Bluetooth headset work OK on MacOS but does not show in avaliable adresses on linux. mobile phone connects ok though.
An Attempt to Synchro key transfer from MacOS to Linux OS - failed.
Followed a guide in arch wiki BluetoothDualBoot to part 2.1.5 sucesfully.
Booting linux OS, commands: bluetoothctl: pair device or connect [MAC address]
return: no results/no such device.
According to Archwiki synchronisation of the Bluetooth KEY between OS1 and OS2 is neded.
followed instructions and generated .txt file with the key. rebooted into linux and
attempted to follow up according to the wiki section 2.1.5 “Finishing Up”
but unsucesfully.
cd /var/lib/bluetooth/BT-Adapter-MAC-address - (MAC address of the machine adapter? ) brings me to:
[mpmacbook ataras]# cd /var/lib/bluetooth/2C:BE:08:ED:C2:2B [mpmacbook 2C:BE:08:ED:C2:2B]#
but its not a folder as per instructions. what i am doing here wrong?
the input of headsets MAC address - returns no result.
Please advice.
sudo rfkill list
[sudo] password for ataras:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo rfkill list
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
[ataras@mpmacbook ~]$ sudo systemctl status bluetooth
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2023-03-10 14:30:37 CET; 3h 18min ago
Docs: man:bluetoothd(8)
Main PID: 481 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9400)
Memory: 2.5M
CPU: 169ms
CGroup: /system.slice/bluetooth.service
└─481 /usr/lib/bluetooth/bluetoothd
Mar 10 15:08:35 mpmacbook bluetoothd[481]: Endpoint registered: sender=:1.44 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Mar 10 15:08:35 mpmacbook bluetoothd[481]: Endpoint registered: sender=:1.44 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Mar 10 15:08:35 mpmacbook bluetoothd[481]: Endpoint registered: sender=:1.44 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Mar 10 15:08:35 mpmacbook bluetoothd[481]: Endpoint registered: sender=:1.44 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Mar 10 15:08:35 mpmacbook bluetoothd[481]: Endpoint registered: sender=:1.44 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Mar 10 15:08:35 mpmacbook bluetoothd[481]: Endpoint registered: sender=:1.44 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Mar 10 15:08:42 mpmacbook bluetoothd[481]: Path / reserved for Adv Monitor app :1.45
Mar 10 15:11:39 mpmacbook bluetoothd[481]: Adv Monitor app :1.45 disconnected from D-Bus
Mar 10 15:50:49 mpmacbook bluetoothd[481]: Path / reserved for Adv Monitor app :1.47
Mar 10 17:45:18 mpmacbook bluetoothd[481]: Controller resume with wake event 0x0
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ccb3bd81-487b-4e33-a499-542688a7355e rw quiet apparmor=1
security=apparmor resume=UUID=8f6b7b2d-7473-44c3-bda4-cb3d194f562b
udev.log_priority=3
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-6F01561E16C75D06
Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2
serial: <superuser required> UEFI: Apple v: 429.0.0.0.0 date: 03/18/2022
ID-1: BAT0 charge: 49.1 Wh (95.7%) condition: 51.3/62.9 Wh (81.5%)
volts: 12.1 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 579
RAM: total: 7.67 GiB used: 2 GiB (26.1%)
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1197 high: 1198 min/max: 1200/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1196 2: 1197 3: 1198
4: 1197 bogomips: 19960
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a driver:
X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 model: Apple Color LCD built: 2009 res: 1280x800 hz: 60
dpi: 114 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1280x800
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp1s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:4331 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1
lmp-v: 4.0 sub-v: 229c hci-v: 4.0 rev: 171a
Info: acl-mtu: 1021:6 sco-mtu: 64:1 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 465.76 GiB used: 12.07 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: HDD HTS545050A7E362
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: B990 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRW GS41N rev: UA04
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 11.11 GiB (29.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: ccb3bd81-487b-4e33-a499-542688a7355e
ID-2: /boot/efi raw-size: 512.3 MiB size: 511.2 MiB (99.80%)
used: 2.6 MiB (0.5%) fs: vfat dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: BF6A-44D0
ID-3: /home raw-size: 245.46 GiB size: 240.55 GiB (98.00%)
used: 981 MiB (0.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: cd07d23a-5a3e-4485-8356-5cdd44a33be5
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 8f6b7b2d-7473-44c3-bda4-cb3d194f562b
ID-1: /dev/sda2 maj-min: 8:2 size: 148.92 GiB fs: apfs label: N/A
uuid: 99ee17c7-f619-4a63-b0da-255bfc8eb117
ID-2: /dev/sda4 maj-min: 8:4 size: 15.03 GiB fs: apfs label: N/A
uuid: 5699fe92-de0c-4eb8-bfc2-030860330d1f
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2513 class-ID: 0900
Hub-6: 2-1.8.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500
Device-1: 2-1.8.1.3:9 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 2-1.8.2:5 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
Device-3: 2-1.8.3:6 info: Apple Internal Keyboard/Trackpad (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0253 class-ID: 0301
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 198 Uptime: 48m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1089 libs: 306 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: urxvtd inxi: 3.3.25
