Sorry @brahma, did not respect your code-marking.
# ldconfig
returns nothing. What to do next?
# ldconfig
just try to reinstall glibc:
pacman -S glibc lib32-glibc
if there are errors post them here
also post output from:
mhwd-kernel -li
and from logs:
journalctl -b-1 -p5 --no-pager
all done in chroot
; here the results:
manjaro-chroot -a ī² ā
==> Mounting (ManjaroLinux) [/dev/nvme0n1p3]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
--> mount: [/mnt/mnt/Daten]
--> mount: [/mnt/home/myname/VirtualBoxVMs]
[manjaro /]# pacman -S glibc lib32-glibc
warning: glibc-2.41+r48+g5cb575ca9a3d-1 is up to date -- reinstalling
warning: lib32-glibc-2.41+r48+g5cb575ca9a3d-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) glibc-2.41+r48+g5cb575ca9a3d-1 lib32-glibc-2.41+r48+g5cb575ca9a3d-1
Total Installed Size: 66.53 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
(2/2) checking keys in keyring [####################################] 100%
(2/2) checking package integrity [####################################] 100%
(2/2) loading package files [####################################] 100%
(2/2) checking for file conflicts [####################################] 100%
(2/2) checking available disk space [####################################] 100%
(1/2) reinstalling glibc [####################################] 100%
Generating locales...
en_US.UTF-8... done
de_DE.UTF-8... done
Generation complete.
(2/2) reinstalling lib32-glibc [####################################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Restarting cronie for libc upgrade...
Running in chroot, ignoring command 'try-restart'
(3/5) Looking for Pacnew/Pacsave created.
(4/5) Checking which packages need to be rebuilt
foreign conky-lua-nv
foreign libreoffice-fresh-rpm
foreign libreoffice-still-micha
foreign transcode
(5/5) Updating the info directory file...
[manjaro /]#
# mhwd-kernel -li
Currently running: 6.12.37-1-MANJARO (linux612)
* linux515
* linux61
* linux612
* linux615
* linux66
manjaro Daten]# journalctl -b-1 -p5 --no-pager
Aug 03 12:15:32 XYZ-T14s kernel: Linux version 6.15.7-1-MANJARO (linux615@manjaro) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Thu, 17 Jul 2025 20:47:04 +0000
Aug 03 12:15:32 XYZ-T14s kernel: random: crng init done
Aug 03 12:15:32 XYZ-T14s kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64 root=UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 rw apparmor=1 security=apparmor resume=UUID=338139c5-0361-42c0-9573-dbd00f711a01 udev.log_priority=3
Aug 03 12:15:32 XYZ-T14s kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64", will be passed to user space.
Aug 03 12:15:32 XYZ-T14s kernel: x86/bugs: return thunk changed
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=2000 audit(1754216126.178:1): state=initialized audit_enabled=0 res=1
Aug 03 12:15:32 XYZ-T14s kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Aug 03 12:15:32 XYZ-T14s kernel: SCSI subsystem initialized
Aug 03 12:15:32 XYZ-T14s kernel: VFS: Disk quotas dquot_6.6.0
Aug 03 12:15:32 XYZ-T14s kernel: Initialise system trusted keyrings
Aug 03 12:15:32 XYZ-T14s kernel: Key type blacklist registered
Aug 03 12:15:32 XYZ-T14s kernel: integrity: Platform Keyring initialized
Aug 03 12:15:32 XYZ-T14s kernel: integrity: Machine keyring initialized
Aug 03 12:15:32 XYZ-T14s kernel: Key type asymmetric registered
Aug 03 12:15:32 XYZ-T14s kernel: Asymmetric key parser 'x509' registered
Aug 03 12:15:32 XYZ-T14s kernel: ACPI: FW issue: working around C-state latencies out of order
Aug 03 12:15:32 XYZ-T14s kernel: Could not retrieve perf counters (-19)
Aug 03 12:15:32 XYZ-T14s kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Aug 03 12:15:32 XYZ-T14s kernel: Loading compiled-in X.509 certificates
Aug 03 12:15:32 XYZ-T14s kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 9aa3fd976e241094f22bc7e8d60560387c02fff3'
Aug 03 12:15:32 XYZ-T14s kernel: Key type .fscrypt registered
Aug 03 12:15:32 XYZ-T14s kernel: Key type fscrypt-provisioning registered
Aug 03 12:15:32 XYZ-T14s kernel: Key type big_key registered
Aug 03 12:15:32 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Lenovo Ltd.: ThinkPad Product CA 2012: 838b1f54c1550463f45f98700640f11069265949'
Aug 03 12:15:32 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Lenovo UEFI CA 2014: 4b91a68732eaefdd2c8ffffc6b027ec3449e9c8f'
Aug 03 12:15:32 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Aug 03 12:15:32 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Aug 03 12:15:32 XYZ-T14s kernel: Key type psk registered
Aug 03 12:15:32 XYZ-T14s kernel: nvme nvme0: missing or invalid SUBNQN field.
Aug 03 12:15:32 XYZ-T14s kernel: thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
Aug 03 12:15:32 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
Aug 03 12:15:32 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
Aug 03 12:15:32 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: Secure display: Generic Failure.
