Can’t boot Manjaro gnome. Returns
mount: /new_root: can’t read superblock on /dev/sda1
You are now being dropped into an emergency shell.
sh: can’t access tty; job control turned off
[rootfs ]#
Hello and welcome,
You might have to chroot
the system from Live Media and run:
sudo fsck /dev/sda1
Also might want/have to try to fully update the chrooted system, and then run:
sudo mkinitcpio -P
sudo update-grub
fsck worked! Thank you!
