JoHubb
24 February 2021 08:38
1
I’ve installed Manjaro Mate on a new SSD. A second drive has Kubuntu.
Both distros are listed in UEFI.
I need a bit of reassurance that the partitions are correct, especially the second drive one here which has ! and a — boot flag.
I guess I need the fat32 partition in this so that it shows in UEFI. Otherwise, is the fat32 partition needed in the second drive.
Sorry, but the forum would not let me post media files or even hyperlinks.
Thanks for having me on board.
John
JoHubb
25 February 2021 16:15
3
This is the inxi output:
[howard@Szamitogep ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=05eae7d8-64f2-4f83-a1ea-16f95a7e8380 rw quiet apparmor=1
security=apparmor resume=UUID=2c5f5a87-81b9-489d-9158-4712a322ca07
udev.log_priority=3
Desktop: MATE 1.24.1 info: mate-panel wm: marco 1.24.1 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: Z170-E v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 3801 date: 03/14/2018
Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 85% rechargeable: yes status: Charging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
status: Discharging
RAM: total: 15.58 GiB used: 1.53 GiB (9.8%)
Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
L2 cache: 6 MiB bogomips: 28009
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: PC Partner Limited driver: amdgpu v: kernel bus ID: 01:00.0
chip ID: 1002:67ef class ID: 0300
Display: x11 server: X.org 1.20.10 compositor: marco v: 1.24.1 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: AMD Radeon RX 460 Graphics (POLARIS11 DRM 3.40.0
5.10.15-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
class ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aae0 class ID: 0403
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Xonar DSX
driver: snd_virtuoso v: kernel bus ID: 06:00.0 chip ID: 13f6:8788
class ID: 0401
Sound Server: ALSA v: k5.10.15-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8 class ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
vendor: TP-LINK TG-3468 driver: r8169 v: kernel port: d000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: down mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 7.28 TiB used: 49.55 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 QVO 1TB
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-08M2NA0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD4004FZWX-00GBGB0 size: 3.64 TiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 0A81
scheme: GPT
ID-1: / raw size: 488.54 GiB size: 479.87 GiB (98.23%)
used: 49.33 GiB (10.3%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 05eae7d8-64f2-4f83-a1ea-16f95a7e8380
ID-2: /boot/efi raw size: 600 MiB size: 598.8 MiB (99.80%)
used: 280 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 80F7-C1FE
ID-3: /run/media/howard/MyWinStuff raw size: 1.55 TiB
size: 1.55 TiB (100.00%) used: 223.3 MiB (0.0%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: MyWinStuff uuid: 635B2E3356F6C764
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 2c5f5a87-81b9-489d-9158-4712a322ca07
ID-1: /dev/sda2 maj-min: 8:2 size: 271.51 GiB fs: ext4 label: N/A
uuid: 62bf8816-3bb8-4ba2-908f-de4f7e4adf5d
ID-2: /dev/sdc1 maj-min: 8:33 size: 512 MiB fs: vfat label: N/A
uuid: 607D-E837
ID-3: /dev/sdc2 maj-min: 8:34 size: 931.01 GiB fs: ext4 label: N/A
uuid: b0f459db-1540-4214-aedc-78b985e72330
ID-4: /dev/sdd1 maj-min: 8:49 size: 48.83 GiB fs: ext4 label: N/A
uuid: 6bba14e3-8176-4a52-93c7-8a2a4201dcc8
ID-5: /dev/sdd2 maj-min: 8:50 size: 3.59 TiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-6:2 info: Canon PIXMA iX6850 Printer type: Printer driver: usblp
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 04a9:10e3 class ID: 0701
serial: <filter>
Device-2: 1-14:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b class ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 22.0 C mobo: N/A gpu: amdgpu temp: 26.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 777
Processes: 202 Uptime: 3h 21m wakeups: 73 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1173 lib: 403 Shell: Bash v: 5.1.0
running in: mate-terminal inxi: 3.3.01
This is the sudo parted --list:
[howard@Szamitogep ~]$ sudo parted --list
[sudo] password for howard:
Model: ATA WDC WD2003FZEX-0 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 1709GB 1709GB primary ntfs
2 1709GB 2000GB 292GB primary ext4
Model: ATA Samsung SSD 860 (scsi)
Disk /dev/sdb: 1000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 630MB 629MB fat32 msftdata
2 630MB 4824MB 4194MB linux-swap(v1) swap
3 4824MB 529GB 525GB ext4 Manjaro
Model: ATA WDC WD10EZEX-08M (scsi)
Disk /dev/sdc: 1000GB
Disk Flags:
1 1049kB 538MB 537MB primary fat32 boot
2 538MB 1000GB 1000GB primary ext4
Model: ATA WDC WD4004FZWX-0 (scsi)
Disk /dev/sdd: 4001GB
Disk Flags:
1 1049kB 52.4GB 52.4GB ext4
2 52.4GB 4001GB 3948GB
What to do now?
Fabby
25 February 2021 20:08
4
JoHubb:
What to do now?
Well, nothing! It’s allowed to have multiple ESPs, (EFI System Partitions) and that’s what you have, so that’s no worries if you want to switch OSes using the UEFI firmware instead of grub and that’s what you did.
It’s not what I would have done, but it’s perfectly allowed.
(emphasis mine)
No, you don’t need that: That’s the advantage of UEFI: You can boot multiple OSes of the same ESP but some people don’t like that and want each OS to have their own ESP, and that’s what you have…
And that i is perfectly fine, but I have a triple boot system using 1 ESP:
sudo ls /boot/efi/EFI
Boot Manjaro Microsoft OEM rEFInd Tools Ubuntu
JoHubb
25 February 2021 20:43
5
Aw, thanks! I’m glad to have the reassurance.
I notice you use rEFind. May I ask why?
Fabby
25 February 2021 21:02
6
Because:
I’m a nerd
a tinkerer
a dork
And rEFInd comes with an EFI shell and that allows me to add / remove EFI drivers and follow this manual . (I’m on page 48 since the last 3 months)
JoHubb
25 February 2021 23:30
7
The manual put me right off. Grub works.
For me, I personally like rEFInd because it’s so much more simple than grub to me. For grub, you have to use update-grub, and make sure it plays well with all of your OS’s
I don’t have grub installed on my computer, only rEFInd. What it does is at boot, it searches for all bootable OS’s (for me is Windows 10, Manjaro, Arch Linux, OpenSUSE) and show it all on the screen.
i.e. (old screenshot)
https://archived.forum.manjaro.org/t/refind-sunset-theme/38078
JoHubb
27 February 2021 21:04
10
I run Manjaro and Kubuntu only, so rEFind, though neat, would be overkill just now.
I ran into so much trouble with Windows 10 that I removed the darned thing. Thankfully, I had it on a separate HDD. Otherwise, it seems you cannot uninstall it, not completely.
Thanks for the heads up though!
system
Closed
14 March 2021 21:05
11