Aug 03 12:15:32 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Aug 03 12:15:32 XYZ-T14s kernel: clocksource: timekeeping watchdog on CPU9: Marking clocksource 'tsc' as unstable because the skew is too large:
Aug 03 12:15:32 XYZ-T14s kernel: clocksource: 'hpet' wd_nsec: 306905207 wd_now: 4208c11 wd_last: 3dd7ebd mask: ffffffff
Aug 03 12:15:32 XYZ-T14s kernel: clocksource: 'tsc' cs_nsec: 623212699 cs_now: 993c4e134 cs_last: 954bd2bb9 mask: ffffffffffffffff
Aug 03 12:15:32 XYZ-T14s kernel: clocksource: Clocksource 'tsc' skewed 316307492 ns (316 ms) over watchdog 'hpet' interval of 306905207 ns (306 ms)
Aug 03 12:15:32 XYZ-T14s kernel: clocksource: 'tsc' is current clocksource.
Aug 03 12:15:32 XYZ-T14s kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.744:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=454 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.744:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=455 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.744:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=447 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.744:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=446 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.744:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=448 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.745:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=453 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.745:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=459 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.745:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chromium" pid=461 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.745:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=451 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: audit: type=1400 audit(1754216132.745:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=456 comm="apparmor_parser"
Aug 03 12:15:32 XYZ-T14s kernel: vboxdrv: loading out-of-tree module taints kernel.
Aug 03 12:15:32 XYZ-T14s kernel: vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
Aug 03 12:15:32 XYZ-T14s kernel: VBoxNetAdp: Successfully started.
Aug 03 12:15:32 XYZ-T14s kernel: VBoxNetFlt: Successfully started.
Aug 03 12:15:33 XYZ-T14s kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: IRQ index 1 not found
Aug 03 12:15:33 XYZ-T14s kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: Error requesting irq at index 1
Aug 03 12:15:33 XYZ-T14s kernel: ccp 0000:06:00.2: ccp: unable to access the device: you might be running a broken BIOS.
Aug 03 12:15:33 XYZ-T14s kernel: ccp 0000:06:00.2: tee enabled
Aug 03 12:15:33 XYZ-T14s kernel: ccp 0000:06:00.2: psp enabled
Aug 03 12:15:33 XYZ-T14s kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
Aug 03 12:15:33 XYZ-T14s kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Aug 03 12:15:33 XYZ-T14s kernel: ipmi_si: Unable to find any System Interface(s)
Aug 03 12:15:33 XYZ-T14s kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Aug 03 12:15:33 XYZ-T14s kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Aug 03 12:15:33 XYZ-T14s systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Loading rules from directory /etc/polkit-1/rules.d
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Loading rules from directory /run/polkit-1/rules.d
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Error opening rules directory: Error opening directory ā/run/polkit-1/rules.dā: No such file or directory (g-file-error-quark, 4)
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Loading rules from directory /usr/local/share/polkit-1/rules.d
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Error opening rules directory: Error opening directory ā/usr/local/share/polkit-1/rules.dā: No such file or directory (g-file-error-quark, 4)
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Loading rules from directory /usr/share/polkit-1/rules.d
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Finished loading, compiling and executing 6 rules
Aug 03 12:15:34 XYZ-T14s polkitd[1148]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Aug 03 12:15:34 XYZ-T14s ModemManager[1221]: <msg> ModemManager (version 1.24.0-2) starting in system bus...
Aug 03 12:15:34 XYZ-T14s (uetoothd)[1320]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Aug 03 12:15:35 XYZ-T14s wpa_supplicant[1328]: Successfully initialized wpa_supplicant
Aug 03 12:15:35 XYZ-T14s systemd-coredump[1359]: [LNK] Process 1350 (Xorg) of user 0 dumped core.
Stack trace of thread 1350:
#0 0x00007f9c001c774c n/a (libc.so.6 + 0x9774c)
#1 0x00007f9c0016ddc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007f9c0015557a abort (libc.so.6 + 0x2557a)
#3 0x00005626ede300be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x00005626ede3d410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x00005626ede325b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007f9c0016def0 n/a (libc.so.6 + 0x3def0)
#7 0x00007f9c007ed45a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007f9c007ef931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007f9c007ebb9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007f9c007e1416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007f9c007eb03c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007f9c007e1416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007f9c007eb4de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007f9c001c1b34 n/a (libc.so.6 + 0x91b34)
#15 0x00007f9c007e1416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007f9c007e1569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007f9c001c1623 n/a (libc.so.6 + 0x91623)
#18 0x00007f9c001c1beb dlopen (libc.so.6 + 0x91beb)
#19 0x00007f9c0079dd33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007f9c0079d176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007f9c0079d377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007f9bff994368 n/a (amdgpu_drv.so + 0xc368)
#23 0x00005626ede583f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x00005626edd046e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007f9c001576b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007f9c00157769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x00005626edd05d15 _start (/usr/lib/Xorg + 0x34d15)
Aug 03 12:15:35 XYZ-T14s sddm[1337]: Failed to read display number from pipe
Aug 03 12:15:35 XYZ-T14s sddm[1337]: Attempt 1 starting the Display server on vt 2 failed
Aug 03 12:15:36 XYZ-T14s dbus-broker-launch[1102]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Aug 03 12:15:36 XYZ-T14s kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Aug 03 12:15:38 XYZ-T14s systemd-coredump[1382]: [LNK] Process 1380 (Xorg) of user 0 dumped core.
