hxl
January 1, 2021, 8:53pm
#1
0/ I have the same problem. I tried to sudo manjaro-chroot -a
an got this:
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
==> Detected systems:
--> 0) Manjaro:linux:btrfs:UUID=63e352b7-8346-41a6-a4e7-adcdac836753
==> Select system to mount [0-0] :
0
==> ERROR: You can't mount 0!
Whether I type 0 or anything I get this message. I will be grateful for your help.
I’ve got exactly this same problem as reported by the users in this post.
I did sudo manjaro-chroot -a
from a Manjaro live USB. Then trying: sudo pacman -Syyuu
as suggested in this post.
This installed Kernel 5.9 (before the first update only 5.10 and 5.4 were installed). However, this hasn’t solved anything. Manjaro is now unable to boot from any kernel after the ‘stable’ update of 2020-12-30.
Any possible ideas or solutions?
Thanks
hxl
January 2, 2021, 6:12am
#4
Wollie:
Here, you have to type 1
I tried and I got:
==> ERROR: You can't mount 1!
Wollie
split this topic
January 2, 2021, 10:52am
#5
hxl
January 2, 2021, 9:36am
#10
I managed to chroot manually . Then I reinstalled grub package: pacman -Syu grub
When I try to:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
i get:
Installing for x86_64-efi platform.
grub-install: error: /boot/efi doesn't look like an EFI partition.
/dev/sda4
is formatted as fat32 and mounted to /boot/efi
Any idea how to resolve this?
Wollie
January 2, 2021, 9:43am
#11
@hxl , is your ESP really formatted in FAT32 (or FAT16 or even FAT12)? Does it carry the boot and ESP flag? Is the size at least 260 MiB? Do you have a gpt parted disk? Are you booting in UEFI mode? All that’s mandatory. Also, when you chrooting the mount point differs to /boot/efi, it’s most likely /mnt/boot/efi , this needs to be considered!
hxl
January 2, 2021, 9:57am
#12
Partition table is
gpt
. I was chrooting like this:
sudo mount /dev/sda2 /mnt/manjaro-root
sudo mount /dev/sda4 /mnt/manjaro-root/@/boot/efi
sudo manjaro-chroot /mnt/manjaro-root/@ /bin/bash
And I use this command grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
from chrooted environment.
Wollie
split this topic
January 2, 2021, 10:48am
#17
TriMoon
January 2, 2021, 12:01pm
#18
That is not the correct way to mount a BTRFS sub-volume…
You should start by mounting your root sub-volume @
at /mnt/manjaro-root
If /dev/sda4
is your ESP you would continue with mounting that at /mnt/manjaro-root/boot/efi
Followed by chroot as sudo manjaro-chroot /mnt/manjaro-root (no @
at end)
hxl
January 2, 2021, 1:50pm
#19
Yes, it helped!
update-grub
I executed commands above from chrooted environment, now /boot/efi/EFI/manjaro/grubx64.efi
file was generated.
Still when launching PC grub menu doesn’t appear. Having pressed F11 on start I can see boot list with Win10 and Manjaro USB stick only.
GaVenga
January 2, 2021, 2:37pm
#20
Maybe:
(Terminal) sudo nano /etc/default/grub
Change entry GRUB_TIMEOUT_STYLE=hidden to: GRUB_TIMEOUT_STYLE=menu
Save: Strg O /Strg x. And sudo update-grub
hxl
January 2, 2021, 3:43pm
#21
That helped too. Now I can at least boot to the installed system from Manjaro USB Stick. I mean I can choose /boot/efi/EFI/manjaro/grubx64.efi
file from Detect EFI bootloaders
menu. But still I can’t see it in motherboard UEFI firmware interface.
