My boot process stops somewhere in the splash screen, no log-in screen is provided. Using a virtual konsole, I found these journals and tthe Xorg.log:
$ journalctl --boot=-1 --priority=3 --catalog --no-pager
Jul 31 18:34:05 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: Secure display: Generic Failure.
Jul 31 18:34:05 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Jul 31 18:34:06 XYZ-T14s kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: IRQ index 1 not found
Jul 31 18:34:06 XYZ-T14s kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: Error requesting irq at index 1
Jul 31 18:34:09 XYZ-T14s systemd-coredump[1381]: Process 1366 (Xorg) of user 0 dumped core.
Stack trace of thread 1366:
#0 0x00007f67abdef74c n/a (libc.so.6 + 0x9774c)
#1 0x00007f67abd95dc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007f67abd7d57a abort (libc.so.6 + 0x2557a)
#3 0x00005565e4c390be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x00005565e4c46410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x00005565e4c3b5b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007f67abd95ef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007f67ac41545a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007f67ac417931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007f67ac413b9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007f67ac409416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007f67ac41303c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007f67ac409416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007f67ac4134de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007f67abde9b34 n/a (libc.so.6 + 0x91b34)
#15 0x00007f67ac409416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007f67ac409569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007f67abde9623 n/a (libc.so.6 + 0x91623)
#18 0x00007f67abde9beb dlopen (libc.so.6 + 0x91beb)
#19 0x00007f67ac3c5d33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007f67ac3c5176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007f67ac3c5377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007f67ab5bc368 n/a (amdgpu_drv.so + 0xc368)
#23 0x00005565e4c613f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x00005565e4b0d6e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007f67abd7f6b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007f67abd7f769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x00005565e4b0ed15 _start (/usr/lib/Xorg + 0x34d15)
░░ Subject: Speicherabbild für Prozess 1366 (Xorg) generiert
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Prozess 1366 (Xorg) ist abgebrochen worden und
░░ ein Speicherabbild wurde generiert.
░░ Üblicherweise ist dies ein Hinweis auf einen Programmfehler und sollte
░░ als Fehler dem jeweiligen Hersteller gemeldet werden.
Jul 31 18:34:09 XYZ-T14s sddm[1360]: Failed to read display number from pipe
Jul 31 18:34:11 XYZ-T14s systemd-coredump[1393]: Process 1391 (Xorg) of user 0 dumped core.
Stack trace of thread 1391:
#0 0x00007fcc207aa74c n/a (libc.so.6 + 0x9774c)
#1 0x00007fcc20750dc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007fcc2073857a abort (libc.so.6 + 0x2557a)
#3 0x000055c7655db0be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x000055c7655e8410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x000055c7655dd5b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007fcc20750ef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007fcc20dd045a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007fcc20dd2931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007fcc20dceb9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007fcc20dc4416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007fcc20dce03c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007fcc20dc4416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007fcc20dce4de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007fcc207a4b34 n/a (libc.so.6 + 0x91b34)
#15 0x00007fcc20dc4416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007fcc20dc4569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007fcc207a4623 n/a (libc.so.6 + 0x91623)
#18 0x00007fcc207a4beb dlopen (libc.so.6 + 0x91beb)
#19 0x00007fcc20d80d33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007fcc20d80176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007fcc20d80377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007fcc1ff77368 n/a (amdgpu_drv.so + 0xc368)
#23 0x000055c7656033f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x000055c7654af6e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007fcc2073a6b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007fcc2073a769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x000055c7654b0d15 _start (/usr/lib/Xorg + 0x34d15)
░░ Subject: Speicherabbild für Prozess 1391 (Xorg) generiert
░░ Prozess 1391 (Xorg) ist abgebrochen worden und
Jul 31 18:34:11 XYZ-T14s sddm[1360]: Failed to read display number from pipe
Jul 31 18:34:13 XYZ-T14s systemd-coredump[1592]: Process 1589 (Xorg) of user 0 dumped core.