Stack trace of thread 1380:
#0 0x00007fe5162b974c n/a (libc.so.6 + 0x9774c)
#1 0x00007fe51625fdc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007fe51624757a abort (libc.so.6 + 0x2557a)
#3 0x00005561406450be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x0000556140652410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x00005561406475b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007fe51625fef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007fe5168df45a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007fe5168e1931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007fe5168ddb9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007fe5168d3416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007fe5168dd03c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007fe5168d3416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007fe5168dd4de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007fe5162b3b34 n/a (libc.so.6 + 0x91b34)
#15 0x00007fe5168d3416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007fe5168d3569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007fe5162b3623 n/a (libc.so.6 + 0x91623)
#18 0x00007fe5162b3beb dlopen (libc.so.6 + 0x91beb)
#19 0x00007fe51688fd33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007fe51688f176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007fe51688f377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007fe515a86368 n/a (amdgpu_drv.so + 0xc368)
#23 0x000055614066d3f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x00005561405196e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007fe5162496b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007fe516249769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x000055614051ad15 _start (/usr/lib/Xorg + 0x34d15)
Aug 03 12:15:38 XYZ-T14s sddm[1337]: Failed to read display number from pipe
Aug 03 12:15:38 XYZ-T14s sddm[1337]: Attempt 2 starting the Display server on vt 2 failed
Aug 03 12:15:38 XYZ-T14s ModemManager[1221]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:02:00.0': not supported by any plugin
Aug 03 12:15:38 XYZ-T14s ModemManager[1221]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0': not supported by any plugin
Aug 03 12:15:38 XYZ-T14s wpa_supplicant[1328]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
Aug 03 12:15:38 XYZ-T14s NetworkManager[1135]: <warn> [1754216138.9695] device (wlp3s0): no secrets: No agents were available for this request.
Aug 03 12:15:38 XYZ-T14s NetworkManager[1135]: <warn> [1754216138.9701] device (wlp3s0): Activation: failed for connection 'intago wLAN'
Aug 03 12:15:38 XYZ-T14s wpa_supplicant[1328]: wlp3s0: WPS-PBC-ACTIVE
Aug 03 12:15:38 XYZ-T14s wpa_supplicant[1328]: wlp3s0: WPS-CANCEL
Aug 03 12:15:40 XYZ-T14s systemd-coredump[1582]: [LNK] Process 1579 (Xorg) of user 0 dumped core.
Stack trace of thread 1579:
#0 0x00007f6aeac2574c n/a (libc.so.6 + 0x9774c)
#1 0x00007f6aeabcbdc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007f6aeabb357a abort (libc.so.6 + 0x2557a)
#3 0x00005585e91930be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x00005585e91a0410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x00005585e91955b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007f6aeabcbef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007f6aeb24b45a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007f6aeb24d931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007f6aeb249b9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007f6aeb23f416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007f6aeb24903c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007f6aeb23f416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007f6aeb2494de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007f6aeac1fb34 n/a (libc.so.6 + 0x91b34)
#15 0x00007f6aeb23f416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007f6aeb23f569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007f6aeac1f623 n/a (libc.so.6 + 0x91623)
#18 0x00007f6aeac1fbeb dlopen (libc.so.6 + 0x91beb)
#19 0x00007f6aeb1fbd33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007f6aeb1fb176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007f6aeb1fb377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007f6aea3f2368 n/a (amdgpu_drv.so + 0xc368)
#23 0x00005585e91bb3f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x00005585e90676e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007f6aeabb56b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007f6aeabb5769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x00005585e9068d15 _start (/usr/lib/Xorg + 0x34d15)
Aug 03 12:15:40 XYZ-T14s sddm[1337]: Failed to read display number from pipe
Aug 03 12:15:40 XYZ-T14s sddm[1337]: Attempt 3 starting the Display server on vt 2 failed
Aug 03 12:15:40 XYZ-T14s sddm[1337]: Could not start Display server on vt 2
Aug 03 12:15:47 XYZ-T14s fprintd[1595]: Device responded with error: 789 retry: 1
Aug 03 12:15:49 XYZ-T14s dbus-broker-launch[1102]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Aug 03 12:15:49 XYZ-T14s (systemd)[1607]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[myname] ruser=[<unknown>] rhost=[<unknown>]
Aug 03 12:15:49 XYZ-T14s systemd-xdg-autostart-generator[1613]: Exec line is empty
Aug 03 12:15:49 XYZ-T14s systemd-xdg-autostart-generator[1613]: /home/myname/.config/autostart/org.kde.kclockd-autostart.desktop: not generating unit, error parsing Exec= line: Invalid argument
Aug 03 12:16:38 XYZ-T14s kernel: netfs: FS-Cache loaded
Aug 03 12:16:38 XYZ-T14s kernel: Key type dns_resolver registered
Aug 03 12:16:39 XYZ-T14s kernel: Key type cifs.spnego registered
Aug 03 12:16:39 XYZ-T14s kernel: Key type cifs.idmap registered
Aug 03 12:16:39 XYZ-T14s kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount.
Aug 03 12:16:39 XYZ-T14s kernel: CIFS: enabling forceuid mount option implicitly because uid= option is specified
Aug 03 12:16:39 XYZ-T14s kernel: CIFS: enabling forcegid mount option implicitly because gid= option is specified
Aug 03 12:20:53 XYZ-T14s systemd-logind[1151]: The system will reboot now!
Aug 03 12:20:53 XYZ-T14s systemd-logind[1151]: System is rebooting.
Aug 03 12:20:53 XYZ-T14s sddm[1337]: Signal received: SIGTERM
Aug 03 12:20:53 XYZ-T14s ModemManager[1221]: <msg> caught signal, shutting down...
