Booting to blank screen is back again. It started after the latest stable update. I tried the old stuff that used to fix it, but it doesn’t work. I tried removing splash, but there is no splash to remove. I tried removing quiet, that seemed to work for a day, then today the blank screen is back.
Welcome to Manjaro!
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you unhide your profile and enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=260c331a-ce37-421e-b75f-696a4df21616 rw nowatchdog zswap.enabled=0
mitigations=off resume=UUID=8b3f4d8e-89ca-47ef-800c-08fce76aa125
udev.log_priority=3 sysrq_always_enabled=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 52.1 Wh (100.0%) condition: 52.1/60.0 Wh (86.8%)
volts: 17.2 min: 15.4 model: Celxpert L19C4PC0 type: Li-poly
serial: <filter> status: Full cycles: 315
RAM: total: 15.08 GiB used: 5.05 GiB (33.5%)
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 cache: L2: 4 MiB bogomips: 92661
Speed: 2633 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 2633 2: 2396 3: 1987 4: 1507 5: 1397 6: 1397 7: 1447 8: 1396 9: 4281
10: 4211 11: 2760 12: 1904 13: 1907 14: 1906 15: 1397 16: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: amdgpu,nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.14-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 159.75 GiB (33.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000L2
lanes: 4 rotation: SSD serial: <filter> rev: 3L1QEXF7 temp: 36.9 C
scheme: MBR
ID-1: / raw-size: 468.13 GiB size: 459.79 GiB (98.22%)
used: 159.51 GiB (34.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 260c331a-ce37-421e-b75f-696a4df21616
ID-1: swap-1 type: partition size: 8.8 GiB used: 244.5 MiB (2.7%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 8b3f4d8e-89ca-47ef-800c-08fce76aa125
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6c2
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-5: 3-1.1:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-1.1.2:6 info: Lenovo Legion M300 RGB Gaming Mouse
type: Mouse,Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 17ef:60e4 class-ID: 0300
Device-2: 3-1.1.3:7 info: Microdia USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0c45:7603 class-ID: 0301
Device-3: 3-3:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-4: 3-4:5 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c100 class-ID: 0301
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 46.5 C mobo: 0 C gpu: amdgpu temp: 36.0 C
Processes: 369 Uptime: 9h 06m wakeups: 1 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1477 pacman: 1447 lib: 484
flatpak: 30 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
- Please install both kernels 5.4 and 5.10 LTS (Long Time Support) and see which one of the two troubles you least and report back afterwards and we’ll take it from there…
- If the above doesn’t make sense to you, please shout out!
Thanks! I tried going down to 5.10. It seems to have fixed it. It also seems to have fixed the Gnome bug where it gets stuck in overview. Although it still gets stuck, but only on the first use. After refreshing Gnome it does ok.
