Bluetooth speaker conflicts with pulseaudio and pipewire
So I’ve been having trouble with my bluetooth speaker for a long time now. Honestly I had neglected this issue since I could just turn off my speaker go to bluetooth devices turn off bluetooth, turn it on and connect my speaker again. But lately it seems that the speaker has gone rogue, I can’t even watch a movie anymore without the constant threat of being muted by this problem. Only turning off my laptop and turning it on seems to work but even that fails sometimes. I checked if this was related to a previous problem that I had (Bluetooth error with blueman-manager: Theme parsing error: gtk.css - #2 by megavolt) since I’ve been using the solution that Megavolt gave to me at that time (reloading the driver) but that doesn’t work anymore.
On this post (Bluetooth Audio Headphones stops randomly (no sound, still connected) - #14 by anon553421) there was the solution concerning to install manjaro-pipewire and agree to remove pulseaudio, I refer to that since it seems that I tried that solution at some point with other issue concerning no sound (Bluetooth Error 104 - No output audio on Bose speaker). I even asked chatgpt to lend me a hand and I realized that I installed both pipewire and pulseaudio at some point (I think that was related to GZDoom or something like that) and now they’re conflicting over bluetooth. However there are a lot of dependencies that are intertwined with both programs and now I can’t find a way to uninstall neither.
Here’s some info:
  Kernel: 6.1.112-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=d97e7378-689f-4116-8a25-2b2c685ad35a rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: albert,xfce4-panel tools: xscreensaver,xscreensaver-systemd
    avail: i3lock vt: 7 dm: 1: LightDM v: 1.32.0 2: SDDM note: stopped
  Type: Laptop System: LENOVO product: 20366 v: Lenovo Z40-70
    serial: <superuser required> Chassis: type: 10 v: Lenovo Z40-70
  Mobo: LENOVO model: Lancer 4A5 v: 31900059WIN serial: <superuser required>
    part-nu: LENOVO_MT_20366_BU_idea_FM_Lenovo Z40-70 uuid: <superuser required>
    UEFI: LENOVO v: 9BCN91WW date: 07/21/2015
  ID-1: BAT0 charge: 9.8 Wh (74.2%) condition: 13.2/28.5 Wh (46.4%)
    power: 18.1 W volts: 14.2 min: 14.4 model: Lenovo IdeaPad type: Unknown
    serial: <filter> status: discharging
  Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2167 min/max: 800/2700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2167 2: 2167 3: 2167 4: 2167 bogomips: 19161
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
    class-ID: 0300
  Device-2: Syntek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-6:3 chip-ID: 174f:14b2
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2 compositors:
    1: Picom v: git-c4107 2: xfwm4 v: 4.18.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: LG Display 0x0455 built: 2014 res: 1366x768 hz: 60
    dpi: 112 gamma: 1.2 size: 310x174mm (12.2x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
    drv: crocus inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
    device-ID: 8086:0a16 memory: 1.46 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4400 (HSW GT2) driver: mesa intel v: 24.2.4-arch1.0.1
    device-ID: 8086:0a16 surfaces: xcb,xlib
  Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  API: ALSA v: k6.1.112-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off tools: jack_control,qjackctl
  Server-3: PipeWire v: 1.2.5 status: active with: wireplumber status: active
    tools: pw-cat,pw-cli,wpctl
  Server-4: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
    vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
    link-max: gen: 6 speed: 64 GT/s port: 4000 bus-ID: 01:00.0
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
    vendor: Lenovo Z50-75 driver: rtl8723be v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:b723
    class-ID: 0280
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Realtek RTL8723B Bluetooth driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:4 chip-ID: 0bda:b728
  Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.0
    lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 931.51 GiB used: 661.53 GiB (71.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 661.53 GiB (72.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB available: 7.65 GiB used: 3.09 GiB (40.3%)
  Processes: 217 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.05 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1853 pm: pacman pkgs: 1841 libs: 523 tools: pamac,yay pm: flatpak
    pkgs: 0 pm: snap pkgs: 12 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash
    v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.36
Some of the error messages that bluetooth manager delivers are:
Connection to Bluez failed. Bluez daemon is not running, blueman-manager connot continue. This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started.
and this one:
Failed to connect. br-connection-adapter-not-powered
One of the suggestions by chatgpt was checking errors related to bluetooth: journalctl -xe | grep -i bluetooth
Which led to this (only posting a small bit because of character limits of this post):
Multiple sound server instances (PipeWire/Pulseaudio/bluez-alsa) are probably trying to use Bluetooth audio at the same time, which can cause problems. The system configuration likely should be fixed to have only one sound server that manages Bluetooth audio.
