I am new to Manjaro and my system seems to be stuck at the below screen.
Just restarts and comes back to the same screen and the keyboard doesnt seem to work.
boot on USB iso manjaro
open a terminal
a browser on this topic
and reports
inxi -Fxza --no-host
sudo parted -l
sudo efibootmgr -v
test -d /sys/firmware/efi && echo efi || echo bios
Well, I reinstalled a new copy of Manajro and now I am still getting a few lines of No irq handler for vector.
Installed the 440xx driver, had the main issue after installing the 450xx driver
0000:2b:00.0 (0300:10de:21c4) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-450xx 2019.10.25 false PCI
video-nvidia-440xx 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa
open a terminal
and reports
sudo parted -l
sudo efibootmgr -v
Here is what I have,
~ >>> inxi -Fxza --no-host System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=4357cac3-ea2c-48fa-b3b2-469fe0d1d9a1 rw quiet apparmor=1 security=apparmor udev.log_priority=3 Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux Machine: Type: Desktop Mobo: Micro-Star model: MAG B550M MORTAR (MS-7C94) v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.00 date: 05/12/2020 CPU: Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021 L2 cache: 4096 KiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 134476 Speed: 4200 MHz min/max: N/A Core speeds (MHz): 1: 4200 2: 4193 3: 4222 4: 4188 5: 4190 6: 4219 7: 4210 8: 4195 9: 4198 10: 4185 11: 4200 12: 4200 13: 4171 14: 4200 15: 4194 16: 4198 Vulnerabilities: Type: itlb_multihit status: Not affected Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: ASUSTeK driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 2b:00.0 chip ID: 10de:21c4 Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: modesetting,nouveau alternate: fbdev,nv,vesa resolution: <xdpyinfo missing> OpenGL: renderer: GeForce GTX 1660 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes Audio: Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 2b:00.1 chip ID: 10de:1aeb Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 2d:00.4 chip ID: 1022:1487 Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 5-2.3:4 chip ID: 046d:0825 serial: <filter> Sound Server: ALSA v: k5.7.15-1-MANJARO Network: Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8125 v: 9.003.05-NAPI modules: r8169 port: f000 bus ID: 2a:00.0 chip ID: 10ec:8125 IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter> Device-2: Realtek 802.11n type: USB driver: usb-network bus ID: 1-6:2 chip ID: 0bda:f179 serial: <filter> Drives: Local Storage: total: 1.36 TiB used: 63.01 GiB (4.5%) SMART Message: Required tool smartctl not installed. Check --recommends ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P1SSD8 size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: P3CR020 scheme: GPT ID-2: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0003 scheme: MBR Partition: ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%) used: 11.87 GiB (2.6%) fs: ext4 dev: /dev/nvme0n1p2 Swap: Alert: No Swap data was found. Sensors: System Temperatures: cpu: 51.1 C mobo: N/A gpu: nvidia temp: 45 C Fan Speeds (RPM): N/A gpu: nvidia fan: 27% Info: Processes: 402 Uptime: 7h 38m Memory: 31.37 GiB used: 14.51 GiB (46.2%) Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1199 pacman: 1191 lib: 344 flatpak: 0 snap: 8 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
~ >>> sudo parted -l
[sudo] password for vikrantshukla:
Model: ATA ST1000LM024 HN-M (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:Number Start End Size Type File system Flags
1 32.8kB 1000GB 1000GB primary ext4Model: CT500P1SSD8 (nvme)
Disk /dev/nvme0n1: 500GB
Partition Table: gpt
Disk Flags:Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 500GB 500GB ext4
sudo efibootmgr -v
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000,0009,0002
Boot0000* Manjaro HD(1,GPT,d59926b0-20db-f84a-a3f8-eca1261b2d20,0x1000,0x96000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0002 Hard Drive BBS(HD,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0200)…GO…NO…S.T.1.0.0.0.L.M.0.2.4. .H.N.-.M.1.0.1.M.B.B….,.@.r.d.=.X…A…>…Gd-.;.A…MQ…L.2.S.U.R.9.J.D.B.0.6.1.9.7.3. . . . . . …BO…NO…C.T.5.0.0.P.1.S.S.D.8….,.@.r.d.=.X…A…u.([.S…Gd-.;.A…MQ…L.2.0.1.6.2.8.5.B.C.7.5.3…BO
Boot0009* UEFI OS HD(1,GPT,d59926b0-20db-f84a-a3f8-eca1261b2d20,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)…BO
~ >>> test -d /sys/firmware/efi && echo efi || echo bios [1]
efi
update your bios
https://www.msi.com/Motherboard/support/MAG-B550M-MORTAR#down-bios
Thanks @stephane will try updating my BIOS.
Hi @stephane BIOS is updated to version 1.20, still getting the IRQ handler errors on boot up
