Hi dear community, I tried to connect my Bose audio speaker and I could do it but there is no audio output.
I tried to verify if the Bluetooth service is enabled and active:
sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Thu 2023-04-27 08:19:10 CST; 1h 10min ago
Docs: man:bluetoothd(8)
Main PID: 766 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9370)
Memory: 2.8M
CPU: 125ms
CGroup: /system.slice/bluetooth.service
└─766 /usr/lib/bluetooth/bluetoothd
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSource/faststream
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSink/opus_05
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSource/opus_05
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 27 09:13:45 conatus bluetoothd[766]: Endpoint registered: sender=:1.260 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 27 09:13:54 conatus bluetoothd[766]: profiles/audio/avctp.c:avctp_control_confirm() Control: Refusing unexpected connect
Apr 27 09:29:34 conatus bluetoothd[766]: profiles/audio/a2dp.c:connect_cb() HUP or ERR on socket: Connection reset by peer (104)
On this post (Bluetooth Audio Headphones stops randomly (no sound, still connected) - #14 by anon553421) there was the solution concerning to install manjaro-pipewire
and agree to remove pulseaudio
sudo pacman -Rdd pulseaudio pulseaudio-alsa pulseaudio-ctl pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-modules-bt pulseaudio-rtp pulseaudio-zeroconf
sudo pacman -S manjaro-pipewire
sudo pacman -Rsn $(sudo pacman -Qdtq)
I gave it a shot but still no sound on my speaker.
Info about my system:
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d97e7378-689f-4116-8a25-2b2c685ad35a rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20366 v: Lenovo Z40-70
serial: <superuser required> Chassis: type: 10 v: Lenovo Z40-70
Mobo: LENOVO model: Lancer 4A5 v: 31900059WIN serial: <superuser required>
UEFI: LENOVO v: 9BCN91WW date: 07/21/2015
ID-1: BAT0 charge: 11.6 Wh (53.7%) condition: 21.6/28.5 Wh (75.8%)
volts: 14.2 min: 14.4 model: Lenovo IdeaPad type: Unknown serial: <filter>
status: discharging
RAM: total: 7.65 GiB used: 3.37 GiB (44.1%)
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1472 high: 1696 min/max: 800/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1696 2: 1696 3: 1696
4: 800 bogomips: 19161
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
class-ID: 0300
Device-2: Syntek Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 2-6:4
chip-ID: 174f:14b2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: LG Display 0x0455 built: 2014 res: 1366x768
dpi: 112 gamma: 1.2 size: 310x174mm (12.2x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 4000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo Z50-75 driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:b723
class-ID: 0280
Device-1: Realtek RTL8723B Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-7:5 chip-ID: 0bda:b728 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 13.94 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 1A scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUC0N rev: T.02
dev-links: cdrom
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 13.94 GiB (1.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d97e7378-689f-4116-8a25-2b2c685ad35a
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: B317-8A71
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 2-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Device-2: 2-4:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 2-6:4 info: Syntek Lenovo EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:14b2
Device-4: 2-7:5 info: Realtek RTL8723B Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 203 Uptime: 1h 16m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1089 libs: 351 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