So in a nutshell I guess that the problem lies with the conflicting sound server instances but when trying to remove either pulseaudio or pipewire there seems to be a lot of problems related to dependencies. Could someone help me to remove some of them?
I’ll make another post with the terminal outputs related to the removal of the sound server instances.
sudo pacman -Rns pipewire
checking dependencies...
:: removing pipewire breaks dependency 'pipewire' required by gst-plugin-pipewire
:: removing pipewire breaks dependency 'pipewire' required by lib32-pipewire
:: removing pipewire breaks dependency 'pipewire' required by pipewire-audio
:: removing pipewire breaks dependency 'pipewire' required by wireplumber
:: removing pipewire breaks dependency 'pipewire' required by xdg-desktop-portal
sudo pacman -Rns gst-plugin-pipewire lib32-pipewire pipewire-audio wireplumber xdg-desktop-portal
:: removing xdg-desktop-portal breaks dependency 'xdg-desktop-portal' required by flatpak
:: removing wireplumber breaks dependency 'pipewire-session-manager' required by kwin
:: removing lib32-pipewire breaks dependency 'lib32-pipewire' required by steam-native-runtime
:: removing xdg-desktop-portal breaks dependency 'xdg-desktop-portal' required by xdg-desktop-portal-gnome
:: removing xdg-desktop-portal breaks dependency 'xdg-desktop-portal' required by xdg-desktop-portal-gtk
:: removing xdg-desktop-portal breaks dependency 'xdg-desktop-portal' required by xdg-desktop-portal-kde
sudo pacman -S pipewire pipewire-pulse pipewire-alsa pipewire-jack
warning: pipewire-1:1.2.5-0 is up to date -- reinstalling
resolving dependencies...
:: pipewire-pulse-1:1.2.5-0 and pulseaudio-17.0-3 are in conflict. Remove pulseaudio? [y/N] y
:: pipewire-jack-1:1.2.5-0 and jack2-1.9.22-1 are in conflict (jack). Remove jack2? [y/N] y
:: removing jack2 breaks dependency 'jack2' required by jack2-dbus
:: removing pulseaudio breaks dependency 'pulseaudio=17.0-3' required by pulseaudio-bluetooth
:: removing pulseaudio breaks dependency 'pulseaudio=17.0-3' required by pulseaudio-equalizer
:: removing pulseaudio breaks dependency 'pulseaudio=17.0-3' required by pulseaudio-jack
Oct 25 12:53:20 conatus kernel: Bluetooth: Core ver 2.22
Oct 25 12:53:20 conatus kernel: NET: Registered PF_BLUETOOTH protocol family
Oct 25 12:53:20 conatus kernel: Bluetooth: HCI device and connection manager initialized
Oct 25 12:53:20 conatus kernel: Bluetooth: HCI socket layer initialized
Oct 25 12:53:20 conatus kernel: Bluetooth: L2CAP socket layer initialized
Oct 25 12:53:20 conatus kernel: Bluetooth: SCO socket layer initialized
Oct 25 12:53:20 conatus kernel: Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
Oct 25 12:53:20 conatus kernel: Bluetooth: hci0: RTL: rom_version status=0 version=1
Oct 25 12:53:20 conatus kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
Oct 25 12:53:20 conatus kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
Oct 25 12:53:20 conatus kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
Oct 25 12:53:20 conatus kernel: Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
Oct 25 12:53:20 conatus kernel: Bluetooth: hci0: RTL: fw version 0x0e2f9f73
Oct 25 12:53:21 conatus systemd[1]: Starting Bluetooth service...
░░ Subject: A start job for unit bluetooth.service has begun execution
░░ A start job for unit bluetooth.service has begun execution.