Stack trace of thread 1589:
#0 0x00007f13f263e74c n/a (libc.so.6 + 0x9774c)
#1 0x00007f13f25e4dc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007f13f25cc57a abort (libc.so.6 + 0x2557a)
#3 0x0000559a5e2940be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x0000559a5e2a1410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x0000559a5e2965b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007f13f25e4ef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007f13f2c6445a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007f13f2c66931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007f13f2c62b9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007f13f2c58416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007f13f2c6203c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007f13f2c58416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007f13f2c624de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007f13f2638b34 n/a (libc.so.6 + 0x91b34)
#15 0x00007f13f2c58416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007f13f2c58569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007f13f2638623 n/a (libc.so.6 + 0x91623)
#18 0x00007f13f2638beb dlopen (libc.so.6 + 0x91beb)
#19 0x00007f13f2c14d33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007f13f2c14176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007f13f2c14377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007f13f1e0b368 n/a (amdgpu_drv.so + 0xc368)
#23 0x0000559a5e2bc3f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x0000559a5e1686e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007f13f25ce6b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007f13f25ce769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x0000559a5e169d15 _start (/usr/lib/Xorg + 0x34d15)
░░ Subject: Speicherabbild für Prozess 1589 (Xorg) generiert
░░ Prozess 1589 (Xorg) ist abgebrochen worden und
Jul 31 18:34:13 XYZ-T14s sddm[1360]: Failed to read display number from pipe
Jul 31 18:34:13 XYZ-T14s sddm[1360]: Could not start Display server on vt 2
$ coredumpctl info
PID: 1589 (Xorg)
UID: 0 (root)
GID: 0 (root)
Signal: 6 (ABRT)
Timestamp: Thu 2025-07-31 18:34:13 CEST (6min ago)
Command Line: /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_Ulouzl -noreset -displayfd 16
Executable: /usr/lib/Xorg
Control Group: /system.slice/sddm.service
Unit: sddm.service
Slice: system.slice
Boot ID: fba55dd769114c79a3a416663a229048
Machine ID: 833ba61336c3473ba1c835e1398995b6
Hostname: XYZ-T14s
Storage: /var/lib/systemd/coredump/core.Xorg.0.fba55dd769114c79a3a416663a229048.1589.1753979653000000.zst (inaccessible)
Message: Process 1589 (Xorg) of user 0 dumped core.
$ cat /var/log/Xorg.0.log
[ 13.951] (--) Log file renamed from "/var/log/Xorg.pid-1589.log" to "/var/log/Xorg.0.log"
[ 13.951]
X.Org X Server 1.21.1.18
[ 13.951] Current Operating System: Linux XYZ-T14s 6.15.7-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu, 17 Jul 2025 20:47:04 +0000 x86_64
[ 13.951] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64 root=UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 rw apparmor=1 security=apparmor resume=UUID=338139c5-0361-42c0-9573-dbd00f711a01 udev.log_priority=3
[ 13.951]
[ 13.951] Current version of pixman: 0.46.2
[ 13.951] Before reporting problems, check http://wiki.x.org
[ 13.951] Markers: (--) probed, (**) from config file, (==) default setting,
[ 13.952] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 31 18:34:13 2025
[ 13.952] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 13.952] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 13.952] (==) No Layout section. Using the first Screen section.
[ 13.952] (==) No screen section available. Using defaults.
[ 13.952] (**) |-->Screen "Default Screen Section" (0)
[ 13.952] (**) | |-->Monitor "<default monitor>"
[ 13.952] (==) No monitor specified for screen "Default Screen Section".
[ 13.952] (**) Allowing byte-swapped clients
[ 13.952] (==) Automatically adding devices
[ 13.952] (==) Automatically enabling devices
[ 13.952] (==) Automatically adding GPU devices
[ 13.952] (==) Automatically binding GPU devices
[ 13.952] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 13.952] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 13.952] Entry deleted from font path.
[ 13.952] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 13.952] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 13.952] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 13.952] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 13.952] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 13.952] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 13.952] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 13.952] (==) FontPath set to:
[ 13.952] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 13.952] (II) The server relies on udev to provide the list of input devices.
[ 13.952] (II) Module ABI versions:
[ 13.952] X.Org ANSI C Emulation: 0.4
[ 13.952] X.Org Video Driver: 25.2
[ 13.952] X.Org XInput driver : 24.4
[ 13.952] X.Org Server Extension : 10.0
[ 13.953] (++) using VT number 2
[ 13.953] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 13.954] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 13.954] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:06:00.0/drm/card1
[ 13.971] (--) PCI:*(6@0:0:0) 1002:1636:17aa:5082 rev 209, Mem @ 0x860000000/268435456, 0x870000000/2097152, 0xfd300000/524288, I/O @ 0x00001000/256
[ 13.971] (II) LoadModule: "glx"
