro\grubx64.efi)
Boot0002* EFI Hard Drive (HGST HTS545050A7E680) PciRoot(0x0)/Pci(0x13,0x0)/Sata(0,0,0)/HD(1,GPT,3338bf45-4929-47c9-b8aa-e5d83a287d65,0x800,0x100000)RC
Boot0003* rEFInd HD(1,GPT,3338bf45-4929-47c9-b8aa-e5d83a287d65,0x800,0x1BootCurrent: 0002
Timeout: 0 seconds
Boot0003* rEFInd HD(1,GPT,3338bf45-4929-47c9-b8aa-e5d83a287d65,0x800,0x100000)/File(\EFI\refind\refind_x64.efi)
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
os-prober
output nothing
inxi -Fazy
Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=027871ce-15e4-4ac8-ac10-1c38675dfa9a rw quiet udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: Compaq 15 Notebook PC
v: 096C110000405F00050660180 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Hewlett-Packard model: 2213 v: 57.46 serial: <filter> UEFI: Insyde
v: F.31 date: 10/23/2014
ID-1: BAT1 charge: 25.5 Wh condition: 25.5/41.4 Wh (61%) volts: 16.7/14.8
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Full
Info: Quad Core model: Intel Pentium N3540 bits: 64 type: MCP
arch: Silvermont family: 6 model-id: 37 (55) stepping: 8 microcode: 838
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17343
Speed: 500 MHz min/max: 500/2666 MHz Core speeds (MHz): 1: 527 2: 559 3: 500
4: 500
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0f31
Device-2: Realtek HP Truevision HD integrated webcam type: USB
driver: uvcvideo bus ID: 1-4:4 chip ID: 0bda:5776 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.2.2
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:0f04
Sound Server: ALSA v: k5.4.77-1-MANJARO
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 2000
bus ID: 02:00.0 chip ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 1000 bus ID: 04:00.0 chip ID: 10ec:8136
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 523.53 GiB used: 154.46 GiB (29.5%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: AH10 scheme: GPT
ID-2: /dev/sdb type: USB vendor: Verbatim model: STORE N GO size: 57.77 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
ID-1: / raw size: 465.26 GiB size: 456.96 GiB (98.22%)
used: 154.45 GiB (33.8%) fs: ext4 dev: /dev/sda2
Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: file size: 3.73 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 49.0 C mobo: 43.0 C
Processes: 204 Uptime: 37m Memory: 7.67 GiB used: 1.33 GiB (17.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1468 pacman: 1453
lib: 430 flatpak: 0 snap: 15 Shell: Zsh v: 5.8 running in: xfce4-terminal
inxi: 3.1.08
I might have messed up, but you be the judge.