Oct 25 12:53:22 conatus bluetoothd[958]: Bluetooth daemon 5.78
Oct 25 12:53:24 conatus systemd[1]: Started Bluetooth service.
░░ Subject: A start job for unit bluetooth.service has finished successfully
░░ A start job for unit bluetooth.service has finished successfully.
Oct 25 12:53:24 conatus systemd[1]: Reached target Bluetooth Support.
░░ Subject: A start job for unit bluetooth.target has finished successfully
░░ A start job for unit bluetooth.target has finished successfully.
Oct 25 12:53:24 conatus bluetoothd[958]: Starting SDP server
Oct 25 12:53:24 conatus dbus-daemon[959]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=958 comm="/usr/lib/bluetooth/bluetoothd")
Oct 25 12:53:24 conatus kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Oct 25 12:53:24 conatus kernel: Bluetooth: BNEP filters: protocol multicast
Oct 25 12:53:24 conatus kernel: Bluetooth: BNEP socket layer initialized
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support bap plugin
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support bass plugin
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support mcp plugin
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support vcp plugin
Oct 25 12:53:24 conatus bluetoothd[958]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support micp plugin
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support ccp plugin
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support csip plugin
Oct 25 12:53:24 conatus bluetoothd[958]: src/plugin.c:init_plugin() System does not support asha plugin
Oct 25 12:53:24 conatus bluetoothd[958]: Bluetooth management interface 1.22 initialized
Oct 25 12:53:24 conatus bluetoothd[958]: Battery Provider Manager created
Oct 25 12:53:24 conatus kernel: Bluetooth: MGMT ver 1.22
Oct 25 12:53:25 conatus bluetoothd[958]: Failed to set mode: Failed (0x03)
Oct 25 12:53:27 conatus NetworkManager[1024]: <info>  [1729882407.7607] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.48.12-1/libnm-device-plugin-bluetooth.so)
Oct 25 12:53:55 conatus systemd-xdg-autostart-generator[1349]: Exec binary 'bluetooth.service' does not exist: No such file or directory
Oct 25 12:53:55 conatus systemd-xdg-autostart-generator[1349]: /home/olm/.config/autostart/bluetooth.desktop: not generating unit, executable specified in Exec= does not exist.
Oct 25 12:54:39 conatus kernel: Bluetooth: RFCOMM TTY layer initialized
Oct 25 12:54:39 conatus kernel: Bluetooth: RFCOMM socket layer initialized
Oct 25 12:54:39 conatus kernel: Bluetooth: RFCOMM ver 1.11
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/ldac_hq
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/ldac_sq
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/ldac_mq
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSink/aptx_hd
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/aptx_hd
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSink/sbc
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/sbc
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSink/faststream
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.56 path=/MediaEndpoint/A2DPSource/faststream
Oct 25 12:54:39 conatus bluetoothd[958]: src/profile.c:register_profile() :1.63 tried to register 0000111f-0000-1000-8000-00805f9b34fb which is already registered
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/ldac
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/aptx_hd
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_hd
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/aac
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aac
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/opus_g
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/opus_g
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/sbc
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/sbc
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/faststream
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/faststream_duplex
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/opus_05
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/opus_05
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Oct 25 12:54:39 conatus bluetoothd[958]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Oct 25 12:54:54 conatus systemd[1]: Starting Bluetooth management mechanism...
Oct 25 12:54:55 conatus systemd[1]: Started Bluetooth management mechanism.
Oct 25 12:55:17 conatus systemd[1342]: Reached target Bluetooth.
Oct 25 12:55:17 conatus bluetoothd[958]: profiles/audio/a2dp.c:connect_cb() HUP or ERR on socket: Connection reset by peer (104)
Oct 25 12:55:20 conatus bluetoothd[958]: /org/bluez/hci0/dev_08_DF_1F_5C_C5_EE/fd0: fd(30) ready
Oct 25 12:55:20 conatus wireplumber[1719]: spa.bluez5: Properties changed in unknown transport '/org/bluez/hci0/dev_08_DF_1F_5C_C5_EE/fd0'. Multiple sound server instances (PipeWire/Pulseaudio/bluez-alsa) are probably trying to use Bluetooth audio at the same time, which can cause problems. The system configuration likely should be fixed to have only one sound server that manages Bluetooth audio.
