Blueman ist installiert, es befindet sich im offiziellen Repository. (Google Übersetzung)
yep, i installed it myself.
This is what I found in the LOG.
Maybe someone else can help with the evaluation.
I would uninstall blueman. I don’t know why you need it.
сер 27 22:18:49 VitvorPC kernel: NET: Registered PF_BLUETOOTH protocol family
сер 27 22:18:49 VitvorPC kernel: Bluetooth: HCI device and connection manager initialized
сер 27 22:18:49 VitvorPC kernel: Bluetooth: HCI socket layer initialized
сер 27 22:18:49 VitvorPC kernel: Bluetooth: L2CAP socket layer initialized
сер 27 22:18:49 VitvorPC kernel: Bluetooth: SCO socket layer initialized
сер 27 22:18:49 VitvorPC systemd[1]: Starting Load/Save RF Kill Switch Status...
сер 27 22:18:49 VitvorPC kernel: [0;1;38;5;185m [0;1;39m [0;1;38;5;185mBluetooth: hci0: CSR: Unbranded CSR clone detected; adding workarounds and force-suspending once... [0m
сер 27 22:18:49 VitvorPC kernel: [0;1;38;5;185m [0;1;39m [0;1;38;5;185mBluetooth: hci0: CSR: Couldn't suspend the device for our Barrot 8041a02 receive-issue workaround [0m
сер 27 22:18:49 VitvorPC kernel: [0;1;38;5;185m [0;1;39m [0;1;38;5;185mBluetooth: hci0: HCI Delete Stored Link Key command is advertised, but not supported. [0m
сер 27 22:18:49 VitvorPC kernel: [0;1;38;5;185m [0;1;39m [0;1;38;5;185mBluetooth: hci0: HCI Read Default Erroneous Data Reporting command is advertised, but not supported. [0m
сер 27 22:20:37 VitvorPC dbus-daemon[616]: [session uid=1000 pid=616] Activating via systemd: service name='org.blueman.Manager' unit='blueman-manager.service' requested by ':1.40' (uid=1000 pid=750 comm="/usr/bin/python /usr/bin/blueman-applet")
сер 27 22:20:37 VitvorPC systemd[593]: Starting Bluetooth Manager...
сер 27 22:20:38 VitvorPC dbus-daemon[616]: [session uid=1000 pid=616] Successfully activated service 'org.blueman.Manager'
сер 27 22:20:38 VitvorPC systemd[593]: Started Bluetooth Manager.
сер 27 22:20:39 VitvorPC blueman-manager[1527]: blueman-manager 22.20.39 ERROR Manager:147 on_dbus_name_appeared: Default adapter not found, trying first available.
сер 27 22:20:39 VitvorPC blueman-manager[1527]: blueman-manager 22.20.39 ERROR Manager:151 on_dbus_name_appeared: No adapter(s) found, exiting
I installed blueman in try to fix my problem, now i deleted it. What i have to see in this logs?
bluetoothctl power on
bluetoothctl list
Is he recognised ?
no, “no default controller available”
have you installed bluez ?
yes, and bluez-utilz, bluez-hid2hci, bluez-libs, bluez-plugins, bluez-qt, bluez-tools, bluez-utils-compat, just in case
I have only installed : bluez, bluez-libs, bluez-qt, bluez-utils
Test
sudo modprobe -r btusbsudo modprobe btusbbluetoothctl power onbluetoothctl list
sudo modeprobe -r btusb
sudo modprobe btusb
bluetoothctl list
[sudo] пароль до vitvor:
sudo: modeprobe: command not founded
No default controller available
modeprobe - not a command, modprobe doesn’t doing anything, bluetoothctl isn’t recognizing my adapter
sudo modprobe btusb
sorry modeprobe not modprobe
my mistake
lol, no, “modeprobe” doesn’t exist, “modprobe” just not working
argh yes sorry modprobe ![]()
no problem bro, thanks for trying to help me. Respect for you. You doing for solving my problem more, than me. and, again, commands not helped:
sudo modprobe btusb
bluetoothctl list
This is my
lsusb -v -s 007:002 1 ✘
Bus 007 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 224 Wireless
bDeviceSubClass 1 Radio Frequency
bDeviceProtocol 1 Bluetooth
bMaxPacketSize0 64
idVendor 0x0a12 Cambridge Silicon Radio, Ltd
idProduct 0x0001 Bluetooth Dongle (HCI mode)
bcdDevice 53.60
iManufacturer 0
iProduct 2 CC&C Multiple SPP
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x00c1
bNumInterfaces 3
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 1 Bluetooth
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0009 1x 9 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0011 1x 17 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0019 1x 25 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0021 1x 33 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0031 1x 49 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 0
iInterface 0
Device Firmware Upgrade Interface Descriptor:
bLength 7
bDescriptorType 33
bmAttributes 7
Will Not Detach
Manifestation Tolerant
Upload Supported
Download Supported
wDetachTimeout 5000 milliseconds
wTransferSize 1023 bytes
and yours ?
lsusb -v -s 002:004 ✔
Bus 002 Device 004: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bMaxPacketSize0 64
bcdDevice 88.91
iManufacturer 0
iProduct 2 USB2.0-BT
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x00c8
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x003f 1x 63 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
they are not the same
