Tried to install blueman, blueberry - not helped, system settings also - button “on” just not working.
On live versions of manjaro and ubuntu isn’t working too, but on windows it’s ok.
There is some random commands:
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
lsusb
Bus 002 Device 004: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 003: ID 258a:001a Gaming KB Gaming KB
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 04d9:a09e Holtek Semiconductor, Inc. COUGAR Minos X2
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sat 2022-08-27 12:00:39 EEST; 1h 4min ago
Docs: man:bluetoothd(8)
Main PID: 2449 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19122)
Memory: 2.0M
CPU: 33ms
CGroup: /system.slice/bluetooth.service
└─2449 /usr/lib/bluetooth/bluetoothd
сер 27 12:00:39 VitvorPC systemd[1]: Starting Bluetooth service...
сер 27 12:00:39 VitvorPC systemd[2449]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 55>
сер 27 12:00:39 VitvorPC bluetoothd[2449]: Bluetooth daemon 5.65
сер 27 12:00:39 VitvorPC systemd[1]: Started Bluetooth service.
сер 27 12:00:39 VitvorPC bluetoothd[2449]: Starting SDP server
сер 27 12:00:39 VitvorPC bluetoothd[2449]: Bluetooth management interface 1.22 initialized
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.5 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 6 (rev c4)
00:1c.7 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 8 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation H77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series/C210 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] (rev e7)
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
04:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
I’m newbie in linux, so hope that solution will be not so hard.
sorry for bad design of post and my english - 1-st post on site, 1-st in english.
In notification area bluetooth devices cannot be founded.
site is telling me that i cannot add a picture in a answer, so here is imgur link for screenshots:
imgur. com/a/A4qXveG
nice, i also cannot add a links. just why
Wiki doesn’t help me, maybe because i’m not so smart.
The device ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode) has a regression bug, and currently only works in the kernel version ≤ 3.9.11. There is a patch available for newer versions. For more information, see Kernel Bug 60824.“”
I have the same Bluetooth and i have diasable it.
sometimes it works sometimes it doesn’t
I bought a new one.
inxi -Eazy ✔
Device-1: ASUSTek ASUS USB-BT500 type: USB driver: btusb v: 0.8
bus-ID: 1-4.2:3 chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: N/A bus-ID: 7-1:2 chip-ID: 0a12:0001 class-ID: e000
From the wiki
If the device will not show up and you have a Windows operating system on your machine, try booting it and enable the Bluetooth adapter from windows.
im so lucky with this adapter…
when i triyng to apply a patch from page what you sent terminal just freezing.
How can i use “application/octet-stream”? what of that files in bugzilla i need to solve my problem?
how i understand - to fix it i must install a old version of kernel or buy a normal adapter… or use a windows. How i say earlier, on windows it’s works perfectly.