Aug 03 12:20:53 XYZ-T14s dbus-broker-launch[1102]: Activation request for 'org.freedesktop.Avahi' failed.
Aug 03 12:20:53 XYZ-T14s ModemManager[1221]: <msg> ModemManager is shut down
Aug 03 12:20:53 XYZ-T14s wpa_supplicant[1328]: p2p-dev-wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 03 12:20:53 XYZ-T14s wpa_supplicant[1328]: nl80211: deinit ifname=p2p-dev-wlp3s0 disabled_11b_rates=0
Aug 03 12:20:53 XYZ-T14s dbus-broker-launch[1102]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 03 12:20:53 XYZ-T14s wpa_supplicant[1328]: p2p-dev-wlp3s0: CTRL-EVENT-TERMINATING
Aug 03 12:20:53 XYZ-T14s wpa_supplicant[1328]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 03 12:20:54 XYZ-T14s wpa_supplicant[1328]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 03 12:20:54 XYZ-T14s wpa_supplicant[1328]: nl80211: deinit ifname=wlp3s0 disabled_11b_rates=0
Aug 03 12:20:54 XYZ-T14s wpa_supplicant[1328]: wlp3s0: CTRL-EVENT-TERMINATING
Aug 03 12:20:54 XYZ-T14s dbus-broker-launch[1102]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 03 12:20:54 XYZ-T14s systemd[1]: Shutting down.
Aug 03 12:20:54 XYZ-T14s kernel: watchdog: watchdog0: watchdog did not stop!
[manjaro Daten]#
post also output from:
cat /etc/mkinitcpio.conf
yes: this may be aimed at finding out whether the microcode is being loaded
Just something that caught my eye, but I donāt know the significance of it:
ā¦
⦠something in /etc/fstab
and there are a few more errors a few lines below.
shouldnāt /tmp be empty, prior to tmpfs being mounted to it?
should /run/polkit-1/rules.d
even exist?
similar to: /usr/local/share/polkit-1/rules.d
- should it even be there?
Thank you! Results from virtual konsole:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap resume consolefont block filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# Use 'blkid' to print the universally unique identifier for a device; this may be used with UUID= as a more robust way to name devices that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=F8E8-132F /boot/efi vfat umask=0077 0 2
UUID=338139c5-0361-42c0-9573-dbd00f711a01 swap swap defaults,noatime 0 2
UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 / ext4 defaults,noatime 0 1
UUID=36be0edf-49c4-4ee0-96a3-4da6bc64a86c /home ext4 defaults 0 2
UUID=249b9b5a-332c-4176-8a2e-9cef91138ce6 /mnt/Daten ext4 defaults 0 2
UUID=c29b5da5-b959-4989-87ed-6db493b9c3a0 /home/myname/VirtualBoxVMs ext4 defaults 0 2
#//10.11.30.230/X230-Daten Einbenutzer-System mit uid=1000,gid=1000, Quelle: https://wiki.ubuntuusers.de/mount/#Einbenutzer-System; ebenso XYZX240
//XYZ-X230/X230-Daten /media/XYZ-X230 cifs noauto,_netdev,users,uid=1000,gid=1000,username=myname 0 0
//XYZ-X240/X240-Daten /media/XYZ-X240 cifs noauto,_netdev,users,uid=1000,gid=1000,username=myname 0 0
#//USB-Laufwerke myBook8_A und myBook8_A und myBook16 sowie HDD2go nofail
#UUID=7f13008d-50e6-4eec-9503-efd757892494 /media/myBook8_A ext4 auto,nofail,rw,async,users 0 0
#UUID=1e05302f-ee5e-4a82-9c45-fa05d2146162 /media/myBook8_B ext4 auto,nofail,rw,async,users 0 0
#UUID=ac186447-9bfd-4785-aa59-5c4b6b235735 /media/myBook16 ext4 auto,nofail,rw,async,users 0 0
#UUID=4bb7051f-0059-4b3d-918e-8d5a97c56a0e /media/HDD2go ext4 auto,users,nofail,rw,async 0 0
$ cd /tmp
$ ls -l
insgesamt 0
srwxr-xr-x 1 root root 0 3. Aug 15:20 sddm-auth-eb8d3bfb-9c8f-4ff3-a26e-4623c20e20b7
drwx------ 2 root root 40 3. Aug 15:20 snap-private-tmp
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-bluetooth.service-fAC2PA
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-colord.service-NnL4yt
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-dbus-broker.service-pIMIVx
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-ModemManager.service-9qTMGV
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-polkit.service-QBMEpT
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-postgresql.service-nR0VAU
drwx------ 3 root root 60 3. Aug 15:20 systemd-private-bdaf464a8535491991603f7739fbb29b-systemd-logind.service-TY9c2a
The rest of the posting from @Nachlese I did not understand ā¦
It was just speculation, based upon what I see in my own system.
These directories (mentioned as errors in your log) do NOT exist in my system as well,
but nothing wantās to access them either
(so: I see no such errors).
@brahma might know
As for /tmp
- it will not be empty in a running system - that is normal.
But the message in your log said
that it wasnāt empty to begin with
That can only be checked from the outside, when the system is not running, by booting from USB, for example - and mounting /
and looking at /tmp
I didnāt want to interfere - Iāll go back to just watching the thread.
ps:
Iād minimize the possible sources of error
by commenting everything not strictly necessary from /etc/fstab
(that would be just the first three or four lines.