Oct 25 12:55:20 conatus bluetoothd[958]: profiles/audio/avdtp.c:session_cb() No pending request, ignoring message
Oct 25 12:55:21 conatus bluetoothd[958]: src/service.c:btd_service_connect() avrcp-controller profile connect failed for 08:DF:1F:5C:C5:EE: Operation already in progress
Oct 25 12:55:25 conatus wireplumber[1719]: spa.bluez5: Properties changed in unknown transport '/org/bluez/hci0/dev_08_DF_1F_5C_C5_EE/fd0'. Multiple sound server instances (PipeWire/Pulseaudio/bluez-alsa) are probably trying to use Bluetooth audio at the same time, which can cause problems. The system configuration likely should be fixed to have only one sound server that manages Bluetooth audio.
Oct 25 12:57:34 conatus wireplumber[1719]: spa.bluez5: Properties changed in unknown transport '/org/bluez/hci0/dev_08_DF_1F_5C_C5_EE/fd0'. Multiple sound server instances (PipeWire/Pulseaudio/bluez-alsa) are probably trying to use Bluetooth audio at the same time, which can cause problems. The system configuration likely should be fixed to have only one sound server that manages Bluetooth audio.
Oct 25 13:14:40 conatus systemd[1342]: Starting Bluetooth Manager...
Oct 25 13:14:41 conatus systemd[1342]: Started Bluetooth Manager.
By the way I installed KDE but barely use it. I have no problems uninstalling it if necessary.
You have other packages in the way.
( And may be out of sync in some fashion )
sudo pacman -Rns pulseaudio-bluetooth pulseaudio-equalizer pulseaudio-jack
sudo pacman -Syu manjaro-pipewire
sudo pacman -Syu pipewire pipewire-pulse pipewire-alsa pipewire-jack
Did ChatGPT suggest that audio servers were responsible for these errors?
Packages pulseaudio and pipewire-pulse are marked as conflicting packages and cannot be installed at the same time on Manjaro
Metapackages manjaro-pulse and manjaro-pipewire to switch pulseaudio and pipewire-pulse audio servers are also marked as conflicting packages and cannot be installed at the same time
bluealsa does not appear to be installed, but can be removed easily
pamac remove bluealsa
Bluetooth headset - ArchWiki
Bluetooth is infamous for being unreliable [1] xkcd: Bluetooth
No, CHATGPT suggested that there was a problem with the bluetooth adapter and one of the tentative solutions was to check the driver to see if the adapter needed a specific driver (dmesg | grep -i bluetooth).
When I opened bluetoothctl and tried to activate it the following message came up:
[bluetooth]# Failed to set power on: org.bluez.Error.Failed.
To fix it ChatGPT suggested many things (reinstall firmware, check kernel modules, restart bluetooth service, upgrade system and check hardware) and practically none of them worked except checking system logs for bluetooth related errors. That’s when I found the conflict between multiple sound servers.
I’m gonna try to remove as many conflicting packages as I can (following cscs and your insights about metapackages) and hopefully won’t end up with a mute system.
Ok after following cscs’ suggestions about removing conflicting packages, checking out for other conflicts and nikgomic’s remarks this is what I did:
These are conflicting packages installed that still were causing trouble:
  • pulseaudio-alsa
  • pulseaudio-qt
    pipewire-pulse
  • Removed those
These are metapackages installed (no trouble so far):
manjaro-pipewire
pipewire-pulse
Also removed Plasma KDE since that got in the way of removing
pulseaudio-alsa and pulseaudio-qt.
So far so good, but I want to wait until tomorrow so I can mark this as solved.
$ pamac info manjaro-pipewire
Version               : 20231009-1
Description           : Manjaro meta package for complete PipeWire support.
Depends On            : gst-plugin-pipewire pipewire pipewire-alsa pipewire-pulse
Conflicts With        : manjaro-pulse pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp
                        pulseaudio-zeroconf