[ 13.972] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 13.974] (II) Module glx: vendor="X.Org Foundation"
[ 13.974] compiled for 1.21.1.18, module version = 1.0.0
[ 13.974] ABI class: X.Org Server Extension, version 10.0
[ 13.974] (II) Applying OutputClass "AMDgpu" to /dev/dri/card1
[ 13.974] loading driver: amdgpu
[ 13.974] (==) Matched amdgpu as autoconfigured driver 0
[ 13.974] (==) Matched ati as autoconfigured driver 1
[ 13.974] (==) Matched modesetting as autoconfigured driver 2
[ 13.974] (==) Matched fbdev as autoconfigured driver 3
[ 13.974] (==) Matched vesa as autoconfigured driver 4
[ 13.974] (==) Assigned the driver to the xf86ConfigLayout
[ 13.974] (II) LoadModule: "amdgpu"
[ 13.974] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 13.975] (II) Module amdgpu: vendor="X.Org Foundation"
[ 13.975] compiled for 1.21.1.11, module version = 23.0.0
[ 13.975] Module class: X.Org Video Driver
[ 13.975] ABI class: X.Org Video Driver, version 25.2
[ 13.975] (II) LoadModule: "ati"
[ 13.975] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 13.975] (II) Module ati: vendor="X.Org Foundation"
[ 13.975] compiled for 1.21.1.11, module version = 22.0.0
[ 13.992] (II) LoadModule: "modesetting"
[ 13.992] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 13.992] (II) Module modesetting: vendor="X.Org Foundation"
[ 13.992] compiled for 1.21.1.18, module version = 1.21.1
[ 13.992] Module class: X.Org Video Driver
[ 13.992] ABI class: X.Org Video Driver, version 25.2
[ 13.992] (II) LoadModule: "fbdev"
[ 13.993] (WW) Warning, couldn't open module fbdev
[ 13.993] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 13.993] (II) LoadModule: "vesa"
[ 13.993] (WW) Warning, couldn't open module vesa
[ 13.993] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 13.993] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 13.993] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 14.015] (WW) Falling back to old probe method for modesetting
[ 14.015] (EE) open /dev/dri/card0: No such file or directory
[ 14.015] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 14.015] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 14.015] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 14.015] (==) AMDGPU(0): Default visual is TrueColor
[ 14.015] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[ 14.015] (==) AMDGPU(0): RGB weight 888
[ 14.015] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 14.015] (--) AMDGPU(0): Chipset: "AMD Radeon Graphics" (ChipID = 0x1636)
[ 14.015] (II) Loading sub module "fb"
[ 14.015] (II) LoadModule: "fb"
[ 14.015] (II) Module "fb" already built-in
[ 14.015] (II) Loading sub module "dri2"
[ 14.015] (II) LoadModule: "dri2"
[ 14.015] (II) Module "dri2" already built-in
[ 14.023] (EE)
[ 14.023] (EE) Backtrace:
[ 14.023] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.023] (EE) 0: /usr/lib/Xorg (?+0x0) [0x559a5e296554]
[ 14.024] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.024] (EE) 1: /usr/lib/libc.so.6 (?+0x0) [0x7f13f25e4ef0]
[ 14.025] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.025] (EE) 2: /lib64/ld-linux-x86-64.so.2 (?+0x0) [0x7f13f2c6445a]
[ 14.026] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.026] (EE) 3: /lib64/ld-linux-x86-64.so.2 (?+0x0) [0x7f13f2c66931]
[ 14.028] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.028] (EE) 4: /lib64/ld-linux-x86-64.so.2 (?+0x0) [0x7f13f2c62b9b]
[ 14.029] (EE) 5: /lib64/ld-linux-x86-64.so.2 (_dl_catch_exception+0xa6) [0x7f13f2c58416]
[ 14.029] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.029] (EE) 6: /lib64/ld-linux-x86-64.so.2 (?+0x0) [0x7f13f2c6203c]
[ 14.030] (EE) 7: /lib64/ld-linux-x86-64.so.2 (_dl_catch_exception+0xa6) [0x7f13f2c58416]
[ 14.031] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.031] (EE) 8: /lib64/ld-linux-x86-64.so.2 (?+0x0) [0x7f13f2c624de]
[ 14.031] (EE) 9: /usr/lib/libc.so.6 (?+0x0) [0x7f13f2638b34]
[ 14.032] (EE) 10: /lib64/ld-linux-x86-64.so.2 (_dl_catch_exception+0xa6) [0x7f13f2c58416]
[ 14.033] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.033] (EE) 11: /lib64/ld-linux-x86-64.so.2 (?+0x0) [0x7f13f2c58569]
[ 14.034] (EE) 12: /usr/lib/libc.so.6 (?+0x0) [0x7f13f2638623]
[ 14.034] (EE) 13: /usr/lib/libc.so.6 (dlopen+0x6b) [0x7f13f2638beb]
[ 14.035] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.035] (EE) 14: /usr/lib/libgbm.so.1 (?+0x0) [0x7f13f2c14d33]
[ 14.035] (EE) 15: /usr/lib/libgbm.so.1 (?+0x0) [0x7f13f2c14176]
[ 14.036] (EE) 16: /usr/lib/libgbm.so.1 (gbm_create_device+0x57) [0x7f13f2c14377]
[ 14.037] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.037] (EE) 17: /usr/lib/xorg/modules/drivers/amdgpu_drv.so (?+0x0) [0x7f13f1e0b368]
[ 14.037] (EE) 18: /usr/lib/Xorg (InitOutput+0x16b1) [0x559a5e2bc3f1]
[ 14.037] (EE) 19: /usr/lib/Xorg (?+0x0) [0x559a5e1686e5]
[ 14.038] (EE) unw_get_proc_name failed: no unwind info found [-10]
[ 14.038] (EE) 20: /usr/lib/libc.so.6 (?+0x0) [0x7f13f25ce6b5]
[ 14.038] (EE) 21: /usr/lib/libc.so.6 (__libc_start_main+0x89) [0x7f13f25ce769]
[ 14.038] (EE) 22: /usr/lib/Xorg (_start+0x25) [0x559a5e169d15]
[ 14.038] (EE)
[ 14.038] (EE) Segmentation fault at address 0x8
[ 14.038] (EE)
Fatal server error:
[ 14.039] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 14.039] (EE)
[ 14.039] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 14.039] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 14.039] (EE)
[ 14.065] (EE) Server terminated with error (1). Closing log file.
How to solve this?