EFI, swap, / and /home - swap should not need to be mentioned, it should work without that fstab entry)
And I wouldnāt use /media
as a mount point.
Create a dedicated one instead.
/media
is different in Manjaro than it is in Ubuntu - but it is probably still a temporary directory which disappears and is recreated with every reboot - but I did not check that.
pps:
I just checked that:
/media
doesnāt exist by default in Manjaro - you have to create it yourself before you can use it
are you in virtual box? so manjaro is not actually installed?
No, for sure not.
ok⦠so you have several kernels installed? did you tried booting with different one? if not try boot with the 5.15 and then with the 6.1ā¦
also add amdgpu to early loading:
from chroot:
nano /etc/mkinitcpio.conf
and edit the MODULES section to look like this:
MODULES=(amdgpu)
save it with ctrl+x
press Y, then enter and update it:
mkinitcpio -P
also check in your installed home directory, open dolphin, go to your installed home directory, check unhide files (ctrl+h) and look for an .Xauthority files(s) and delete it/them if there are more than oneā¦
reboot and test with the different kernelsā¦
Thank you, this is what I did:
$ sudo mhwd-kernel --list
boot pressing ESC
grub menu: switched to 5.15 --> same issue
boot pressing ESC
grub menu: switched to 6.1 --> same issue
$ manjaro-chroot -a
added: MODULES=(amdgpu)
$ mkinitcpio -P
reboot --> same issue
$ manjaro-chroot -a
dolphin
/home/myname
show hidden files
deleted one .Xauthority file
boot pressing ESC
ok, try adding this kernel parameter from chroot:
nano /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT
inside the quotes you add the parameter:
amdgpu.dc=0
dont remove anything from there, just add it to existing parameters, then save it with ctrl+x
update-grub
rebootā¦
if you still have issues, try what nachlese is suggesting by uncomenting the fstab entries:
after that run:
mkinitcpio -P
if you still have issues post again logs:
$ manjaro-chroot -a
in line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes added parameter:
amdgpu.dc=0
as first entry.
# update-grub
reboot -- shows this (ref.Screenshot)
Reduced /etc/fstab; this is the actal one:
reboot- ā same issue
In an already difficult and murky situation, you should try to be precise with your feedback of what you did and what responses you got to commands.
This:
cannot be true.
Two issues with that:
Of course you can reboot the system you used to get into chroot
and you can run Dolphin in that system,
but then the path /home/myname
is wrong.
You should remove all .Xauthority
files - in case there was more than one.
Incidentally:
I donāt even have an .Xauthority
in my virtual machine, even though Plasma is running under xorg there.
Does the directory /media
even exist?
Itās not present by default ā¦
You are right, sorry for that.
In the first session I had chroot running and could not start dolphin. Then I started Dolphin from the home screen and selected the drive /home/myname. There was one .Xauthority file which I deleted.
In an actual session I started MANJARO from USB-stick and DOLPHIN from the home screen and selected the drive /home/myname. Actually there is no .Xauthority file.
you can revert your fstab backā¦
and post the logs
and do you have corectrl installed?
pacman -Qs corectrl
if dont, do not install it
This is what I did:
$ manjaro-chroot -a
in line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes REMOVED parameter:
amdgpu.dc=0
# update grub
Reboot ā> same issue
Switched to kernel linux-612
From a virtual konsole:
$ pacman -Qs corectrl
journalctl -b-1 -p5 -- nopager
Aug 03 19:45:34 XYZ-T14s kernel: Linux version 6.12.39-1-MANJARO (linux612@manjaro) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Thu, 17 Jul 2025 20:46:35 +0000
Aug 03 19:45:34 XYZ-T14s kernel: random: crng init done
Aug 03 19:45:34 XYZ-T14s kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=3fb81935-3c2a-4b83-ae67-7b8f75e23839 rw apparmor=1 security=apparmor resume=UUID=338139c5-0361-42c0-9573-dbd00f711a01 udev.log_priority=3
Aug 03 19:45:34 XYZ-T14s kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64", will be passed to user space.