moson
January 2, 2021, 3:53pm
#22
Please post output of:
efibootmgr -v
hxl
January 2, 2021, 4:02pm
#23
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0003,0000,0001,0002
Boot0000* Windows Boot Manager HD(2,GPT,cb5a4e2d-3dfc-4f01-9cca-fa06ca117c14,0xfa000,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
Boot0001 Hard Drive BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0200)..GO..NO..........S.S.D. .1.2.8.G.B...................\.,.@.r.d.=.X..........A...........................>..Gd-.;.A..MQ..L.S.A.B.F.8.1.0.1.5.2.2.0.7.6. . . . . . ........BO..NO..........S.a.m.s.u.n.g. .S.S.D. .8.6.0. .E.V.O. .5.0.0.G.B...................\.,.@.r.d.=.X..........A...........................>..Gd-.;.A..MQ..L.4.S.N.F.Z.N.N.F.0.8.7.9.9.4. .V. . . . ........BO..NO..........W.D.C. .W.D.6.4.0.0.A.A.D.S.-.0.0.M.2.B.0...................\.,.@.r.d.=.X..........A...........................>..Gd-.;.A..MQ..L. . . . .W. .-.D.C.W.V.A.7.5.2.4.4.2.0.8........BO
Boot0002 USB KEY BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0b00)..GO..NO..........K.i.n.g.s.t.o.n.D.a.t.a.T.r.a.v.e.l.e.r. .3...0...................\.,.@.r.d.=.X..........A.......................F..Gd-.;.A..MQ..L.1.8.3.1.B.F.B.7.7.F.A.9.F.3.8.1.C.9.9.F.0.2.9.B........BO
Boot0003* UEFI: KingstonDataTraveler 3.0, Partition 1 PciRoot(0x0)/Pci(0x14,0x0)/USB(17,0)/HD(1,MBR,0x0,0x53e904,0x2000)..BO
moson
January 2, 2021, 4:07pm
#24
Indeed missing.
But you should be able to create a new one.
lsblk
findmnt |grep efi
btw. you did boot from hdd now (via stick) or are you running on the live ISO?
hxl
January 2, 2021, 4:12pm
#25
~ >>> lsblk [1]
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 116,1M 1 loop /var/lib/snapd/snap/icloud-for-linux/166
loop1 7:1 0 30,9M 1 loop /var/lib/snapd/snap/snapd/9721
loop2 7:2 0 30,9M 1 loop /var/lib/snapd/snap/snapd/9607
loop3 7:3 0 55,4M 1 loop /var/lib/snapd/snap/core18/1932
loop4 7:4 0 142,1M 1 loop /var/lib/snapd/snap/icloud-for-linux/205
loop5 7:5 0 61M 1 loop /var/lib/snapd/snap/core20/634
loop6 7:6 0 55,3M 1 loop /var/lib/snapd/snap/core18/1885
sda 8:0 0 119,2G 0 disk
├─sda1 8:1 0 8G 0 part [SWAP]
├─sda2 8:2 0 24G 0 part /
├─sda3 8:3 0 86,7G 0 part /home
└─sda4 8:4 0 512M 0 part /boot/efi
sdb 8:16 0 465,8G 0 disk
├─sdb1 8:17 0 499M 0 part
├─sdb2 8:18 0 100M 0 part
├─sdb3 8:19 0 16M 0 part
└─sdb4 8:20 0 465,2G 0 part /mnt/WIN10SYS
sdc 8:32 0 596,2G 0 disk
└─sdc1 8:33 0 596,2G 0 part /mnt/STORAGE
sdd 8:48 1 14,4G 0 disk
├─sdd1 8:49 1 2,6G 0 part /run/media/hxl/MANJARO_GNOME_202
└─sdd2 8:50 1 4M 0 part
findmnt |grep efi
│ ├─/sys/firmware/efi/efivars efivarfs efivarfs rw,nosuid,nodev,noexec,relatime
├─/boot/efi /dev/sda4 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
I did boot to already installed system via stick.
moson
January 2, 2021, 4:15pm
#26
Ok, please run and show output of:
sudo efibootmgr -c -d /dev/sda -p 4 -l /EFI/manjaro/grubx64.efi -L "Manjaro" -v
hxl
January 2, 2021, 4:23pm
#27
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0004,0003,0000,0001,0002
Boot0004* Manjaro HD(4,GPT,167ace5b-a90d-d942-a0f9-9cf0cd398247,0x800,0x100000)/File(\EFI\manjaro\grubx64.efi)
moson
January 2, 2021, 4:27pm
#28
All right. Looks good.
Reboot and see what happens.
