I installed the latest version of Manjaro on my Acer Aspire 5740G laptop. The OS is working great on it! I have just one little annoyance which seems to persist: Bluetooth. I need it for the BT mouse I use… this causes my mouse to not work on login or stop working after some minutes / hours.
Sometimes bluetooth doesn’t get enabled when I log in, or becomes disabled after a certain amount of time. When this happens the button to enable Bluetooth in the KDE System Settings - Hardware - Bluetooth menu is available but clicking it does nothing, I need to reboot and hope it works next time. The bluetooth button on the laptop has a blue light to indicate it’s on but pressing it has no effect.
Do you by any chance have an Intel AX200 or AX201?
Can you please edit this output and either put ``` before and after the output or highlight the output and click on </>?
It makes it a lot easier to read.
AX200 & AX201 are having issues currently due to regression from the linux-firmware package as of 2021. Someone posted about it a few days ago as well .
You need to temporarily use linux-firmware v20201218.646f159-1, this is a package version from 2020-12-18
I got my package from Arch Linux Archive
sudo pacman -U https://archive.archlinux…
How do I check, what do I check for? If you mean CPU that’s an Intel Core i5.
MirceaKitsune:
How do I check
Please provide inxi -Fza
MirceaKitsune:
You check for if your network/bluetooth card is Intel AX200 or AX201
[mircea@mircea-aspire5740 ~]$ inxi -Fza
System: Kernel: 5.13.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9e216875-7e86-4961-a21d-55584ef987f9 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Acer product: Aspire 5740 v: V1.28 serial: <filter>
Mobo: Acer model: Aspire 5740 v: V1.28 serial: <filter> BIOS: Phoenix v: 1.28
date: 08/12/2010
Battery: ID-1: BAT0 charge: 46.0 Wh (100.0%) condition: 46.0/48.8 Wh (94.1%)
volts: 12.3 min: 11.1 model: SONYCorp AS07A41 type: Li-ion serial: <filter>
status: Full
CPU: Info: Dual Core model: Intel Core i3 M 330 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 25 (37) stepping: 2 microcode: 11 cache: L2: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17034
Speed: 1382 MHz min/max: 933/2133 MHz Core speeds (MHz): 1: 1382 2: 1788
3: 1515 4: 1533
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Graphics: Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470]
vendor: Acer Incorporated ALI driver: radeon v: kernel bus-ID: 02:00.0
chip-ID: 1002:68e0 class-ID: 0300
Device-2: Chicony Acer CrystalEye Webcam type: USB driver: uvcvideo
bus-ID: 2-1.5:3 chip-ID: 04f2:b044 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS res: 1366x768 hz: 60
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.13.5-1-MANJARO LLVM 12.0.1)
v: 3.3 Mesa 21.1.5 compat-v: 3.1 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 02:00.1
chip-ID: 1002:aa68 class-ID: 0403
Sound Server-1: ALSA v: k5.13.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Network: Device-1: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI Aspire 7740G driver: tg3 v: kernel port: 2000
bus-ID: 03:00.0 chip-ID: 14e4:1692 class-ID: 0200
Device-2: Qualcomm Atheros AR928X Wireless Network Adapter
vendor: Quanta Microsystems EM306 802.11bgn driver: ath9k v: kernel port: 2000
bus-ID: 05:00.0 chip-ID: 168c:002a class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Bluetooth: Device-1: Foxconn / Hon Hai Acer Bluetooth module type: USB driver: btusb
v: 0.8 bus-ID: 1-1.4:3 chip-ID: 0489:e011 class-ID: fe01 serial: <filter>
Drives: Local Storage: total: 298.09 GiB used: 77.67 GiB (26.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545032B9A300
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C60F scheme: GPT
Partition: ID-1: / raw-size: 294.09 GiB size: 288.41 GiB (98.07%) used: 77.67 GiB (26.9%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 1.8 MiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
Sensors: System Temperatures: cpu: 56.0 C mobo: 42.0 C gpu: radeon temp: 58.0 C
Info: Processes: 185 Uptime: 2h 1m wakeups: 1 Memory: 3.7 GiB used: 1.18 GiB (31.8%)
Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: pacman: 1562 lib: 398 flatpak: 0 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
Nope, it is a different bluetooth device. Hopefully someone else can help you. Or you can look that up to see if anyone else had the same issue.
With some research I finally found a command to fix Bluetooth at runtime after it breaks, saving me from having to restart the laptop every 15 minutes:
sudo rfkill block bluetooth;sudo rfkill unblock bluetooth;sudo systemctl restart bluetooth.service
First two commands seem to be required, the third is added for completion’s sake. Using systemctl alone to restart the BT service won’t affect the issue, only rfkill seems to.