Aug 03 19:45:34 XYZ-T14s kernel: x86/bugs: return thunk changed
Aug 03 19:45:34 XYZ-T14s kernel: audit: type=2000 audit(1754243128.203:1): state=initialized audit_enabled=0 res=1
Aug 03 19:45:34 XYZ-T14s kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Aug 03 19:45:34 XYZ-T14s kernel: SCSI subsystem initialized
Aug 03 19:45:34 XYZ-T14s kernel: VFS: Disk quotas dquot_6.6.0
Aug 03 19:45:34 XYZ-T14s kernel: Initialise system trusted keyrings
Aug 03 19:45:34 XYZ-T14s kernel: Key type blacklist registered
Aug 03 19:45:34 XYZ-T14s kernel: integrity: Platform Keyring initialized
Aug 03 19:45:34 XYZ-T14s kernel: integrity: Machine keyring initialized
Aug 03 19:45:34 XYZ-T14s kernel: Key type asymmetric registered
Aug 03 19:45:34 XYZ-T14s kernel: Asymmetric key parser 'x509' registered
Aug 03 19:45:34 XYZ-T14s kernel: ACPI: FW issue: working around C-state latencies out of order
Aug 03 19:45:34 XYZ-T14s kernel: Could not retrieve perf counters (-19)
Aug 03 19:45:34 XYZ-T14s kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Aug 03 19:45:34 XYZ-T14s kernel: Loading compiled-in X.509 certificates
Aug 03 19:45:34 XYZ-T14s kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 69046061655f891c2ff77cb4e18b0ec87b911ea8'
Aug 03 19:45:34 XYZ-T14s kernel: Key type .fscrypt registered
Aug 03 19:45:34 XYZ-T14s kernel: Key type fscrypt-provisioning registered
Aug 03 19:45:34 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Lenovo Ltd.: ThinkPad Product CA 2012: 838b1f54c1550463f45f98700640f11069265949'
Aug 03 19:45:34 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Lenovo UEFI CA 2014: 4b91a68732eaefdd2c8ffffc6b027ec3449e9c8f'
Aug 03 19:45:34 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Aug 03 19:45:34 XYZ-T14s kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Aug 03 19:45:34 XYZ-T14s kernel: clocksource: timekeeping watchdog on CPU3: Marking clocksource 'tsc' as unstable because the skew is too large:
Aug 03 19:45:34 XYZ-T14s kernel: clocksource: 'hpet' wd_nsec: 510597436 wd_now: 1ba4457 wd_last: 14ab66d mask: ffffffff
Aug 03 19:45:34 XYZ-T14s kernel: clocksource: 'tsc' cs_nsec: 506666074 cs_now: 10d613dc7e cs_last: 10a26fd30a mask: ffffffffffffffff
Aug 03 19:45:34 XYZ-T14s kernel: clocksource: Clocksource 'tsc' skewed -3931362 ns (-3 ms) over watchdog 'hpet' interval of 510597436 ns (510 ms)
Aug 03 19:45:34 XYZ-T14s kernel: clocksource: 'tsc' is current clocksource.
Aug 03 19:45:34 XYZ-T14s kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
Aug 03 19:45:34 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
Aug 03 19:45:34 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
Aug 03 19:45:34 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: Secure display: Generic Failure.
Aug 03 19:45:34 XYZ-T14s kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Aug 03 19:45:35 XYZ-T14s kernel: nvme nvme0: missing or invalid SUBNQN field.
Aug 03 19:45:35 XYZ-T14s kernel: thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=444 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=439 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=434 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=443 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=433 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=432 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=441 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="vscode" pid=447 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=442 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: audit: type=1400 audit(1754243134.858:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=438 comm="apparmor_parser"
Aug 03 19:45:35 XYZ-T14s kernel: vboxdrv: loading out-of-tree module taints kernel.
Aug 03 19:45:35 XYZ-T14s kernel: vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
Aug 03 19:45:35 XYZ-T14s kernel: VBoxNetAdp: Successfully started.
Aug 03 19:45:35 XYZ-T14s kernel: VBoxNetFlt: Successfully started.
Aug 03 19:45:35 XYZ-T14s kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: IRQ index 1 not found
Aug 03 19:45:35 XYZ-T14s kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: Error requesting irq at index 1
Aug 03 19:45:35 XYZ-T14s kernel: ccp 0000:06:00.2: ccp: unable to access the device: you might be running a broken BIOS.
Aug 03 19:45:35 XYZ-T14s kernel: ccp 0000:06:00.2: tee enabled
Aug 03 19:45:35 XYZ-T14s kernel: ccp 0000:06:00.2: psp enabled
Aug 03 19:45:35 XYZ-T14s kernel: ipmi_si: Unable to find any System Interface(s)
Aug 03 19:45:35 XYZ-T14s kernel: r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
Aug 03 19:45:35 XYZ-T14s kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Aug 03 19:45:35 XYZ-T14s kernel: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Aug 03 19:45:35 XYZ-T14s kernel: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Aug 03 19:45:35 XYZ-T14s systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Loading rules from directory /etc/polkit-1/rules.d
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Loading rules from directory /run/polkit-1/rules.d
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Error opening rules directory: Error opening directory ā/run/polkit-1/rules.dā: No such file or directory (g-file-error-quark, 4)
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Loading rules from directory /usr/local/share/polkit-1/rules.d
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Error opening rules directory: Error opening directory ā/usr/local/share/polkit-1/rules.dā: No such file or directory (g-file-error-quark, 4)
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Loading rules from directory /usr/share/polkit-1/rules.d
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Finished loading, compiling and executing 6 rules
Aug 03 19:45:36 XYZ-T14s polkitd[1131]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Aug 03 19:45:36 XYZ-T14s ModemManager[1198]: <msg> ModemManager (version 1.24.0-2) starting in system bus...
Aug 03 19:45:36 XYZ-T14s (uetoothd)[1312]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Aug 03 19:45:37 XYZ-T14s kernel: Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
Aug 03 19:45:37 XYZ-T14s wpa_supplicant[1331]: Successfully initialized wpa_supplicant
Aug 03 19:45:37 XYZ-T14s systemd-coredump[1361]: Process 1352 (Xorg) of user 0 dumped core.
