Well hello, the thing is bluetooth isnt really working. When I try to use it via settings>bluetooth its searching and thats it ;/ .
This is what I get when I use systemctl status bluetooth.service :
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sat 2024-04-27 15:11:04 +07; 5min ago
Docs: man:bluetoothd(8)
Main PID: 2578 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 5802)
Memory: 832.0K (peak: 1.3M)
CPU: 64ms
CGroup: /system.slice/bluetooth.service
└─2578 /usr/lib/bluetooth/bluetoothd
апр 27 15:11:04 gabe-hpnotebook systemd[1]: Started Bluetooth service.
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: Starting SDP server
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: src/plugin.c:plugin_init() System does not support csip plu>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: profiles/audio/micp.c:micp_init() D-Bus experimental not en>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: src/plugin.c:plugin_init() System does not support micp plu>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: src/plugin.c:plugin_init() System does not support vcp plug>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: src/plugin.c:plugin_init() System does not support mcp plug>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: src/plugin.c:plugin_init() System does not support bass plu>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: src/plugin.c:plugin_init() System does not support bap plug>
апр 27 15:11:04 gabe-hpnotebook bluetoothd[2578]: Bluetooth management interface 1.22 initialized
when I go to bluetoothctl with power on:
bluetoothctl ✔
Waiting to connect to bluetoothd...[bluetooth]# Agent registered
[bluetooth]# power on
No default controller available
I have a feeling somethings wrong with the drivers
You need to install more bluetooth programs like manjaro-bluetooth bluez and more from bluez like bluez-libs bluez tools etc.
Just open octopi and search for blue, install programs until it works.
No, you don’t throw all kinds of software at the problem without having made sure that the system can even see a bluetooth adapter.
Looking at system information is the first step.
Oh? Are we now spamming the thread with semi-funny comments?
By exactly that two guys what reply fruitless at other threads until a point, where it then ends at "sorry, its not my field of expertise "
Well, i first installed bluez, as i had my first bluetooth device. It did not really work out of the box without adding more stuff.
Hows about, you care first more about working software for bluetooth. Unnecessary Software can be easy removed.
But i guess, we are then again at that point of “oh, its not my field of expertise”.
Actually, I thought that you were trying to be funny.
…at least, at first.
What is interesting is that you somehow managed to pad out my comment with your additional waffling.
Yes, unnecessary software can be removed.
However, when you throw many of the same types of software at a problem, with all of them competing, you’re sure to have conflicts of some kind which ultimately, defeats the purpose.
Incidentally, it is not my field(s) of expertise that are in question here, but, yours. You could have simply enjoyed/ignored a ‘semi-funny’ comment and moved on, however, you chose differently. That’s on you.