Stack trace of thread 1352:
#0 0x00007ff7b17f174c n/a (libc.so.6 + 0x9774c)
#1 0x00007ff7b1797dc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007ff7b177f57a abort (libc.so.6 + 0x2557a)
#3 0x000055b6f25e80be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x000055b6f25f5410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x000055b6f25ea5b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007ff7b1797ef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007ff7b1e1545a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007ff7b1e17931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007ff7b1e13b9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007ff7b1e09416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007ff7b1e1303c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007ff7b1e09416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007ff7b1e134de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007ff7b17ebb34 n/a (libc.so.6 + 0x91b34)
#15 0x00007ff7b1e09416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007ff7b1e09569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007ff7b17eb623 n/a (libc.so.6 + 0x91623)
#18 0x00007ff7b17ebbeb dlopen (libc.so.6 + 0x91beb)
#19 0x00007ff7b1dc7d33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007ff7b1dc7176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007ff7b1dc7377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007ff7b0fbe368 n/a (amdgpu_drv.so + 0xc368)
#23 0x000055b6f26103f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x000055b6f24bc6e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007ff7b17816b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007ff7b1781769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x000055b6f24bdd15 _start (/usr/lib/Xorg + 0x34d15)
Aug 03 19:45:37 XYZ-T14s sddm[1340]: Failed to read display number from pipe
Aug 03 19:45:37 XYZ-T14s sddm[1340]: Attempt 1 starting the Display server on vt 2 failed
Aug 03 19:45:38 XYZ-T14s dbus-broker-launch[1085]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Aug 03 19:45:40 XYZ-T14s systemd-coredump[1374]: Process 1371 (Xorg) of user 0 dumped core.
Stack trace of thread 1371:
#0 0x00007fbadc95274c n/a (libc.so.6 + 0x9774c)
#1 0x00007fbadc8f8dc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007fbadc8e057a abort (libc.so.6 + 0x2557a)
#3 0x00005611d4b9c0be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x00005611d4ba9410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x00005611d4b9e5b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007fbadc8f8ef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007fbadcf7645a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007fbadcf78931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007fbadcf74b9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007fbadcf6a416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007fbadcf7403c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007fbadcf6a416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007fbadcf744de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007fbadc94cb34 n/a (libc.so.6 + 0x91b34)
#15 0x00007fbadcf6a416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007fbadcf6a569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007fbadc94c623 n/a (libc.so.6 + 0x91623)
#18 0x00007fbadc94cbeb dlopen (libc.so.6 + 0x91beb)
#19 0x00007fbadcf28d33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007fbadcf28176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007fbadcf28377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007fbadc11f368 n/a (amdgpu_drv.so + 0xc368)
#23 0x00005611d4bc43f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x00005611d4a706e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007fbadc8e26b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007fbadc8e2769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x00005611d4a71d15 _start (/usr/lib/Xorg + 0x34d15)
Aug 03 19:45:40 XYZ-T14s sddm[1340]: Failed to read display number from pipe
Aug 03 19:45:40 XYZ-T14s sddm[1340]: Attempt 2 starting the Display server on vt 2 failed
Aug 03 19:45:40 XYZ-T14s ModemManager[1198]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.2/0000:02:00.0': not supported by any plugin
Aug 03 19:45:40 XYZ-T14s ModemManager[1198]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0': not supported by any plugin
Aug 03 19:45:41 XYZ-T14s wpa_supplicant[1331]: wlp3s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
Aug 03 19:45:41 XYZ-T14s NetworkManager[1110]: <warn> [1754243141.3693] device (wlp3s0): no secrets: No agents were available for this request.
Aug 03 19:45:41 XYZ-T14s NetworkManager[1110]: <warn> [1754243141.3697] device (wlp3s0): Activation: failed for connection 'intago wLAN'
Aug 03 19:45:41 XYZ-T14s wpa_supplicant[1331]: wlp3s0: WPS-CANCEL
Aug 03 19:45:42 XYZ-T14s systemd-coredump[1570]: Process 1532 (Xorg) of user 0 dumped core.
Stack trace of thread 1532:
#0 0x00007f50724ab74c n/a (libc.so.6 + 0x9774c)
#1 0x00007f5072451dc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007f507243957a abort (libc.so.6 + 0x2557a)
#3 0x000055631a4610be OsAbort (/usr/lib/Xorg + 0x15f0be)
#4 0x000055631a46e410 FatalError (/usr/lib/Xorg + 0x16c410)
#5 0x000055631a4635b3 n/a (/usr/lib/Xorg + 0x1615b3)
#6 0x00007f5072451ef0 n/a (libc.so.6 + 0x3def0)
#7 0x00007f5072acf45a n/a (ld-linux-x86-64.so.2 + 0xe45a)
#8 0x00007f5072ad1931 n/a (ld-linux-x86-64.so.2 + 0x10931)
#9 0x00007f5072acdb9b n/a (ld-linux-x86-64.so.2 + 0xcb9b)
#10 0x00007f5072ac3416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#11 0x00007f5072acd03c n/a (ld-linux-x86-64.so.2 + 0xc03c)
#12 0x00007f5072ac3416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#13 0x00007f5072acd4de n/a (ld-linux-x86-64.so.2 + 0xc4de)
#14 0x00007f50724a5b34 n/a (libc.so.6 + 0x91b34)
#15 0x00007f5072ac3416 _dl_catch_exception (ld-linux-x86-64.so.2 + 0x2416)
#16 0x00007f5072ac3569 n/a (ld-linux-x86-64.so.2 + 0x2569)
#17 0x00007f50724a5623 n/a (libc.so.6 + 0x91623)
#18 0x00007f50724a5beb dlopen (libc.so.6 + 0x91beb)
#19 0x00007f5072a81d33 n/a (libgbm.so.1 + 0x2d33)
#20 0x00007f5072a81176 n/a (libgbm.so.1 + 0x2176)
#21 0x00007f5072a81377 gbm_create_device (libgbm.so.1 + 0x2377)
#22 0x00007f5071c78368 n/a (amdgpu_drv.so + 0xc368)
#23 0x000055631a4893f1 InitOutput (/usr/lib/Xorg + 0x1873f1)
#24 0x000055631a3356e5 n/a (/usr/lib/Xorg + 0x336e5)
#25 0x00007f507243b6b5 n/a (libc.so.6 + 0x276b5)
#26 0x00007f507243b769 __libc_start_main (libc.so.6 + 0x27769)
#27 0x000055631a336d15 _start (/usr/lib/Xorg + 0x34d15)
Aug 03 19:45:42 XYZ-T14s sddm[1340]: Failed to read display number from pipe
Aug 03 19:45:42 XYZ-T14s sddm[1340]: Attempt 3 starting the Display server on vt 2 failed
Aug 03 19:45:42 XYZ-T14s sddm[1340]: Could not start Display server on vt 2
Aug 03 19:45:50 XYZ-T14s fprintd[1584]: Device responded with error: 789 retry: 1
Aug 03 19:45:55 XYZ-T14s dbus-broker-launch[1085]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Aug 03 19:45:55 XYZ-T14s (systemd)[1596]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[myname] ruser=[<unknown>] rhost=[<unknown>]
Aug 03 19:45:55 XYZ-T14s systemd-xdg-autostart-generator[1602]: Exec line is empty
Aug 03 19:45:55 XYZ-T14s systemd-xdg-autostart-generator[1602]: /home/myname/.config/autostart/org.kde.kclockd-autostart.desktop: not generating unit, error parsing Exec= line: Invalid argument
Aug 03 19:46:15 XYZ-T14s kernel: scsi 0:0:0:0: Direct-Access USB SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
Aug 03 19:46:15 XYZ-T14s kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Aug 03 19:46:15 XYZ-T14s kernel: sd 0:0:0:0: [sda] 488374272 512-byte logical blocks: (250 GB/233 GiB)
Aug 03 19:46:15 XYZ-T14s kernel: sd 0:0:0:0: [sda] Write Protect is off
Aug 03 19:46:15 XYZ-T14s kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Aug 03 19:46:15 XYZ-T14s kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Aug 03 19:46:17 XYZ-T14s systemd-logind[1134]: The system will reboot now!
Aug 03 19:46:17 XYZ-T14s systemd-logind[1134]: System is rebooting.
Aug 03 19:46:17 XYZ-T14s sddm[1340]: Signal received: SIGTERM
Aug 03 19:46:17 XYZ-T14s ModemManager[1198]: <msg> caught signal, shutting down...
Aug 03 19:46:17 XYZ-T14s dbus-broker-launch[1085]: Activation request for 'org.freedesktop.Avahi' failed.
Aug 03 19:46:17 XYZ-T14s ModemManager[1198]: <msg> ModemManager is shut down
Aug 03 19:46:17 XYZ-T14s wpa_supplicant[1331]: p2p-dev-wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 03 19:46:17 XYZ-T14s wpa_supplicant[1331]: nl80211: deinit ifname=p2p-dev-wlp3s0 disabled_11b_rates=0
Aug 03 19:46:17 XYZ-T14s dbus-broker-launch[1085]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 03 19:46:17 XYZ-T14s wpa_supplicant[1331]: p2p-dev-wlp3s0: CTRL-EVENT-TERMINATING
Aug 03 19:46:17 XYZ-T14s wpa_supplicant[1331]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 03 19:46:18 XYZ-T14s wpa_supplicant[1331]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Aug 03 19:46:18 XYZ-T14s wpa_supplicant[1331]: nl80211: deinit ifname=wlp3s0 disabled_11b_rates=0
Aug 03 19:46:18 XYZ-T14s wpa_supplicant[1331]: wlp3s0: CTRL-EVENT-TERMINATING
Aug 03 19:46:18 XYZ-T14s dbus-broker-launch[1085]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Aug 03 19:46:18 XYZ-T14s systemd[1]: Shutting down.
Aug 03 19:46:18 XYZ-T14s kernel: watchdog: watchdog0: watchdog did not stop!
well have no idea what to de nextā¦
you have installed some widgets/addons and some sus packages in the pacman -Qm output⦠lets remove them:
pacman -R plasma-simplemenu conky-lua-nv lib32-libva-vdpau-driver libva-vdpau-driver
also reinstall the driver:
mhwd -r pci video-linux
install it back:
mhwd -a pci free 0300
reboot and test
Thaynk you @brahma, sorry for the delay: Several meeting took my full attention.
Did it now step by step:
conky-lua-nv --> same issue
plasma-simplemenu --> same issue, last boot event Starting TLP system startup/shutdown. Typically last entry is Finished target TLP ...
lib32-libva-vdpau-driver libva-vdpau-driver --> same isse, last boot event is Finished target TLP ...
mhwd -r pci video-linux --> 11 Packages removed
mhwd -a pci free 0300 # install it back --> 13 Packages installed
But same issue again.
Is it worth to remove all xf86-video-
packages*:
$ pamac list -i | grep xf86-video-
xf86-video-amdgpu 23.0.0-2 extra 170,2 KB
xf86-video-ati 1:22.0.0-2 extra 488,1 KB
xf86-video-intel 1:2.99.917+939+g4a64400e-1 extra 2,3 MB
xf86-video-nouveau 1.0.18-1 extra 216,0 KB
Actually the machine is running for about half an hour in virtual konsole; I did not do anything there for at least last 20 minutes.
Suddenly I see messages ext4-fs error device nvme0n1p4 ...
This is /home
Could this be in connection with the sreen issue? What to do?
